Page 7 of 27
Siri / HomeKit support for Domoticz
Posted: Monday 15 June 2015 22:13
by simon_rb
I didn't have to install node-persist. I just followed the wiki.. Strange.
Did you install node.js correctly?
Try node -v see what version you have..
Re: Siri / HomeKit support for Domoticz
Posted: Monday 15 June 2015 22:45
by thebeetleuk
pi@domoticzpi ~/homebridge $ node -v
v0.12.1
Not sure what version I should have.
Posted: Monday 15 June 2015 22:46
by simon_rb
That's the correct version.. Is it still not working?
Posted: Monday 15 June 2015 22:49
by simon_rb
Eduard wrote:As an addition to the roomid-config, i made a new domoticz.js with a parameter to disable the scenes...
"description": "Configuration file for Domoticz platform.",
"platforms": [
"platform": "Domoticz",
"name": "Domoticz",
"server": "127.0.0.1",
"port": "8080",
"roomid": 123 (0=no roomplan),
"usescenes": 0 (0=off, 1=on)
"accessories": [
Also made HomeBridge start at reboot with a startup-script:
#!/bin/sh
#/etc/init.d/homebridge.sh
export PATH=$PATH:/usr/local/bin
export NODE_PATH=$NODE_PATH:/usr/local/lib/node_modules
case "$1" in
start)
exec forever start /home/pi/homebridge/app.js -p /home/pi/.forever
stop)
exec forever stop /home/pi/homebridge/app.js
echo "Usage: homebridge.sh {start|stop}"
exit 1
esac
exit 0
sudo chmod 755 /etc/init.d/homebridge.sh
update-rc.d homebridge.sh defaults
To remove from startup at reboot:
update-rc.d -f homebridge.sh remove
Tried this and mine still imported all the scenes..
Posted: Monday 15 June 2015 23:34
by thebeetleuk
simon_rb wrote:That's the correct version.. Is it still not working?
nope still not working. this is the error I get....
v0.12.1
pi@domoticzpi ~/homebridge $ npm run start
[email protected] start /home/pi/homebridge
> node app.js
module.js:338
throw err;
Error: Cannot find module 'node-persist'
at Function.Module._resolveFilename (module.js:336:15)
at Function.Module._load (module.js:278:25)
at Module.require (module.js:365:17)
at require (module.js:384:17)
at Object.<anonymous> (/home/pi/homebridge/app.js:3:15)
at Module._compile (module.js:460:26)
at Object.Module._extensions..js (module.js:478:10)
at Module.load (module.js:355:32)
at Function.Module._load (module.js:310:12)
at Function.Module.runMain (module.js:501:10)
npm ERR! Linux 3.18.11+
npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "run" "start"
npm ERR! node v0.12.1
npm ERR! npm v2.5.1
npm ERR! code ELIFECYCLE
npm ERR!
[email protected] start: `node app.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the
[email protected] start script 'node app.js'.
npm ERR! This is most likely a problem with the homebridge package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node app.js
npm ERR! You can get their info via:
npm ERR! npm owner ls homebridge
npm ERR! There is likely additional logging output above.
npm ERR! Please include the following file with any support request:
npm ERR! /home/pi/homebridge/npm-debug.log
Posted: Monday 15 June 2015 23:36
by simon_rb
Have you tried sudo npm run start?
I had a similar error except it couldn't find mdns module.
Posted: Monday 15 June 2015 23:44
by thebeetleuk
Yeah tried that but the error is just the same
Posted: Monday 15 June 2015 23:45
by pepijn
Did you run npm install?
Posted: Monday 15 June 2015 23:46
by simon_rb
Install the node.js part of the wiki using sudo.. It maybe a permissions thing..
by simon_rb
pepijn wrote:Did you run npm install?
Or that! Lol
Posted: Monday 15 June 2015 23:47
by simon_rb
I'm having an issue where no matter how I ask Siri to turn on a single light or device in a room it seems to turn everything on or off in the room. Dunno what I'm doing wrong.
Posted: Monday 15 June 2015 23:57
by thebeetleuk
simon_rb wrote:Install the node.js part of the wiki using sudo.. It maybe a permissions thing..
ok so tried all that part again using sudo and no luck. just the same error
might need to give up
Posted: Monday 15 June 2015 23:59
by simon_rb
Did you run npm install twice?
Posted: Tuesday 16 June 2015 1:23
by simon_rb
Is anybody having success with this? As in able to add all their devices and reliably control them individually using Siri. I have spent 3 days on this now and I'm no closer to understanding what it is I'm doing wrong?!? Or is it just buggy as hell and nothing I can do to correct it?
Posted: Tuesday 16 June 2015 6:47
by Eduard
simon_rb wrote:Tried this and mine still imported all the scenes..
Did you overwrite the Domoticz.js file in folder Platforms with the attachted file?
Posted: Tuesday 16 June 2015 8:22
by thebeetleuk
simon_rb wrote:Did you run npm install twice?
I tried to run again to see if it missed anything. Is that wrong? would I need to uninstall first? If so, how would I do that?
Posted: Tuesday 16 June 2015 9:59
by simon_rb
Eduard wrote:simon_rb wrote:Tried this and mine still imported all the scenes..
I did.
Posted: Tuesday 16 June 2015 10:00
by simon_rb
thebeetleuk wrote:simon_rb wrote:Did you run npm install twice?
It has to be run inside the lib-node folder..
Posted: Tuesday 16 June 2015 19:30
by thebeetleuk
simon_rb wrote:thebeetleuk wrote:simon_rb wrote:Did you run npm install twice?
Is that this directory?
Posted: Tuesday 16 June 2015 20:22
by Heisenberg
Today I experience new issues with Eve/Siri so I resetted Homekit configuration on my IOS device. After that I opened Eve but it couldnt find my devices anymore.
Trying to run 'npm run start' gives the following message:
[Domoticz] Loaded services for Zonnescherm
Cannot create another accessory with the same name 'Zonnescherm'. The 'name' property must be unique for each accessory.
[Domoticz] Initializing device with name Alle Lampen AAN...
