Siri / HomeKit support for Domoticz
- Target OS: -
I didn't have to install node-persist. I just followed the wiki.. Strange.
Did you install node.js correctly?
Try node -v see what version you have..
Re: Siri / HomeKit support for Domoticz
Not sure what version I should have.pi@domoticzpi ~/homebridge $ node -v
v0.12.1
My Setup: Pi, RFXtrx433, HomeEasy: 13 Dimmers & 4 Sockets, 2 motion-sensors, 3 magnetic switches, 1 OWL Electricity Sensor, 3 Oregon Temp Sensor.
- Target OS: -
That's the correct version.. Is it still not working?
- Target OS: -
Tried this and mine still imported all the scenes..Eduard wrote:As an addition to the roomid-config, i made a new domoticz.js with a parameter to disable the scenes...
{ "description": "Configuration file for Domoticz platform.", "platforms": [ { "platform": "Domoticz", "name": "Domoticz", "server": "127.0.0.1", "port": "8080", "roomid": 123 (0=no roomplan), "usescenes": 0 (0=off, 1=on) } ], "accessories": [ ] }
Also made HomeBridge start at reboot with a startup-script:Code: Select all
#!/bin/sh #/etc/init.d/homebridge.sh export PATH=$PATH:/usr/local/bin export NODE_PATH=$NODE_PATH:/usr/local/lib/node_modules case "$1" in start) exec forever start /home/pi/homebridge/app.js -p /home/pi/.forever ;; stop) exec forever stop /home/pi/homebridge/app.js ;; *) echo "Usage: homebridge.sh {start|stop}" exit 1 ;; esac exit 0
To remove from startup at reboot:Code: Select all
sudo chmod 755 /etc/init.d/homebridge.sh update-rc.d homebridge.sh defaults
update-rc.d -f homebridge.sh remove
nope still not working. this is the error I get....simon_rb wrote:That's the correct version.. Is it still not working?
v0.12.1
pi@domoticzpi ~/homebridge $ npm run start
> [email protected] start /home/pi/homebridge
> node app.js
module.js:338
throw err;
Error: Cannot find module 'node-persist'
at Function.Module._resolveFilename (module.js:336:15)
at Function.Module._load (module.js:278:25)
at Module.require (module.js:365:17)
at require (module.js:384:17)
at Object.<anonymous> (/home/pi/homebridge/app.js:3:15)
at Module._compile (module.js:460:26)
at Object.Module._extensions..js (module.js:478:10)
at Module.load (module.js:355:32)
at Function.Module._load (module.js:310:12)
at Function.Module.runMain (module.js:501:10)
npm ERR! Linux 3.18.11+
npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "run" "start"
npm ERR! node v0.12.1
npm ERR! npm v2.5.1
npm ERR! code ELIFECYCLE
npm ERR! [email protected] start: `node app.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script 'node app.js'.
npm ERR! This is most likely a problem with the homebridge package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node app.js
npm ERR! You can get their info via:
npm ERR! npm owner ls homebridge
npm ERR! There is likely additional logging output above.
npm ERR! Please include the following file with any support request:
npm ERR! /home/pi/homebridge/npm-debug.log
- Target OS: -
Have you tried sudo npm run start?
I had a similar error except it couldn't find mdns module.
Yeah tried that but the error is just the same
Did you run npm install?
- Target OS: -
Install the node.js part of the wiki using sudo.. It maybe a permissions thing..
- Target OS: -
Or that! Lolpepijn wrote:Did you run npm install?
- Target OS: -
I'm having an issue where no matter how I ask Siri to turn on a single light or device in a room it seems to turn everything on or off in the room. Dunno what I'm doing wrong.
ok so tried all that part again using sudo and no luck. just the same errorsimon_rb wrote:Install the node.js part of the wiki using sudo.. It maybe a permissions thing..
might need to give up
- Target OS: -
Did you run npm install twice?
- Target OS: -
Is anybody having success with this? As in able to add all their devices and reliably control them individually using Siri. I have spent 3 days on this now and I'm no closer to understanding what it is I'm doing wrong?!? Or is it just buggy as hell and nothing I can do to correct it?
Did you overwrite the Domoticz.js file in folder Platforms with the attachted file?simon_rb wrote:Tried this and mine still imported all the scenes..
I tried to run again to see if it missed anything. Is that wrong? would I need to uninstall first? If so, how would I do that?simon_rb wrote:Did you run npm install twice?
- Target OS: -
I did.Eduard wrote:Did you overwrite the Domoticz.js file in folder Platforms with the attachted file?simon_rb wrote:Tried this and mine still imported all the scenes..
- Target OS: -
It has to be run inside the lib-node folder..thebeetleuk wrote:I tried to run again to see if it missed anything. Is that wrong? would I need to uninstall first? If so, how would I do that?simon_rb wrote:Did you run npm install twice?
Is that this directory?simon_rb wrote:It has to be run inside the lib-node folder..thebeetleuk wrote:I tried to run again to see if it missed anything. Is that wrong? would I need to uninstall first? If so, how would I do that?simon_rb wrote:Did you run npm install twice?
/usr/local/lib/node_modules/
Today I experience new issues with Eve/Siri so I resetted Homekit configuration on my IOS device. After that I opened Eve but it couldnt find my devices anymore.
Trying to run 'npm run start' gives the following message:
[Domoticz] Loaded services for Zonnescherm
Cannot create another accessory with the same name 'Zonnescherm'. The 'name' property must be unique for each accessory.
[Domoticz] Initializing device with name Alle Lampen AAN...
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
RFXCOMtrx433e
