Script examples (Lua)
Vopis
Re: Check last seen?
Post by Vopis »
After many hours of research and tests, I found the solution!
I have some Xiaomi/Aqara sensors (Door sensors, Water Leak, Motion Sensor). The problem is that Domoticz is not saving "Last Seen" datetime from "Devices" and there are no ways to get this value into a script for determinating the sensor timeout.
I'm using a Raspberry Pi + Zigbee2MQTT (CC2531). From the logs I found that the sensors are connecting to the Zigbee2MQTT every 50 minutes. When this happens, the sensor changes the "Last Seen" but it doesn't change the "Last Update". If for example the sensor is in the same state, then this value doesn't change. I found how to make a kind of watchdog relaying on "Last Seen". I got this value using JSON API from domoticz, so when you send a GET request for the specific idx, you get the Last Seen value.
For this we need 2 LUA scripts and some variables.
Script 1: Checking Last Seen and updating variable with the actual Last Seen timer:
json = (loadfile "/home/domoticz/scripts/lua/JSON.lua")()  -- For Linux
local config=assert(io.popen('curl "http://127.0.0.1/json.htm?type=devices&rid=71"')) -- json data off all solar panels
local Stringjson = (config:read("*all"))
config:close()
local jsonData = json:decode(Stringjson)
commandArray['Variable:Entrance_Door_Sensor']=jsonData["result"][1]["LastUpdate"]
local config=assert(io.popen('curl "http://127.0.0.1/json.htm?type=devices&rid=84"')) -- json data off all solar panels
config:close()
commandArray['Variable:Bedroom_Balcony_Door_Sensor']=jsonData["result"][1]["LastUpdate"]
local config=assert(io.popen('curl "http://127.0.0.1/json.htm?type=devices&rid=80"')) -- json data off all solar panels
config:close()
commandArray['Variable:Living_Room_Balcony_Door_Sensor']=jsonData["result"][1]["LastUpdate"]
local config=assert(io.popen('curl "http://127.0.0.1/json.htm?type=devices&rid=53"')) -- json data off all solar panels
config:close()
commandArray['Variable:Kitchen_Water_Leak_Sensor']=jsonData["result"][1]["LastUpdate"]
local config=assert(io.popen('curl "http://127.0.0.1/json.htm?type=devices&rid=67"')) -- json data off all solar panels
config:close()
commandArray['Variable:Bathroom_Water_Leak_Sensor']=jsonData["result"][1]["LastUpdate"]
local config=assert(io.popen('curl "http://127.0.0.1/json.htm?type=devices&rid=75"')) -- json data off all solar panels
config:close()
commandArray['Variable:Kitchen_Motion_Sensor']=jsonData["result"][1]["LastUpdate"]
Script 2: Script that sends notification if the timeout timer expired:
-- $Id: script_time_sensormonitor.lua,v 1.3 2016/03/13 12:13:03 pi Exp $
logging = false
debug = false
-- User variables from Domoticz setup
--	SensorTimeOut (integer) is useful to change for debugging, or undefined for defaults
--	SensorsAlerted (string) - blank / undefined for no alerts, set to "None" as initial value for alterts
--	SensorMonitorDevices (string) - comma separated list of substrings to match for device names
--	SensorMonitorExcluded (string) - comma separated list of substrings out of the matched devices to exclude
monitordevices=uservariables["Zigbee_SensorMonitorDevices"];
sensorsalerted=uservariables["Zigbee_SensorsAlerted"];
devicetimeout=uservariables["Zigbee_SensorTimeOut"];
-- Fallback values
-- No changes should be needed below here
function changedsince(device)
	t1 = os.time()
	ts = uservariables[device]
	year = string.sub(ts, 1, 4)
	month = string.sub(ts, 6, 7)
	day = string.sub(ts, 9, 10)
	hour = string.sub(ts, 12, 13)
	minutes = string.sub(ts, 15, 16)
	seconds = string.sub(ts, 18, 19)
	difftime=(os.difftime(t1,t2))
	-- if (debug) then print("Device " .. device .. " not changed in " .. difftime .. " seconds") end
	return difftime
for device, value in pairs(uservariables)
do
	pos = nil
	exclpos = nil
	for matchname in string.gmatch(monitordevices, "[^,]+")
	do
		pos = string.find(device,matchname,1,true)
		if ( pos ) then
			if ( exclpos ) then break end
			if (debug) then print("Included device " ..  device .. " matching " .. matchname .. " value=" .. value) end
			deltatime =  changedsince(device)
			if ( deltatime > devicetimeout ) then
				if (logging) then print("Timeout for " .. device .. ". Not seen for " .. deltatime .. " seconds" ) end
				if ( sensorsalerted ) then
					pos = string.find(sensorsalerted,"," .. device,1,true)
					if not ( pos ) then
						sensorsalerted = sensorsalerted .. "," .. device
						if (logging) then print("sensorsalterted addition: " .. device .. " added to " .. sensorsalerted) end
						commandArray['Variable:Zigbee_SensorsAlerted']=sensorsalerted
						commandArray['SendNotification']="Sensor " .. device .. " inactive for " .. deltatime .." seconds"
					if ( pos ) then
						len = string.len(device) + 1
						sensorsalerted = string.sub(sensorsalerted, 1, pos - 1) .. string.sub(sensorsalerted, pos + len)
						if (logging) then print("sensorsalterted removal: " .. device .. " removed from " .. sensorsalerted) end
						commandArray['SendNotification']="Sensor " .. device .. " active again"
			if (debug) then print("No match device " ..  device .. " no match for " .. matchname) end
Creating variables: You need to create a variable for every sensor you want to monitor. This variable will be updated by Script 1 with the "Last Seen" date and time (when the sensor was reaching Zigbee2MQTT last time, not when the sensor status changed).
Also you need to create 3 variables for Script 2:
Zigbee_SensorTimeOut - time in seconds for sensors to send notification. (Sensors are connecting to Zigbee2MQTT every 50 minutes. I recommend to set: 3600 (60 minutes)
Zigbee_SensorMonitorDevices - variables for every sensor to monitor
Zigbee_SensorsAlerted - This variable will change once a notification was sent for a specific sensor. By default you must set it: None
Krenstik
Counter data
Post by Krenstik »
HI,
I reading data usage from Synology router via SNMP and I get text or value, but I wish to have it counter, but to be honest I spend a week to understand a Lua script without result.
SO can any one of you please make for me a stupid simple script that takes a value from virtual / or text (I have both) and put it in the counter?
Device id is 682 - Data: "5398910887", (HardwareName: "SNMP Router upx",)
or
device is 688- Data: "5.3991e+09 ",
and virtual counter is a 689
Thank you........
timmpo
Re: Script examples (Lua)
Post by timmpo »
Domoticz input device!
I needed a device to store settings and other information.
The device creates a uservariable and saves input information witch you can use in other scripts outside and inside domoticz.
The text box is set to only accept numbers if strings neded you have to change "number" to "text" --> html_3 = "</label><br> <input type=\"number\"
    --Create a text device and enable this script
    --Settings
    domoticsURL         = "192.168.1.2:8080"    --Domoticz ip address
    domoticsUser        = "gDgDgDgD"            --Username in base64! https://www.base64encode.org/
    domoticsPass        = "LsLsLsLSL"   	--Password in base64! https://www.base64encode.org/
    userVariableName    = "pris"                --Variable name (its automatly created)
    label               = " Öre"                --Your label
    textDeviceName      = "Avblockeringspris"   --Name on your text device
    html_1 = "<iframe name=\"dummyframe\" id=\"dummyframe\" style=\"display: none\"></iframe> <form method=\"POST\" action=\"/json.htm\" target=\"dummyframe\"> <input type=\"hidden\" id=\"\" name=\"type\" value=\"command\"> <input type=\"hidden\" id=\"\" name=\"param\" value=\"udevice\"> <input type=\"hidden\" id=\"\" name=\"idx\" value=\""
    html_2 = "\"> <input type=\"hidden\" id=\"\" name=\"nvalue\" value=\"0\"> <label for=\"fname\">"
    html_3 = "</label><br> <input type=\"number\" id=\"fname\" name=\"svalue\" value=\"\"> <input type=\"image\" class=\"btnsmall\" alt=\"Save\"></form>"
function url_encode(str)
  if (str) then
    str = string.gsub (str, "\n", "\r\n")
    str = string.gsub (str, "([^%w %-%_%.%~])",
        function (c) return string.format ("%%%02X", string.byte(c)) end)
    str = string.gsub (str, " ", "+")
  return str
if(uservariables[userVariableName] == nil) then
    print("Variable dont exist")
    commandArray['OpenURL']=domoticsURL..'/json.htm?username='..domoticsUser..'&password='..domoticsPass..'&type=command&param=adduservariable&vname='..url_encode(userVariableName)..'&vtype=0&vvalue=0'
if (otherdevices[textDeviceName] == 'Hello World') then
    ttext = "0"
    commandArray['Variable:'..userVariableName] = ttext
    ttidx = otherdevices_idx[textDeviceName]
    html = html_1..ttidx..html_2..ttext..label..html_3
    commandArray['UpdateDevice'] = ttidx..'|0|'..html
if (devicechanged[textDeviceName]) then
    ttext = otherdevices[textDeviceName]
Thorgal789
Post by Thorgal789 »
Nice, so usefull.
Good idea too, using html code in text, I think I will do same for other stuff.
Thx a lot.
Neutrino
Domoticz version: 2021.1
Post by Neutrino »
Very good !
Looks like a hack, but very useful.
Thanks 🍺
Nautilus
Post by Nautilus »
Has there been some sort of quite fundamental change in Lua recently? These used to work fine but now I've noticed in two places that changing On/Off with commandArray in Lua, the changed device does not trigger the associated automation (from "devicechanged").
E.g.
elseif otherdevices['Kotona'] == 'Off' and otherdevices['Nukkumassa'] == 'On' then
    commandArray[#commandArray+1]={['Nukkumassa'] = 'Off'}
    commandArray[#commandArray+1]={['Variable:AwakeCounter'] = '0'}
does not trigger the automation associated to device "Nukkumassa".
But this works:
    os.execute('curl -s -m 10 --connect-timeout 10 "http://127.0.0.1:30/json.htm?type=command&param=switchlight&idx='..otherdevices_idx['Nukkumassa']..'&switchcmd=Off" &')
zicht
Domoticz version: 2023.1+
Post by zicht »
Check on daylight saving or not (also timezone offset)
local timezone = os.date('%z')
local signum, hours, minutes = timezone:match '([+-])(%d%d)(%d%d)'
signum : returns + or -
hours : the amount of hours for timezone offset
minutes : the amount of minutes for timezone offset, (i don't see a usercase for this)
In summer hours returns for amsterdam +2
During daylight saving it returns for amsterdam +1
This can be handy to adjust timing in script based on time of year and taking into acount daylight saving time.
zicht
Post by zicht »
Previous duration
I think we all know that its usefull to know sometimes how long a "switch" is on. Thats pretty much explained and in use.
But some times its not about the current state duration but the previous state duration....
Lets say you want to send a message on a current "On" state change but only if the "Off" state has been longer than x seconds ? (Like: display a welcome greeting only if longer detected away then 30 minutes, as soon as you arrive)
Thats where the below script can help you ;
function get_previous_state_duration(idx)
 		cmd='C:/progra~2/Domoticz/curl.exe -4 -s "http://192.168.xxx.xxx:xxxx/json.htm?type=command&param=getlightlog&idx='..idx..'"'
	        local f,err=assert(io.popen(cmd, 'r')) if f~=nil then content=assert(f:read('*a')) f:close() end
	        if content~=nil and string.find(content,'"Data"',0)~=nil then
		a=string.find(content,'"Data"',0) b=string.find(content,'"User"',a) eerste=string.sub(content,a,b) a1=string.find(eerste,'Date') b1=string.find(eerste,'Level',a1) eerste=string.sub(eerste,a1+9,b1-8)
		c=string.find(content,'"Data"',b) d=string.find(content,'"User"',c) tweede=string.sub(content,c,d) a1=string.find(tweede,'Date') b1=string.find(tweede,'Level',a1) tweede=string.sub(tweede,a1+9,b1-8)
		yearx=string.sub(eerste, 1, 4) monthx=string.sub(eerste, 6, 7) dayx=string.sub(eerste, 9, 10) hourx=string.sub(eerste, 12, 13) minutesx=string.sub(eerste, 15, 16) secondsx=string.sub(eerste, 18, 19)
		t1=os.time{year=tonumber(yearx), month=tonumber(monthx), day=tonumber(dayx), hour=tonumber(hourx), min=tonumber(minutesx), sec=tonumber(secondsx)}
		yeary=string.sub(tweede, 1, 4) monthy=string.sub(tweede, 6, 7) dayy=string.sub(tweede, 9, 10) houry=string.sub(tweede, 12, 13) minutesy=string.sub(tweede, 15, 16) secondsy=string.sub(tweede, 18, 19)
		t2=os.time{year=tonumber(yeary), month=tonumber(monthy), day=tonumber(dayy), hour=tonumber(houry), min=tonumber(minutesy), sec=tonumber(secondsy)}
		difference=os.difftime (t1, t2) print(difference)
		return difference
		return err
I use it on a windows machine so you need to alter the curl command to your sys. Dont forget to alter the domoticz IP and PORT
In setting i have disabled the username passw verification for the local host and for api call. (i sadly was never able to get the new api call security to work with curl on windows, it just does not work at all )
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
zicht wrote: Tuesday 29 October 2024 12:45 I think we all know that its usefull to know sometimes how long a "switch" is on.
Yes, thats right. Thats my solution:
        timer = {'Every 20 minutes'},
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'Check backdoor lights',
        local switch = domoticz.devices(1)  -- idx of the switches to check
	function disp_time(total_seconds)
          local days = math.floor(total_seconds/86400)
          local remaining = total_seconds % 86400
          local hours = math.floor(remaining/3600)
          remaining = remaining % 3600
          local minutes = math.floor(remaining/60)
          remaining = remaining % 60
          local seconds = remaining
          local hoursstr = "hours"
          local daysStr = ""
          if days > 0 then
              daysStr = days .. ' days'
          if (minutes < 10) then
            minutes = "0" .. tostring(minutes)
          if (seconds < 10) then
            seconds = "0" .. tostring(seconds)
          answer =daysStr..' '.. tostring(hours)..' '..hoursstr..' '..minutes..' minutes'
          return answer
            if (switch.state == 'On' and switch.lastUpdate.secondsAgo > 7000 and item.isTimer ) then  -- if switch is on > 7000 seconds
                local total_seconds = switch.lastUpdate.secondsAgo
                -- sending notify to Telegram^
                domoticz.executeShellCommand('curl -v -X POST --silent --output /dev/null https://api.telegram.org/bot'.. domoticz.variables('TbotNumber').value ..'/sendMessage -d chat_id='.. domoticz.variables('MyChatId').value ..' -d text="Backdor light is ON for more then '..disp_time(total_seconds)..'!!! Do you forgot about it??"')
P.S. I'm on windows too.
Why dont you use 'domoticz.openURL' method for example ?
zicht
Post by zicht »
I am still on plain lua, dzevents is really nice and i should switch... just to lazy to transform all my scripts.
openurl on lua is working great as output, but i also need sometimes a return value.
As for offloading domoticz, i put recurrent url or curl callings on windows taskschedular (writing to a txt file.)"
This way domoticz only does a discoperation and thats lightning fast = without any delay (<1 ms on my machine)
With all automations timing in the end becomes a problem if not managed well.
Tukker
Domoticz version: 2023.2
Post by Tukker »
You don't have to switch to dzVents for every lua script.
I suggest to do it one by one, try, learn, enjoy.
Bugs bug me.
KoffieNu
Domoticz version: 2024.7
Post by KoffieNu »
I'm using 2024.7 and I'm trying to use a motionsensor to switch on and off a light in the hallway (socket switch, as I'm still messing about, so main light needs to be manual) and limit it's workings to moments when it's dark enough to need it.
However, I get the error "attempt to index a nil value (global 'devicechanged')" the 1st time I try to use devicechanged. The device names I use are copy'n'pasted from the devices list, as to prevent typos (I'm good at them).
Exact error:
Error: EventSystem: in Licht gang: [string "-- ..."]:26: attempt to index a nil value (global 'devicechanged')
Script (without the 24 line header of the template, so line 26 is the 2nd line of real code.
if (devicechanged['BewegingsensorGang']) then
   luxLevel=tonumber(otherdevices['LichtsensorGang'])
   if (devicechanged['BewegingsensorGang'] == 'On' and otherdevices['StopcontactGang'] == 'Off' and luxLevel < 2300 ) then
       commandArray['StopcontactGang']='On'
            print('StopcontactGang was switched ON')
   if (devicechanged['BewegingsensorGang'] == 'Off') then
      commandArray['StopcontactGang']='Off'
      print('StopcontactGang was switched OFF')
   if (devicechanged['BewegingsensorGang'] == 'On' and luxLevel >= 2300 ) then
      print('StopcontactGang was switched ON but it\'s daytime!')
And the devices I use according to the 'Devices current state' tab while editing the script via the web interface:
I have the motion sensor as switch for the socket, that works, but I want to prevent the light being turned on when it's already light enough in the hallway. When I turn on the main light, the value of the lux meter is 2359, so 2300 is a test value that should be usable, but I can't get past the 1st line, or is the error on line 26 indicating I have an error in that if statement, somewhere?
Edit: PEBKAC... (user error) I got the error as I had all as trigger. With device as trigger the script gives errors I can fix. I'm working on it now and will post the end result. I still have the issue that the switch isn't triggered from time to time, leaving either the light on when it should be off or not turning on. I see loads of resets from the dongle though, could be a power issue.
Edit 2: Got the code below running and it runs pretty well.
hallLightLux = 2300
switchedLightLux = 1150
dayLightLux = 650
-- Enable for debugging
-- print("Light : "..otherdevices['LichtsensorGang'])
-- print("Plug  : "..otherdevices['StopcontactGang'])
-- State change BewegingsensorGang
then
   -- make a number from lux level in hallway
   -- When motion sensor detects motion
   if (devicechanged['BewegingsensorGang'] == 'On')
   then
      -- Plug hallway is off
      if (otherdevices['StopcontactGang'] == 'Off')
      then
         -- When to dark, turn on
         if ( luxLevel < dayLightLux )
         then
            print('Motion was detected, StopcontactGang was switched ON')
      -- Plug hallway is on and enough light (more then the switched light)
      elseif (luxLevel >= switchedLightLux )
      then
         --- turn light off as it's not needed
         -- check level for log message
         if (luxLevel >= hallLightLux )
         then
            print('Motion was detected, but the main light is on, StopcontactGang switched OFF!')
            print('Motion was detected, but there is enough light ('..luxLevel..'), StopcontactGang switched OFF!')
         print('Motion was detected, but there is enough light ('..luxLevel..'), nothing switched.')
   if (devicechanged['BewegingsensorGang'] == 'Off' and otherdevices['StopcontactGang'] == 'On')
   then
      print('No more motion detected, StopcontactGang was switched OFF')
-- State change LichtsensorGang
if (devicechanged['LichtsensorGang'])
then
   -- check is motion sensor is off and light is on.
   -- delayed off when found on. (dirty hack on random disconnects)
   if (otherdevices['BewegingsensorGang'] == 'Off' and otherdevices['StopcontactGang'] == 'On')
   then
The extra section for LichtsensorGang is to use the more often changing lux sensor to trigger an off event when it's still on. Stability of the stick isn't to great.
What I haven't figured out yet is how to delay a power-off. I tried to use the scene I have for the light with a delayed power-off, but that doesn't seem to work to well. I don't want to put the delay on the device StopcontactGang, as that needs to be switched off without delay when the light level is high enough. Something to think about.
Edit 3: Found how to switch a scene thanks to this question about checking the state of a scene. Added it to my script and it seems to work. (alas, not working, reverting to device, so I'm still looking for a timer option)
FlyingDomotic
Post by FlyingDomotic »
devicechanged is not a variable but a table, that may contain more than one value.
The right way to extract name and value of changing devices is :
[code
for deviceName,deviceValue in pairs(devicechanged) do
<<Use here deviceName and deviceValue>>
[/code]
lost
Post by lost »
FlyingDomotic wrote: Sunday 15 December 2024 21:01 devicechanged is not a variable but a table, that may contain more than one value.
Are you really sure of this statement? This contradict what's written in script_device_demo.lua that states:
-- device changed contains state and svalues for the device that changed.
otherdevices and otherdevices_svalues are arrays for all devices
Hence the singular for this name/state table (not the case for otherdeviceS)... but that's in my understanding for a single device.
Never parsed the full table in my device scripts & did not observed missed actions based on devicechanged filtering as well!
jvdz
Domoticz version: 4.107
Post by jvdz »
devicechanged is a table/array containing the devices changed for this event.
Try to put this code in a device event script and you will see:
for i, v in pairs(devicechanged) do
   print("! Device =>"..i.." new   status:"..v)
lost
Post by lost »
As device/time... type scripts are all triggered when an event occurs, not sure parsing the devicechanged table would make a difference anyway (the device parse loop in a single script would be somehow transferred to the event system script calling loop).
But I always observe a few ms between prints, not a single one in the exact same time range. IMO, even on a PI3, the parse+print itself is far from needing a single ms to be processed... and there is always at least 1ms (the log time resolution) difference, mostly several, even for a device like my smartmeter that always send all measurements (I/V/P/CosPhy) if a single value change exceed 2% vs last reported.
FlyingDomotic
Here's the default script for LUA/Device (click on "+", right most on scripts tab):
-- Domoticz passes information to scripts through a number of global tables
--   devicechanged['yourdevicename'] = state
--   devicechanged['svalues'] = svalues string
-- otherdevices, otherdevices_lastupdate and otherdevices_svalues are arrays for all devices:
--   otherdevices['yourotherdevicename'] = "On"
--   otherdevices_lastupdate['yourotherdevicename'] = "2015-12-27 14:26:40"
--   otherdevices_svalues['yourotherthermometer'] = string of svalues
-- uservariables and uservariables_lastupdate are arrays for all user variables:
--   uservariables['yourvariablename'] = 'Test Value'
--   uservariables_lastupdate['yourvariablename'] = '2015-12-27 11:19:22'
-- other useful details are contained in the timeofday table
--   timeofday['Nighttime'] = true or false
--   timeofday['SunriseInMinutes'] = number
--   timeofday['Daytime'] = true or false
--   timeofday['SunsetInMinutes'] = number
--   globalvariables['Security'] = 'Disarmed', 'Armed Home' or 'Armed Away'
-- To see examples of commands see: http://www.domoticz.com/wiki/LUA_commands#General
-- To get a list of available values see: http://www.domoticz.com/wiki/LUA_commands#Function_to_dump_all_variables_supplied_to_the_script
-- Based on your logic, fill the commandArray with device commands. Device name is case sensitive.
-- loop through all the changed devices
    print ("Device based event fired on '"..deviceName.."', value '"..tostring(deviceValue).."'");
--    if (deviceName=='myDevice') then
--        if deviceValue == "On" then
--            print("Device is On")
--        elseif deviceValue == "Off" then
--            commandArray['a device name'] = "On"
--            commandArray['another device name'] = "Off AFTER 10"
--            commandArray['Scene:MyScene'] = "Off"
--            commandArray['Group:My Group'] = "Off AFTER 30"
--        end
--    end
Concerning timing, don't forget that there's only one script active at a time. Guess what will happen if you spend too much time in a script, while few events will be delivered (but nor executed, as waiting for current script to end).
lost
Post by lost »
The time difference observation I made was with jvzd test script. So I presumed prints always resulted from successive calls but... Looks this was not the case, if I add a counter to the loop (+ here I have some logs with exact same timing up to 1ms resolution) that counts devices that trig'ed in a single call:
2024-12-17 08:09:30.992 Status: LUA: ! Device1 =>Prise Seche Linge W_Utility new status:685.0
2024-12-17 08:09:30.994 Status: LUA: ! Device2 =>Prise Seche Linge W new status:685.0
2024-12-17 08:09:35.986 Status: LUA: ! Device1 =>Prise Seche Linge W new status:678.0
2024-12-17 08:09:35.986 Status: LUA: ! Device2 =>Prise Seche Linge W_Utility new status:678.0
2024-12-17 08:09:36.987 Status: LUA: ! Device1 =>Prise Seche Linge W_Utility new status:684.0
2024-12-17 08:09:36.987 Status: LUA: ! Device2 =>Prise Seche Linge W new status:684.0
2024-12-17 08:09:39.991 Status: LUA: ! Device1 =>Prise Seche Linge W new status:677.0
2024-12-17 08:09:39.991 Status: LUA: ! Device2 =>Prise Seche Linge W_Utility new status:677.0
2024-12-17 08:09:41.449 Status: LUA: ! Device1 =>SmartMeterW CTR new status:975.300;22682400.000
2024-12-17 08:09:41.449 Status: LUA: ! Device2 =>SmartMeterW CTR_Utility new status:975.29998779297
2024-12-17 08:09:41.851 Status: LUA: ! Device1 =>SmartMeter W new status:983.2
2024-12-17 08:09:41.851 Status: LUA: ! Device2 =>SmartMeter W_Utility new status:983.20001220703
2024-12-17 08:09:41.905 Status: LUA: ! Device1 =>SmartMeterW CTR new status:983.200;22682400.000
2024-12-17 08:09:41.905 Status: LUA: ! Device2 =>SmartMeterW CTR_Utility new status:983.20001220703
2024-12-17 08:09:42.050 Status: LUA: ! Device1 =>SmartMeter V new status:233.500
2024-12-17 08:09:42.050 Status: LUA: ! Device2 =>SmartMeter V_Utility new status:233.5
2024-12-17 08:09:42.263 Status: LUA: ! Device1 =>SmartMeter I new status:4.4;0.0;0.0
2024-12-17 08:09:42.466 Status: LUA: ! Device1 =>SmartMeter PF_Utility new status:1.0
2024-12-17 08:09:42.467 Status: LUA: ! Device2 =>SmartMeter PF new status:1.00
2024-12-17 08:09:45.033 Status: LUA: ! Device1 =>Prise Seche Linge W new status:684.0
2024-12-17 08:09:45.033 Status: LUA: ! Device2 =>Prise Seche Linge W_Utility new status:684.0
2024-12-17 08:09:49.762 Status: LUA: ! Device1 =>PI CPU Usage_Utility new status:4.8899998664856
2024-12-17 08:09:49.762 Status: LUA: ! Device2 =>PI CPU Usage new status:4.89
=> There can be a few ms gap between 2 prints for the same call, as the very 1st in this log extract so my assumption was wrong.
But also note (sub-)devices that change always are part of the same hardware, for now I did not saw exceptions to this + that's mostly 1 or 2, rarely up to 4 (only for weather virtual devices on which I do not have any script handling, not real hardware)... See for instance my Smart-Meter that sends many measurements in bursts: They are in fact always split in Lua handling.
So agree this may optimize Lua scripts handling a bit, but as sub-devices that belongs to the same hardware will most probably be handled in a single script not sure this makes so big difference.
Here is the modified script to make it clear (script_device_test.lua):
local devicesTriggeredNb = 0
   devicesTriggeredNb = devicesTriggeredNb + 1
   print("! Device"..devicesTriggeredNb.." =>"..i.." new   status:"..v)
On my side (2024.7), the demo device script have your lines commented and also have these lines as supposed real case examples at the end (that's the one in domoticz/scripts/lua, I don't use event editor as having a messy script stored in DB can turn to headache if this cause domoticz runtine issues, with no easy way to remove it!):
-- TBD: nice time example, for instance get temp from svalue string, if time is past 22.00 and before 00:00 and temp is bloody hot turn on fan.
print('this will end up in the domoticz log')
if (devicechanged['MyDeviceName'] == 'On' and otherdevices['MyOtherDeviceName'] == 'Off') then
	commandArray['MyOtherDeviceName']='On'
And no loop based handling there, the commented one looked to target debugging IMO & induced my understanding.
Anyway, I keep in mind that (sub-)devices handling may be optimized using a loop... or even prefilter early in scripts using name prefix as I always use a real hardware name prefix for their included devices before the targeted handling that'll follow.
Tukker
Post by Tukker »
FlyingDomotic wrote: Monday 16 December 2024 18:43 Here's the default script for LUA/Device (click on "+", right most on scripts tab):
So great a script!
It's a realy simple way to be able to watch what's happening behind the scenes PLUS the data being displayed.
I have put in the list of scripts and named it All data display
Activate it, wait a little while, deactivate it and read the log to get all information you're searching for.
Bugs bug me.
zicht
Post by zicht »
A while ago i posted some inspiration and got asked to share some of my scripts.
Below 2 useful functions for being able to mix names and idx in scripts and have the script figure out what it should be.
The last function is a plain lua solution to change the color on hue lights (you could invest in DZevent that should make things more easy)
function getdevname4idx(deviceIDX)
	for i, v in pairs(otherdevices_idx) do
		if v == deviceIDX then
			return i
	return 0
function getdevidx4name(name)
    v=otherdevices_idx[name]
	return v
function kleur(idxorname,hex,brightnes,iswhite,timing)
	--usage : kleur(idxorname,hex,brightnes,iswhite,timing)
	-- idorname : the idx or name of the light bulb
	-- hex :  the hex color value, schould be 0 when using on an iswhite lamp
	-- brightnes : the amount of light
	-- iswhite : value should be 0 when using hex (hue has color and non color bulbs this can be used for the non color bulbs, i have non so this is
	  	         not testet)
        --print(idxorname,hex,brightnes,iswhite,timing)
	if tonumber(idxorname)==nil then naam=idxorname idx=getdevidx4name(idxorname) else idx=tonumber(idxorname) naam=getdevname4idx(idxorname) end
	if idx==nil then return end
	if hex==nil then return end
	if brightnes==nil then return end
	if iswhite==nil then return end
	if tostring(hex)=="0" or tonumber(hex)==0 then return end
	--if tostring(brightnes)=="0" or tonumber(brightnes)==0 then return end
        --print("Kleur "..tostring(naam)..":"..tostring(idx))
	if iswhite~="0" then url="http://192.168.0.XXX:XXXX/json.htm?type=command&param=setcolbrightnessvalue&idx="..tostring(idx).."&hue="..iswhite.."&brightness="..brightnes.."&iswhite=false"
	if hex~="000000" then url="http://192.168.0.XXX:XXXX/json.htm?type=command&param=setcolbrightnessvalue&idx="..tostring(idx).."&hex="..hex.."&brightness="..brightnes.."&iswhite=false"
	if timing~=nil and timing~=0 then url=url.." AFTER "..timing end
	commandArray[#commandArray +1]={['OpenURL']=url}
usage : kleur("Douche plafon","30FF0A",40,0,0.5)
0.5 is the delay in seconds ( dont use 0.0 -> that wil sometimes fail somehow)
I have an habit of storing the current color in a uservariable but that is not nessecary ( but handy if you want to make predictable color changes)
kleur("nb","fe00fe",25,0,0) commandArray['Variable:nb_status']="rose"
I use this for example
- to blink the shower bulb red for 1 sec if the warm water is on longer than 5 minutes
- blink a bulb in the living room upon facerecogn.
another one that can be handy :
viewtopic.php?p=320953#p320953
>> Remember that you have to change the urls based on your webserver and security settings. <<
