Page 7 of 7
Re: Dashticz v3.8.2 beta: New weather block
Posted: Monday 01 November 2021 19:53
by Lokonli
whoami wrote: Sunday 31 October 2021 12:13
whoami wrote: Friday 29 October 2021 17:22
I have a question about the new weather block and the power consumption.
I’m running dashticz on an intel nuc and I use a power measurement adapter.
Since the moment I use the new weather block my powerusage is slowly growing throughout the day.
When not using the weather block my usage is 11 watt.
The moment I add the weather block my usage goes to 16 watt and slowly going after 12 hours reaching 20 watt and stays steady.
If I refresh the dashticz it goed back to 16 watt and after 12 hours again steady at 20 watt.
When I remove the weather block again it is direct steady at 11 watt again.
Is it normal that this happens?
If I use static icons the usage is still 12 watt, so the problem is the dynamic animations. That is using almost 8 watt…
Is that normal @lokloni?
I noticed as well that the animated weather icons are pretty CPU intensive. The increase from 16W to 20W is a bit strange however. I'll try to find out what is causing that.
In the mean time I'll check whether there are less CPU demanding animated weather icons.
Posted: Friday 05 November 2021 15:32
by whoami
Lokonli wrote: Monday 01 November 2021 19:53
That would be nice, is there no option to set colors on the static icons for the weather?
Posted: Saturday 06 November 2021 10:15
by HansieNL
You can find the styling options for the weather block here:
https://github.com/Dashticz/dashticz/b ... st#styling
If you mean the the color option: Object to color the animated weather icons.
So will not work for static icons.
Posted: Saturday 27 November 2021 12:01
by whoami
Did you had time to look into the animated weather icons?
Posted: Sunday 26 December 2021 22:06
by McMelloW
Hi Lokonli,
Since I Have installed my own Weather Station and receive all data directly form it in Domoticz by the wudirect plugin. How do I put this data in the Dashticz weather block? Is this possible?
