enphase envoy with (HTTP) interface
- gizmocuz
Re: enphase envoy with (HTTP) interface
@Sebastiii, are you using firmware 7+?
As this call was not working last time I checked:
https://ENVOYIP/stream/meter
@AintBigAintClever ,
There was a extra kWh counter that was not necessary. That is why it has been removed.
You should have all available info from the hardware
- gizmocuz
Why would you need this? The native hardware in Domoticz works correct and does even moreTurboX wrote: Thursday 20 July 2023 13:20 There is this project too https://github.com/vk2him/Enphase-Envoy-mqtt-json
Sebastiii
- Domoticz version: 2023.1
Higizmocuz wrote: Monday 31 July 2023 11:15 @Sebastiii, are you using firmware 7+?
Yes but was working too with 5 firmware before, it seems to be specific with Envoy S metered version.
Can you get information from URL (IVP)?
https://ENVOYIP/ivp/meters/readings
With this one but ned'ed to keep production.json too.
We have a proper counter for net power, it means when exporting counter as is.
Look at my post here :
viewtopic.php?p=304972#p304972
- gizmocuz
Firstly, you are probably using a metered envoy.
The negative values you see are actually a one-on-one copy from the envoy.
It just reports this way.
I also don't think there is anything wrong with this.
Can you compile Domoticz yourself?
Change the code a bit, find the following line in the Enphase.cpp file
Json::Value reading = (bIsMeteredVersion) ? root["production"][1] : root["production"][0];
Now add this just before this line:
bIsMeteredVersion = false;
Then compile
This should bring back the previous behavior that someone wanted to be changed.
I also think that the "ivp" url calls need you to have installer rights, while the normal calls you can also execute with normal user rights.
Which is of most important to some users as you might understand.
Then compile
Sebastiii
@gizmocuz
Yes, I'm using metered version, sorry to didn't saying it.
On fact that would be great.
Is to have some configure option depend of hardware owner configuration.
Yes I'm able to compile not right now but I can test for sure and thanks.
I will be back to you after testing can take time because I'm in convalescence
Tapatalk
Tapatalk
- gizmocuz
@Sebastiii , thanks I will wait for your testing
Hope you recover quickly!
Sebastiii
Thank you @gizmocuz
I will surely do the testing in the week because I need to move a little and it will me force (in good way) kind of good motivation
Tapatalk
Tapatalk
TurboX
Hello,gizmocuz wrote: Monday 31 July 2023 11:17
Why would you need this? The native hardware in Domoticz works correct and does even more![]()
I have explained my point of view here viewtopic.php?p=305064#p305064
Moreover the stream can give positive and negative cumulative energy for each Current Transformer. If I want to measure the voltage, it's easier to add by myself with this kind of plugin than modify and compile from source.
Sebastiii
SalutTurboX wrote: Tuesday 01 August 2023 10:31Hello,gizmocuz wrote: Monday 31 July 2023 11:17
Hi, I can confirm that I'm able to have a proper counter value by creating a counter instant device configured as computed, to have it working at 100 % it's important to have data always filled.
But in computed mode when value is negative, the counter decrease, in this case for us, it's not correct.
So in final in a day with a lot of export the net counter doesn't match the linky enedis TIC information because the device created decrease.
And using IVT url, enphase give a counter that doesn't decrease like production.json (still need to test the code to compile that I didn't do yet)
So for now the node red configuration with stream and production and IVT permit to have something working on my side with my metered envoy.
So yes if we can have something to be able to setup in an advanced mode on default plug-ins, it would be great and avoid nodered/mqtt setup.
Sebastiii
I did quickly try but I'm not able to connect to enphase from Domoticz, I have noticed that when working on Node-Red, it's like token for commissioned device on Node-Red side has blocked the one from Domoticz and not sure why (except, that I'm generating a lot of token but it"s working on Node-Red) !gizmocuz wrote: Monday 31 July 2023 11:33 Firstly, you are probably using a metered envoy.
Then compile
Will retry later
Sebastiii
Hello
@gizmocuz
I wasn't able to make Enphase native plugin working anymore, it seems to be related to how token is getting on Node-RED, like it was renewed all 15 seconds, it breaks something.
Still I was able to look at production[0] or [1], and on metered version, I must use production[1] and consumption[1] too, the value in [0] are not correct, it doesn't match, If I didn't make an error.
And Enphase counter decrease !
@gizmocuz
Hi!
First of all, thank you for your work on this great home automation package!
I am a happy user for years now.
However, since july, my Enphase Metered is not reporting anymore, and yesterday I finally found the time to dive into it.
The below post set me on the right track.
Actually, return 47 in my case. I guess it ever had a reading but it is not updated.
But since it is > 0, domotics uses:
instead of
By changing the test to it works again for me.
My question is: can we find a solution that works for everybody?
The nicest way is if we would have a setting "Enphase Metered" in the hardware setup, which tells Domoticz to use the first or second array index.
I am willing to make a patch to implement something like that, I somebody can show me the direction where to add such a setting?
Otherwise, what would be an alternative approach?
Thanks again,
Berkrub
Change the code a bit, find the following line in the Enphase cpp file
Then compile
Actually,
root["production"][1]["whLifetime"]But since it is > 0, domotics uses:
root["production"][1]Code: Select all
root["production"][0]Code: Select all
bIsMeteredVersion = root["production"][1]["whLifetime"].asInt() > 1000;My question is: can we find a solution that works for everybody?
Thanks again,
Berkrub
- gizmocuz
@Berkrub, that would indeed be a good solution... but it could break existing installations as now it is automatically being detected.
So to understand correctly, you do have a metered envoy, but you are not using CT Clamps?
You are on the latest firmware (7+) and also powered off and on the device ?
Feel free to make a patch. Please use Mode3 as its default 0 (and make 0 the value for the standard envoy)
Hi Gizmocuz,
Yes correct, I have a metered Envoy, and am not using the CT Clamps.
But no, the firmware version is D5-0-34. I have contacted Enphase support, but they wouldn't trigger an update since that is not available for my region.
I was thinking to make Mode3 default '1', and call it something like "Read metered values".
In that case nothing changes to the default, and in case it is not workng for somebody they can uncheck it.
A question for me: I made a branch of development. Is development the branch whene the beta releases are build from?
What I was just asking myself: is it all possible to define Mode3 with a default value other than 0?
Otherwise I'll flip the setting so that it disables reading measured values, if Mode3 is set.
- gizmocuz
Development is indeed the active branch
mode3 is currently 0, so when you use this, all current users have no issue
You should be able to update yourself to the latest firmware (V7)
Mode3 set to 'true' forces Domoticz now to read from 'production[0]', in case of a Envoy-S Metered.
I created a pull request for this change.
Xavier82
- Domoticz version: 2023.2
I have some strange behaviour since 2024.1 version.
I use the 2 hardware applications (Native Domoticz hardware and the Python Plugin with P1 meter).
The left one is the device from the Native hardware, the right one is the device based on the Python Plugin with P1 meter.
As can be seen on the left one it shows me a production of 30.706kWh.... There was no/very little sun today so this is not possible.
The right device (P1) shows the correct value.
Settings of the left device (native hardware): Any body any idea what is going on here?
- gizmocuz
Could be a counter issue, as the native uses a different counter from the Envoy
Tomorrow it will be OK
Xavier82
Thanks for the quick reponse!
I will wait then till tomorrow.
