Domoticz-Google-Assistant (dzga) Topic is solved
samourai47
Re: Domoticz-Google-Assistant (dzga)
in config.yaml i configure
# Use SSL encryption in HTTP server if not using ngrok
use_ssl: true
ssl_key: # /etc/letsencrypt/live/mysite.duckdns.org/privkey.pem
ssl_cert: # /etc/letsencrypt/live/mysite.duckdns.org/fullchain.pem
Is it good?
use_ssl: true
Is it good?
samourai47
I retart all the configuration, but all the same problem
So i have a idea about my problem?
When i go to https://mysite.duckdns.org -> i go on domoticz
when i go https://mysite.duckdns.org/settings
Idem in https://mysite.duckdns.org/Domoticz-Goo ... t/settings -> page not found
Mysite.duckdns.org is for secure domoticz and have a valide certificat
I have this in crontab
If not is there a solution? If yes how to do?
Thank's for your help
The scriptsudo /etc/letsencrypt/certbot-auto renew --webroot -w ~/domoticz/www/ --deploy-hook ~/domoticz/scripts/deploy-cert.sh >/dev/null
My idea. This certificat can or not serve the 2 services (domoticz and dzga)?#!/bin/bash
sudo mv /home/pi/domoticz/server_cert.pem /home/pi/domoticz/server_cert.pem.org
sudo cat /etc/letsencrypt/live/mysite.duckdns.org/privkey.pem >> /home/pi/domoticz/server_cert.pem
sudo cat /etc/letsencrypt/live/mysite.duckdns.org/fullchain.pem >> /home/pi/domoticz/server_cert.pem
sudo cp /home/pi/domoticz/server_cert.pem /home/pi/domoticz/letsencrypt_server_cert.pem
sudo cat /etc/ssl/certs/dhparam.pem >> /home/pi/domoticz/server_cert.pem
sudo /etc/init.d/domoticz.sh restart
Xavier82
- Domoticz version: 2023.2
@samourai47, I use for myself ngrok for this.
I don't know if tje issue could be that the certificate can't be used on 2 service.
What does the logging in DZGA say?
Do you see al the domoticz devices in DZGA?
Did you downloaded and renamed the json file from google and saved it in the dzga folder?
samourai47
Thank's xavier82 for your help
I try to install ngrok. It work's...
A question. With a free version of ngrok, i must change the configuration on console google each time i reboot the raspberry?
Thank for your help
Thank for your help
- DewGew
- Domoticz version: V4.10618
You can use a reverse proxy see dzga wiki for examplesamourai47 wrote: Tuesday 27 October 2020 12:11 Thank's xavier82 for your help
Thank for your help
portafreak
DZGA Service blocking login at boot?
DZGA seems to be blocking the login prompt when the raspberry boots:
Is there any way to fix that? My unit file looks like this:
[Unit]
Description=Domoticz-Google-Assistant Service
After=multi-user.target
[email protected]
[Service]
Environment=VIRTUAL_ENV=/home/pi/Domoticz-Google-Assistant/env
Environment=PATH=/home/pi/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
ExecStart=/home/pi/Domoticz-Google-Assistant/env/bin/python3 /home/pi/Domoticz-Google-Assistant/
User=pi
Restart=on-failure
[Install]
WantedBy=multi-user.target
samourai47
Hello
I don't undestand. All works fine for 3 days. I must reboot aund dzga dosen't work. I change nothing, juste update and upgrade my system
The probleme is when i set ngrok_tunnel : true
Imossible to log to UI dzga. If i set to false no soucy
My config
My config
# Configuration:
port_number: 3030
# Debug, Info or Error
loglevel: 'Info'
# Set logtofile: 'false' logs will not show in the LOG tab. Set logtofile: 'Overwrite' or true Log file will be overwritten when dzga server restarts
# Set logtofile: 'Append' Logs will append to logfile when dzga server restarts
logtofile: false
# If pathToLogFile is commented, removed or set to '', logs will be saved in Domoticz-Google-Assistant folder
pathToLogFile: ''
# Enable or disable UI
userinterface: true
# Check for updates
CheckForUpdates: true
# Change pidfile name and path if needed
# PidFile: '/var/run/dzga.pid'
# Instantly create a public HTTPS URL. Don't have to open any port on router and do not require a reverse proxy.
# When ngrok_tunnel set to True the auth token is required to keep the tunnel alive.
# Create account at ngrok.com and paste the token in this file.
# Ngrok assigns random urls. When server restart the server gets a new url.
ngrok_tunnel: true
ngrok_auth_token: 1j******************9el1_d5DS899GvZaspqPf3SZ3
use_ssl: false
ssl_key: # /path/to/privkey.pem
ssl_cert: # /path/to/fullchain.pem
# Login on Google Home app and configuration interface
auth_user: 'admin'
auth_pass: 'admin'
# Google Assistant Settings:
ClientID: 'clientid_from aog'
ClientSecret: 'clientsecret_from_aog'
# Domoticz Settings:
Domoticz:
ip: 'http://192.168.0.120'
port: '8080'
roomplan: '0'
username: 'toto'
password: '?***********?'
switchProtectionPass: '1234' #Set this to false if ask for pin function is not needed
# Report low battry
Low_battery_limit: 9
- DewGew
You can try start manually to see the out put:samourai47 wrote: Saturday 31 October 2020 22:41 Hello
My config
# Configuration:
port_number: 3030
loglevel: 'Info'
logtofile: false
pathToLogFile: ''
userinterface: true
# Check for updates
ngrok_tunnel: true
use_ssl: false
auth_user: 'admin'
auth_pass: 'admin'
Domoticz:
port: '8080'
roomplan: '0'
username: 'toto'
# Report low battry
cd /home/${USER}/
sudo systemctl stop dzga #If service is running
source Domoticz-Google-Assistant/env/bin/activate
python3 Domoticz-Google-AssistantRaspberry Pi 3 | domoticz | Aeon Labs Z-Stick GEN5 | RFlink gateway
samourai47
somewhere i found this line
Ngrok was unable to start. Error: 'NgrokTunnel' object has no attribute 'replace' is not valid
But ngrock seems to be ok because he give a new url.
in config.yaml i writed
ngrok_tunnel: true
ngrok_auth_token: 1-------------------yrO9el1_d5DS899GvZaspqPf3SZ3
I don't understand
ngrok_tunnel: true
I don't understand
- DewGew
Try reinstall ngroksamourai47 wrote: Sunday 01 November 2020 21:06 somewhere i found this line
ngrok_tunnel: true
I don't understand
cd /home/${USER}/
pip3 install pyngrok
samourai47
hello
I make change on my domoticz devices.
I update syns devices on dzga and i restart TEST on google console
And the modifications aren't visible in google home
Where is the problem? How is it possible to update rooms, divices etc etc
A solution?
A solution?
Last edited by samourai47 on Saturday 07 November 2020 15:22, edited 1 time in total.
samourai47
Sorry but i have an another question.
I have many temperature in my house. For example an is
Temperature du Salon with idx : 150
I want when i ask the temperature Goggle voice said :" La temperature du salon" est de 19°, and no just "La température est de 19°"
fraisdos125
- Domoticz version: 2021.1
Trying to get working dzga on rpi4.
Few infos on the RPi4 setup:
- Domoticz 2020.2
- Octoprint
- Homebridge
- Plex server,
- Nextcloud,
- Dzga
- in fex others servers,...
- reverse proxy with ssl management through haproxy.
Everything works impressively good expect few issues with current on progress configuration of dzga.
I can get syncing data through google and dzga.
Log level to Debug, but no errors in it.
anyway I think there is an mistake with the oauth currently.
I did the following tests:
- https://[my public url]/smarthome ---> not supported
- https://[my public url]/oauth ----> response_type must equal "code"
- https://[my public url]/token ----> Page not found!: '/token'
If I replace "https://[my public url]/" to "http://localhost:3030/" I get the same replies.
Then I believe there is something wrong into my config.yaml or smart-homekey.json.
Nevertheless I did follow the wiki https://github.com/DewGew/Domoticz-Goog ... stant/wiki upto chapter 4 without apparent issue.
Here is the log:
2020-11-06 08:43:02 - INFO - Connecting to Domoticz on http://192.168.1.2:8080
2020-11-06 08:43:02 - DEBUG - Starting new HTTP connection (1): 192.168.1.2:8080
2020-11-06 08:43:02 - DEBUG - http://192.168.1.2:8080 "GET /json.htm?type=command¶m=addlogmessage&message=Connected%20to%20Google%20Assistant%20with%20DZGA%20v1.8.13 HTTP/1.1" 200 49
2020-11-06 08:43:02 - DEBUG - Popen(['git', 'version'], cwd=/, universal_newlines=False, shell=None, istream=None)
2020-11-06 08:43:02 - DEBUG - Starting new HTTPS connection (1): raw.githubusercontent.com:443
2020-11-06 08:43:02 - DEBUG - https://raw.githubusercontent.com:443 "GET /DewGew/Domoticz-Google-Assistant/master/const.py HTTP/1.1" 200 9029
2020-11-06 08:43:02 - DEBUG - <pid.posix.PidFile object at 0xb5cefe68> entering setup
2020-11-06 08:43:02 - DEBUG - <pid.posix.PidFile object at 0xb5cefe68> create pidfile: /run/user/1000/dzga.pid
2020-11-06 08:43:02 - DEBUG - <pid.posix.PidFile object at 0xb5cefe68> check pidfile: /run/user/1000/dzga.pid
2020-11-06 08:43:02 - INFO - ========
2020-11-06 08:43:02 - INFO - Started DZGA v1.8.13 server at port 3030
2020-11-06 08:43:02 - INFO - Visit http://localhost:3030/settings to access the user interface
2020-11-06 08:43:02 - INFO - =========
2020-11-06 08:43:02 - INFO - Visit the Actions on Google console at http://console.actions.google.com
2020-11-06 08:43:02 - INFO - Under Develop section, replace the fulfillment URL in Actions with:
2020-11-06 08:43:02 - INFO - https://[your public url]/smarthome
2020-11-06 08:43:02 - INFO - In Account linking, set the Authorization URL to:
2020-11-06 08:43:02 - INFO - https://[your public url]/oauth
2020-11-06 08:43:02 - INFO - Then set the Token URL to:
2020-11-06 08:43:02 - INFO - https://[your public url]/token
2020-11-06 08:43:02 - INFO - Finally press 'SAVE' and then 'TEST' button
2020-11-06 08:43:02 - DEBUG - http://192.168.1.2:8080 "GET /json.htm?type=devices&plan=0&filter=all&used=true HTTP/1.1" 200 3606
2020-11-06 08:43:02 - DEBUG - {
"Je pars": {
"idx": 1,
"type": "Scene",
"state": "On",
"lastupdate": "2019-05-08 17:10:06",
"willReportState": true
Many other lines for each device without error.
any idea what to do ? I believe that as long as I don't get a good answer to http://localhost:3030/token, I will not go ahead. How to see what is blocking this ?
Is there any others redirections required than the following ones for the reverse proxy ?:
- Domoticz 2020.2
- Octoprint
- Homebridge
- Plex server,
- Nextcloud,
- Dzga
Here is the log:
"Je pars": {
"idx": 1,
"type": "Scene",
"state": "On",
- DewGew
Those cant be a local ip. Need to be accessed from internetfraisdos125 wrote: Friday 06 November 2020 9:07 Hi,
- Domoticz 2020.2
- Octoprint
- Homebridge
- Plex server,
- Nextcloud,
- Dzga
Here is the log:
"Je pars": {
"idx": 1,
"type": "Scene",
"state": "On",
- DewGew
This is a google issue. Dzga cant manage google assistant voice responsessamourai47 wrote: Thursday 05 November 2020 9:21 Sorry but i have an another question.
fraisdos125
Hi,DewGew wrote: Friday 06 November 2020 14:11
It is accessible from the internet (through a free dynamic DNS : duckdns).
If I do https://xxx.duckdns.org/oauth ---> response_type must equal "code"
https://xxx.duckdns.org/token ---> Page not found!: '/token'
https://xxx.duckdns.org/smarthome ---> not supported.
fraisdos125
Fixed, please follow all steps in the wiki, including step 4, do not test dzga before that step
samourai47
No solutions?samourai47 wrote: Wednesday 04 November 2020 21:13 hello
I make some change on my domoticz devices. (add devices, add room....)
I update sync devices on dzga and i restart TEST on google console
samourai47
I try to install nginx.
The port 80 is occupated with zigbee deconz i think. so i configure with the 83
When i change configuration to have the same certificate for domoticz :
When i reboot my rpi all seems good, but in domoticz logs i found that
I don't understand the problem. Domoticz is in /home/pi/domoticz
and DZGA in home/pi/Domoticz-Google-Assistant
in domoticz. sh i have
server {
listen 83;
listen [::]:83;
server_name toto.duckdns.org;
#change to match your address
return 301 https://$server_name$request_uri;
server {
listen 443 ssl;
listen [::]:443 ssl;
ssl_certificate /etc/letsencrypt/live/toto.duckdns.org/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/toto.duckdns.org/privkey.pem;
ssl on;
ssl_session_cache builtin:1000 shared:SSL:10m;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_ciphers HIGH:!aNULL:!eNULL:!EXPORT:!CAMELLIA:!DES:!MD5:!PSK:!RC4;
ssl_prefer_server_ciphers on;
location / {
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Scheme $scheme;
proxy_pass http://192.168.0.120:3030; #Local ipno to dzga
proxy_read_timeout 90;
location /domoticz {
rewrite ^/domoticz/?(.*) /$1 break;
proxy_pass http://192.168.0.120:8080; #local ipno to domoticz
location /assistant {
rewrite ^/assistant/?(.*) /$1 break;
proxy_pass https://192.168.0.120:3030; #local ipno to dzga
}Code: Select all
2020-11-08 09:30:03.454 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Address already in use
2020-11-08 09:30:03.455 Error: WebServer(SSL) check privileges for opening ports below 1024 and DZGA in home/pi/Domoticz-Google-Assistant
Thank's for your helpDAEMON=/home/pi/domoticz/$NAME
DAEMON_ARGS="-daemon"
#AEMON_ARGS="$DAEMON_ARGS -daemonname $NAME -pidfile $PIDFILE"
DAEMON_ARGS="$DAEMON_ARGS -www 8080"
DAEMON_ARGS="$DAEMON_ARGS -sslwww 443"
#DAEMON_ARGS="$DAEMON_ARGS -log /tmp/domoticz.txt"
#DAEMON_ARGS="$DAEMON_ARGS -syslog"
fraisdos125
Discovering the different possibilities currently, I like the capacity to merge thermostat to temperature.
There is something I don't know how to change, the min/max value of the reported temp & setting points. For a water heater I can only this 32°C and set 32 as max temp from google home. Under domoticz, no issue I can do it to 60.
Where this can be defined ?
P.S.: latest beta version of dzga under use
