Page 7 of 51
Re: Pilot: Home Automation Control (iOS app)
Posted: Friday 26 September 2014 13:19
by LanWolf
you can use telegram for messaging :) works great!
even pictures of the camera included
http://www.domoticz.com/forum/viewtopic.php?f=5&t=1985
Posted: Thursday 09 October 2014 9:08
by patoo77
Version 1.3.0 is out!
It should fix the "login authentication" issues, broken "unlock" button, and brings support for Domoticz room plans!
Let me know what you think ;-)
Posted: Thursday 09 October 2014 9:20
by bing69
patoo77 wrote:Version 1.3.0 is out!
i think great!! But.....
the switches like this one: http://www.klikaanklikuit.nl/shop/nl/pr ... -acd-3501/
are on/off switches. I see them with on level 100%. I think on or off is good.
Posted: Thursday 09 October 2014 9:35
by patoo77
Did it work before the update?
Posted: Thursday 09 October 2014 9:54
by bing69
No the same problemImage.
a picture say more then ......
Posted: Thursday 09 October 2014 9:58
by Steven84
Where can i find 1.3.0? Appstore or testflight?
Posted: Thursday 09 October 2014 10:00
by patoo77
Steven84 wrote:Where can i find 1.3.0? Appstore or testflight?
App Store ;)
Posted: Thursday 09 October 2014 10:12
by Steven84
No app store update for iphone 5S
Posted: Thursday 09 October 2014 10:37
by patoo77
Steven84 wrote:No app store update for iphone 5S
The update has been out for a few hours. Might take a while to get in the App Store worldwide.
Posted: Thursday 09 October 2014 11:08
by bing69
Vaassen is Dutch, and i have the update for the 5s
Posted: Thursday 09 October 2014 14:15
by LanWolf
Apeldoorn Too :) Running 1.3.0 since this morning :)
Posted: Thursday 09 October 2014 14:52
by Dynamic
I can't find the roomplans?
Posted: Thursday 09 October 2014 14:54
by patoo77
Dynamic wrote:I can't find the roomplans?
Should be in the "Data" tab.
Can you see the regular Domoticz categories?
Posted: Thursday 09 October 2014 14:56
by Dynamic
I see the categories, but the roomplans are missing. They are in my Domoticz-system (running V2.2040)
Fixed: removing the server and adding it again solved it.
Posted: Thursday 09 October 2014 15:55
by patoo77
Dynamic wrote: I see the categories, but the roomplans are missing. They are in my Domoticz-system (running V2.2040)
That's weird...
There must be something wrong in the update process...
Thanks for reporting it, I will check what's wrong, so it doesn't bug on every app update.
Posted: Thursday 09 October 2014 22:20
by grant
HI Just wanted to ask if there is anyway to use the app while at home connected to wifi and while away from home on 3g?
At the moment i have it configured for use away from home with the public IP, but this will not work within the home network as it needs to use the private internal ip to communicate.
it would be good if you could add two servers so that it would try the first one and if not able to reach it try the second one?
Grant
Posted: Thursday 09 October 2014 22:22
by patoo77
grant wrote:HI Just wanted to ask if there is anyway to use the app while at home connected to wifi and while away from home on 3g?
Grant
Hi Grant,
Can't you use the public IP to access it from your home network? Would be much simpler :)
I think you can set that up with your router. That way you can access both from inside and outside.
Posted: Thursday 09 October 2014 22:29
by grant
No I really don't think that will work due to the routing on the subnet. Has anyone else found a way around this?
Got to say fantastic app! :)
Posted: Friday 10 October 2014 9:15
by LanWolf
Grant
Hi Grant,
I would like such a function too, my router (Horizon box) does also not support that. (may routers don't, and since providers hand out locked in routers it is getting more and more difficult to use your own (not possible to use bridge mode in many modems )
Posted: Thursday 16 October 2014 21:37
by markk
Hi. I'm suddenly getting a message saying "error while trying to connect to server" is there a problem with this?
