Script to restart Domoticz if it crashes Topic is solved
Toulon7559
- Domoticz version: <2025
Re: Script to restart Domoticz if it crashes
@Egregius
Because of rather frequent crashes of one Domoticz_at_Raspberry, with interest looked at your 'crash-check-script'.
Problem I have that most of the time 'my' crashes are not 100%, but only for certain applications (similar to problem of HFman): see this thread_at_other_forum.
In one of the previous messages you presented a nice php-script for that aspect, but I prefer running as few scripts of different types as possible:
would it be possible to add some lines for application_check in your 'crash-check-script''?
On the other hand, perhaps a periodic check on failing application(s) is 'luxury', and a brutely forced restart or reboot by a timer e.g. every 6 hours might be effective as well.
Only preferable precaution for such timed, forced restart or reboot seems that it should not simply happen at the full hour, but at some 'odd' time such as 11 minutes after the full hour, to prevent conflicts with timed scriptrunning for backups, uploads, downloads, etc.
Last edited by Toulon7559 on Wednesday 30 August 2017 23:03, edited 1 time in total.
- Egregius
- Domoticz version: v2024.7
Well... Hmmm...
You could do a periodic reboot from cron, for example, this would reboot daily at 4:11AM (when you probably aren't bothered with it):
I use PHP for all stuff, only bash for some very basic things. PHP is very easy and versatily to handly any sort of data. Coming from Mysql, sqlite, xml, json, you name it, PHP can handle it.
If only part of the systems hangs I think I would add the devices that stop to a floorplan. Query their status in PHP, loop thru those and remember the last update time.
If the last update time is more than x minutes ago do something.
Of course, this would only work reliable if the devices report frequently.
11 4 * * * sudo rebootIf only part of the systems hangs I think I would add the devices that stop to a floorplan. Query their status in PHP, loop thru those and remember the last update time.
Toulon7559
@Egregius
Perhaps a challenge ....
Further analyzing the 'misbehaviours' in my system, which can be solved by reboot, I detect that one specific lua-script running at Raspberry3 randomly stops somewhere after 8 to 14 hours of running.
[Unfortunately very visible because it handles an upload to WUnderground. And strange, because the system load is insignificant for an upload each 20 minutes, and a similar lua-script on a RaspberryB runs without problems]
Is in your inventory of clever scripts somewhere a remedy to catch&restart such script?
Not a beauty-solution, but my own (first) idea is application of an additional semaphore set by the suspected script: outside the script in Domoticz visible as a Dummy Switch. If the status (= validity time) of the Dummy is not updated within x minutes, then time to take measures.
Any better idea is welcome .......
- Egregius
I don't use lua, can't help you with that. And why does a script has to run for so long? Is it in a loop or something? Why not break that loop after 1 minute and trigger the script to run by cron. That way you're sure the script starts every minute.
I could create a php script that checks the lastupdate of one or several devices and act upon that, but you don't want to use php...
Toulon7559
@Egregius
PHP is for me still in the learning curve (=> my own 'inventions' are still rather basic), and therefore any example is useful (and better starting point) as basis for adaptation.
Quite on purpose I put in the previous message "Is in your inventory of clever scripts"....? ", because I do not discriminate on type of available scripts, whether PHP, Python or lua, or ........
The upload of weather-data to WUnderground is on purpose running 24/7, because the need for continuous registration. Interval is also quite on purpose at 20 minutes, because otherwise you exceed the max. number of uploads allowed per 24 hours: weather is (usually) not changing that fast that higher rate is meaningful.
Obviously, then it is a pain-in-the-ass if the upload is unexpectedly failing.
Last edited by Toulon7559 on Sunday 19 November 2017 20:10, edited 1 time in total.
- Egregius
I wouldn't run a script in loop if it only needs to do something every 20 minutes.
Set it by cron
0,20,40 * * * * /path/to/script
If you want to check lastupdate of devices, this script checks devices of roomplan 2 and remembers the last update time. If lastupdatetime is more than 3600 seconds ago do something:
Set it by cron
<?php
$lastupdate=0;
$domoticz=json_decode(file_get_contents('http://127.0.0.1:8080/json.htm?type=devices&filter=all&used=true&plan=2'),true);
if(isset($domoticz['result'])){
foreach($domoticz['result'] as $dom){
$name=$dom['Name'];
$update=strtotime($dom['LastUpdate']);
if($update>$lastupdate)$lastupdate=$update;
if($lastupdate>0&&$lastupdate<$_SERVER['REQUEST_TIME']-3600){
shell_exec('/home/pi/restartsomething.sh');
Toulon7559
Looks like a good starter to check&remedy by PHP-script those 'failing' ESP-readouts mentioned here
In my setup WUnderground tellback-info appears as device in Domoticz. If upload fails, also the time validity from the read info stalls, and with such PHP-script I can detect the anomaly: useful script-example also for dealing with this 'problem'!
For the above applications developed PHP-scripts based on your example, with json triggered by rid and running under a cron like the one in this message.
Refinements come after the basic testing ........
Toulon7559
Trying to find a solution for the 'problems' described in my previous message, put in a cron (besides the first line calling an sh-file containing calls to a series of Python-scripts):
# 1 line calling the crash_checker described earlier in this thread, triggered twice each hour
# 1 'simple' line commanding a reboot, triggered twice a day
# 2 lines pointing to PHP-scripts for continuous check on status of 2 devices [derived from Egregius' example]:
- report from an ESP8266 by MTTQ to Domoticz
- tellback from WUnderground
Is an odd collection, but purely intended for temporary experiments.
*/5 * * * * /home/pi/domoticz/scripts/PythonRuntime01.sh 2>&1
25/50 * * * * /home/pi/domoticz/scripts/domoticz_crash_checker.sh 2>&1
11 4/20 * * * sudo reboot
* * * * * /usr/bin/php /home/pi/PHP/php_ESP8266C_91_reboot.php
* * * * * /usr/bin/php /home/pi/PHP/php_WU101_46_reboot.phpNo errors when calling from the CLI the scriptlines contained under the above cron, but no results visible, except for line 3 (= reboot).
No effect visible when the lines 2 till 5 are individually added to line 1.
Apparently it makes a difference whether you trigger a line from CLI, or from cron.
Any suggestion to get them running_with_effect?
- Egregius
Does the script works if you execute "/usr/bin/php /home/pi/PHP/php_ESP8266C_91_reboot.php" ?
What's in those php files?
Toulon7559
@Egregius
This is the PHP-script php_ESP8266C_91_reboot.php
The second php-script only differs by rid-number 46 instead of 91.
This is Putty_CLI for first PHP-script with result:
That is reason to state 'no result visible'
In hindsight, perhaps useful (like I do for all my lua- and Python-scripting) to add at least during testing somewhere one or more simple one-line print-instruction(s): then you get positive&visible reporting that and how far the script is executing.
<?php
$lastupdate=0;
$domoticz=json_decode(file_get_contents('http://127.0.0.1:8080/json.htm?type=devices&rid=91'),true);
$name=$dom['Name'];
shell_exec('sudo service domoticz restart');
?>This is Putty_CLI for first PHP-script with result:
xx@raspberrypi:~$ sudo /usr/bin/php /home/pi/PHP/php_ESP8266C_91_reboot01.php
xx@raspberrypi:~$In hindsight, perhaps useful (like I do for all my lua- and Python-scripting) to add at least during testing somewhere one or more simple one-line print-instruction(s): then you get positive&visible reporting that and how far the script is executing.
- Egregius
Why did you change the json url?
now you only get the status of one device. No point of looping thru the result then.
If you don't want to use a roomplan to combine the 2 devices in 1 json call you can combine them in 1 script.
prefered way: http://www.domoticz.com/forum/viewtopic ... 89#p149685
Devices separately (added some echo statements):
<?php
$idx1=183;
$idx2=257;
$timeout=3600;
$domoticz=json_decode(file_get_contents('http://127.0.0.1:8080/json.htm?type=devices&rid='.$idx1),true);
$lastupdate1=$domoticz['result'][0]['LastUpdate'];
echo 'Device '.$idx1.' last updated at '.$lastupdate1.PHP_EOL;
}else echo 'Error retrieving data from domoticz for idx '.$idx1.PHP_EOL;
$domoticz2=json_decode(file_get_contents('http://127.0.0.1:8080/json.htm?type=devices&rid='.$idx2),true);
if(isset($domoticz2['result'])){
$lastupdate2=$domoticz2['result'][0]['LastUpdate'];
echo 'Device '.$idx2.' last updated at '.$lastupdate2.PHP_EOL;
}else echo 'Error retrieving data from domoticz for idx '.$idx2.PHP_EOL;
$lastupdate1=strtotime($lastupdate1);
$lastupdate2=strtotime($lastupdate2);
if($lastupdate1>0&&$lastupdate2>0&&$lastupdate1<$_SERVER['REQUEST_TIME']-3600&&$lastupdate2<$_SERVER['REQUEST_TIME']-$timeout){
echo 'Last updates both more than '.$timeout.' seconds ago, restarting!';
Toulon7559
@Egregius
2 Simple reasons for my changes and dedicated, separate scripts:
1) I have no roomplan
2) not yet far in the learning curve for php-scripts, and therefore only try small tuning-changes
=> run first simple test with only the most critical devices, and separate the handling of those devices to see whether one or the other, or all run without errors and/or report something. If they react differently also a lesson.
Thanks for upgrade of the script, because then just 1 script to run for checking of multiple, different rids:
slightly contrary to 2), but the echo-lines should really help visualizing the operation. The end result counts .........
Homework for tomorrow to tune your example, perhaps adding a few more devices, and 'upgrade' the cron.
- Egregius
If you add more devices I would definitely recommend using a roomplan for this. They are easy to create and maintain.
Also if more devices are added later you just have to add them to the roomplan without need to change the script.
Toulon7559
Now: see that 'single' PHP-script for multiple devices is running with effects as expected
Status 15th September2017:
The combination in cron of 'checkers' plus 'reboot/12hours' seems to work.
Very rude&basic, not a 100% remedy, but better than before .......
For 'Todo'-list: Make Roomplan & change 'checker' to Roomplan-script
Derik
- Domoticz version: BETA
mmm is there perhaps some one with a script that can reboot the rpi ?
My board is loosing connecting with my router...
And then i need to reboot, for new connection.
I monitor the board with a slave. so from that board i hope i can give a reboot command...
- Egregius
Is it connected on wifi? I have one pi that loses wifi connection from time to time.
You don't need to reboot, just disable/enable wifi.
This is the script I use for that:
Execute it every minute by cron and you should be fine.
If you're not on wifi try the script but replace wlan0 with the name of your connection, useally eth0 for cable.
#!/bin/bash
sudo ping -c1 192.168.2.1 > /dev/null
if [ $? != 0 ]
then
echo "No network connection, restarting wlan0"
sudo /sbin/ifdown 'wlan0'
sleep 2
sudo /sbin/ifup --force 'wlan0'
fiIf you're not on wifi try the script but replace wlan0 with the name of your connection, useally eth0 for cable.
Derik
mmm i do have a very fast and great Odroid Xu4....Egregius wrote: Tuesday 03 October 2017 7:31 Is it connected on wifi? I have one pi that loses wifi connection from time to time.
This is the script I use for that:Execute it every minute by cron and you should be fine.Code: Select all
#!/bin/bash sudo ping -c1 192.168.2.1 > /dev/null if [ $? != 0 ] then echo "No network connection, restarting wlan0" sudo /sbin/ifdown 'wlan0' sleep 2 sudo /sbin/ifup --force 'wlan0' fi
The only problem he have,,, when i have a unstable internetconnection, he lose the connection.
Can i use this script also for a utp conection?
Thanks..
- Egregius
Yes, replace wlan0 with the name of your connection
Derik
mmm the name of my homenetwork??
i do not have a static in device i set it static in my router..
jannl
- Domoticz version: 2026.1.x
He means the ssid of your wifi accesspoint
Verstuurd vanaf mijn SM-G930F met Tapatalk
