There is an old issue with same device than this one https://github.com/dresden-elektronik/d ... ssues/1024
"manufacturername":"Phoscon"
http://192.168.1.1:80/api/36E138295E/configCode: Select all
python3 API_KEY.pyHave you finally solved your problem, whith changing your API key ?marcelbolhuis wrote: Tuesday 21 May 2019 21:39 Hi there,
I'm trying to install the deCONZ brigde, but something is going wrong.. see a part of the log:
2019-05-21 21:33:43.632 Error: (ZIgbee) Not managed JSON : {'bridgeid': '00212EFFFF02A042', 'factorynew': False, 'apiversion': '1.16.0', 'modelid': 'deCONZ', 'name': 'Phoscon-GW', 'replacesbridgeid': None, 'mac': 'b8:27:eb:10:28:5f', 'datastoreversion': '60', 'starterkitid': '', 'swversion': '2.5.64'}
I got know clue what to do.
2019-04-02 20:10:47.032 (deconz) Received 182 bytes of data
2019-04-02 20:10:47.032 (deconz) 81 7e 00 b2 7b 22 65 22 3a 22 63 68 61 6e 67 65 64 22 2c 22 �~.�{"e":"changed","
2019-04-02 20:10:47.032 (deconz) 69 64 22 3a 22 31 22 2c 22 72 22 3a 22 73 65 6e 73 6f 72 73 id":"1","r":"sensors
2019-04-02 20:10:47.032 (deconz) 22 2c 22 73 74 61 74 65 22 3a 7b 22 64 61 72 6b 22 3a 74 72 ","state":{"dark":tr
2019-04-02 20:10:47.033 (deconz) 75 65 2c 22 64 61 79 6c 69 67 68 74 22 3a 66 61 6c 73 65 2c ue,"daylight":false,
2019-04-02 20:10:47.033 (deconz) 22 6c 61 73 74 75 70 64 61 74 65 64 22 3a 22 32 30 31 39 2d "lastupdated":"2019-
2019-04-02 20:10:47.033 (deconz) 30 34 2d 30 32 54 31 38 3a 31 30 3a 34 37 22 2c 22 73 74 61 04-02T18:10:47","staHello, have you solved the bug by yourself ?salopette wrote: Tuesday 28 May 2019 21:37 Hi, I have this mistake again and again:
2019-05-28 20:03:04.518 Error: (deconz) Malformed JSON response, can't repair : b'\x81W{"e":"changed","id":"7","r":"groups","state":{"all_on":true,"any_on"'
What can this be?
Ok so I have make some more debug line, you don't need to save all logs, they will be in error log too (in red), check the beta branch (only some lines edited)salopette wrote: Thursday 06 June 2019 15:38 Hello, I have this mistake again and again.
At least once a day he comes
What could that be,
2019-06-06 06:48:12.426 Error: (deconz) Malformed JSON response, can't repair : b'\x81W{"e":"changed","id":"5","r":"groups","state":{"all_on":true,"any_on"'
It seems to work!
