Re: dzVents get garbage collection dates (various)
Posted: Wednesday 06 January 2021 17:28
I was very content with the script, till 2021
Something goes wrong, but I do not understand what goes wrong in line 159.
The log shows the following error:
I'm using this script, based on waarens work, with some minor modifications (line 159 contains:
dz.log(garbage.ophaaldatum .. ' = ' .. longGarbageName[garbage.afvalstroom_id], dz.LOG_DEBUG)
It looks like the garbage date GET works fine, the link gives the following results:
Anyone experiencing the same problem since 2021? And anyone with a solution?
2021-01-06 17:19:00.307 Status: dzVents: Info: collectGarbage: ------ Start external script: get_garbage_dates_v2.lua:, trigger: "at 17:19"
2021-01-06 17:19:00.308 Status: dzVents: Debug: collectGarbage: Processing device-adapter for Disable get_garbage_dates: Switch device adapter
2021-01-06 17:19:00.308 Status: dzVents: Debug: collectGarbage: OpenURL: url = https://inzamelschema.rmn.nl/rest/adressen/0312200000006752/kalender/2021
2021-01-06 17:19:00.308 Status: dzVents: Debug: collectGarbage: OpenURL: method = GET
2021-01-06 17:19:00.308 Status: dzVents: Debug: collectGarbage: OpenURL: post data = nil
2021-01-06 17:19:00.308 Status: dzVents: Debug: collectGarbage: OpenURL: headers = nil
2021-01-06 17:19:00.308 Status: dzVents: Debug: collectGarbage: OpenURL: callback = getGarbage_Response
2021-01-06 17:19:00.309 Status: dzVents: Info: collectGarbage: ------ Finished get_garbage_dates_v2.lua
2021-01-06 17:19:00.313 Status: dzVents: Debug: - OpenURL = {["URL"]="https://inzamelschema.rmn.nl/rest/adressen/0312200000006752/kalender/2021", ["method"]="GET", ["_trigger"]="getGarbage_Response", ["_after"]=1}
2021-01-06 17:19:01.882 Status: dzVents: Debug: - HTTPResponse: getGarbage_Response
2021-01-06 17:19:01.959 Status: dzVents: Info: Handling httpResponse-events for: "getGarbage_Response"
2021-01-06 17:19:01.959 Status: dzVents: Info: collectGarbage: ------ Start external script: get_garbage_dates_v2.lua: HTTPResponse: "getGarbage_Response"
2021-01-06 17:19:01.973 Status: dzVents: Debug: collectGarbage: Processing device-adapter for Disable get_garbage_dates: Switch device adapter
2021-01-06 17:19:01.973 Status: dzVents: Debug: collectGarbage: 2021-01-08 = Restafval (grijs)
2021-01-06 17:19:01.973 Status: dzVents: Debug: collectGarbage: 2021-01-09 = Oud papier (blauw)
2021-01-06 17:19:01.973 Status: dzVents: Info: collectGarbage: ------ Finished get_garbage_dates_v2.lua
2021-01-06 17:19:01.973 Error: dzVents: Error: (3.0.2) collectGarbage: An error occurred when calling event handler get_garbage_dates_v2
2021-01-06 17:19:01.973 Error: dzVents: Error: (3.0.2) collectGarbage: ...omoticz/scripts/dzVents/scripts/get_garbage_dates_v2.lua:159: attempt to concatenate a nil value (field '?')dz.log(garbage.ophaaldatum .. ' = ' .. longGarbageName[garbage.afvalstroom_id], dz.LOG_DEBUG)
--[[ getGarbageDates.lua for [ dzVents >= 2.4.28 ]
Enter your bagid in the appropriate place between the lines starting with --++++
Next is to set your virtual text and or virtual alert device.
the text device will contain the most nearby collectdates for the four types of household garbage
the alert device will contain the date and type for the garbagecollecion that will arrive first
local eveningRun = 'at 20:00'
local morningRun = 'at 17:19'
package.path = package.path .. ';' .. '/home/pi/domoticz/scripts/lua/Telegram.lua'
local telegram = require('Telegram')
return
active = true,
on =
timer =
morningRun,
eveningRun,
devices =
-- 'getGarbage', -- Only for test purposes can be ignored
httpResponses =
'getGarbage_Response' -- Trigger to handle Json part
logging =
level = domoticz.LOG_DEBUG, -- set to LOG_DEBUG when something does not work as expected
marker = 'collectGarbage',
data =
garbage =
initial = {}, -- Keep a copy of last json just in case
execute = function(dz, item)
-- uitschakelen van script
local manualOverrideSwitch = 150
if (manualOverrideSwitch and dz.devices(manualOverrideSwitch).state == 'On') then
dz.log('Get garbage dates script is handmatig uitgeschakeld (disable script switches)', dz.LOG_DEBUG)
return
--++++--------------------- Mandatory: Set your values and device names below this Line --------------------------------------
local myBagId = "0312200000006752"
local myYear = os.date("%Y")
local myTextDevice = "Garbage" -- Name with quotes or idx without when created as virtual text device
local myAlertDevice = "GarbageAlert" -- Name with quotes or idx without when created as virtual alert device
local myNotificationTable =
-- table with one or more notification systems.
-- uncomment the notification systems that you want to be used
-- Can be one or more of
-- dz.NSS_FIREBASE_CLOUD_MESSAGING,
-- dz.NSS_PUSHOVER,
-- dz.NSS_HTTP,
-- dz.NSS_KODI,
-- dz.NSS_LOGITECH_MEDIASERVER,
-- dz.NSS_NMA,
-- dz.NSS_PROWL,
-- dz.NSS_PUSHALOT,
-- dz.NSS_PUSHBULLET,
-- dz.NSS_PUSHOVER,
-- dz.NSS_PUSHSAFER,
dz.NSS_TELEGRAM,
local longGarbageName =
[100] = "Plastic",
[3] = "GFT (bruin)",
[87] = "Oud papier (blauw)",
[1] = "Restafval (grijs)"
--++++---------------------------- No changes required below this line --------------------------------------------
local function collectGarbageDates(secondsFromNow)
local getGarbage_url = "https://inzamelschema.rmn.nl/rest/adressen/" ..myBagId .. "/kalender/" .. myYear
dz.openURL ({ url = getGarbage_url ,
callback = "getGarbage_Response" }).afterSec(secondsFromNow)
-- Add entry to log and notify to set subsystems
local function errorMessage(message)
dz.log(message,dz.LOG_ERROR)
telegram.sendText(telegram.getId('zeisterweg'), message)
dz.notify('Garbage',message, dz.PRIORITY_HIGH, dz.SOUND_DEFAULT, "" , myNotificationTable)
local function convertDateFormat(dateString, fromPattern, toFormat)
local fromPattern = fromPattern or '(%d+)-(%d+)-(%d+)'
local toFormat = toFormat or '%a %d %b'
local runyear, runmonth, runday= dateString:match(fromPattern)
return os.date(toFormat, os.time({year = runyear, month = runmonth, day = runday}) )
local function text(lines)
if dz.utils.deviceExists(myTextDevice) then
dz.devices(myTextDevice).updateText( table.concat(lines, '\n') )
local function alertLevel(delta)
if delta < 2 then return dz.ALERTLEVEL_RED end
if delta < 3 then return dz.ALERTLEVEL_YELLOW end
if delta < 4 then return dz.ALERTLEVEL_ORANGE end
return dz.ALERTLEVEL_GREEN
local function alert(lines)
if dz.utils.deviceExists(myAlertDevice) then
dz.devices(myAlertDevice).updateAlertSensor(alertLevel(lines.delta), lines[1])
if dz.time.matchesRule('at 05:00-09:00') and lines.delta == 0 then
telegram.sendText(telegram.getId('zeisterweg'), lines[1]:match('%: (.*)') .. ' wordt vandaag opgehaald')
--dz.notify('Huisafval',lines[1]:match('%: (.*)') .. ' will be collected today', dz.PRIORITY_NORMAL,dz.SOUND_DEFAULT, "" , myNotificationTable)
elseif dz.time.matchesRule('at 17:00-22:00') and lines.delta == 1 then
telegram.sendText(telegram.getId('zeisterweg'), lines[1]:match('%: (.*)') .. ' wordt morgen opgehaald')
--dz.notify('Huisafval',lines[1]:match('%: (.*)') .. ' will be collected tomorrow', dz.PRIORITY_NORMAL,dz.SOUND_DEFAULT, "" , myNotificationTable)
local function selectRecords(t)
dateRecords = {}
for _, garbage in ipairs(t) do
if garbage.ophaaldatum >= dz.time.rawDate then
if dateRecords[garbage.ophaaldatum] then
table.insert(dateRecords[garbage.ophaaldatum], longGarbageName[garbage.afvalstroom_id] )
dateRecords[garbage.ophaaldatum] = { longGarbageName[garbage.afvalstroom_id] }
return dateRecords
local function makeLines(t)
local startDate = dz.time
local futureDay = 0
local lineCounter = 1
local textLines = {}
if dz.time.matchesRule(eveningRun) then futureDay = 1 end
while lineCounter < 5 and futureDay < 60 do
local traverseDate = startDate.addDays(futureDay).rawDate
if t[traverseDate] then
local textLine = convertDateFormat(traverseDate) .. ': ' .. table.concat(t[traverseDate], ' plus ')
if lineCounter == 1 then textLines.delta = futureDay end
textLines[lineCounter] = textLine
lineCounter = lineCounter + 1
futureDay = futureDay + 1
return textLines
local function handleResponse()
if not(item.ok and item.json) then
errorMessage('Problem with response (no data). Try using data from earlier run')
rt = dz.data.garbage -- json empty. Get last valid from dz.data
if #rt < 1 then -- No valid data in dz.data either
errorMessage('No previous data. is bagnumber ok?')
return false
rt = selectRecords(item.json)
textLines = makeLines(rt)
alert(textLines)
text(textLines)
-- Main
if item.isHTTPResponse then
if item.ok then
handleResponse()
errorMessage('Problem with response (not ok)')
collectGarbageDates(600) -- response not OK, try again after 10 minutes
collectGarbageDates(1)
}Code: Select all
[{"afvalstroom_id":3,"ophaaldatum":"2021-01-02"},{"afvalstroom_id":1,"ophaaldatum":"2021-01-08"},{"afvalstroom_id":87,"ophaaldatum":"2021-01-09"},{"afvalstroom_id":37,"ophaaldatum":"2021-01-11"},{"afvalstroom_id":100,"ophaaldatum":"2021-01-14"},{"afvalstroom_id":3,"ophaaldatum":"2021-01-15"},{"afvalstroom_id":1,"ophaaldatum":"2021-01-22"},{"afvalstroom_id":100,"ophaaldatum":"2021-01-28"},{"afvalstroom_id":3,"ophaaldatum":"2021-01-29"},{"afvalstroom_id":1,"ophaaldatum":"2021-02-05"},{"afvalstroom_id":87,"ophaaldatum":"2021-02-06"},{"afvalstroom_id":100,"ophaaldatum":"2021-02-11"},{"afvalstroom_id":3,"ophaaldatum":"2021-02-12"},{"afvalstroom_id":1,"ophaaldatum":"2021-02-19"},{"afvalstroom_id":100,"ophaaldatum":"2021-02-25"},{"afvalstroom_id":3,"ophaaldatum":"2021-02-26"},{"afvalstroom_id":1,"ophaaldatum":"2021-03-05"},{"afvalstroom_id":87,"ophaaldatum":"2021-03-06"},{"afvalstroom_id":100,"ophaaldatum":"2021-03-11"},{"afvalstroom_id":3,"ophaaldatum":"2021-03-12"},{"afvalstroom_id":1,"ophaaldatum":"2021-03-19"},{"afvalstroom_id":100,"ophaaldatum":"2021-03-25"},{"afvalstroom_id":3,"ophaaldatum":"2021-03-26"},{"afvalstroom_id":1,"ophaaldatum":"2021-04-02"},{"afvalstroom_id":87,"ophaaldatum":"2021-04-03"},{"afvalstroom_id":100,"ophaaldatum":"2021-04-08"},{"afvalstroom_id":3,"ophaaldatum":"2021-04-09"},{"afvalstroom_id":1,"ophaaldatum":"2021-04-16"},{"afvalstroom_id":100,"ophaaldatum":"2021-04-22"},{"afvalstroom_id":3,"ophaaldatum":"2021-04-23"},{"afvalstroom_id":1,"ophaaldatum":"2021-04-30"},{"afvalstroom_id":87,"ophaaldatum":"2021-05-01"},{"afvalstroom_id":100,"ophaaldatum":"2021-05-06"},{"afvalstroom_id":3,"ophaaldatum":"2021-05-07"},{"afvalstroom_id":1,"ophaaldatum":"2021-05-14"},{"afvalstroom_id":100,"ophaaldatum":"2021-05-20"},{"afvalstroom_id":3,"ophaaldatum":"2021-05-21"},{"afvalstroom_id":1,"ophaaldatum":"2021-05-28"},{"afvalstroom_id":100,"ophaaldatum":"2021-06-03"},{"afvalstroom_id":3,"ophaaldatum":"2021-06-04"},{"afvalstroom_id":87,"ophaaldatum":"2021-06-05"},{"afvalstroom_id":1,"ophaaldatum":"2021-06-11"},{"afvalstroom_id":100,"ophaaldatum":"2021-06-17"},{"afvalstroom_id":3,"ophaaldatum":"2021-06-18"},{"afvalstroom_id":1,"ophaaldatum":"2021-06-25"},{"afvalstroom_id":100,"ophaaldatum":"2021-07-01"},{"afvalstroom_id":3,"ophaaldatum":"2021-07-02"},{"afvalstroom_id":87,"ophaaldatum":"2021-07-03"},{"afvalstroom_id":1,"ophaaldatum":"2021-07-09"},{"afvalstroom_id":100,"ophaaldatum":"2021-07-15"},{"afvalstroom_id":3,"ophaaldatum":"2021-07-16"},{"afvalstroom_id":1,"ophaaldatum":"2021-07-23"},{"afvalstroom_id":100,"ophaaldatum":"2021-07-29"},{"afvalstroom_id":3,"ophaaldatum":"2021-07-30"},{"afvalstroom_id":1,"ophaaldatum":"2021-08-06"},{"afvalstroom_id":87,"ophaaldatum":"2021-08-07"},{"afvalstroom_id":100,"ophaaldatum":"2021-08-12"},{"afvalstroom_id":3,"ophaaldatum":"2021-08-13"},{"afvalstroom_id":1,"ophaaldatum":"2021-08-20"},{"afvalstroom_id":100,"ophaaldatum":"2021-08-26"},{"afvalstroom_id":3,"ophaaldatum":"2021-08-27"},{"afvalstroom_id":1,"ophaaldatum":"2021-09-03"},{"afvalstroom_id":87,"ophaaldatum":"2021-09-04"},{"afvalstroom_id":100,"ophaaldatum":"2021-09-09"},{"afvalstroom_id":3,"ophaaldatum":"2021-09-10"},{"afvalstroom_id":1,"ophaaldatum":"2021-09-17"},{"afvalstroom_id":100,"ophaaldatum":"2021-09-23"},{"afvalstroom_id":3,"ophaaldatum":"2021-09-24"},{"afvalstroom_id":1,"ophaaldatum":"2021-10-01"},{"afvalstroom_id":87,"ophaaldatum":"2021-10-02"},{"afvalstroom_id":100,"ophaaldatum":"2021-10-07"},{"afvalstroom_id":3,"ophaaldatum":"2021-10-08"},{"afvalstroom_id":1,"ophaaldatum":"2021-10-15"},{"afvalstroom_id":100,"ophaaldatum":"2021-10-21"},{"afvalstroom_id":3,"ophaaldatum":"2021-10-22"},{"afvalstroom_id":1,"ophaaldatum":"2021-10-29"},{"afvalstroom_id":100,"ophaaldatum":"2021-11-04"},{"afvalstroom_id":3,"ophaaldatum":"2021-11-05"},{"afvalstroom_id":87,"ophaaldatum":"2021-11-06"},{"afvalstroom_id":1,"ophaaldatum":"2021-11-12"},{"afvalstroom_id":100,"ophaaldatum":"2021-11-18"},{"afvalstroom_id":3,"ophaaldatum":"2021-11-19"},{"afvalstroom_id":1,"ophaaldatum":"2021-11-26"},{"afvalstroom_id":100,"ophaaldatum":"2021-12-02"},{"afvalstroom_id":3,"ophaaldatum":"2021-12-03"},{"afvalstroom_id":87,"ophaaldatum":"2021-12-04"},{"afvalstroom_id":1,"ophaaldatum":"2021-12-10"},{"afvalstroom_id":100,"ophaaldatum":"2021-12-16"},{"afvalstroom_id":3,"ophaaldatum":"2021-12-17"},{"afvalstroom_id":1,"ophaaldatum":"2021-12-24"},{"afvalstroom_id":100,"ophaaldatum":"2021-12-30"},{"afvalstroom_id":3,"ophaaldatum":"2021-12-31"}]
