Python plugin: Xiaomi Mi Robot Vacuum Topic is solved
Re: Python plugin: Xiaomi Mi Robot Vacuum
Hi, I have already reinstalled everything, but keep getting this error:
2018-03-01 22:37:48.027 Error: (xiaomi-mi-robot-vacuum) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/xiaomi-mirobot/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-03-01 22:37:48.027 Error: (Robotstofzuiger Xiaomi) Module Import failed, exception: 'ImportError'
2018-03-01 22:37:48.027 Error: (Robotstofzuiger Xiaomi) Module Import failed: ' Name: msgpack'
2018-03-01 22:37:48.027 Error: (Robotstofzuiger Xiaomi) Error Line details not available.
I know my Python path is different. I I type: "which python3" I get: /home/pi/domoticz/plugins/xiaomi-mirobot/.env/bin/python3
I pasted this path in miio_server.py. But I keep getting this error! Hop someone can help....
Any ideas? I'm on Stretch, Domoticz newest beta.
Zwave, Zigate, RFlink etc.
I already found out.
See this post: http://www.domoticz.com/forum/viewtopic ... ck#p163889.
Note: insert:
sys.path.append('/usr/local/lib/python3.5/site-packages')
after "import domoticz" in the plugin.py file.
so WITHOUT the and /b codes mentioned in the post, if you insert them too it does nog work I found out!
Note: insert:
its posible to obtain the map afther the vacuum finish the cleaning?
I have two Mii Vacuums at home (and a Neato, but that's not a connected one). The server config in the plugin only allows for one set of IP + Token... Is there a way (other than me rewriting the code
) to support two vacuums?
Hey, i get the following error messages.
Any ideas on this?
Regards Marc
2018-03-26 11:30:09.214 (Staubsauger) Calling message handler 'onHeartbeat'.
2018-03-26 11:30:09.215 Error: (Staubsauger) 'onHeartbeat' failed 'AttributeError':''NoneType' object has no attribute 'Connecting''.
2018-03-26 11:30:09.215 Error: (Staubsauger) ----> Line 383 in /home/pi/domoticz/plugins/xiaomi-mirobot/plugin.py, function onHeartbeat
2018-03-26 11:30:09.215 Error: (Staubsauger) ----> Line 289 in /home/pi/domoticz/plugins/xiaomi-mirobot/plugin.py, function onHeartbeat
Regards Marc
- remb0
how nice
Guys, if anyone prefer using docker and its containers (such as me) I've created docker container with miio server for this plugin:
https://hub.docker.com/r/demydiuk/mirobot-miio-server/
Additionally have checked this plugin with Xiaomi Mi Robot, 2nd generation and it works well
- gijsje
- Domoticz version: Stable
I am trying to get this to work.
I have installed the latest beta domoticz on a pi
Did all the steps and it works, but only one time.
when i restart the pi the python script is gone from the list
when i test with sudo ./test.py i can still see the vacuum b but i can not select the vacuum from the hardware list.
It is still there from the first time it worked but the type is empty and the is no vacuum to select
The files are also still there
The deceives where created on the first try
After a reboot the type is not showing anymore
the files are still there
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
- gijsje
This is the output i i run sudo ./test.py
So it can see the vacuum only the plugin is not loading somehow
pi@raspberrypi:~/domoticz/plugins/xiaomi-mirobot $ sudo ./test.py
test: python modules path: ././.env/lib/python3.5/site-packages
test: trying connect to 127.0.0.1:22222
test: sent request to server [status]
test: reading response...
test: got server reply {'error': None, 'state_code': 8, 'battery': 100, 'clean_seconds': 0, 'clean_area': 1.125, 'fan_level': 60, 'cmd': 'status'}
- gijsje
Found it
There seems to be a function in settings to disable all plugins
- Domoticz version: 3.9224
I had the vacuum working fine in Domoticz on Ubuntu 16.04. I upgraded to Ubuntu 17.10 due to needing an updated version of Python for another app.
Everything is working fine except for the vacuum in Domoticz.
I have re-done the installation steps at: https://github.com/mrin/domoticz-mirobot-plugin
When running the test script I get the following:
I saw a couple of pages back someone had a similar issue and so did what they suggested. Uninstall and reinstall python-miio. When I went to uninstall I got a message saying it wasn't installed. Once installed I then went through the steps again from the github page and received the same error as above.
If I do the manual test: sudo ./miio_server.py 192.168.1.15 xxxxxxxxxxxxxxxxxxxxxxxxxx --host 127.0.0.1 --port 22222 I get the following:
Which seems to indicate the manual test is working without issue?
Hoping someone may be able to assist.
test: python modules path: ././.env/lib/python3.6/site-packages
Traceback (most recent call last)
File "./test.py", line 22, in
client = socket.create_connection((args.host, args.port))
File "/usr/lib/python3.6/socket.py", line 724, in create_connection
raise err
File "/usr/lib/python3.6/socket.py", line 713, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
server: Starting server on 127.0.0.1 22222
server: connected ('127.0.0.1', 35486)
server: got socket msg: ['status']
server: vac result {'error': None, 'state_code': 8, 'battery': 100, 'fan_level': 60, 'clean_seconds': 0, 'clean_area': 0.0, 'cmd': 'status'}
server: send reply ('127.0.0.1', 35486)
I try to install the plugin only after the following command i get two error i think:
Raspberry 2B
Wich python is really recommend? (I did all command from beginning and have allready 3.5 running if i'm correct)
virtualenv -p python3 .env
Error 1:
I'm not sure if a both is really an error but the next command gives an error. (I think because of above failing)
Tried:
pip3 install -r pip_req.txt
And
pip3 install gevent msgpack-python python-miio==0.3.1
Can someone point me the good direction im not an linux expert
Error:
Raspberry 2B
Error 1:
(.env) pi@raspberrypi:~/domoticz/plugins/xiaomi-mirobot $ virtualenv -p python3 .env
Running virtualenv with interpreter /home/pi/domoticz/plugins/xiaomi-mirobot/.env/bin/python3
Please use the *system* python to run this script
File "/usr/local/lib/python3.5/dist-packages/virtualenv.py", line 2349, in <module>
main()
File "/usr/local/lib/python3.5/dist-packages/virtualenv.py", line 712, in main
symlink=options.symlink)
File "/usr/local/lib/python3.5/dist-packages/virtualenv.py", line 927, in create_environment
site_packages=site_packages, clear=clear, symlink=symlink))
File "/home/pi/domoticz/plugins/xiaomi-mirobot/.env/lib/python3.5/posixpath.py", line 357, in abspath
if not isabs(path):
File "/home/pi/domoticz/plugins/xiaomi-mirobot/.env/lib/python3.5/posixpath.py", line 64, in isabs
return s.startswith(sep)
AttributeError: 'NoneType' object has no attribute 'startswith'
Tried:
And
Error:
(.env) pi@raspberrypi:~/domoticz/plugins/xiaomi-mirobot $ pip3 install gevent msgpack-python python-miio==0.3.1
pip is configured with locations that require TLS/SSL, however the ssl module in Python is not available.
Collecting gevent
Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.",)': /simple/gevent/
Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.",)': /simple/gevent/
Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.",)': /simple/gevent/
Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.",)': /simple/gevent/
Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.",)': /simple/gevent/
Could not fetch URL https://pypi.python.org/simple/gevent/: There was a problem confirming the ssl certificate: HTTPSConnectionPool(host='pypi.python.org', port=443): Max retries exceeded with url: /simple/gevent/ (Caused by SSLError("Can't connect to HTTPS URL because the SSL module is not available.",)) - skipping
Could not fetch URL https://www.piwheels.hostedpi.com/simple/gevent/: There was a problem confirming the ssl certificate: HTTPSConnectionPool(host='www.piwheels.hostedpi.com', port=443): Max retries exceeded with url: /simple/gevent/ (Caused by SSLError("Can't connect to HTTPS URL because the SSL module is not available.",)) - skipping
Could not find a version that satisfies the requirement gevent (from versions: )
No matching distribution found for gevent
- Domoticz version: 3.9389
Sorry for the noob question, but there is a way to use this plugin with a Windows 10 installation of domoticz?
can you say me how are the compatible vacuum cleaner model?
Raspberry PI 3, 3x Yeelight bulbs, 1x Yeeligh led strip, 1x Sonoff with ESP826, Controlicz, Kodi
Very good, thanks. You would share the time between.lua script?RichardBokker wrote: ↑Wednesday 14 February 2018 10:37 I got the script working, but had to convert the Robot - state with tostring().
Here is my case-construction that i'm using.
-- Using TimeBetween script in main LUA script folder package.path = package.path .. ';' .. '/home/pi/domoticz/scripts/lua/script_time_TimeBetween.lua' local TimeBetween = require('timebetween') time = os.date("*t") commandArray = {} -- Possible state's of Robot Vacuum: Charging / Paused / Cleaning / Waiting / Back to home / Sleeping -- Selector witch Robot Vacuum: Clean(10) / Home(20) / Spot(30) / Pauze(40) / Stop(50) / Find(60) ---- Variabele to use -- StoffieState (uservariable) -- AtHome (uservariable) -- Stoffie - Control (device) -- Stoffie - Status (device) local stoffie = 'Stoffie - Status' -- print(otherdevices_svalues[stoffie] .. " dit is de actuele status") -- Required to convert State to Stringvalue StoffieStatus = tostring(otherdevices_svalues[stoffie]); -- IDLE if (uservariables['StoffieState'] == 'IDLE') then print ("Stoffie is idle"); if timebetween("08:00","16:00") then -- Run's only during day hours. if (uservariables['AtHome'] == 'NO') then -- Run's only when nobody is at home commandArray['SendNotification']='Stoffie is Starting' commandArray['Variable:StoffieState']='STARTING' -- Start Robot command, command send once. commandArray['Stoffie - Control'] = 'Set Level 10' end end end -- STARTING if (uservariables['StoffieState'] == 'STARTING') then if StoffieStatus == 'Cleaning' then -- If robot is cleaning, continu to next step commandArray['SendNotification']='Stoffie is Running' commandArray['Variable:StoffieState']='RUNNING' end if timebetween("16:00","08:00") then -- is program hangs, to executed state commandArray['Variable:StoffieState']='EXECUTED' end end -- RUNNING if (uservariables['StoffieState'] == 'RUNNING') then if StoffieStatus == 'Back to home' then -- If robot is going back to home, continu to next step commandArray['SendNotification']='Stoffie is Stopping' commandArray['Variable:StoffieState']='STOPPING' end end -- STOPPING if (uservariables['StoffieState'] == 'STOPPING') then if StoffieStatus == 'Charging' then -- if robot is Charging, continu to next step commandArray['SendNotification']='Stoffie is Executed' commandArray['Variable:StoffieState']='EXECUTED' -- Stop Robot command, command send once. commandArray['Stoffie - Control'] = 'Set Level 50' end end -- EXECUTED if (uservariables['StoffieState'] == 'EXECUTED') then if timebetween("23:55","23:56") then -- Runs only once a day. Reset at end of day. commandArray['SendNotification']='Stoffie going to Idle' commandArray['Variable:StoffieState']='IDLE' end end return commandArray
Same question here.andreaburlizzi wrote: ↑Thursday 03 May 2018 21:41 Sorry for the noob question, but there is a way to use this plugin with a Windows 10 installation of domoticz?
Furthermore I'd like to know if python-miio would work under windows.
corederoma82 wrote: ↑Friday 11 May 2018 9:39 Hi,
Somebody can answer me?
Geitje wrote: ↑Tuesday 06 March 2018 1:29 I already found out.
Note: insert:
Hi, I have a similar problem, but the solution didn't work for me.
When I try to add the line, domoticz won't boot (ie. the browser keeps indicating domoticz is offline or not available)
The error in the domoticz log (without the line)
Error: (xiaomi-mi-robot-vacuum) failed to load 'plugin.py', Python Path used was '/home/jeroen/domoticz/plugins/xiaomi-robot/:/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
Error: (Robottest) Module Import failed, exception: 'ImportError'
Error: (Robottest) Module Import failed: ' Name: msgpack'
sys.path.append('/usr/local/lib/python3.4/dist-packages')
I get this response for searching for msgpack:
jeroen@Domoticz:~ $ sudo find / -name msgpack*
[sudo] password for jeroen:
/home/jeroen/domoticz/plugins/xiaomi-robot/.env/lib/python3.4/site-packages/pip/_vendor/msgpack
/home/jeroen/.cache/pip/wheels/62/f3/0d/f77f20fce259496b053d6c0dc0eea7114527cf0a7da115a980/msgpack_python-0.4.8-cp34-cp34m-linux_armv6l.whl
/usr/local/lib/python3.4/dist-packages/msgpack_python-0.4.8-py3.4.egg-info
But if I start the server from the command line and run the test.py from another console, I can get valid output.jeroen@Domoticz:~/domoticz/plugins/xiaomi-robot $ sudo ./test.py
test: python modules path: ././.env/lib/python3.4/site-packages
File "./test.py", line 22, in <module>
File "/usr/lib/python3.4/socket.py", line 509, in create_connection
raise err
File "/usr/lib/python3.4/socket.py", line 500, in create_connection
sock.connect(sa)
sudo python3 miio_server.py 192.168.1.43 token
server: connected ('127.0.0.1', 42656)
server: vac result {'clean_area': 62.4725, 'error': None, 'battery': 100, 'cmd': 'status', 'state_code': 8, 'clean_seconds': 4418, 'fan_level': 60}
server: send reply ('127.0.0.1', 42656)
server: closed connection ('127.0.0.1', 42656)
This message is invisiblecorederoma82 wrote: ↑Wednesday 16 May 2018 11:16corederoma82 wrote: ↑Friday 11 May 2018 9:39 Hi,
Nice.
No it's not.corederoma82 wrote: ↑Saturday 19 May 2018 12:34This message is invisiblecorederoma82 wrote: ↑Wednesday 16 May 2018 11:16corederoma82 wrote: ↑Friday 11 May 2018 9:39 Hi,
Thanks![]()
Nice.
As the name of the topic suggest and you can read on the linked github in the first post; it's for the Xiaomi Mi Robot Vacuum.
http://www.mi.com/roomrobot/
The only question you can ask next is if the newer V2 model is compatible. I think no one reported using that one yet and nothing is mentioned on the python-miio page, but I from the looks of it, it is using the same miio interface and i would guess it will work.
Users browsing this forum: RNEE and 1 guest
