Python plugin: UPS Monitor
manuloup
Re: Python plugin: UPS monitoring
I tried the new version of file plugin.py but I don't see anything in the log file if I check for UPS.
Not sure it is working though.
Rapberry PI B+ (RaspBian), RFXtrx433E USB 433.92MHz Transceiver, AEON LABS Controler Z-Wave, Aeon Labs Z-Stick S2, Everspring ST814 Temperature Sensor, Everspring SF812 Smoke Detector, 2x Fibaro Wallplug, Aeon Zwave Miniremote , Xbee Teleinfo USB
manuloup
Devices look up to date, so I guess this is good.
Thanks for your help, madpatrick.
eddieb
I noticed this error on my rpi running under docker...
this did work for a couple of months, is there some recent change that removed telnetlib ?
suggestions how to fix ?
2026-06-02 10:31:43.121 Error: UPS Meterkast: (NUT_UPS) failed to load 'plugin.py'.
2026-06-02 10:31:43.258 Error: UPS Meterkast: Traceback (most recent call last):
2026-06-02 10:31:43.258 Error: UPS Meterkast: File "/opt/domoticz/userdata/plugins/NUT_UPS/plugin.py", line 37, in <module>
2026-06-02 10:31:43.258 Error: UPS Meterkast: import telnetlib
2026-06-02 10:31:43.258 Error: UPS Meterkast: ModuleNotFoundError: No module named 'telnetlib'suggestions how to fix ?
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / IndeVolt SF3000 / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
- Domoticz version: 2026.3
For docker and installations of Python modules see https://wiki.domoticz.com/Docker#Python_Pluginseddieb wrote: Tuesday 02 June 2026 11:19 I noticed this error on my rpi running under docker...
this did work for a couple of months, is there some recent change that removed telnetlib ?Code: Select all
2026-06-02 10:31:43.121 Error: UPS Meterkast: (NUT_UPS) failed to load 'plugin.py'. 2026-06-02 10:31:43.258 Error: UPS Meterkast: Traceback (most recent call last): 2026-06-02 10:31:43.258 Error: UPS Meterkast: File "/opt/domoticz/userdata/plugins/NUT_UPS/plugin.py", line 37, in <module> 2026-06-02 10:31:43.258 Error: UPS Meterkast: import telnetlib 2026-06-02 10:31:43.258 Error: UPS Meterkast: ModuleNotFoundError: No module named 'telnetlib'
Also docker image has moved to Python 13 so perhaps the module is not compliant.
- madpatrick
- Domoticz version: 2026.1
eddieb
I used your adjusted plugin.py and now it works.
Are you pushing that changes to the plugin developer ?
Re: Python plugin: UPS Monitor
I merged the UPS Monitor sub discussion with the original discussion. Probably something went wrong while creating the question.
rini52
- Domoticz version: 2025.2
Guys many thanks.
I got nut running on trixi with domoticz in docker. I can confirm that updating the plugin.py with the pluging.py.txt and in stalling telnetlib3 works. Just changing the original plugin.py with "import telnetlib3 as telnetlib" didn't work. Also make sure that you have the config files set with root:nut credetials.
Gr.
Gr.
Domoticz running on Pi-4, Ubuntu(amd64), Synology Nas and VM
Hardware: RFXCOM, RFLINK, P1-smartmeter-HomeWizard, Z2M Sonoff dongle(20+ devices), Esp8266 (counters), Eaton_3S ups
