Page 7 of 18
Re: Sharing : Afval kalendar in text sensor
Posted: Saturday 12 January 2019 16:35
by EddyG
Tnx, at the end you left a "needupdate = true" to many.
Posted: Saturday 12 January 2019 20:37
by Derik
Sorry removed ..
see something on github...
GREAT work Jos
Edit:
Only here is dombo71 again....
I mis in the github codee the local part etc.[ like the script i use before ]
Do i need to replace your new config precisely or do i need to edit so it is like on the old part?
local myAfvalDevice='D.M.:fval'
local Postcode='6AW'
local Huisnummer='9'
local Notificat
The new:
myAfvalDevice='Container' -- The Text devicename in Domoticz
ShowNextEvents = 3 -- indicate the next x events to show in the TEXT Sensor in Domoticz
Postcode='your-zip-here' -- Your postalcode
Huisnummer='your-housenr-here' -- Your housnr
NotificationEmailAdress = "your-email-address(es)-here" -- Specify your Email Address for the notifications
-- uncoment any of the b
So just only replace the the whole old config part for the new one?
Posted: Saturday 12 January 2019 20:54
by jvdz
EddyG wrote: Saturday 12 January 2019 16:35
Sorry about that, will fix it later this evening.
Jos
Posted: Saturday 12 January 2019 20:56
by jvdz
Derik wrote: Saturday 12 January 2019 20:37
It will work with and without local, but only when changed in the main script. When you use the separate config file it has to be without local or else it won't work.
Jos
Posted: Saturday 12 January 2019 21:50
by jvdz
jvdz wrote: Saturday 12 January 2019 20:54
Fixed in Github.
This will fix the update running each minute!
I have used that while testing/debugging and forgot to remove it before commiting to Github ... but fixed now.
Jos
Posted: Sunday 13 January 2019 13:51
by jvdz
Just committed some updates to script_time_afvalwijzer.lua:
- Added the option to use the different Notification systems configured in Domoticz:
NotificationEmailAdress = "" -- Specify your Email Address for the notifications. Leave empty to skip email notification
Notificationsystem = "" -- Specify notification system eg "telegram/pushover/.." leave empty to skip
- added a commented line to use the JSON.lua distributed with Domoticz for those that haven't installed the generic version. Just comment the first line and uncomment the second line in case you get errors for the first.
-- load JSON lib
JSON = require "JSON" -- use generic JSON.lua
--~ JSON = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- Use default Domoticz JSON.lua
- Added versionnumber and start logmessage when update starts.
- Renamed alvalwijzerconfig.lua to alvalwijzerconfig.lua.example to avoid messing up any local version.
Let me know in case of issue.
Jos
Posted: Sunday 13 January 2019 14:16
by JuanUil
Hi Folks,
Just to let you know:
I have been struggeling with the program from Jos for a couple of days and I could not got it working.
I PM-ed Jos and in 1 hour he fixed the problem for me!!!
Now I can collect the data for Blink in the Helmond area.
Many thanks to Jos!!
Posted: Sunday 13 January 2019 14:25
by jvdz
JuanUil wrote: Sunday 13 January 2019 14:16
You're welcome.
The script is also added to my github:
https://github.com/jvanderzande/mijnafvalwijzer
Jos
Posted: Sunday 13 January 2019 14:48
by JuanUil
Just one more question:
The program keeps checking every minute if there is an update.
I sroke out the dummy 1 and changed the dummy 2 time but it keeps checking every minute.
Posted: Sunday 13 January 2019 15:43
by jvdz
Oops ... did it again.
Just remove line 218:
I add that line while testing/debugging to force the update each run.
Updated it also in Github.
Jos
Posted: Sunday 13 January 2019 15:48
by JuanUil
Thnx Jos,
that did the trick!!
Posted: Monday 14 January 2019 8:45
by freijn
Hi Jos,
Found an issue in the logfile :
2019-01-14 02:11:00.729 Error: EventSystem: in AfvalAlarm: [string "-- AF-PUR module to get the Afval schedule fo..."]:145: bad argument #1 to 'gmatch' (string expected, got nil)
Line 145:
for web_afvaldate, web_afvaltype in string.gmatch(tmp, '<td>(.-)</td>[\r\n%s]-<td>(.-)</td>[\r\n%s]-<td>.-</td>') do
My afvaltypes:
local afvaltype_cfg = {
["Rest"] ={hour=19,min=22,daysbefore=1,text="Grijze Container met Restafval"},
["GFT"] ={hour=19,min=22,daysbefore=1,text="Bruine Container met Tuinfval"},
["Papier"] ={hour=12,min=00,daysbefore=0,text="Blauwe Container met Oud papier"},
["Dummy"] ={hour=02,min=11,daysbefore=1,text="dummy"}}
Any clue why tmp is empty?
Posted: Monday 14 January 2019 9:16
by jvdz
freijn wrote: Monday 14 January 2019 8:45
Hi Jos,
-snip-
Het lijkt erop dat de gemeente Purmerend een andere Website is gaan gebruiken:
https://afvalkalender.purmerend.nl/
Klopt dat?
Jos
Posted: Monday 14 January 2019 10:07
by freijn
Shit. indeed ... #$%#$^%@% just had the scritping fun for 1 week only
they announced an app last week, so i assume they have moved everything...
Posted: Monday 14 January 2019 12:28
by jvdz
Luckily the new website format is the same as the one for West Friesland, so that makes it easy.
I have adapted that script and made a new Purmerend version available in GitHub.
It now also contains the option for the other notification options available in domoticz.
Let me know if there are issue/questions.
Jos
Posted: Monday 14 January 2019 13:15
by freijn
oohhh wauw !! incredible speed service! I will download and implement.. and let you know.. Thanks !
Posted: Monday 14 January 2019 16:14
by jvdz
It looks like a lot of gemeentes use the services from
http://www.opzet.nl/afvalkalender_digitaal for their garbage collection calendar.
All these sites also have a REST/JSON interface available for the use by the APPs they provide, so I had a look at supporting that process instead of the website scraping I do for some of these currently with:
- huisvuil-purmerend
- huisvuil-mijnblink
- huisvuil-zuidwest-friesland
I am looking at supporting that approach as that will more reliable, flexible and supporting potentially supporting some 2.5 million households. See the above linked page for a list of supported site, or look at your own calendar website and see whether they refer to "Ontwerp & techniek: Opzet"
Anyone interested in this and willing to assist testing?
I would like to get testers for some different gemeentes to test the portability of one script across these "separate" websites.
Jos
Posted: Monday 14 January 2019 21:57
by freijn
BTW Jos, its working in Purmerend and a few hrs ago I also got my Telegram reminder, Thanks !!
Posted: Monday 14 January 2019 22:26
by rron
jvdz wrote: Monday 14 January 2019 16:14
Jos
Thanks for the quick help.
Ronald
Posted: Wednesday 16 January 2019 15:59
by RR46
Finaly, after several PM's, trail and error, I got today the Pushover notifcation of the next garbage run
@JVDZ; many thanks for support and help!!
