Sharing : Afval kalendar in text sensor
Re: Sharing : Afval kalendar in text sensor
Tnx, at the end you left a "needupdate = true" to many.
- Domoticz version: BETA
Sorry removed ..
see something on github...
GREAT work Jos
Edit:
Only here is dombo71 again....
I mis in the github codee the local part etc.[ like the script i use before ]
Do i need to replace your new config precisely or do i need to edit so it is like on the old part?
The new:
So just only replace the the whole old config part for the new one?
GREAT work Jos
Edit:
local myAfvalDevice='D.M.:fval'
local Postcode='6AW'
local Huisnummer='9'
local Notificat
myAfvalDevice='Container' -- The Text devicename in Domoticz
ShowNextEvents = 3 -- indicate the next x events to show in the TEXT Sensor in Domoticz
Postcode='your-zip-here' -- Your postalcode
Huisnummer='your-housenr-here' -- Your housnr
NotificationEmailAdress = "your-email-address(es)-here" -- Specify your Email Address for the notifications
-- uncoment any of the b
- jvdz
- Domoticz version: 4.107
Sorry about that, will fix it later this evening.
Jos
- jvdz
It will work with and without local, but only when changed in the main script. When you use the separate config file it has to be without local or else it won't work.
Jos
- jvdz
Fixed in Github.
This will fix the update running each minute!
I have used that while testing/debugging and forgot to remove it before commiting to Github ... but fixed now.
Jos
- jvdz
Just committed some updates to script_time_afvalwijzer.lua:
Jos
- Added the option to use the different Notification systems configured in Domoticz:
NotificationEmailAdress = "" -- Specify your Email Address for the notifications. Leave empty to skip email notification Notificationsystem = "" -- Specify notification system eg "telegram/pushover/.." leave empty to skip
- added a commented line to use the JSON.lua distributed with Domoticz for those that haven't installed the generic version. Just comment the first line and uncomment the second line in case you get errors for the first.
-- load JSON lib JSON = require "JSON" -- use generic JSON.lua --~ JSON = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- Use default Domoticz JSON.lua
- Added versionnumber and start logmessage when update starts.
- Renamed alvalwijzerconfig.lua to alvalwijzerconfig.lua.example to avoid messing up any local version.
Jos
- Domoticz version: 4.11083
Hi Folks,
Just to let you know:
I have been struggeling with the program from Jos for a couple of days and I could not got it working.
I PM-ed Jos and in 1 hour he fixed the problem for me!!!
Now I can collect the data for Blink in the Helmond area.
Many thanks to Jos!!
- jvdz
You're welcome.
The script is also added to my github: https://github.com/jvanderzande/mijnafvalwijzer
Jos
Just one more question:
The program keeps checking every minute if there is an update.
I sroke out the dummy 1 and changed the dummy 2 time but it keeps checking every minute.
- jvdz
Oops ... did it again.
Just remove line 218:
I add that line while testing/debugging to force the update each run.
Updated it also in Github.
Jos
needupdate = true
Jos
Thnx Jos,
that did the trick!!
- Domoticz version: Stable
Hi Jos,
Found an issue in the logfile :
Line 145:
My afvaltypes:
local afvaltype_cfg = {
Any clue why tmp is empty?
2019-01-14 02:11:00.729 Error: EventSystem: in AfvalAlarm: [string "-- AF-PUR module to get the Afval schedule fo..."]:145: bad argument #1 to 'gmatch' (string expected, got nil)
for web_afvaldate, web_afvaltype in string.gmatch(tmp, '<td>(.-)</td>[\r\n%s]-<td>(.-)</td>[\r\n%s]-<td>.-</td>') do
["Rest"] ={hour=19,min=22,daysbefore=1,text="Grijze Container met Restafval"},
["GFT"] ={hour=19,min=22,daysbefore=1,text="Bruine Container met Tuinfval"},
["Papier"] ={hour=12,min=00,daysbefore=0,text="Blauwe Container met Oud papier"},
["Dummy"] ={hour=02,min=11,daysbefore=1,text="dummy"}}
- jvdz
Het lijkt erop dat de gemeente Purmerend een andere Website is gaan gebruiken: https://afvalkalender.purmerend.nl/freijn wrote: ↑Monday 14 January 2019 8:45 Hi Jos,
-snip-Code: Select all
Klopt dat?
Jos
Shit. indeed ... #$%#$^%@% just had the scritping fun for 1 week only
they announced an app last week, so i assume they have moved everything...
- jvdz
Luckily the new website format is the same as the one for West Friesland, so that makes it easy.
I have adapted that script and made a new Purmerend version available in GitHub.
It now also contains the option for the other notification options available in domoticz.
Let me know if there are issue/questions.
Jos
Jos
oohhh wauw !! incredible speed service! I will download and implement.. and let you know.. Thanks !
- jvdz
It looks like a lot of gemeentes use the services from http://www.opzet.nl/afvalkalender_digitaal for their garbage collection calendar.
All these sites also have a REST/JSON interface available for the use by the APPs they provide, so I had a look at supporting that process instead of the website scraping I do for some of these currently with:
Anyone interested in this and willing to assist testing?
I would like to get testers for some different gemeentes to test the portability of one script across these "separate" websites.
Jos
- huisvuil-purmerend
- huisvuil-mijnblink
- huisvuil-zuidwest-friesland
Jos
BTW Jos, its working in Purmerend and a few hrs ago I also got my Telegram reminder, Thanks !!
Thanks for the quick help.jvdz wrote: ↑Monday 14 January 2019 16:14 It looks like a lot of gemeentes use the services from http://www.opzet.nl/afvalkalender_digitaal for their garbage collection calendar.
All these sites also have a REST/JSON interface available for the use by the APPs they provide, so I had a look at supporting that process instead of the website scraping I do for some of these currently with:I am looking at supporting that approach as that will more reliable, flexible and supporting potentially supporting some 2.5 million households. See the above linked page for a list of supported site, or look at your own calendar website and see whether they refer to "Ontwerp & techniek: Opzet"
Jos
Ronald
Rpi, RFXcom, klikaan klikuit switch,thermosmart, z-wave, espeasy, smartevse
Finaly, after several PM's, trail and error, I got today the Pushover notifcation of the next garbage run
@JVDZ; many thanks for support and help!!
