Page 7 of 8
Re: Python Plugin Beta testers - please read this
Posted: Sunday 05 March 2017 21:19
by gysmo38
@gizmocuz, @Dnpwwo
I am not sure to understand eerything.
I start to code my own functions to connection to MELCloud.
It look like it work. It is not yet finish. I will share with you the result.
Posted: Sunday 12 March 2017 23:47
by gysmo38
Thank a lot for creating Python plugin. It is perfect for me.
I create a first version of MELCloud plugin.
I create a Wiki page for instructions
http://www.domoticz.com/wiki/Plugins/MELCloud.html
It is not finish but it work well.
Posted: Monday 13 March 2017 21:30
by gysmo38
@Dnpwwo
For code my plugin, i made a fresh install of domoticz on ubuntu. It work well.
My plugin work, well, I would like to install it on my domoticz setup. I use a raspberry pi for this.
plugin directory is not available. Do you kwnow why? I have the same version on Ubuntu and Raspberry Pi.
Posted: Tuesday 14 March 2017 7:59
by ubee
I you update to latest beta by running ./updatebeta in the domoticz directory, the plugin directory should be created. And there will be a few examples included as well. At least that happened to me when I made a fresh install on a new Rasp.
Posted: Saturday 08 April 2017 15:42
by StasDemydiuk
I'm trying to use Python requests library to make HTTP calls. I have the latest Domoticz Beta version 3.7266, but with previous versions I have the same problem.
I faced with really strange behavior:
1. When I'm trying to import request module in the file head, plugin stops working immediately, even onStart is not called
import Domoticz
import sys
sys.path.append(sys.prefix+'/lib/site-packages')
import requests;
def onStart():
Domoticz.Log('Start')
return True
2. When I'm trying to import request module in onHeartbeat function then this function will be called ones, return result to Domoticz (log message in example) and plugin stops working
Maybe someone know what's happening or faced with the same problem?
Sample plugin code is in attachment.
Posted: Saturday 08 April 2017 15:49
by G3rard
I had the same issue with the requests module and my Sony Bravia python scripts.
I changed to urllib module and then it's working fine.
See
https://www.domoticz.com/forum/viewtopi ... 10#p126606.
Posted: Saturday 08 April 2017 18:09
by StasDemydiuk
Thank you for solution.
Maybe someone know the root cause of problem or the way how I can debug it.
Posted: Saturday 08 April 2017 19:01
by ubee
I have seen a similar problem importing a GPIO library. The complete plugin system halts. No callback function is called. Just a import reference is enough to result in this error.
Skickat från min ONEPLUS A3003 via Tapatalk
Posted: Thursday 13 April 2017 9:23
by avgays
I got the same problem with "import uuid".
Posted: Thursday 13 April 2017 11:05
by Dnpwwo
One thing to consider is that a 'Just a import reference' means that Python will load and execute the library.
Some libaries will just not be happy with the restriction that Domoticz does not enable Python threading and will not be usable.
Posted: Thursday 13 April 2017 11:18
by jorgh
@Dnpwwo,
I can understand, that not everything is possible within the Domoticz 'restricted' python environment. However I do think there is something strange going on. I've seen that calling a library function lock's up Domoticz depending on when it's called. In addition if a plugins throws an exception, Domoticz tends to completely lockup.
It would be nice if Domoticz would be protected against 'faulty' plugins. There could be coding errors resulting in throwing exceptions within the plugin, errors within standard libraries used or Domoticz restrictions that are not handled correctly within a library etc. All of these now tend to lockup the complete Domoticz system instead of just crashing/stopping the plugin it concerns.
The plugin system is a great new feature, and definitely gives Domoticz an edge over other systems, but in its current state (still beta of course) I think it compromises the stability of the Domoticz system and some steps should be made there.
Kind regards,
Jorg
Posted: Thursday 11 May 2017 23:23
by Mat2Vence
[UPDATE] It seems it is working in fact even if there no message in the log. I can find the new element in the material list
Please apologize for my coming question but in the Kodi plugin there are a lot of reference to image number, swichType number, subtype... where could I found the reference for all those elements?
I went through the wiki but I have not been able to find it.
Thanks for your help.
I have tried to play with python plugin... but can't make it working. I am using the Kodi plugin that I put in a dedicated directory.
Here is my log file after restart
2017-05-11 23:11:40.017 Domoticz V3.7450 (c)2012-2017 GizMoCuz
2017-05-11 23:11:40.018 Build Hash: 586c31f9, Date: 2017-05-11 18:05:12
2017-05-11 23:11:40.019 Startup Path: /home/mthomas/domoticz/
2017-05-11 23:11:40.093 Sunrise: 06:11:00 SunSet:20:44:00
2017-05-11 23:11:40.093 EventSystem: reset all events...
2017-05-11 23:11:40.146 PluginSystem: Started, Python version '3.4.3'.
2017-05-11 23:11:40.151 Active notification Subsystems: email, nma (2/12)
2017-05-11 23:11:40.152 WebServer(HTTP) started on address: :: with port 8080
2017-05-11 23:11:40.155 WebServer(SSL) started on address: :: with port 443
2017-05-11 23:11:40.155 Proxymanager started.
2017-05-11 23:11:40.157 Starting shared server on: :::6144
2017-05-11 23:11:40.157 RxQueue: queue worker started...
2017-05-11 23:11:40.157 TCPServer: shared server started...
I don't have any error message but the plugin is not starting at all. An idea on what I might do wrong?
Thanks for your help.[/i]
Posted: Thursday 11 May 2017 23:54
by Dnpwwo
@Mat2Vence,
The plugin system is starting and if 'plugin.py' is in '/home/mthomas/domoticz/plugins/<any folder name>' then it will be found. There are no messages from plugins unless you create an entry on the hardware page that uses one.
Go to the hardware page and add the Kodi selecting 'Kodi Players' from the 'Type' drop down. After that you should see entries in the log as it starts.
Posted: Friday 12 May 2017 0:13
by Mat2Vence
@Dnpwwo,
Thanks. You are right. It's working.
Did you know where to find all these reference of type, subtype, image ID that are used in Python plugin?
Posted: Friday 12 May 2017 5:29
by Dnpwwo
@Mat2Vence,
That stuff is not really documented all in one place, its in the Domoticz code itself.
If possible I would recommend using the TypeName parameter (see
http://www.domoticz.com/wiki/Developing ... in#Devices) which will give you a working Type, SubType and ImageID combination.
If you know of device that has what you want you can create one then look in the DeviceStatus table in the database to find the Type & SubType.
What are you trying to create?
Posted: Saturday 13 May 2017 12:20
by mastair
I'm trying to develop a python plugin using google maps package. But at very basic level, when I just import the Google maps package, onStart is not being called anymore. If I drop the googlemaps import it is working again.
I don't get any errors however in the Domoticz log. What could be the problem?
So the output in the log in case of importing the package is just (nothing more):
2017-05-13 12:13:14.757 (Test) Initialized version 1.0.0, author 'mastair'
While when I drop the import the output is like expected:
2017-05-13 12:13:14.757 (Test) onStart called
<plugin key="TrafficDelays" name="Traffic Delays" author="mastair" version="1.0.0">
<params>
</params>
</plugin>
import Domoticz
import googlemaps
def onStart():
Domoticz.Log("onStart called")
return True
def onStop():
return True
def onConnect(Status, Description):
return True
def onMessage(Data, Status, Extra):
return True
def onCommand(Unit, Command, Level, Hue):
return True
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
return True
def onDisconnect():
return True
def onHeartbeat():
return True
# Generic helper functions
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != "":
Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
Domoticz.Debug("Device count: " + str(len(Devices)))
for x in Devices:
Domoticz.Debug("Device: " + str(x) + " - " + str(Devices[x]))
Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug("Device nValue: " + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
return
Posted: Saturday 13 May 2017 13:02
by Dnpwwo
@mastair,
That normally means that the library is trying to do asyncronous or thread stuff (which is not supported).
Posted: Tuesday 16 May 2017 17:25
by mastair
Thanks, got another question. Trying to create a custom sensor from Python, and I want to add the axis label / units.
In SQLite the options field of a similar device contains "1;minutes" without the quotes of course. I wouldn't know how to translate this to a python dictionary.
Anyone?
Edit: Figured it out, needed a newer version of Domoticz and provide this as dictionary: Options={"Custom": "1;minutes"}
Plugin system not starting at all post update
Posted: Tuesday 06 June 2017 21:52
by superczar
I had been using the Lifx plugin for the last 4-5 months and it was running very stable
I unfortunately ended up updating to the latest beta today and now the plugin system isn't starting at all
2017-06-07 01:16:31.957 Domoticz V3.7680 (c)2012-2017 GizMoCuz
2017-06-07 01:16:31.958 Build Hash: 81c1918, Date: 2017-06-06 11:57:47
2017-06-07 01:16:31.958 System: Raspberry Pi
2017-06-07 01:16:31.958 Startup Path: /home/pi/domoticz/
2017-06-07 01:16:32.285 EventSystem: reset all events...
2017-06-07 01:16:32.314 Using 1-Wire support (kernel W1 module)...
2017-06-07 01:16:32.317 Philips Hue: Using default poll interval of 10 secs.
2017-06-07 01:16:32.366 WebServer(HTTP) started on address: :: with port 8080
2017-06-07 01:16:32.393 WebServer(SSL) started on address: :: with port 443
2017-06-07 01:16:32.398 Proxymanager started.
2017-06-07 01:16:32.401 Camera: settings (re)loaded
2017-06-07 01:16:32.408 TCPServer: shared server started...
2017-06-07 01:16:32.410 RxQueue: queue worker started...
2017-06-07 01:16:34.411 Hardware Monitor: Started
2017-06-07 01:16:34.413 AppLamp: Worker Started...
2017-06-07 01:16:34.413 1Wire: Added Device: 28-000005b6dc30
2017-06-07 01:16:34.413 1Wire: Added Device: 28-000005b6aa6d
2017-06-07 01:16:34.793 Incoming connection from: 103.253.166.8
2017-06-07 01:16:36.086 I2C_BMP085/180: Worker started...
2017-06-07 01:16:36.087 AppLamp: Worker Started...
2017-06-07 01:16:36.087 Kodi: Started
2017-06-07 01:16:36.088 Harmony Hub: Worker thread started...
2017-06-07 01:16:36.088 Kodi: Started
2017-06-07 01:16:36.088 Philips Hue: Worker started...
2017-06-07 01:16:36.089 YeeLight Worker started...
2017-06-07 01:16:36.089 EventSystem: reset all events...
2017-06-07 01:16:36.092 EventSystem: reset all device statuses...
2017-06-07 01:16:36.104 EventSystem: Started
2017-06-07 01:16:37.084 MySensors: Using serial port: /dev/ttyUSB0
2017-06-07 01:16:38.346 Harmony Hub: Authentication successful
2017-06-07 01:17:00.311 LUA: 0.0059666786
2017-06-07 01:17:00.312 LUA: 20531.288041762
2017-06-07 01:17:02.994 Incoming connection from: 192.168.0.115
2017-06-07 01:17:03.548 PROXY: Authenticate result: success.
2017-06-07 01:17:07.392 Incoming connection from: 192.168.0.8
2017-06-07 01:17:07.579 Incoming connection from: 127.0.0.1
2017-06-07 01:17:10.700 Incoming connection from: 192.168.0.100
2017-06-07 01:17:13.235 Incoming connection from: 192.168.0.114
I even tried copying one of the example plugins (Denon4306) as /home/pi/domoticz/plugins/Denon4306/plugin.py and gave it execution rights (chmod 755) but for some reason,the plugin system seems to be dead altogether
Posted: Tuesday 06 June 2017 22:07
by bcaroll
I experience the same problem as @superczar
