Page 7 of 14
Re: Find My iPhone implementation in LUA script
Posted: Friday 16 December 2016 13:35
by BluesBro
Is there a way to make the script send this info instead:
json.htm?type=command¶m=udevice&idx=IDX&nvalue=0&svalue=<iframe%20width="365"%20height="300"%20frameborder="0"%20style="border:0"%20src="
https://www.google.com/maps/embed/v1/pl ... n></iframe>
Should pop up like the attached image if possible...
Posted: Friday 16 December 2016 13:49
by Nautilus
BluesBro wrote:Is there a way to make the script send this info instead:
Yes, check my post on previous page:
http://www.domoticz.com/forum/viewtopic ... 00#p107716
As I describe, having some weird issues with it while a family member was travelling, I'm now using just:
position_text = '<a style="color:black" target="blank" href="https://www.google.com/maps/place/'..string.gsub(address, ' ','+')..'/@'..lat..','..lon..'">'..string.gsub(address, ', Finland', '')..'</a><br>('..drivedistance..' / '..drivetime..')'
which gives the person's position as address which is a clickable link that opens in a new tab (or google maps app if browsing with phone). The drivedistance / drivetime variable I parse from google maps api to see the actual distance (not just the "direct line" distance) and the expected drivetime...
Posted: Friday 16 December 2016 14:38
by BluesBro
Nautilus wrote:BluesBro wrote:Is there a way to make the script send this info instead:
I get this error when using your code:
lua: script_time_checkphones.lua:52: bad argument #1 to 'gsub' (string expected, got function)
stack traceback:
[C]: in function 'gsub'
script_time_checkphones.lua:52: in main chunk
[C]: ?
Posted: Friday 16 December 2016 14:52
by Nautilus
BluesBro wrote:Nautilus wrote:BluesBro wrote:Is there a way to make the script send this info instead:
stack traceback:
[C]: ?
I assume you are not parsing the drive time or distance, did you remove those? Do you get an error from:
position_text = '<a style="color:black" target="blank" href="https://www.google.com/maps/place/'..string.gsub(address, ' ','+')..'/@'..lat..','..lon..'">'..address..'</a>'
I've modified the original so much that I'm not exactly sure what needs to be changed in order to get this to work. The point is anyhow that just change the "position_text = ..." to your liking and "anything" is possible...
Edit: I checked the first post and yes, now "address" is a function and "position" the result. So you need to have something like:
position_text = '<a style="color:black" target="blank" href="https://www.google.com/maps/place/'..string.gsub(position, ' ','+')..'/@'..lat..','..lon..'">'..position..'</a>'
Posted: Friday 16 December 2016 16:02
by BluesBro
Thank you! It's working now
Posted: Monday 19 December 2016 10:18
by pinda
edit: omg i switched the dummy switch and text name.....got it working now.
I'm doing this with almost zero script knowledge. So just followed the manual and tried some googling
Getting the following errors in domoticz on my synology nas. So any help would be welcome
2016-12-19 10:05:01.658 Error: EventSystem: in check_iphone: [string "-- Script to check the location of multiple i..."]:51: bad argument #1 to 'match' (string expected, got nil)
2016-12-19 10:10:01.945 Error: EventSystem: in check_iphone: [string "-- Script to check the location of multiple i..."]:51: bad argument #1 to 'match' (string expected, got nil)
-- Script to check the location of multiple iPhones every X minutes,
-- test if they are "home" and represent this using virtual switches
-- polling interval in minutes (1-59), setting this too low may drain the phones' batteries
interval = 5
local m = os.date('%M')
if (m % interval == 0) then
json = (loadfile "XXXX PATH/JSON.lua")()
-- Array of users to be checked
users = {
Tom = {username = '[email protected]' ; password = 'XXXXXXXXXXX' ; devicename = 'XXXXXXXXX'};
-- The latitude and longitude of your house (use Google Maps or similar to find this)
homelongitude = XXXXXXXXXX
homelatitude = XXXXXXXXXX
-- Radius (in km) which will be used to determine if a device is at home
radius = 5
function address(longitude, latitude)
command = "curl -s https://maps.googleapis.com/maps/api/geocode/json?latlng=" .. latitude .. "," .. longitude .. "&sensor=false"
local handle = io.popen(command)
local result = handle:read("*a")
handle:close()
output = json:decode(result)
return output.results[1].formatted_address
for user,credentials in pairs(users) do
stage1command = "curl -s -X POST -D - -o /dev/null -L -u '" .. credentials.username .. ":" .. credentials.password .. "' -H 'Content-Type: application/json; charset=utf-8' -H 'X-Apple-Find-Api-Ver: 2.0' -H 'X-Apple-Authscheme: UserIdGuest' -H 'X-Apple-Realm-Support: 1.0' -H 'User-agent: Find iPhone/1.3 MeKit (iPad: iPhone OS/4.2.1)' -H 'X-Client-Name: iPad' -H 'X-Client-UUID: 0cf3dc501ff812adb0b202baed4f37274b210853' -H 'Accept-Language: en-us' -H 'Connection: keep-alive' https://fmipmobile.icloud.com/fmipservice/device/" .. credentials.username .."/initClient"
local handle = io.popen(stage1command)
handle:close()
stage2server = string.match(result, "X%-Apple%-MMe%-Host%:%s(.*%.icloud%.com)")
stage2command = "curl -s -X POST -L -u '" .. credentials.username .. ":" .. credentials.password .. "' -H 'Content-Type: application/json; charset=utf-8' -H 'X-Apple-Find-Api-Ver: 2.0' -H 'X-Apple-Authscheme: UserIdGuest' -H 'X-Apple-Realm-Support: 1.0' -H 'User-agent: Find iPhone/1.3 MeKit (iPad: iPhone OS/4.2.1)' -H 'X-Client-Name: iPad' -H 'X-Client-UUID: 0cf3dc501ff812adb0b202baed4f37274b210853' -H 'Accept-Language: en-us' -H 'Connection: keep-alive' https://" .. stage2server .. "/fmipservice/device/" .. credentials.username .."/initClient"
local handle = io.popen(stage2command)
handle:close()
for key,value in pairs(output.content) do
if value.name == credentials.devicename then
lon = value.location.longitude
lat = value.location.latitude
distance = math.sqrt(((lon - homelongitude) * 111.320 * math.cos(math.rad(lat)))^2 + ((lat - homelatitude) * 110.547)^2) -- approximation
position = address(lon,lat)
position_text = string.gsub(position, ', Netherlands', '') .. ' (' .. (math.floor(distance*10+0.5)/10) .. ' km)'
prev_distance_str = string.match(otherdevices['Position ' .. user], '%(.*%)') or '(1000 km)'
prev_distance = tonumber(string.sub(prev_distance_str, 2,-5))
-- update text device, but only if postion has changed more than defined in "radius" to reduce log size
if math.abs(prev_distance - distance) > radius then
table.insert(commandArray,{['UpdateDevice'] = otherdevices_idx['Position ' .. user] .. '|0|' .. position_text})
--print('iPhone ' .. user .. ': ' .. math.floor(distance*100+0.5)/100 .. ' km from home')
if distance < radius then
if otherdevices['iPhone ' .. user] == 'Off' then
commandArray['iPhone ' .. user] = 'On'
table.insert(commandArray, {['SendNotification'] = 'Presence update#' .. user .. ' came home'})
if otherdevices['iPhone ' .. user] == 'On' then
commandArray['iPhone ' .. user] = 'Off'
table.insert(commandArray, {['SendNotification'] = 'Presence update#' .. user .. ' left home'})
Posted: Monday 09 January 2017 18:14
by fiscvs
i got it to work but in prowl i get a notification that i came home every 5 minutes. What can i do to change that? I only want it to give me 1 notification when someone gets home. And when someone left, but not every 5 minutes! I know i am home
Posted: Monday 09 January 2017 20:32
by ben53252642
mvzut, change this in your first post. It allows for names like:
Ben's iPhone
devicename = "Ben's iPhone"};
Specifically swap the '' for double "" around the device name.
Posted: Monday 09 January 2017 20:45
by mvzut
fiscvs wrote:i got it to work but in prowl i get a notification that i came home every 5 minutes. What can i do to change that? I only want it to give me 1 notification when someone gets home. And when someone left, but not every 5 minutes! I know i am home
Hmmm... that's strange. It should only change the value of the virtual switches to "On" if it was off, using the following statements:
End
What do you see in the logs, does it report successive "On"s every 5 minutes?
Posted: Monday 09 January 2017 21:07
by mvzut
ben53252642 wrote:mvzut, change this in your first post. It allows for names like:
Ben's iPhone
Good suggestion, I updated the original post.
Posted: Tuesday 10 January 2017 13:01
by fiscvs
It seems the dummy switch doesnt toggle?
2017-01-10 12:50:02.175 LUA: Adress, Postcode, Netherlands
2017-01-10 12:50:03.665 EventSystem: Script event triggered: script_time_checkphones.lua
But the switch is not flipped. If i do it manually then the notification stops..
What have i forgotten?
Posted: Wednesday 11 January 2017 16:31
by blindlight
Great script!!
I've got it working.....for almost 48h
but i get an error this morning.
Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_checkphones.lua: /home/pi/domoticz/scripts/lua/script_time_checkphones.lua:40: attempt to concatenate global 'stage2server' (a nil value)
so i put print(result) right before stage2server = string.match(.....) to see what stage1command gets. here's what log shows:
LUA: HTTP/1.1 200 OK
Server: AppleHttpServer/3b804a0
Date: Wed, 11 Jan 2017 15:23:02 GMT
Content-Type: application/json;charset=UTF-8
Transfer-Encoding: chunked
X-Responding-Instance: fmipservice:10200801:st11p02me-fmipservice008:8001:16H103:2cc8f06
X-Responding-Server: st11p02me-fmipservice008_001
X-Responding-Partition: p02
Vary: Accept-Encoding
Strict-Transport-Security: max-age=31536000; includeSubDomains
Set-Cookie: NSC_q02-gnjqtfswjdf=ffffffff12a4c85645525d5f4f58455e445a4a422971;path=/;secure;httponly
via: icloudedge:hk03p01ic-zteu010412:7402:16G41:Hong Kong
X-Apple-Request-UUID: a82b2ad2-6903-4d6c-91ca-80e675c434c0
access-control-expose-headers: X-Apple-Request-UUID
access-control-expose-headers: Via
i see there's no "X-Apple-MMe-Host" in the result. maybe that's the reason stage2server is a nil.
so why suddenly it doesn't work? can anyone show me a correct response of stage1command?(maybe statue 200 is not ok?)
thx a lot!
Posted: Wednesday 11 January 2017 16:34
by Egregius
I think Apple changed something yesterday or today.
There are also replies about not functioning anymore on the PHP implementation on Github.
Posted: Thursday 12 January 2017 13:32
by Nautilus
If someone has access to Vera plugins there seems to be a fix available already:
http://forum.micasaverde.com/index.php/ ... #msg306362
http://forum.micasaverde.com/index.php/ ... 7.885.html
Was not able to find a source for those anywhere, though, so I guess you need to have Vera to be able to download and use (them and hopefully see what they contain?)...
Posted: Thursday 12 January 2017 13:50
by redina
They seemed to simplified it. They use the same dns-name for all. So no need to call twice.
Remove stage1Command (to find server) and call the generic server directly: fmipmobile.icloud.com
Snippet:
stage2command = "curl -s -X POST -L -u '" .. credentials.username .. ":" .. credentials.password .. "' -H 'Content-Type: application/json; charset=utf-8' -H 'X-Apple-Find-Api-Ver: 2.0' -H 'X-Apple-Authscheme: UserIdGuest' -H 'X-Apple-Realm-Support: 1.0' -H 'User-agent: Find iPhone/1.3 MeKit (iPad: iPhone OS/4.2.1)' -H 'X-Client-Name: iPad' -H 'X-Client-UUID: 0cf3dc501ff812adb0b202baed4f37274b210853' -H 'Accept-Language: en-us' -H 'Connection: keep-alive' https://fmipmobile.icloud.com/fmipservice/device/" .. credentials.username .."/initClient"
handle:close()
Posted: Thursday 12 January 2017 14:05
by MarceldeJongNL
Yes!
Changed
Into
stage2server = "fmipmobile.icloud.com"
And it works again!
Posted: Thursday 12 January 2017 22:23
by Nautilus
redina wrote:They seemed to simplified it. They use the same dns-name for all. So no need to call twice.
Out of curiosity - is the Vera source (for plugins at least) available somewhere or did you find this out from somewhere else?
Posted: Friday 13 January 2017 7:33
by redina
I just tested and saw that it's returning the data in the first call.
Posted: Friday 13 January 2017 9:28
by ropske
stack traceback:
[C]: ?
Hi Nautilus,
thanks for this script!
One question: is the link made where you can see your devices?
Because there i cannot click anythone that opens this 'map'
In my domoticz log i get a link and i can click it.
Am i doing something wrong?
Posted: Friday 13 January 2017 9:48
by Nautilus
ropske wrote:
Hi Nautilus,
not sure if I quite understand the question
What do you mean with Domoticz log? There are two things updated with the script, the On/Off switch which only gives the status whether the phone is at home or not (i.e. no links there) and then the "text sensor" that shows the current position as text. And this text you can format into a clickable link as well as discussed earlier in this thread.
Maybe you have some debug setting on that writes the text sensor value to log as well, but the sensor itself (once you create it) is found on the Utility tab (add as favorite to see it on the Dashboard)...
