Find My iPhone implementation in LUA script
Re: Find My iPhone implementation in LUA script
Is there a way to make the script send this info instead:
json.htm?type=command¶m=udevice&idx=IDX&nvalue=0&svalue=<iframe%20width="365"%20height="300"%20frameborder="0"%20style="border:0"%20src="https://www.google.com/maps/embed/v1/pl ... n></iframe>
Should pop up like the attached image if possible...
- 2016-12-16 13_33_56-Domoticz.png (81.73 KiB) Viewed 5578 times
Nautilus
Yes, check my post on previous page: http://www.domoticz.com/forum/viewtopic ... 00#p107716BluesBro wrote:Is there a way to make the script send this info instead:
As I describe, having some weird issues with it while a family member was travelling, I'm now using just:
position_text = '<a style="color:black" target="blank" href="https://www.google.com/maps/place/'..string.gsub(address, ' ','+')..'/@'..lat..','..lon..'">'..string.gsub(address, ', Finland', '')..'</a><br>('..drivedistance..' / '..drivetime..')'Re: Find My iPhone implementation in LUA script
I get this error when using your code:Nautilus wrote:Yes, check my post on previous page: http://www.domoticz.com/forum/viewtopic ... 00#p107716BluesBro wrote:Is there a way to make the script send this info instead:
As I describe, having some weird issues with it while a family member was travelling, I'm now using just:which gives the person's position as address which is a clickable link that opens in a new tab (or google maps app if browsing with phone). The drivedistance / drivetime variable I parse from google maps api to see the actual distance (not just the "direct line" distance) and the expected drivetime...Code: Select all
lua: script_time_checkphones.lua:52: bad argument #1 to 'gsub' (string expected, got function)
stack traceback:
[C]: in function 'gsub'
script_time_checkphones.lua:52: in main chunk
[C]: ?
Nautilus
I assume you are not parsing the drive time or distance, did you remove those? Do you get an error from:BluesBro wrote:I get this error when using your code:Nautilus wrote:Yes, check my post on previous page: http://www.domoticz.com/forum/viewtopic ... 00#p107716BluesBro wrote:Is there a way to make the script send this info instead:
stack traceback:
[C]: ?
position_text = '<a style="color:black" target="blank" href="https://www.google.com/maps/place/'..string.gsub(address, ' ','+')..'/@'..lat..','..lon..'">'..address..'</a>'Edit: I checked the first post and yes, now "address" is a function and "position" the result. So you need to have something like:
position_text = '<a style="color:black" target="blank" href="https://www.google.com/maps/place/'..string.gsub(position, ' ','+')..'/@'..lat..','..lon..'">'..position..'</a>'Re: Find My iPhone implementation in LUA script
Thank you! It's working now
pinda
edit: omg i switched the dummy switch and text name.....got it working now.
I'm doing this with almost zero script knowledge. So just followed the manual and tried some googling
Getting the following errors in domoticz on my synology nas. So any help would be welcome
2016-12-19 10:05:01.658 Error: EventSystem: in check_iphone: [string "-- Script to check the location of multiple i..."]:51: bad argument #1 to 'match' (string expected, got nil)
2016-12-19 10:10:01.945 Error: EventSystem: in check_iphone: [string "-- Script to check the location of multiple i..."]:51: bad argument #1 to 'match' (string expected, got nil)
-- Script to check the location of multiple iPhones every X minutes,
-- test if they are "home" and represent this using virtual switches
-- polling interval in minutes (1-59), setting this too low may drain the phones' batteries
interval = 5
local m = os.date('%M')
if (m % interval == 0) then
json = (loadfile "XXXX PATH/JSON.lua")()
-- Array of users to be checked
users = {
Tom = {username = '[email protected]' ; password = 'XXXXXXXXXXX' ; devicename = 'XXXXXXXXX'};
-- The latitude and longitude of your house (use Google Maps or similar to find this)
homelongitude = XXXXXXXXXX
homelatitude = XXXXXXXXXX
-- Radius (in km) which will be used to determine if a device is at home
radius = 5
function address(longitude, latitude)
command = "curl -s https://maps.googleapis.com/maps/api/geocode/json?latlng=" .. latitude .. "," .. longitude .. "&sensor=false"
local handle = io.popen(command)
local result = handle:read("*a")
handle:close()
output = json:decode(result)
return output.results[1].formatted_address
for user,credentials in pairs(users) do
stage1command = "curl -s -X POST -D - -o /dev/null -L -u '" .. credentials.username .. ":" .. credentials.password .. "' -H 'Content-Type: application/json; charset=utf-8' -H 'X-Apple-Find-Api-Ver: 2.0' -H 'X-Apple-Authscheme: UserIdGuest' -H 'X-Apple-Realm-Support: 1.0' -H 'User-agent: Find iPhone/1.3 MeKit (iPad: iPhone OS/4.2.1)' -H 'X-Client-Name: iPad' -H 'X-Client-UUID: 0cf3dc501ff812adb0b202baed4f37274b210853' -H 'Accept-Language: en-us' -H 'Connection: keep-alive' https://fmipmobile.icloud.com/fmipservice/device/" .. credentials.username .."/initClient"
local handle = io.popen(stage1command)
handle:close()
stage2server = string.match(result, "X%-Apple%-MMe%-Host%:%s(.*%.icloud%.com)")
stage2command = "curl -s -X POST -L -u '" .. credentials.username .. ":" .. credentials.password .. "' -H 'Content-Type: application/json; charset=utf-8' -H 'X-Apple-Find-Api-Ver: 2.0' -H 'X-Apple-Authscheme: UserIdGuest' -H 'X-Apple-Realm-Support: 1.0' -H 'User-agent: Find iPhone/1.3 MeKit (iPad: iPhone OS/4.2.1)' -H 'X-Client-Name: iPad' -H 'X-Client-UUID: 0cf3dc501ff812adb0b202baed4f37274b210853' -H 'Accept-Language: en-us' -H 'Connection: keep-alive' https://" .. stage2server .. "/fmipservice/device/" .. credentials.username .."/initClient"
local handle = io.popen(stage2command)
handle:close()
for key,value in pairs(output.content) do
if value.name == credentials.devicename then
lon = value.location.longitude
lat = value.location.latitude
distance = math.sqrt(((lon - homelongitude) * 111.320 * math.cos(math.rad(lat)))^2 + ((lat - homelatitude) * 110.547)^2) -- approximation
position = address(lon,lat)
position_text = string.gsub(position, ', Netherlands', '') .. ' (' .. (math.floor(distance*10+0.5)/10) .. ' km)'
prev_distance_str = string.match(otherdevices['Position ' .. user], '%(.*%)') or '(1000 km)'
prev_distance = tonumber(string.sub(prev_distance_str, 2,-5))
-- update text device, but only if postion has changed more than defined in "radius" to reduce log size
if math.abs(prev_distance - distance) > radius then
table.insert(commandArray,{['UpdateDevice'] = otherdevices_idx['Position ' .. user] .. '|0|' .. position_text})
--print('iPhone ' .. user .. ': ' .. math.floor(distance*100+0.5)/100 .. ' km from home')
if distance < radius then
if otherdevices['iPhone ' .. user] == 'Off' then
commandArray['iPhone ' .. user] = 'On'
table.insert(commandArray, {['SendNotification'] = 'Presence update#' .. user .. ' came home'})
if otherdevices['iPhone ' .. user] == 'On' then
commandArray['iPhone ' .. user] = 'Off'
table.insert(commandArray, {['SendNotification'] = 'Presence update#' .. user .. ' left home'})
return commandArray Re: Find My iPhone implementation in LUA script
i got it to work but in prowl i get a notification that i came home every 5 minutes. What can i do to change that? I only want it to give me 1 notification when someone gets home. And when someone left, but not every 5 minutes! I know i am home
ben53252642
mvzut, change this in your first post. It allows for names like:
Ben's iPhone
devicename = "Ben's iPhone"};
Specifically swap the '' for double "" around the device name.
Ben's iPhone
mvzut
Hmmm... that's strange. It should only change the value of the virtual switches to "On" if it was off, using the following statements:fiscvs wrote:i got it to work but in prowl i get a notification that i came home every 5 minutes. What can i do to change that? I only want it to give me 1 notification when someone gets home. And when someone left, but not every 5 minutes! I know i am home
EndRaspberry Pi 4 - RFXtrx433 - CC2531 Zigbee - Opentherm Gateway - P1 smart meter - Netatmo - Philips Hue - ELV Max! - ESP8266 DIY water meter - 6 x Sonos - 4 x IP cameras - Wall mounted tablet + Dashticz - Google Home integration - MANY switches/sensors
mvzut
Good suggestion, I updated the original post.ben53252642 wrote:mvzut, change this in your first post. It allows for names like:
Ben's iPhone
It seems the dummy switch doesnt toggle?
2017-01-10 12:50:02.175 LUA: Adress, Postcode, Netherlands
2017-01-10 12:50:03.665 EventSystem: Script event triggered: script_time_checkphones.lua
But the switch is not flipped. If i do it manually then the notification stops..
What have i forgotten?
blindlight
Great script!!
I've got it working.....for almost 48h
but i get an error this morning.
so i put print(result) right before stage2server = string.match(.....) to see what stage1command gets. here's what log shows:
i see there's no "X-Apple-MMe-Host" in the result. maybe that's the reason stage2server is a nil.
so why suddenly it doesn't work? can anyone show me a correct response of stage1command?(maybe statue 200 is not ok?)
thx a lot!
Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_checkphones.lua: /home/pi/domoticz/scripts/lua/script_time_checkphones.lua:40: attempt to concatenate global 'stage2server' (a nil value)so i put print(result) right before stage2server = string.match(.....) to see what stage1command gets. here's what log shows:
LUA: HTTP/1.1 200 OK
Server: AppleHttpServer/3b804a0
Date: Wed, 11 Jan 2017 15:23:02 GMT
Content-Type: application/json;charset=UTF-8
Transfer-Encoding: chunked
X-Responding-Instance: fmipservice:10200801:st11p02me-fmipservice008:8001:16H103:2cc8f06
X-Responding-Server: st11p02me-fmipservice008_001
X-Responding-Partition: p02
Vary: Accept-Encoding
Strict-Transport-Security: max-age=31536000; includeSubDomains
Set-Cookie: NSC_q02-gnjqtfswjdf=ffffffff12a4c85645525d5f4f58455e445a4a422971;path=/;secure;httponly
via: icloudedge:hk03p01ic-zteu010412:7402:16G41:Hong Kong
X-Apple-Request-UUID: a82b2ad2-6903-4d6c-91ca-80e675c434c0
access-control-expose-headers: X-Apple-Request-UUID
access-control-expose-headers: Via
thx a lot!
- Egregius
- Domoticz version: v2024.7
I think Apple changed something yesterday or today.
There are also replies about not functioning anymore on the PHP implementation on Github.
Nautilus
If someone has access to Vera plugins there seems to be a fix available already:
http://forum.micasaverde.com/index.php/ ... #msg306362
http://forum.micasaverde.com/index.php/ ... 7.885.html
Was not able to find a source for those anywhere, though, so I guess you need to have Vera to be able to download and use (them and hopefully see what they contain?)...
redina
They seemed to simplified it. They use the same dns-name for all. So no need to call twice.
Remove stage1Command (to find server) and call the generic server directly: fmipmobile.icloud.com
Snippet:
Snippet:
stage2command = "curl -s -X POST -L -u '" .. credentials.username .. ":" .. credentials.password .. "' -H 'Content-Type: application/json; charset=utf-8' -H 'X-Apple-Find-Api-Ver: 2.0' -H 'X-Apple-Authscheme: UserIdGuest' -H 'X-Apple-Realm-Support: 1.0' -H 'User-agent: Find iPhone/1.3 MeKit (iPad: iPhone OS/4.2.1)' -H 'X-Client-Name: iPad' -H 'X-Client-UUID: 0cf3dc501ff812adb0b202baed4f37274b210853' -H 'Accept-Language: en-us' -H 'Connection: keep-alive' https://fmipmobile.icloud.com/fmipservice/device/" .. credentials.username .."/initClient"
handle:close()-
MarceldeJongNL
- Domoticz version: 3.5108
Yes!
Changed
Into
And it works again!
Changed
stage2server = "fmipmobile.icloud.com"And it works again!
Hardware: Raspberry Pi 2B | RFXCOM RFXtrx433E v1 | Synology DS213+ | KaKu Clones | Conrad RSL switches | KAKu Doorbell Clone | USB Webcam | ICY Thermostat | Resol DL2 | Imatic Relay Board | Eminent 6230 | Eminent 6220 | iMatic 16 ports Relay Board
Nautilus
Thanks!redina wrote:They seemed to simplified it. They use the same dns-name for all. So no need to call twice.
Out of curiosity - is the Vera source (for plugins at least) available somewhere or did you find this out from somewhere else?
redina
I just tested and saw that it's returning the data in the first call.
ropske
- Domoticz version: V3_8394
Nautilus wrote:I assume you are not parsing the drive time or distance, did you remove those? Do you get an error from:BluesBro wrote:I get this error when using your code:Nautilus wrote:
stack traceback:
[C]: ?I've modified the original so much that I'm not exactly sure what needs to be changed in order to get this to work. The point is anyhow that just change the "position_text = ..." to your liking and "anything" is possible...Code: Select all
Edit: I checked the first post and yes, now "address" is a function and "position" the result. So you need to have something like:Code: Select all
Hi Nautilus,
thanks for this script!
One question: is the link made where you can see your devices?
Because there i cannot click anythone that opens this 'map'
In my domoticz log i get a link and i can click it.
Am i doing something wrong?
Nautilus
Hi,ropske wrote:
Hi Nautilus,
not sure if I quite understand the question
Maybe you have some debug setting on that writes the text sensor value to log as well, but the sensor itself (once you create it) is found on the Utility tab (add as favorite to see it on the Dashboard)...
