Domoticz on synology for evohome
DanD
Re: Domoticz on synology for evohome
Post by DanD »
@Erwinvos72
Thanks for laying out the steps so clearly.
Dan
Windows 7, Raspberry Pi3, Honeywell Evohome Wifi, HGI80 + RFBee(s)
Erwinvos72
Post by Erwinvos72 »
DanD wrote:@Erwinvos72
Dan
@DanD no problem. I created the topic and know when you're not a programmer it can be very difficult. I had those problems too. And screwed my NAS under water so many extra steps which i had to do, weren't neccessary. I noticed that after my DSM crashed and got a clean DSM version. After that these steps did the trick. And the last 'not working' part was the last piece that got my evohome fully function within domoticz
dejvisss
Post by dejvisss »
Hello Dear friends,
very thans I do this:
root@NAS-BIALONOVI:/home# clone https://github.com/watchforstock/evohome-client.git
bash: clone: command not found
root@NAS-BIALONOVI:/home# git clone https://github.com/watchforstock/evohome-client.git
fatal: destination path 'evohome-client' already exists and is not an empty directory.
root@NAS-BIALONOVI:/home# sudo pip install ./evohome-client
bash: sudo: command not found
root@NAS-BIALONOVI:/home# pip install ./evohome-client
Unpacking ./evohome-client
  Running setup.py (path:/tmp/pip-lAYrly-build/setup.py) egg_info for package from file:///home/evohome-client
  Requirement already satisfied (use --upgrade to upgrade): evohomeclient==0.2.5 from file:///home/evohome-client in /usr/local/lib/python2.7/dist-packages
Requirement already satisfied (use --upgrade to upgrade): requests in /usr/lib/python2.7/dist-packages (from evohomeclient==0.2.5)
Cleaning up...
But I not understand how and where I have to do this:
You then need to create the following scripts in an appropriate location on the Domoticz server (you can put them in the evohome-client directory after running the git clone)
maybe one important information, when I see on my snology Packingcenter: I have instaled two pythons: python 2.7 and python 3.5, is it problem?
mschut
Domoticz version: V3.5613
Post by mschut »
danika00 wrote:Dear Gordon,
Thank you for your information,
I have one more question.
I have this error message.
pi@raspberrypi ~/evohome-client $ python evo-update.sh init
File "evo-update.sh", line 29, in <module>
client = EvohomeClient(evoconfig.usr,evoconfig.pw)
File "/home/pi/evohome-client/evohomeclient2/__init__.py", line 18, in __init__
self._login()
File "/home/pi/evohome-client/evohomeclient2/__init__.py", line 76, in _login
self.installation()
File "/home/pi/evohome-client/evohomeclient2/__init__.py", line 86, in installation
r = requests.get('https://tccna.honeywell.com/WebAPI/emea ... stems=True' % self.account_info['userId'], headers=self.headers)
TypeError: list indices must be integers, not str
Do you know what is the problem?
Did you solve this? I do have exactly the same issue. If I use a wrong password I do get stuck earlier in the output, si it seems to me it is not the password which causes the issue.
However, I do have a "#" in my password, do you also have this?
I am trying to change my password to remove the #, but somehow I am not able to change the password on the Honeywell site...
danika00
Post by danika00 »
I can not solved this problem, I waiting the good idea.
FlatBread
Post by FlatBread »
I know this thread hasn't been used for a while, but I have troubles getting my Evohome back to work in Domotociz on my Synology DS412+.
It used to work and suddenly it stopped and even caused Domoticz to stop. This was some while ago already, but I gave up and now try to get it back working. Since then I have removed the hardware to use the Evohome web API and Domoticz runs properly again.
However, as soon as I add an Evohome Web API device, Domoticz quits after it tries to fetch data from Evohome. The only thing I have done sofar is add the hardware device for Evohome Web API and fill in my username and password.
Is anyone still using the Evohome Web API in Domoticz (on a Synology NAS)? What do I do wrong?
Hope someone is able to help me get it back to work!
