How to check presence of Beacon ?
micbou
Re: How to check presence of Beacon ?
Post by micbou »
I just got my NUT's, went back to this topic and I'm so lost. Is there already a wiki available? Im really excited about this project and cant wait to execute.
jmleglise
Domoticz version: 2022.1
Post by jmleglise »
The wiki will be there :
http://www.domoticz.com/wiki/Presence_d ... _Beacon%29
Need some hours to write it ...
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
micbou
Post by micbou »
jmleglise wrote:Hi,
Great! Can I help in any way?
jmleglise
Post by jmleglise »
Yes !
I'm on it. When, I will finish , You may try and report/correct all the mistakes in the wiki.
Edit :
An idea, if you really want to contribute, you could make screen shot of all the phase of your installation. This will help a lot. And if something goes wrong , I may help you in return.
KMTronic USB relay
jmleglise
Post by jmleglise »
All,
Could you publish here a link to the beacon you've bought ? This will help the next buyers.
KMTronic USB relay
korniza
Domoticz version: V3.6028
Post by korniza »
here is the tested and working NUT2 that broadcast ble beacons even they are not paired:
http://www.banggood.com/Mini-Smart-Patc ... 88462.html
The following stop transmit ble beacons after a while. still can be used as PANIC BUTTONS:
http://www.banggood.com/Bluetooth-4_0-S ... 74320.html
http://www.banggood.com/Wifi-Smart-Blue ... 28944.html
I have ordered another type which it suppose to be programmed and wait to be delived so to perform validation:
http://www.aliexpress.com/snapshot/7667 ... 7725846383
Also there TI SensorTag which is more than a simple tag as it incudes 9 sensors. It goes on deep sleep if no connection performed in 2 minutes so it not recommended.
Recently, I find out a review page for ble beacons and you can also purchase.
https://www.beaconzone.co.uk/allbeacons
>>>> Google Home <<<<<
micbou
Post by micbou »
jmleglise wrote:Yes !
Edit :
No problem. Just say when
blackdog65
Post by blackdog65 »
Hi Guys,
My hardware is:-
https://www.amazon.co.uk/gp/product/B01 ... UTF8&psc=1
https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1
This BT dongle is the smallest form I've ever seen, it's tiny! It works 1st time (I have 4 of them) but an be inserted upside down :oops:
I tried an ASUS dongle at twice the price and had to return it as it didn't play well with the RasPi.
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
blackdog65
Hi, jmleglise,
Is it ok if I run through the WIKI and correct a few spelling and grammar errors?
Your English is a 1,000,000X better than my French (I live on "vin" and "fromage" when I visit :oops: )
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
jmleglise
Post by jmleglise »
Ouch ! It's upsetting :o
I'm kidding. Of course, please do ! :)
KMTronic USB relay
jmleglise
Post by jmleglise »
micbou wrote:
jmleglise wrote: No problem. Just say when
Now, you can. The wiki is up to date.
KMTronic USB relay
Raspberry Piet
Post by Raspberry Piet »
Looks great!
I had to install requests (it was not installed on my RPI) as the check_beacon_presence.py script gave me error messages.
sudo apt-get install python-pip
sudo pip install requests
micbou
Post by micbou »
I run into a bunch of undeleted stuff half way, but was able to fix that with
apt-get install libusb-dev libdbus-1-dev libglib2.0-dev automake libudev-dev libical-dev libreadline-dev
micbou
Post by micbou »
I cant seem to run the gatttool. Any idea?
root@raspberrypi:/home/pi/bluez/bluez-5.39# sudo cp gatttool /usr/local/bin/
cp: cannot stat ‘gatttool’: No such file or directory
UPDATE: Was able to fix above with
sudo cp attrib/gatttool /usr/bin/
Now running the service is giving me a 404 error. Typo somewhere?
root@raspberrypi:/home/pi# sudo wget https://raw.githubusercontent.com/jmleglise/mylittle-domoticz/master/Presence%20detection%20%28beacon%29/check_beacon_presence/check_beacon_presence
--2016-05-21 14:03:10--  https://raw.githubusercontent.com/jmleglise/mylittle-domoticz/master/Presence%20detection%20%28beacon%29/check_beacon_presence/check_beacon_presence
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 23.235.43.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|23.235.43.133|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2016-05-21 14:03:10 ERROR 404: Not Found.
micbou
Post by micbou »
micbou
Post by micbou »
micbou wrote:I cant seem to run the gatttool. Any idea?
ANOTHER UPDATE:
Found the typo and corrected the WIKI
Westcott
Post by Westcott »
micbou
Post by micbou »
Sorry for all the questions, but here's another error I'm getting
root@raspberrypi:/home/pi# sudo /etc/init.d/check_beacon_presence start
[....] Starting check_beacon_presence (via systemctl): check_beacon_presence.serviceFailed to start check_beacon_presence.service: Unit check_beacon_presence.service failed to load: No such file or directory.
 failed!
Westcott
Post by Westcott »
Did you do the final -
sudo update-rc.d check_beacon_presence defaults
micbou
Post by micbou »
Got it, but must admit I'm starting to feel a bit discouraged, because now that I have everything up I have no idea how to get my switches or variables set up to actually show whether or not Im HOME or AWAY. Tried copying some of the LUA scripts, but I guess I just need to do some more research to learn.
