Locked
Clemen
Re: Dashticz v2.0, custom positioning and multiple screens
Post by Clemen »
robgeerts wrote:NEW VERSION
- Swipe to change screens
- New thermostat-design (Thanks to @madrian)
- Some small performance fixes
- Graph on iphone battery-status block
- Bug in fan-block (mentioned by @gielie)
- Added swedish translations
- Disabled ios double click to zoom-function
- Fix when using device AND scene with same IDX-numbers
- Translations of wind direction (thanks to @Wizjos)
BE CAREFUL, THINGS MAY FAIL SO BACKUP YOUR OLD DASHBOARD-FOLDER!!!
NICE!
If i have multiple thermostat set points on the screen in this version and changes the set point. then it changes on every thermostat on that page.
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Thats right, i have to fix that multiple thermostats are allowed...
mvveelen
Post by mvveelen »
And how about the weather? Because, when I enter the api key, the screen won't load anymore.
robgeerts
Post by robgeerts »
mvveelen wrote:And how about the weather? Because, when I enter the api key, the screen won't load anymore.
Most likely, there's a javascript-error.
Could you send me your config.js OR open console (f12) en check for an error? (Just after loading the page)
madrian
Post by madrian »
robgeerts wrote:Thats right, i have to fix that multiple thermostats are allowed...
I am working on it.
EdwinK
Post by EdwinK »
SwordFish wrote:
I changed your script a little to my needs 8-)
Care to share? Btw. I hope that @ierlandfan will make another version for those special days that trash isn't collected. And since our city doesn't use the orange bin, those could go too.
Will also try to use the 'official' version of Afvalwijzer. For now it's good.
EdwinK
Post by EdwinK »
Perhaps you made an error with the APIkey. It should go between the ' '. And make sure you don't delete the ; and the end of the line. It might cause the problem
mvveelen
Post by mvveelen »
I'm sure I didn't make an error. I copy-pasted the key between the 's and didn't delete the ;
Maybe rob can find out what's wrong. I've sent him a message.
By-the-way, I like the afvalwijzer add-on. I uploaded the lua script and made a selector switch. I have to take a look at the week numbers, but that won't be a problem. Nice !
robgeerts
Post by robgeerts »
Error only occured when no blocks, screens or something were defined, fixed in latest version!
mvveelen
Post by mvveelen »
robgeerts wrote:Error only occured when no blocks, screens or something were defined, fixed in latest version!
Thanks Rob !
Update the api key, and now I have no problems loading the screen, except.....I don't see any weather blocks. I might have to read the whole topic I guess :o
freakshock
Post by freakshock »
Thanks for the new version Rob, I like the new thermostat buttons :)
They work, but the information on the dashboard is a bit confusing.
If you change for instance 19 degrees to 19.5 degrees, it shows 19.5 for a second, and then returns to 19 degrees. After a while it shows 19.5 again, probably when the dashboard gets this value back from Domoticz again. Not sure if there is a fix for this, it's not a big problem for me.
Also I found an error which causes the news block not to show:
XMLHttpRequest cannot load http://www.nu.nl/rss/algemeen. No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'http://192.168.1.88' is therefore not allowed access.
robgeerts
Post by robgeerts »
freakshock wrote:Thanks for the new version Rob, I like the new thermostat buttons :)
I know, will fix this!
freakshock wrote: Also I found an error which causes the news block not to show:
Try adding https://crossorigin.me before the url, so:
https://crossorigin.me/http://www.nu.nl/rss/algemeen
(Yes, seems strange, but try :))
madrian
Post by madrian »
[/code]
Yeah, it's working pretty awkward. For me it's jumping 1 number instead of 0.5. +:hover style is strange too, when I move mouse over button it's always changing. +icons are flashing:
axelbaas
Post by axelbaas »
robgeerts wrote:
axelbaas wrote:See underneath.
It is a MySensors Temperature sensors
"ActTime" : 1492694695,
"ServerTime" : "2017-04-20 15:24:55",
"Sunrise" : "06:31",
"Sunset" : "20:43",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "20.5 C, 38 %",
"Description" : "",
"DewPoint" : "5.69",
"Favorite" : 1,
"HardwareID" : 9,
"HardwareName" : "Mysensors_PI",
"HardwareType" : "MySensors Gateway with LAN interface",
"HardwareTypeVal" : 42,
"HaveTimeout" : false,
"Humidity" : 38,
"HumidityStatus" : "Comfortable",
"ID" : "4B01",
"LastUpdate" : "2017-04-20 15:24:50",
"Name" : "Huiskamer",
"Notifications" : "false",
"PlanID" : "4",
"PlanIDs" : [ 4 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "WTGR800",
"Temp" : 20.5,
"Timers" : "false",
"Type" : "Temp + Humidity",
"TypeImg" : "temperature",
"Unit" : 0,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "288"
"status" : "OK",
"title" : "Devices"
Try latest version I've just pushed!
You nailed it!
freakshock
robgeerts wrote: Try adding https://crossorigin.me before the url, so:
That works, thanks :) Sent you some tablet money, hehe ;)
Another thing I've found: The graph direct display function ('graph_1') does not display the graphs immediately after page refresh, I have to click one of the three options (laatste uren,vandaag,afgelopen maand) first for the graph to show.
A better solution for me anyway would be to have clickable blocks for gas and power usage, but that's already been requested ;)
Ierlandfan
Post by Ierlandfan »
@EdKo66
the trash is defined in weeks. So if it's a special "week" don't put the weeknumber into the bincolor.
If you don't have a orange bin, then there are no weeknumbers needed in the part for orange.
And so no orange value will reach Domoticz.
EdwinK
Post by EdwinK »
Just noticed that the 'Buienradar' wind tile doesn't give the 'gust' anymore.
This is the output from the json
ActTime" : 1492712572,
   "ServerTime" : "2017-04-20 20:22:52",
   "Sunrise" : "06:35",
   "Sunset" : "20:46",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "Chill" : 7.7999999999999998,
         "CustomImage" : 0,
         "Data" : "270.0;W;30;46;9.4;7.8",
         "Description" : "",
         "Direction" : 270.0,
         "DirectionStr" : "W",
         "Favorite" : 1,
         "Gust" : "3",
         "HardwareID" : 21,
         "HardwareName" : "Buienradar",
         "HardwareType" : "Buienradar.nl (Weather lookup)",
         "HardwareTypeVal" : 94,
         "ID" : "00150006",
         "LastUpdate" : "2017-04-20 20:08:18",
         "Name" : "Wind",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Speed" : "2",
         "SubType" : "TFA",
         "Temp" : 9.4000000000000004,
         "Timers" : "false",
         "Type" : "Wind",
         "TypeImg" : "wind",
         "Unit" : 6,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "98"
   "status" : "OK",
   "title" : "Devices"
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
Sure,
I put in the weeknumbers and days when they come to collect the garbage.
script_device_bin_selector.txt
(4.6 KiB) Downloaded 115 times
EdwinK
Post by EdwinK »
Bedankt :)
robgeerts
Post by robgeerts »
freakshock wrote: That works, thanks :) Sent you some tablet money, hehe ;)
Thanks!!!
freakshock wrote: A better solution for me anyway would be to have clickable blocks for gas and power usage, but that's already been requested ;)
It is already available but not all devices get recognized correctly... Please send me the output of the devices and I will fix it a.s.a.p.
EdKo66 wrote:Just noticed that the 'Buienradar' wind tile doesn't give the 'gust' anymore.
   "Sunset" : "20:46",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Description" : "",
         "Favorite" : 1,
         "Gust" : "3",
         "HardwareID" : 21,
         "ID" : "00150006",
         "Name" : "Wind",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Speed" : "2",
         "SubType" : "TFA",
         "Timers" : "false",
         "Type" : "Wind",
         "TypeImg" : "wind",
         "Unit" : 6,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "98"
   "status" : "OK",
   "title" : "Devices"
Will fix this a.s.a.p.
Currently, I'm working on bigger buttons for blinds:
When this is done, I will make mediaplayer buttons bigger too.
Locked
