Page 59 of 120
Re: Domoticz app 2.0
Posted: Monday 05 September 2016 7:52
by galadril
NiklasO wrote:Can't control blinds from the widget?
Would like to see "Open" and/or "Close" button..
Ill look into it
Posted: Monday 05 September 2016 18:34
by Shaggie_NB
galadril wrote:Shaggie_NB wrote:I'm still having problems with the graphs from the Gas and CO2 meters (they won't show). For Electricity and Temp they are working OK!
In the Domotictz (website) they are all working fine...
This was already mentioned by me but everybody was so busy with all the new (and great!) functionalities I thougt it would be picked up later.....
So here is my question again...
Can you create a read-only account for me and PM me de details?
Did PM you but the message stays in my outbox??
Posted: Tuesday 06 September 2016 9:58
by galadril
Should be fixed in next beta.
Posted: Tuesday 06 September 2016 20:12
by pollefinario
I've got a Philips 23" android touch screen. At the moment it is not able to install the app. Is this due to the screen resolution being in the config files?
The device is stuck at 4.2.2.
Any possibility to make this device compatible?
Thanks a lot.
Device info:
http://www.philips.nl/c-p/S231C4AFD_00/ ... cificaties
Posted: Wednesday 07 September 2016 8:57
by galadril
You can now also modify the user variables values in the next beta
Posted: Wednesday 07 September 2016 11:59
by martk
Finally! Tried this a few times already but couldn't. Thanks
Posted: Wednesday 07 September 2016 12:10
by roblom
"Zet"?
Verstuurd vanaf mijn HTC One M9 met Tapatalk
Posted: Thursday 08 September 2016 13:30
by galadril
Posted: Thursday 08 September 2016 14:29
by piokuc
Please correct aligment text on dashboard in grid view. Should all text center or alligment to left.
Posted: Thursday 08 September 2016 14:36
by galadril
piokuc wrote:Please correct aligment text on dashboard in grid view. Should all text center or alligment to left.
They should be centered.. maybe you have something where with your naming..?
Posted: Thursday 08 September 2016 14:54
by piokuc
Yes. Some naming is center and is ok but some is not center.. look on my screen.
- Screenshot_20160908-145234.png (133.46 KiB) Viewed 3555 times
Example:
TV salon -KWh is ok
But temperatura -"wschód" is not ok.
Posted: Friday 09 September 2016 10:26
by piokuc
Today i install new beta and alligment is still problem.
Next problem is that option Configuration server download not working. When i click on this it nothing do.
Posted: Friday 09 September 2016 16:21
by MarcelMAH
I recieved the non beta update yesterday and AGAIN I had to remove my data from the app to be able to use it again (after setting it up again)
Posted: Friday 09 September 2016 19:30
by jannl
In the new update all settings where gone. Remaining problem is that it is not possible to set the protocol to https (every time I look it is back to http). I do not use the standard https port.
Posted: Saturday 10 September 2016 9:52
by mlamie
The latest update caused an issue which I can not resolve. With version (0.1.316) something changed in the network configuration. Normally I only connect via the local ip (192.168.x.x) and if I'm outside I use openvpn. Can someone help me! P.s. via an internet browser everything works fine.
Posted: Sunday 11 September 2016 15:37
by Shaggie_NB
Thanks!!!!
In te new beta all graphs are working OK.
Keep up the great work!!
Posted: Sunday 11 September 2016 15:51
by Timdgr
galadril wrote:From the play store device compatibility list:
So according to that list, it should work if plain Nexus 7 means the original 2012 version...
Unfortunately i can't install it. Too bad that it does not give any clue on why it refuses to install.
I googled around a bit and found some instructions on clearing google play cache and such but didn't help out.
Any ideas?
I'm actually running the Domoticz lite version 0.1.243 app on the very same tablet...
even more strange isn't it? Or have requirements changed since that version?
Posted: Monday 12 September 2016 7:12
by mlamie
mlamie wrote:The latest update caused an issue which I can not resolve. With version (0.1.316) something changed in the network configuration. Normally I only connect via the local ip (192.168.x.x) and if I'm outside I use openvpn. Can someone help me! P.s. via an internet browser everything works fine.
In the Play store the 4 latest comments did report the same issue after the update. Can someone have a look soonest?
Posted: Monday 12 September 2016 9:17
by galadril
mlamie wrote:In the Play store the 4 latest comments did report the same issue after the update. Can someone have a look soonest?
Can you create a view-only account for me and pm me the details?
Posted: Monday 12 September 2016 9:26
by mlamie
galadril wrote:mlamie wrote:In the Play store the 4 latest comments did report the same issue after the update. Can someone have a look soonest?
I don't know what you mean with a view-only account. So far I know the issue is in the Android app, not the Domoticz installation it selfs. If you have some instructions or suggestions I can try to provide you details to troubleshoot.
P.s. I already cleared the caches and removed the app and reinstalled it. Did not help.
