aldodemi
Domoticz version: 3.8275
Post by aldodemi »
@corbin: gateway parameters seems correct:
2017-04-05 14:04:45.474 {"cmd":"report","model":"motion","sid":"158d00013fa661","short_id":36170,"data":"{\"no_motion\":\"120\"}"}
2017-04-05 14:05:13.499 {"cmd":"report","model":"gateway","sid":"f0b429cc5693","short_id":0,"data":"{\"rgb\":0,\"illumination\":948}"}
2017-04-05 14:05:45.358 {"cmd":"report","model":"motion","sid":"158d00013fa661","short_id":36170,"data":"{\"no_motion\":\"180\"}"}
2017-04-05 14:06:36.705 User: Admin initiated a switch command (43/Xiaomi Gateway Alarm Ringtone/Set Level)
2017-04-05 14:07:16.721 {"cmd":"heartbeat","model":"switch","sid":"158d00011376c8","short_id":61982,"data":"{\"voltage\":3062}"}
2017-04-05 14:07:45.105 {"cmd":"report","model":"motion","sid":"158d00013fa661","short_id":36170,"data":"{\"no_motion\":\"300\"}"}
as you can see after then "User: Admin initiated a switch command" no other line for the gateway in the log.
Server Domoticz 3.7243 (usually the last beta) on Debian Linux (Jessie) - Hw homemade with Atom CPU/4 GB RAM
RFXCom and ZWave Stick (Aeon)
StefanoA
Post by StefanoA »
Hi everyone,
I'm very happy with domoticz and the plugin to use xiaomi gateway and sensors, it's really good work
however I'm experiencing a new problem like follows:
first I made some tests at home with a gateway, some sensors, some power socket running on a raspberry and everything was fine
today I tried moving to another system like that at my parent's place but I cannot have the devices connected to the gateway detected properly
I have 2 temp+hum sensors and 5 power plugs, but this is what I see
the power plugs are NOT detected as switches anymore as in my first tests,
what's going on ??
this is the log:
2017-04-05 14:32:36.903 XiaomiGateway: will listen on 9898 for hardware id 9
2017-04-05 14:32:36.903 XiaomiGateway: Worker started...
2017-04-05 14:32:36.903 XiaomiGateway: Using 192.168.1.11 for local IP address.
2017-04-05 14:32:36.913 XiaomiGateway: RGB Gateway Detected
2017-04-05 14:32:36.913 XiaomiGateway: unknown cmd received: get_id_list
2017-04-05 14:32:36.913 {"cmd" : "get_id_list"}
2017-04-05 14:32:41.904 XiaomiGateway: stopped
2017-04-05 14:32:41.906 XiaomiGateway: will listen on 9898 for hardware id 9
2017-04-05 14:32:41.906 XiaomiGateway: Worker started...
2017-04-05 14:32:41.906 XiaomiGateway: Using 192.168.1.11 for local IP address.
2017-04-05 14:32:41.910 XiaomiGateway: RGB Gateway Detected
2017-04-05 14:32:41.911 XiaomiGateway: unknown cmd received: get_id_list
2017-04-05 14:32:41.911 {"cmd" : "get_id_list"}
I just updated to latest beta Domoticz V3.7253
StefanoA
Post by StefanoA »
and now, after a couple of hours, I found these errors into log:
2017-04-05 16:56:00.758 Error: Gateway Negozio hardware (9) thread seems to have ended unexpectedly
2017-04-05 16:56:30.763 Error: Gateway Negozio hardware (9) thread seems to have ended unexpectedly
2017-04-05 16:57:00.769 Error: Gateway Negozio hardware (9) thread seems to have ended unexpectedly
2017-04-05 16:57:30.774 Error: Gateway Negozio hardware (9) thread seems to have ended unexpectedly
2017-04-05 16:58:00.779 Error: Gateway Negozio hardware (9) thread seems to have ended unexpectedly
2017-04-05 16:58:30.784 Error: Gateway Negozio hardware (9) thread seems to have ended unexpectedly
2017-04-05 16:59:00.789 Error: Gateway Negozio hardware (9) thread seems to have ended unexpectedly
2017-04-05 16:59:30.794 Error: Gateway Negozio hardware (9) thread seems to have ended unexpectedly
2017-04-05 17:00:31.116 Error: Gateway Negozio hardware (9) thread seems to have ended unexpectedly
2017-04-05 17:01:00.121 Error: Gateway Negozio hardware (9) thread seems to have ended unexpectedly
2017-04-05 17:01:30.127 Error: Gateway Negozio hardware (9) thread seems to have ended unexpectedly
2017-04-05 17:02:00.132 Error: Gateway Negozio hardware (9) thread seems to have ended unexpectedly
2017-04-05 17:02:30.138 Error: Gateway Negozio hardware (9) thread seems to have ended unexpectedly
2017-04-05 17:03:00.143 Error: Gateway Negozio hardware (9) thread seems to have ended unexpectedly
2017-04-05 17:03:30.148 Error: Gateway Negozio hardware (9) thread seems to have ended unexpectedly
2017-04-05 17:04:00.154 Error: Gateway Negozio hardware (9) thread seems to have ended unexpectedly
2017-04-05 17:04:30.159 Error: Gateway Negozio hardware (9) thread seems to have ended unexpectedly
2017-04-05 17:05:00.799 Error: Gateway Negozio hardware (9) thread seems to have ended unexpectedly
2017-04-05 17:05:30.804 Error: Gateway Negozio hardware (9) thread seems to have ended unexpectedly
there must really be something wrong, I didn't experience any problem like this in my tests with previous system
what's going on ?
I've tried already to reboot and to delete and add again the xiaomi gateway but these problems still happening
please help :roll:
StefanoA
Post by StefanoA »
here I am again,
the problem in my previous post was just caused by wrong ip changed after reboot, so now I guess communication is
ok but the problem is in the wrong detection of device type as you can see below:
model is reported "plug" but General/Voltage (Xiaomi Voltage) is detected in place of plug or power plug
2017-04-05 18:01:08.732 XiaomiGateway: will listen on 9898 for hardware id 9
2017-04-05 18:01:08.732 XiaomiGateway: Worker started...
2017-04-05 18:01:08.733 XiaomiGateway: Using 192.168.1.7 for local IP address.
2017-04-05 18:01:08.737 XiaomiGateway: RGB Gateway Detected
2017-04-05 18:01:09.147 {"cmd":"read_ack","model":"sensor_ht","sid":"158d00010f2abd","short_id":212,"data":"{\"voltage\":3025,\"temperature\":\"2064\",\"humidity\":\"5001\"}"}
2017-04-05 18:01:09.148 {"cmd":"read_ack","model":"plug","sid":"158d00010c5930","short_id":43823,"data":"{\"voltage\":3600,\"status\":\"on\",\"inuse\":\"1\",\"power_consumed\":\"81677\",\"load_power\":\"84\"}"}
2017-04-05 18:01:09.148 {"cmd":"read_ack","model":"plug","sid":"158d000125938d","short_id":62008,"data":"{\"voltage\":3600,\"status\":\"on\",\"inuse\":\"0\",\"power_consumed\":\"14335\",\"load_power\":\"0\"}"}
2017-04-05 18:01:09.148 {"cmd":"read_ack","model":"plug","sid":"158d0001104c2a","short_id":25300,"data":"{\"voltage\":3600,\"status\":\"on\",\"inuse\":\"1\",\"power_consumed\":\"30666\",\"load_power\":\"36\"}"}
2017-04-05 18:01:09.149 {"cmd":"read_ack","model":"sensor_ht","sid":"158d00015b2ef7","short_id":42729,"data":"{\"voltage\":2985,\"temperature\":\"2112\",\"humidity\":\"4993\"}"}
2017-04-05 18:01:09.149 {"cmd":"read_ack","model":"plug","sid":"158d00010dd9e8","short_id":34536,"data":"{\"voltage\":3600,\"status\":\"off\",\"inuse\":\"0\",\"power_consumed\":\"79632\",\"load_power\":\"0\"}"}
2017-04-05 18:01:09.147 (Gateway_negozio) Temp (Xiaomi Temperature)
2017-04-05 18:01:09.150 (Gateway_negozio) Humidity (Xiaomi Humidity)
2017-04-05 18:01:09.151 (Gateway_negozio) General/Voltage (Xiaomi Voltage)
2017-04-05 18:01:09.152 (Gateway_negozio) General/Voltage (Xiaomi Voltage)
2017-04-05 18:01:09.153 (Gateway_negozio) General/Voltage (Xiaomi Voltage)
2017-04-05 18:01:09.154 (Gateway_negozio) Temp (Xiaomi Temperature)
2017-04-05 18:01:09.156 (Gateway_negozio) Humidity (Xiaomi Humidity)
2017-04-05 18:01:09.157 (Gateway_negozio) General/Voltage (Xiaomi Voltage)
Jumper3126
Post by Jumper3126 »
Hi guys
Anyone an idea how to get my installation working. Haven't gotten further then in my last post (see below).
As I did get it to work on a raspyzero, but not on my main raspi3, I made a database backup of the raspi3 and loaded that on the zero. Without a problem I could install the gateway and could control the switches! Then I backed up this database and restored it back on the raspi3.
Unfortunately, still the same error. It appears to be related to my raspi 3. :(
Jumper3126 wrote:Received my set last week. First the gateway and temp sensor. Was able to install them. Could receive the temp and humidity, but not control the light via domoticz. Few days later received more sensors, like IR. Could install those as well, but no couldn't get more data then the temp/hum.
Then I started to see these "Error sending switch command, check device/hardware !" messages when I tried to turn on the gateway light. I'm not the only one with this issue, but couldnt find a clear solution.
Today installed domoticz also on my new raspi zero w (very nice). Installed the latest beta and right away got the gateway and all sensors/plugs to work! No hassle at all (@Berth, perhaps you need to have accept new hardware devices turned on. Just a thought).
So.. I thought it all is related to latest beta update. So I removed the gateway hardware from my original raspi. restarted it. cleared cache, etc. Reinstalled the gateway. all sensors showed up, but..... still the error message :? :(
No idea what the problem is. Solution might be just a complete new installation. For now I'll just tinker around with my zero. Like the idea of having a stably running main system, with a small satellite for tinkering.
Last edited by Jumper3126 on Wednesday 05 April 2017 23:34, edited 1 time in total.
Swifty
Post by Swifty »
I see the same issue as @aldodemi - Compiled the latest (as of 1 hr ago) version from @corbin github, the audio devices appear but nothing happens when I select (shows it should be playing in domoticz, but there is no sound).
Log doesn't show any response - does it need any additional parameter somewhere to turn up the log level?
2017-04-05 22:14:21.635 User: Admin initiated a switch command (111/Xiaomi Gateway Alarm Clock/Off)
2017-04-05 22:14:21.637 XiaomiGateway: level 0
2017-04-05 22:14:21.788 XiaomiGateway: request {"cmd":"write","model":"gateway","sid":"286c078892ae","short_id":0,"data":"{\"mid\":10000,\"key\":\"F047771F01A4644EB9C13B3AAD1D88AF\"}" }
2017-04-05 22:14:21.789 (Xiaomi Gateway) Light/Switch (Xiaomi Gateway Alarm Clock)
2017-04-05 22:15:10.376 RFLink: 20;04;PONG;
Btw - My Domoticz is running on Rpi, and Gateway shows firmware version 1.4.1_143.0141 (latest according to the MiHome app...)
aldodemi
Post by aldodemi »
New Xiaomi Gateway firmware this morning: 1.4.1_145.0141 and new app version.
marcotini
Post by marcotini »
aldodemi wrote:New Xiaomi Gateway firmware this morning: 1.4.1_145.0141 and new app version.
And if you update it's working fine?
StefanoA
Post by StefanoA »
I updated to latest fw of gateway but still getting same, wrong device type
2017-04-06 10:07:20.851 XiaomiGateway: stopped
2017-04-06 10:07:20.852 XiaomiGateway: will listen on 9898 for hardware id 11
2017-04-06 10:07:20.852 XiaomiGateway: Worker started...
2017-04-06 10:07:20.852 XiaomiGateway: Using 192.168.1.7 for local IP address.
2017-04-06 10:07:20.886 XiaomiGateway: RGB Gateway Detected
2017-04-06 10:07:21.395 (Gateway_negozio) Temp (Xiaomi Temperature)
2017-04-06 10:07:21.398 (Gateway_negozio) Humidity (Xiaomi Humidity)
2017-04-06 10:07:21.400 {"cmd":"read_ack","model":"sensor_ht","sid":"158d00010f2abd","short_id":212,"data":"{\"voltage\":3025,\"temperature\":\"10000\",\"humidity\":\"0\"}"}
2017-04-06 10:07:21.401 {"cmd":"read_ack","model":"plug","sid":"158d00010c5930","short_id":43823,"data":"{\"voltage\":3600,\"status\":\"on\",\"inuse\":\"1\",\"power_consumed\":\"81997\",\"load_power\":\"82\"}"}
2017-04-06 10:07:21.401 {"cmd":"read_ack","model":"plug","sid":"158d000125938d","short_id":62008,"data":"{\"voltage\":3600,\"status\":\"on\",\"inuse\":\"0\",\"power_consumed\":\"14335\",\"load_power\":\"0\"}"}
2017-04-06 10:07:21.401 {"cmd":"read_ack","model":"plug","sid":"158d0001104c2a","short_id":25300,"data":"{\"voltage\":3600,\"status\":\"on\",\"inuse\":\"1\",\"power_consumed\":\"30804\",\"load_power\":\"36\"}"}
2017-04-06 10:07:21.401 {"cmd":"read_ack","model":"sensor_ht","sid":"158d00015b2ef7","short_id":42729,"data":"{\"voltage\":2985,\"temperature\":\"2038\",\"humidity\":\"4734\"}"}
2017-04-06 10:07:21.402 {"cmd":"read_ack","model":"plug","sid":"158d00010dd9e8","short_id":34536,"data":"{\"voltage\":3600,\"status\":\"off\",\"inuse\":\"0\",\"power_consumed\":\"79632\",\"load_power\":\"0\"}"}
2017-04-06 10:07:21.402 (Gateway_negozio) General/Voltage (Xiaomi Voltage)
2017-04-06 10:07:21.404 (Gateway_negozio) General/Voltage (Xiaomi Voltage)
2017-04-06 10:07:21.405 (Gateway_negozio) General/Voltage (Xiaomi Voltage)
2017-04-06 10:07:21.407 (Gateway_negozio) Temp (Xiaomi Temperature)
2017-04-06 10:07:21.409 (Gateway_negozio) Humidity (Xiaomi Humidity)
2017-04-06 10:07:21.411 (Gateway_negozio) General/Voltage (Xiaomi Voltage)
aldodemi
Post by aldodemi »
No, still the same problem
marcotini
Post by marcotini »
aldodemi wrote:No, still the same problem
Ok for the sound, even to me it's not working but what about the other sensor with the new firmware?
StefanoA wrote:I updated to latest fw of gateway but still getting same, wrong device type
Have you try to remove and re-add? Maybe with a different password (everytime the app generate a new one).
corbin
Post by corbin »
@StefanoA
The voltage devices are removed in the next update to Xiaomi Gateway (this is not in the offical beta yet)
@aldodemi
Try my latest github update, and delete the Xiaomi Gateway audio devices as they will need to be rediscovered.
@Swifty
that is the command to stop playing audio - triggered from the 'off' option, do you get that no matter what sound you select?
aldodemi
Post by aldodemi »
@corbin: removed Xiamoi Gateway (the gateway) on your latest update and then aded again, no audio device nor lux device discovered...
2017-04-06 12:16:36.851 XiaomiGateway: will listen on 9898 for hardware id 5
2017-04-06 12:16:36.852 XiaomiGateway: Worker started...
2017-04-06 12:16:36.852 XiaomiGateway: Using 192.168.10.8 for local IP address.
2017-04-06 12:16:36.982 XiaomiGateway: RGB Gateway Detected
2017-04-06 12:16:36.982 XiaomiGateway: New Gateway Found (29cc5693/Xiaomi RGB Gateway)
2017-04-06 12:16:36.994 {"cmd":"read_ack","model":"sensor_ht","sid":"158d00010dd4c8","short_id":24186,"data":"{\"voltage\":3025,\"temperature\":\"2384\",\"humidity\":\"4442\"}"}
2017-04-06 12:16:36.994 {"cmd":"read_ack","model":"magnet","sid":"158d000112fcaa","short_id":24968,"data":"{\"voltage\":3005,\"status\":\"close\"}"}
2017-04-06 12:16:36.994 {"cmd":"read_ack","model":"magnet","sid":"158d000112fac8","short_id":38897,"data":"{\"voltage\":3025,\"status\":\"open\"}"}
2017-04-06 12:16:36.995 {"cmd":"read_ack","model":"magnet","sid":"158d0001130c81","short_id":12547,"data":"{\"voltage\":3045,\"status\":\"open\"}"}
2017-04-06 12:16:36.995 {"cmd":"read_ack","model":"magnet","sid":"158d0001137f75","short_id":25119,"data":"{\"voltage\":3025,\"status\":\"open\"}"}
2017-04-06 12:16:36.995 {"cmd":"read_ack","model":"sensor_ht","sid":"158d000156dcc4","short_id":13435,"data":"{\"voltage\":2975,\"temperature\":\"2453\",\"humidity\":\"4184\"}"}
2017-04-06 12:16:36.996 {"cmd":"read_ack","model":"cube","sid":"158d00010f03fa","short_id":9970,"data":"{\"voltage\":2975}"}
2017-04-06 12:16:36.996 {"cmd":"read_ack","model":"sensor_ht","sid":"158d00010fb3bb","short_id":57917,"data":"{\"voltage\":2995,\"temperature\":\"2370\",\"humidity\":\"4269\"}"}
2017-04-06 12:16:36.996 {"cmd":"read_ack","model":"motion","sid":"158d00013fa661","short_id":36170,"data":"{\"voltage\":3045,\"status\":\"no_motion\"}"}
2017-04-06 12:16:36.996 {"cmd":"read_ack","model":"magnet","sid":"158d0001583301","short_id":42871,"data":"{\"voltage\":3045,\"status\":\"open\"}"}
2017-04-06 12:16:36.997 {"cmd":"read_ack","model":"magnet","sid":"158d0001539245","short_id":44915,"data":"{\"voltage\":3005,\"status\":\"open\"}"}
2017-04-06 12:16:36.997 {"cmd":"read_ack","model":"magnet","sid":"158d000130c989","short_id":31442,"data":"{\"voltage\":3025,\"status\":\"open\"}"}
2017-04-06 12:16:36.997 {"cmd":"read_ack","model":"switch","sid":"158d00011376c8","short_id":61982,"data":"{\"voltage\":3062}"}
2017-04-06 12:16:36.997 {"cmd":"read_ack","model":"switch","sid":"158d00010aca3d","short_id":9562,"data":"{\"voltage\":3092}"}
2017-04-06 12:17:19.398 XiaomiGateway: New Device Found (013fa661)
2017-04-06 12:17:19.400 {"cmd":"report","model":"motion","sid":"158d00013fa661","short_id":36170,"data":"{\"no_motion\":\"1200\"}"}
2017-04-06 12:18:06.605 {"cmd":"report","model":"sensor_ht","sid":"158d00010fb3bb","short_id":57917,"data":"{\"temperature\":\"2368\"}"}
2017-04-06 12:18:06.614 {"cmd":"report","model":"sensor_ht","sid":"158d00010fb3bb","short_id":57917,"data":"{\"humidity\":\"4358\"}"}
doelle4
Post by doelle4 »
I have now latest Update, restart Raspberry, new Xiaomi Key ist ok
Log shows this:
"2017-04-06 13:04:29.283 {"cmd":"heartbeat","model":"plug","sid":"158d00013e61a5","short_id":55421,"data":"{\"voltage\":3600,\"status\":\"off\",\"inuse\":\"0\",\"power_consumed\":\"8689\",\"load_power\":\"0\"}"}
2017-04-06 13:04:29.284 (Xiaomi Gateway) General/Voltage (Xiaomi Voltage)
2017-04-06 13:04:36.725 {"cmd":"heartbeat","model":"plug","sid":"158d0001291d64","short_id":9291,"data":"{\"voltage\":3600,\"status\":\"on\",\"inuse\":\"1\",\"power_consumed\":\"50075\",\"load_power\":\"227\"}"}
2017-04-06 13:04:36.725 (Xiaomi Gateway) General/Voltage (Xiaomi Voltage)"
But i cant see new Hardware Parts, no Lux, no Alarm, no Power Plug consumed.
I need only Power Value from the Plugs.
Why Domotics shows no new Hardware ?
Greetings Hans
corbin
Post by corbin »
because you do not have the latest update.
doelle4
Post by doelle4 »
Thanks for answer.
V 3.7253 from Yesterday. No Errors in Logs.
Greetings Hans
bertbigb
Post by bertbigb »
Jumper3126 wrote:Hi guys
I hope to receive my Raspberry 3 and Raspberry zero tomorrow and will test. Keep you informed OK?
If you have find the root cause yourself please tell us so we don't fell in the same pit as you.
Best regards Bert
Synology DS1517+ - DSM 6.2
StefanoA
Post by StefanoA »
corbin wrote:@StefanoA
thanks corbin,
so my problem will be solved when beta is updated?
or should I revert to an older beta version?
I didn't have this problem when I started my tests,
but how to downgrade on raspberry ?
joebar
Post by joebar »
doelle4 wrote:Thanks for answer.
Greetings Hans
That is not Corbin's version, that is now on .7162. Guess this is the official beta without all the new goodies
doelle4
Post by doelle4 »
But i cant compile the Files self ..
https://www.domoticz.com/forum/viewtopi ... 20#p127138
