domoticz in synology as package! Available now.
jumbotroll
Re: domoticz in synology as package! Available now.
Post by jumbotroll »
Gravityz wrote: Wednesday 13 September 2017 19:40 Hi
will the package for the DS716+II also run on the 718+
i noticed that they vboth have a celeron cpu but one is the N3160 4 core anbd the other is the J3455
thanks
Hi.
I think DS718+ will use arch-denverton and kernel 4.4.15, then the USB serial drivers will not be compatible with DS716+II.
I will check out the new kernel source code and toolchain and compile a test version when someone want to test.
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Gravityz
Post by Gravityz »
ok thanks. still deciding 716+ or 718+
these things never ever get discounted
jumbotroll
I have build some test version for the new Synology NAS.
Compiled for arch-apollolake, arch-denverton and arch-rtd1296.
This test versions will be found under beta section.
Last edited by jumbotroll on Monday 18 September 2017 22:59, edited 1 time in total.
Jumbotroll
Gravityz
Post by Gravityz »
thanks Jumbotroll
now i only have to buy that ds718+
strange that the ds718+ is available and the ds716+(which is 2 years old) still gets no discount.
proably the minute i buy the 718+ the 716+II will be discounted
Gravityz
Post by Gravityz »
is the 718+ not apollolake?
on your site you link the 718+ to denverton
jumbotroll
Gravityz wrote: Monday 18 September 2017 20:07 is the 718+ not apollolake?
Changed to Apollolake!
Edit:
Added:
DS418j arch-rtd1296
DS218+ arch-apollolake
DS718+ arch-apollolake
DS1517+ arch-denverton
DS1817+ arch-denverton
Only for DSM6.1x
Last edited by jumbotroll on Thursday 21 September 2017 19:30, edited 2 times in total.
Jumbotroll
gongjingou2
Post by gongjingou2 »
there is no package for ds218+
can i use any other instead?
jumbotroll
Updated.
Jumbotroll
jumbotroll
Added:
DS418j arch-rtd1296
Jumbotroll
wedge34
Post by wedge34 »
Hello
I managed to install Domoticz adding http://www.jadahl.com/domoticz_stable/ into the synlogy package center.
but it doesn't start and i have no error message.
I have a Synology EDS14 can you help me ?
jumbotroll
wedge34 wrote: Friday 22 September 2017 15:36 Hello
What DSM version du you have installed on this device?
What version of domoticz did you install? Armada370 ?
Log in to your NAS with telnet or ssh and type: uname -a
write the output here.
Jumbotroll
wedge34
Post by wedge34 »
It's the latest for the device : DSM 6.0.3-8754 Update 4
i have tried with Armada370 and with adding the repository
here is the output of uname -a
Linux DATASTATION 3.2.40 #8754 Thu Apr 20 02:24:24 CST 2017 armv7l GNU/Linux synology_armada370_eds14
jumbotroll
wedge34 wrote: Friday 22 September 2017 20:20 It's the latest for the device : DSM 6.0.3-8754 Update 4
You have the right version of my package, compiled with arch-armada370 and it should work.
It's working on another NAS with armada370, so why this is not working on your device I don't understand.
Maybe your device not have enough memory to run domoticz, just a speculation....
EDS14 only have 512MB memory.
Jumbotroll
wedge34
Post by wedge34 »
yes i know... :(
is there any log file, that can help me to solve the problem ?
wedge34
Post by wedge34 »
Maybe it's also because EDS14 has no internal drive ? i use a 64Gb SDcard
jumbotroll
wedge34 wrote: Saturday 23 September 2017 11:52 Maybe it's also because EDS14 has no internal drive ? i use a 64Gb SDcard
Unfortunately, I'm not familiar with EDS14, so I do not have much to contribute with to this model. It works with Raspberry Pi and it also uses sd card.
Jumbotroll
wedge34
Post by wedge34 »
thank you anyway :)
ehelms
Post by ehelms »
I have installed the lates beta 8440 for the ds214 but all my buttons on the web browser page are strange it put all buttons to the same place and the temperature page it comes with domoticz offline.
jeroenkl
Post by jeroenkl »
ehelms wrote: Friday 29 September 2017 11:48 I have installed the lates beta 8440 for the ds214 but all my buttons on the web browser page are strange it put all buttons to the same place and the temperature page it comes with domoticz offline.
Works fine at my side
Gravityz
Post by Gravityz »
Hi Jumbotroll,
installed 8153 stable version on the DS718+(apollolake)
restored a backup from the DS112+ version
aparently USB A was the top one which i got right the first time.
seems to runs without any problems
now with the DS718+ i can run docker and homebridge.
i need homebridge for interfacing my Zwave devices to Homekit.
