Page 55 of 76
Re: Pass2PHP
Posted: Wednesday 02 October 2019 5:51
by Egregius
About the delays:
Where do they happen?
Use tail -f on your logfile, make sure pass2php logs to the same file as domoticz.
Re: Pass2PHP
Posted: Wednesday 02 October 2019 21:41
by ropske
delays are fine now, thank you.
I'm running now on a new install with a ssd hardisk.
I also see you have the files: regenputleeg.php and regenputvol.php
I'm curious how you measure this?
Also how do you now the sunrise and sunset ?
i want to use this as a reference to set my blinds.
thank you
Re: Pass2PHP
Posted: Thursday 03 October 2019 6:50
by Egregius
I have 2 float sensors in my rain pit (regenput) connected to a Fibaro Universal sensor.
1 at the bottom to indicate he's empty and I need to switch all the water to "city water" (sorry, don't know the exact term for that in English).
1 at about 20% of the top to indicate he's full and I should switch the hot water to rain water because we have plenty.
The only thing they do is an indication on my secondary floorplan and send me a telegram.
Sunrise is scraped in _cron3600 with:
$sunrise=json_decode(
file_get_contents(
'http://api.sunrise-sunset.org/json?lat='
.$lat.'&lng='
.$lon.'&date=today&formatted=0'
true
if (isset($sunrise['results']['civil_twilight_begin'])) {
if (strtotime($sunrise['results']['civil_twilight_begin'])!=$d['civil_twilight']['s']) {
store('civil_twilight', strtotime($sunrise['results']['civil_twilight_begin']), basename(__FILE__).':'.__LINE__);
if (strtotime($sunrise['results']['civil_twilight_end'])!=$d['civil_twilight']['m']) {
storemode('civil_twilight', strtotime($sunrise['results']['civil_twilight_end']), basename(__FILE__).':'.__LINE__);
if (TIME>$d['civil_twilight']['s']&&TIME<$d['civil_twilight']['m']) {
$uv=json_decode(
shell_exec(
"curl -X GET 'https://api.openuv.io/api/v1/uv?lat=".$lat."&lng=".$lon."' -H 'x-access-token: ".$openuv."'"
true
if (isset($uv['result'])) {
if ($uv['result']['uv']!=$d['uv']['s']) {
store('uv', round($uv['result']['uv'], 1), basename(__FILE__).':'.__LINE__);
if ($uv['result']['uv_max']!=$d['uv']['m']) {
storemode('uv', round($uv['result']['uv_max'], 1), basename(__FILE__).':'.__LINE__);
sunrise is stored in $d['civil_twilight']['s'] and sunset in $d['civil_twilight']['m'].
The advantage of sunrise-sunset.org is that they provide different types of them. I use the civil one. For sunrise that means the moment where the sky starts to get lighter but it's actually still dark.
Here's an example result from their site:
"results":
"sunrise":"2019-10-03T05:51:34+00:00",
"sunset":"2019-10-03T17:21:26+00:00",
"solar_noon":"2019-10-03T11:36:30+00:00",
"day_length":41392,
"civil_twilight_begin":"2019-10-03T05:18:52+00:00",
"civil_twilight_end":"2019-10-03T17:54:08+00:00",
"nautical_twilight_begin":"2019-10-03T04:40:40+00:00",
"nautical_twilight_end":"2019-10-03T18:32:20+00:00",
"astronomical_twilight_begin":"2019-10-03T04:01:42+00:00",
"astronomical_twilight_end":"2019-10-03T19:11:18+00:00"
"status":"OK"
Then, in _cron60 I check wether the time is between sunrise and sunset to store it in the mode of my virtual switch 'auto':
if ($d['auto']['m']!=true) {
storemode('auto', true, basename(__FILE__).':'.__LINE__);
$d['auto']['m']=true;
} else {
if ($d['auto']['m']!=false ) {
storemode('auto', false, basename(__FILE__).':'.__LINE__);
$d['auto']['m']=false;
Then I use the combinations of $d['auto']['m'] and $d['zon']['s'] to know if it's night, day or that there's actual solar power from the panels.
Domoticz uses the sunrise/sunset values, I prefer the civil ones. I like my blinds to be open so I can enjoy the sunrise instead of sitting in a closed dark house untill it's completely light outside.
For today the difference between this sunrise/sunset and the one in Domoticz is:
Re: Pass2PHP
Posted: Monday 07 October 2019 22:01
by ropske
thank you mate.
will try to do the same for the regenput
can you give me a type of what kind of flood sensor you used?
Also, the status of 'Weg' and 'auto' ; is this a virtual dummy sensor? (dutch: keuzeschakelaar?)
or is it a user variable (dutch: gebruikersvariabele?)
thank you
Re: Pass2PHP
Posted: Tuesday 08 October 2019 7:12
by Egregius
I used these:
https://www.conrad.be/p/binsack-11132-b ... uks-701629 connected to a Fibaro universal binary sensor.
'Weg' and 'Auto' are switches only known in pass2php.
I don't use dummy hardware or uservariables in Domoticz. You just need to do a sw command and it's created automatically. The sw function knows that when there's no idx known it doesn't need to send it to domoticz.
So you just do a sw('auto', 'On'); or a sw('Weg', 2);
'Weg' in my case is the global state of the house. 0= home, 1= sleeping, 2=away. That's used to control blinds, heating and alarm.
Re: Pass2PHP
Posted: Tuesday 08 October 2019 21:55
by ropske
Ok thank you mate for the information, already ordered 2 of these.
About the weg and auto; can you explain how you set/activate them and where?
For example, is weg set to 1 (slapen) when all pir in your house does not see action for lets say 30minutes?
and the rollers, are they allways in automatic mode?
what i've done now is: my rollers are also in automatic mode and they are working to go up on sunrise and down on sunset, but if i switch them manually (with my hardware roller switch) down to for example 25% (because the sun is pointing at the tv) then they are automatically going up again because sunset was not activated
there are ghosts in the house for my kids haha
thank you
Re: Pass2PHP
Posted: Wednesday 09 October 2019 7:38
by Egregius
That's where the modes come in to play.
My rollers only go automatic when for example $d['Rbureel']['m']==0.
When I control any of the rollers by hand, either with a remote control or with the floorplan the mode is set to 1.
Then, in a cron you can check for the last change with the past function to set them back to automatic after 4 hours or something like you want.
Re: Pass2PHP
Posted: Wednesday 09 October 2019 10:36
by ropske
So when you set a roller by hand (hardware switch) , you set the mode for this roller to 1 (manual)
And when is it set back to automatic mode then? by program? or when you set rollers to automatic in your floorplan?
Re: Pass2PHP
Posted: Wednesday 09 October 2019 16:06
by Trigun
ropske wrote:So when you set a roller by hand (hardware switch) , you set the mode for this roller to 1 (manual)
Hi Robske,
Which rollers do you use?
I am searching my butt off for some good(and cheap) automatically rollers
Re: Pass2PHP
Posted: Wednesday 09 October 2019 16:56
by ropske
i will need to check on my papers from my windows what type they used.
I didn't install them, i asked them together with my new windows.
Re: Pass2PHP
Posted: Thursday 10 October 2019 6:47
by Egregius
My rollers use the cheapest Somfy motor. I explicitly for 3 wire motors without receiver in them so I could connect them to a Fibaro roller shutter switch. They have never had that question and where quite surprised about what I was going to do with them
About the manual switches: I don't have those. I can only control them from domoticz.
The first thing you can add to your automation is a past function. Something like this:
if (past('Rbureel'')>14400&&$d['Rbureel']['s']<100) {
sl('Rbureel', 100);
With that, the roller will stay in the same position for 4 hours.
Re: Pass2PHP
Posted: Thursday 10 October 2019 6:51
by Egregius
Everything I do for the rollers is in
https://github.com/Egregius/PHP-Floorpl ... luiken.php
It's quite a mess at the moment. I'm totally rewritten it because it was way to complicated before. It used to be more than a thousand lines of code. Now I only have about 150 lines.
Re: Pass2PHP
Posted: Thursday 10 October 2019 10:12
by Trigun
[/quote]
Please, if you can find the time.
right now I am holding back because the motors to operate it cost as much as new rollers so there is no gain
thanks again!
Re: Pass2PHP
Posted: Thursday 10 October 2019 10:14
by Trigun
Egregius wrote: Thursday 10 October 2019 6:47
Is there a chance you can share wich motor you are using?
In my case, I have venetian shutters and I only want them to tilt whenever the sun is shining through my windows. that means it doesn't have to be a heavy weight motor.
thanks again!
Re: Pass2PHP
Posted: Thursday 10 October 2019 10:53
by Egregius
Mine are Somfy Ilmo, don't know the type exactly.
Re: Pass2PHP
Posted: Friday 11 October 2019 13:05
by Trigun
Egregius wrote: Thursday 10 October 2019 10:53
wow! those are expensive as well!
Re: Pass2PHP
Posted: Friday 11 October 2019 16:29
by Egregius
Are they? Don't know, don't look at that
Re: Pass2PHP
Posted: Monday 14 October 2019 20:16
by ropske
to save the status of the battery devices, you needed to change the file attributes of: '/domoticz/Config/zwcfg_0xe9238f6e.xml'
Mine i called this way.
Because, standard, it has root privileges and it wont save the battery status to the mysql database.
or am i'm doing something wrong?
Thank you
Re: Pass2PHP
Posted: Tuesday 15 October 2019 6:54
by Egregius
Yes, you need to update the name of the Zwave config file.
Mine is owned by root with 644 rights.
There is a glitch in the code tough, think you have to manually enter a line for each battery powered device for the first time. Can't remember, to long ago
Re: Pass2PHP
Posted: Tuesday 15 October 2019 10:07
by Trigun
Egregius wrote:Are they? Don't know, don't look at that
Hahah compared to the ones IKEA has brought out. They are a bit
