- G3rard
- Target OS: -
- Domoticz version: No
@tcar79, can you check if idx 152 is used in another place in frontpage_settings.js as well? If so please remove it there (I use some idx's for special actions in frontpages.js).
Not using Domoticz anymore
Tcar79
Thx. I forgot To mention I already did that, so that's not it.G3rard wrote:@tcar79, can you check if idx 152 is used in another place in frontpage_settings.js as well?.
It just seems to skip the code completely, but it does find thename/description.
Extra info:
I have a second sensor (156) and it has the same problem.
This is the 2nd try with this front page (first one kept loading and I wanted a bit much for a first try) Maybe there are some files in the www folder which can create a conflict?
- G3rard
- Target OS: -
I will have a closer look at it this evening. Can you pm me the frontpage_settings.js and frontpage.js?
Polygontrauma
- Target OS: -
Thanks to Gerards great work and his help I finally managed to get his frontpage working.
Although the buttons do work on my windows PC, they do not work on my android tablet. Does anybody know if this is a problem caused by my changes on Gerards files, or is it a general problem on this design?
- frontpage.jpg (159.47 KiB) Viewed 4357 times
- G3rard
- Target OS: -
The buttons are working on my Android tablet (Nexus), so let's have another look at that. Will answer your PM to try to find the issue.
Ingmar
Hi Gerard,
I just found this thread and your frontpage looks great. I've been scrolling through many pages, but I didn't see a link or anything to where I can find the latest version with the various improvements that have been implemented over time. Where can I find that?
Synology NAS with stable release, AEON Z-wave, RFXCOM, Toon, Echo Dot, HAbridge, HarmonyHUB, Dashticz.
- G3rard
- Target OS: -
Ingmar
Lol, totally overlooked that, the font is so tiny!!!
Thank you Gerard, i'll have a go at it
possible
HI All,
I was wondering how you can add the buienradar realtime page into a cell ?
Like this:
Like this:
Hi Guys,
What would be the best way to add this FrontPage to a Synology NAS?
lukev
Just put all the files on your syno webserver, like /volume1/web/domofrontpage (or whatever subdir you want to make).amens wrote:Hi Guys,
From there, all is the same as in this thread
naitsirhc
I do have a very strange problem. I can see my Hikvision camera in frontpage. Also the pop up is working OK. But when I open the frontpage on my tablet, the camera doesn't show anything. Webcam offline.
It doesn't work with Firefox, Chrome and Opera....
Is it Android which is horrassing me?
Edit:
Excuse I forgot to tell my frontpage which is working OK, runs on Windows with Firefox.
Edit:
Und Tschjuß
satanasinc
- Domoticz version: 4.9700
Hi!!
Im trying to config frontpage and it works great. Thanks for your work.
Ive got a problem changing th e big cells (camera and radar) in G3rard version. Someone can give a clue to solve it?
Solved Cell3 and cell25.
Greetings from spain!
- G3rard
- Target OS: -
You can change those cells in frontpage.html (if not already found
).Not using Domoticz anymore
stlaha2007
- Target OS: -
Re: RE: Re: NEW frontpage.html - request comments
Got same problem... Have a webcam which is shown correctly on Windows and Android. But have a webcam as in combined .jpegs to show al analog meters. Those images alone display also correctly on Windows and Android, however the combined one, doesn't work on some Androids (5.x and up) but do work on Windows and Android 4.x.naitsirhc wrote:Hi
Edit:
Think it has to do with jpeg-headers and libs in Android.
Sent from my D6603 using Tapatalk
marcelonline
Hello people,
Is it possible to get sound from the iPad? For voice (Voicerss) and radio streams (buttons)?
In frontpage.
Kind regards,
Marcel of Dordrecht
In frontpage.
Kind regards,
Marcel of Dordrecht
stlaha2007
- Target OS: -
Dont know how its implemented, however the keypad from the securitypanel beeps...
Need to investigate that to lower the frequenty of the beeps for myself.
But there are wiki's about streaming audio and talking to or from the tablet. Don't know if its Android or iPad...
stlaha2007
- Target OS: -
[Edit: 2016-11-03 19.34 CET]G3rard wrote:You can change those cells in frontpage.html (if not already found).
Found the big cells and the corresponding PopUp/Unders. But couldn't find out how the sizing was made.
Solved it for now... Needs some finetuning. Then i deliver an addon based on the colorbox.js and plain html with css to enable a screensaver.
Very useful to protect from ghosting/burn in on LCD-panels in the tablets etc.
stlaha2007
- Target OS: -
Ran into a few problems now.
Basically downloaded and finetuned G3rards latest version from github.
So far managed to change background image and fontcolors.
Created a screensaver.html beside frontpage.html with the source from http://codepen.io/dlim/pen/LrAwt. Runs fine in a browser tab and also in an iframe {replaced Buienradar url}
Also embedded the code from http://stackoverflow.com/questions/1324 ... javascript with green mark below the popup/under at the end of frontpage.html
Remarked the alert and called the lightbox_open('screensaver')
Which will be displayed, however its not touchable to remove it now.
Anyone an idee how to overcome this behaviour. Would love to have this working as a screensaver to save my tabletscreen. {And please; yes have tried other solutions on this older Android Sony Tablet S
gmccarthy
Trying to customize this for an alarm page I want to setup. For temperatures its working well but I want to display Alert status. Any idea how to do this?
I've changed the index and the type in the config but its displaying as ??'s
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "normal",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 6,
"HardwareName" : "MyDummy",
"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
"HardwareTypeVal" : 15,
"HaveTimeout" : false,
"ID" : "82023",
"LastUpdate" : "2016-11-03 19:04:15",
"Level" : 1,
"Name" : "Garage Door",
"Notifications" : "false",
"PlanID" : "5",
"PlanIDs" : [ 5 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "Alert",
"Timers" : "false",
"Type" : "General",
"TypeImg" : "Alert",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "24"
