ftsikogi
Domoticz version: 2022.1
Latest Android version
Post by ftsikogi »
Yesterday the domoticz android app got a new update. After installing the update the android app got stucked many timesand othertimes it was getting realy slow. Alsoô some devices couldn't show any logs and in general the application seems very unstable. Has anyone else mentioned the same behaviour?
Jango
Re: Domoticz app 2.0
Post by Jango »
Works fine over here ;)
Verstuurd vanaf mijn E5823 met Tapatalk
bvduijv
Post by bvduijv »
Only Setpoint is still not working :-( Currently not using due to summer temperatures but still..
Brutus
Post by Brutus »
Just want to say WOW on the latest update. The Speech recognition works super great (dutch)! Maybe in the future we can also send commands to groups/scenes? Or attach multiple switches to one speech command?
Keep up the great work, this app is a nice addition to the already nice Domoticz platform!
Greetings Brutus
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
ftsikogi
Post by ftsikogi »
Regarding my previous post i found that this unstable behavior was due to an event that got triggered repeatedly. As a result the logs of one of my devices got huge and could not be opened. I fixed that and everything is normal again. The application is great , i have also tested the speech recognition and it works!. Only downside is that still i cannot make nfc to work. I can register a new tag, assign a switch but when i scan it , android opens google play and try to find an older application that i used to have installed.
Domoticz does not open or execute any command.
Beside that everything else is perfect!
RoadXY
Domoticz version: 2.2331
Post by RoadXY »
ftsikogi wrote:Only downside is that still i cannot make nfc to work. I can register a new tag, assign a switch but when i scan it , android opens google play and try to find an older application that i used to have installed.
I think that the issue is not with the Domoticz app, I'm afraid.
You could check the app associations of the one being opened?
http://forums.androidcentral.com/lg-g2/ ... tions.html
galadril
Domoticz version: latest
Post by galadril »
ftsikogi wrote:Regarding my previous post i found that this unstable behavior was due to an event that got triggered repeatedly. As a result the logs of one of my devices got huge and could not be opened. I fixed that and everything is normal again. The application is great , i have also tested the speech recognition and it works!. Only downside is that still i cannot make nfc to work. I can register a new tag, assign a switch but when i scan it , android opens google play and try to find an older application that i used to have installed.
Please write the next text / url to the nfc tag:
http://www.domoticz.com/app
We've implemented this filter so calls for domoticz get redirected to the domoticz app right away without dialog..
ftsikogi
Post by ftsikogi »
That was it. After writing the url to the nfc tag it works fine!. Thanks for the valuable tip!
EdwinDaems
Post by EdwinDaems »
Jordyboytjuh wrote:I've a problem with the app that my battery is drain very fast. I've deleted it temporally now, and my battery stays the same. Is this a known problem by you guys? I've also a question about the blinds. It sends a stop command only even when I push the up or down button. I want to send an on / off signal. Keep up the good work!
If Domoticz can't connect to the server for whatever reason, the battery will drain very fast.
25% in an hour or so.
jannl
Domoticz version: 2025.5.x
Post by jannl »
No problem here with battery drain
jompie
Domoticz version: 3.5877
Post by jompie »
Thanks for the app. I've got a question, I think it is a bug. I've turned on the speech recognition, but when I want to assign a switch to the command, only the first 6 switches (alphabetical order) are displayed although I have a lot more switches. It is not possible to scroll in the list of switches to assign speech command.
I'm running domoticz app 0.1.266(142) on android 4.2
How can I enable more switches with speech recognition
KAKU switches/receivers/Motion sensor/Doorbell
Oregon Temp sensors, TFA Temp sensor
Mertik controller
Raspberry Pi, RFXCom
pluggin
Post by pluggin »
Great apps!!!!
There is a way to use voice recognition without touching the microphone button??
Just saying something like "Hello home" and then the desired command? This way you don´t need to have the device (phone or tablet) with you just near you.
Razberry + 4 Eversrping HSM02 + 2 Aeotec Multi-Sensor + 1 Aeotec Micro Dimmer + 4 Aeotec Micro Smart Energy Switch, 2nd + 1 Remotec ZXT-120 + 1 Aeotec Smart Energy Monitor + 1 Everspring SE812 indoor Siren + 2 fibaro motion sensor + Aeotec water sensor
fransiefrans
Domoticz version: stable
Post by fransiefrans »
I'm also experiencing the battery to go very fast. I thought it was because of the use of geofence and nfc. But with both disabled and not using the app it's still responsible for 35% of my battery usage. How can I solve this?
piokuc
Post by piokuc »
I found bug in app. I have in Domoticz set for some switches to protect it by password. When in app i click on this switch and before click has status off , it prompt me for password. But when i no type password and click Cancel on button scroll toogle show that switch is on but status is still off. After refresh toogle again back to show as off. For me it is bug.
Wysłane z mojego Galaxy S6 za pomocą Tapatalk
galadril
Post by galadril »
pluggin wrote:There is a way to use voice recognition without touching the microphone button??
There is a speech recognition widget available
galadril
Post by galadril »
piokuc wrote: But when i no type password and click Cancel on button scroll toogle show that switch is on but status is still off. After refresh toogle again back to show as off. For me it is bug.
Thanks, well look into this
galadril
Post by galadril »
Well look into the battery issues!
RayAmsterdam
Post by RayAmsterdam »
jannl wrote:Hm, for now geofencing does not seem to work at all from de domoticz app
Only when I go into the settings the switch is being updated. Am I missing a setting somewhere?
I have the same issue. Only when I open the Gefence settings the switch is turned on. After leaving the menu the switch is turned off after a couple of minutes. I set the radius at 500m.
abductor
Post by abductor »
Huge upgrade today!
Anyone else have the problem where they can't install it on their Amazon Fire tablet? It says in the play store its not compatible with this version :(
The tablet is running 5.x Android, and previous Domoticz app installed fine...
galadril
Post by galadril »
abductor wrote:Anyone else have the problem where they can't install it on their Amazon Fire tablet? It says in the play store its not compatible with this version :(
That's weird! Can you also see why in the Play Store?
http://lifehacker.com/google-play-shows ... -496328577
