[MyDomoAtHome] Support thread
mcwieger
Domoticz version: 2020.1
Re: [MyDomoAtHome] Support thread
Post by mcwieger »
I still have nightly crashes, which is getting annoying. I checked usage.log and see the following:
{"level":"info","message":"Refreshing version cache: v0.2.39","timestamp":"2020-02-09T14:40:48.501Z"}
{"level":"info","message":"Domoticz server: http://127.0.0.1:8084/json.htm","timestamp":"2020-05-27T12:57:03.723Z"}
{"level":"info","message":"Node version: 12.14.0","timestamp":"2020-05-27T12:57:03.816Z"}
{"level":"info","message":"MDAH version: MyDomoAtHome 0.2.39","timestamp":"2020-05-27T12:57:03.816Z"}
{"level":"info","message":"OS version: Linux linux 3.2.40","timestamp":"2020-05-27T12:57:03.818Z"}
{"level":"info","message":"Hostname: NAS 192.168.2.201 in /root /root","timestamp":"2020-05-27T12:57:03.874Z"}
{"level":"info","message":"Refreshing version cache: v0.2.41","timestamp":"2020-05-27T12:57:06.694Z"}
{"level":"info","message":"Domoticz server: http://127.0.0.1:8084/json.htm","timestamp":"2020-05-28T07:18:22.463Z"}
{"level":"info","message":"Node version: 12.14.0","timestamp":"2020-05-28T07:18:23.993Z"}
{"level":"info","message":"MDAH version: MyDomoAtHome 0.2.39","timestamp":"2020-05-28T07:18:23.994Z"}
{"level":"info","message":"OS version: Linux linux 3.2.40","timestamp":"2020-05-28T07:18:23.996Z"}
{"level":"info","message":"Hostname: NAS 192.168.125.1 in /root /root","timestamp":"2020-05-28T07:18:24.108Z"}
Two things I notice:
- Hostname: NAS 192.168.125.1: this is from my address range I configured for OpenVPN and is the starting IP address that's assigned when connecting to my Synology via VPN. Why is it appearing in the MDAH log? I haven't used VPN to connect to MDAH or even Domoticz recently.
- Version cache says v0.2.41 while I'm on version 0.2.39. How did this happen?
I moved to HomeAssistant. It was fun while it lasted!
teo1966
Domoticz version: 2025.1
Post by teo1966 »
this version node-mydomoathome-0.2.42 dont start on my ds916+
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
Sopalin
Post by Sopalin »
I'm currently migrating to Archlinux and i was wondering if MyDomoAtHome will work on this OS.
Thanks.
epierre
Post by epierre »
yes this is pure nodejs.
IP is the one answered by the OS, fon't know if multiple is well managed.
Cache version is the latest available based on github
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
Micha
Post by Micha »
Happy new year,
I'm trying to install mydomoathome and I'm getting following:
pi@raspberrypi:~ $ wget -qO - http://www.e-nef.com/domoticz/mdah/gpg.mykey | sudo apt-key add -
OK
pi@raspberrypi:~ $ sudo apt-get update
Ign:1 http://www.e-nef.com/domoticz/mdah InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Err:3 http://www.e-nef.com/domoticz/mdah Release
404 Not Found [IP: 164.132.235.17 80]
Hit:4 http://archive.raspberrypi.org/debian buster InRelease
Reading package lists... Done
E: The repository 'http://www.e-nef.com/domoticz/mdah Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Does anybody have an idea? I tried with http and https
Kind Regards
epierre
Post by epierre »
try this instead:
deb https://www.e-nef.com/domoticz/mdah/ buster contrib
Knight
Domoticz version: 2024.7
Post by Knight »
Hello, i need support with a new install. I have installed Bulleseye on a new Rasp 4 with the newest domoticz
When i try to install MyDomoAtHome a get this problem.
I get this error "MyDomoAtHome not found" when i type sudo apt-get install MyDomoAtHome
pi@raspberrypi:~ $ sudo apt-get install MyDomoAtHome
Läser paketlistor… Färdig
Bygger beroendeträd… Färdig
Läser tillståndsinformation… Färdig
E: Kunde inte hitta paketet MyDomoAtHome
I also tried to install by download the package but I can't find the execute command to install it,
Open Terminal
Extract the .tar.gz or (.tar.bz2) file with the following commands
tar xvzf MyDomoAtHome-0.2.45.tar.gz
Navigate to the extracted folder using cd command
cd MyDomoAtHome-0.2.45
Now run the following command to install the tarball
./configure (When i type this i get error "File not found" )
make
sudo make install
Can someone help me?
epierre
Post by epierre »
if you have the .deb in local it is :
sudo dpkg -i MyDomoAtHome-xxxxx.deb
Knight
Post by Knight »
epierre wrote: Monday 24 January 2022 17:44 if you have the .deb in local it is :
Where can i download MyDomoAtHome-xxxxx.deb ?
I only found these https://github.com/empierre/MyDomoAtHom ... ag/v0.2.45
Thank you !
epierre
Post by epierre »
Knight
Post by Knight »
I Found where the Deb files are
http://e-nef.com/domoticz/mdah/dists/bu ... ary-armhf/
But when I run "sudo dpkg -i node-mydomoathome-0.2.45.deb"
pi@raspberrypi:~ $ sudo dpkg -i node-mydomoathome-0.2.45.deb
(Läser databasen ... 103577 filer och kataloger installerade.)
Förbereder att packa upp node-mydomoathome-0.2.45.deb ...
dpkg: fel vid hantering av arkivet node-mydomoathome-0.2.45.deb (--install):
conffile name 'etc/mydomoathome/config.json' is not an absolute pathname
Fel uppstod vid hantering:
epierre
Post by epierre »
hmmm...surprising, try this one (should be the same cannot test it...)
https://www.e-nef.com/domoticz/mdah/dis ... ary-armhf/
Knight
Post by Knight »
Can it be a problem with "bullseye"? with rasp 4 ( I have a Rasp2 with working mydomoathome)
I have problem with the first steps.
nodejs is already the newest version (12.22.5~dfsg-2~11u1).
(Updated)
manage to update to nodejs 14.18.3-deb-1nodesource1
same problem :cry:
epierre
Post by epierre »
I would have to install a pi with it to check...
Knight
Post by Knight »
Im stuck. I broke the OS so i have to reinstall the Debian Bullseye
I really want it to work..
I have found a solution "work around" with ImperieHome
Download it from https://oceanofapk.com/imperihome-smart ... -download/
and restore an old backup then you are in :D
Knight
Post by Knight »
epierre wrote: Monday 24 January 2022 19:11 I would have to install a pi with it to check...
Hello, did you get it to work? :?
Knight
Post by Knight »
I think there's a compatibility issue with debian bullseye. I have installed a new fresh version of bullesyes with desktop. You can install .deb files directly on the desktop. However, the operating system does not approve this .deb file and I get an error message.
I will try to install the deb file on a fresh iso "buster with desktop"
Knight
Post by Knight »
It works flawlessly to install it on a newly installed version of Buster.
Code
sudo apt update
sudo apt upgrade
sudo apt install nodejs npm
Installs the latest versions of both nodejs and nom
then download mydomoathome
wget http://www.e-nef.com/domoticz/mdah/node-mydomoathome-latest.deb
install domoathome
sudo dpkg -i node-mydomoathome-latest.deb
Bulleyes.... no luck there. Error "conffile name 'etc/mydomoathome/config.json' is not an absolute pathname"
empierre, if you have time over. I can place a donation true paypal
epierre
Post by epierre »
can try testing it, writing the sdcard on a pi 3.
Are you running a lite or with ui and recommended ?
epierre
Post by epierre »
For Debian 11/Bullseye here is the procedure
curl -fsSL https://deb.nodesource.com/setup_12.x | sudo -E bash -
sudo apt-get install -y nodejs
wget https://www.e-nef.com/domoticz/mdah/dis ... 0.2.49.deb
sudo dpkg -i node-mydomoathome-0.2.49.deb
