Page 6 of 32
Re: Testers wanted!
Posted: Saturday 23 January 2016 21:40
by chimit
sclk34 wrote:Hello!
I'm a novice. And I did not understand the information from Wikipedia about my.domoticz.com.
I share the instance, but how to use it ? How to see the Web Interface of domoticz server?
You can see it after you log in at
https://my.domoticz.com/.
Re: Testers wanted!
Posted: Saturday 23 January 2016 22:08
by sclk34
All that I can see on this site (see the attachment). how can I go to my devices?
Re: Testers wanted!
Posted: Saturday 23 January 2016 22:13
by chimit
sclk34 wrote:All that I can see on this site (see the attachment)
You can click on the green icon and you will have access to your Domoticz.
Something to include on the Wiki pages.
Re: Testers wanted!
Posted: Saturday 23 January 2016 22:16
by sclk34
chimit wrote:sclk34 wrote:All that I can see on this site (see the attachment)
Its work))) but it is not obvious. Thank you!
Re: Testers wanted!
Posted: Sunday 24 January 2016 11:47
by JC38
To solve this: Check the "Shared Domoticz Allowed" checkbox on the slave instance.
It is checked (on the slave) so I've unchecked and checked it again. Still the same error :
2016-01-24 11:43:07.299 Error: PROXY: Shared Server access disallowed, denying receive data request.
Re: Testers wanted!
Posted: Sunday 24 January 2016 12:00
by JC38
chimit wrote:Does this occur when you have two Domoticz's in your roster (dashboard)? I've seen this before, when one (or both) use the login page.
The cookie path is set wrong in Domoticz for use with MyDomoticz. I will try to submit a patch soon. Meanwhile, trying one or two times more helps for me in such a case.
I have four Dz into the dashboard. I will check again at the next update.
As you can see
https://github.com/domoticz/domoticz/commits/master, some changes had been published for the update feature 2 days ago.
Re: Testers wanted!
Posted: Sunday 24 January 2016 12:23
by chimit
JC38 wrote:To solve this: Check the "Shared Domoticz Allowed" checkbox on the slave instance.
Even though master/slave communication via MyDomoticz is (very) experimental, it should work.
I assume you get this error on the slave, right? Maybe the checkbox on the UI doesn't work anymore since a change from another contributor. Need to check when I get the time.
Re: Testers wanted!
Posted: Sunday 24 January 2016 12:29
by chimit
As requested, I am giving an update about a new update of the MyDomoticz service.
Angular is now used to render your roster (dashboard) and many other things have changed internally.
The update was not supposed be deployed online yet. But since there was a casual bug in the current version that made the service seem to stop working, I decided in favor of this step.
Please continue to report bugs and also please allow for some time to get a response from me due to a busy schedule.
== Rene
EDIT: I reverted to the previous version again due to some persistent problem unknown. Will update later.
Re: Testers wanted!
Posted: Sunday 24 January 2016 16:22
by JC38
René, maybe a simple way to keep us informed of a new version would be to add something in the login page below the actual footer
Note: This is a beta service and not meant for production use. Use at your own risk.
For a description, see the Domoticz Wiki.
By using this page, you agree to our Terms & Conditions.
Compiled on yyyy/mm/dd
MyDomoticz service is online for xxxx
Adding date + time of your latest compilation would be nice and also the duration since the last start of your service.("Online for" like you do with the clients)
Re: Testers wanted!
Posted: Sunday 24 January 2016 17:27
by chimit
JC38 wrote:René, maybe a simple way to keep us informed of a new version would be to add something in the login page below the actual footer
Nice idea. We already have the online time on our admin pages. Will put it on the list as well.
Re: Testers wanted!
Posted: Monday 25 January 2016 16:02
by erik4281
I made a mistake myself. I was running 2 Raspberry Pi's with a copy of the Domoticz database at the same time. This also means the Instance ID, API and password were the same. I guess there might have been some conflicts on the MyDomoticz service because of this.
I actually needed only one of them to connect to the MyDomoticz service. Now I removed the MyDomoticz settings in Domoticz on the second Pi, but I still cannot connect.
The MyDomoticz website says my Domoticz has been online for almost 21 hours, but if I connect (click the green icon), an empty page shows up. If I check the logging in Domoticz I see the following message: "Error: PROXY: Connect failed, reconnecting: Connection refused". I get this message every 10 seconds.
If I switch om MyDomoticz on the second Pi, I get the following message: "Error: PROXY: Connect failed, reconnecting: Network is unreachable".
How can I fix this? Or is this an actual bug and something I cannot fix myself?
Re: Testers wanted!
Posted: Monday 25 January 2016 19:31
by ukwebfx
I would like to use my domoticz, I have just in the last week build an automation system to control my lights and have created an account on my domotica, but I am having problems and i have noticed on the wiki that i need to ask chimit if I can be added to the alpa testing, I am unable to pm chimit as I have only just created my account on here as have not needed to ask for help up until now and pm are unavailble to me. thanks in advance.
ps, i love domoticz its brilliant and allows me so much flexibility
thanks
Re: Testers wanted!
Posted: Wednesday 27 January 2016 9:17
by michaldobrotka
Hi Guys,
I know that my.domoticz is Beta, but since 22.1. I cant connect to this service. Yesterday I made new account but same result - "my green Buddy" is still red! Its general problem or its in my Beta version of Domoticz?
PS:
Its my favorite feature for Domoticz, I love it, great job!
Thanks for help.
Re: Testers wanted!
Posted: Wednesday 27 January 2016 9:31
by Varazir
michaldobrotka wrote:Hi Guys,
PS:
Thanks for help.
Any error on your Domoticz ? Could sometime help to disable/enable the service on Domoticz.
Skickat från min Nexus 5 via Tapatalk
Re: Testers wanted!
Posted: Wednesday 27 January 2016 16:45
by michaldobrotka
Thanks man!
Its working now.
Re: Testers wanted!
Posted: Wednesday 27 January 2016 22:07
by raym
Hi guys. I'm just wondering if it will be possible to route ImperiHome app users via this service to the MDAH gateway? If anyone has done it already, I'd appreciate the steps needed to set this up.
http://domoticz.com/wiki/ImperiHome
Re: Testers wanted!
Posted: Wednesday 27 January 2016 22:09
by Varazir
raym wrote:Hi guys. I'm just wondering if it will be possible to route ImperiHome app users via this service to the MDAH gateway? If anyone has done it already, I'd appreciate the steps needed to set this up.
As they say, apps isn't supported yet.
Re: Testers wanted!
Posted: Wednesday 27 January 2016 22:10
by raym
Varazir wrote:raym wrote:Hi guys. I'm just wondering if it will be possible to route ImperiHome app users via this service to the MDAH gateway? If anyone has done it already, I'd appreciate the steps needed to set this up.
Oh sorry. Ok, thanks.
Re: Testers wanted!
Posted: Wednesday 27 January 2016 22:11
by Varazir
raym wrote:Varazir wrote:raym wrote:Hi guys. I'm just wondering if it will be possible to route ImperiHome app users via this service to the MDAH gateway? If anyone has done it already, I'd appreciate the steps needed to set this up.
Just keep a eye up.
Re: Testers wanted!
Posted: Sunday 31 January 2016 12:58
by chimit
To keep you updated a bit: Meanwhile I find time for a newer update, I put online just some fixes that prevents the web server part from responding at certain times.
It will be active after the next restart. I will be monitoring, so I can revert back in case of anomalies.
== Rene
