How do I import it manually? I've the issue with 2 FGD212 in combination with "Halogeenlampen". After I replaced the old-fashion "gloeilampen" for the "halogeenlampen" the flickering occurs except while on 100%.YcKe wrote:
I've added parameter 38 to the config file at the OpenZwave GitHub.
You can track this pull request to check the merge status: https://github.com/OpenZWave/open-zwave ... f1725866f6
Note that the Domoticz team merges the OpenZwave sources manually on a regular basis so it might not be available immediately in Domoticz. You can always import it manually.
Enjoy.
Greetz YcKe
Fibaro Dimmer 2 FGD-212 supported? New type!
- htilburgs
Re: Fibaro Dimmer 2 FGD-212 supported? New type!
Hardware:
- htilburgs
Somebody? Im using Domoticz v3.5877. In the \domoticz\config\fibaro\fgd212.xml I can see parameter 38, but within Domoticz Settings - Hardware I'm missing parameter 38. It goes from 37 to 39....
How can I update Domoticz so that I've parameter 38 in Domoticz available??
Hardware:
Nederveen
Hi, how can I add my fibaro dimmer 2 to homebridge without Home center? I use a raspberry pi, z-stick.
The dimmer works fine in the domoticz page, but it will not show as an accessory in homekit-homebridge.
Rolfie
In Domoticz settngs you can set the release channel for updates to beta, this will give you the latest beta updates. Not sure if this will give you parameter 38. Also be aware that beta versions are called beta versions for a reason, things could not work 100%.htilburgs wrote:Somebody? Im using Domoticz v3.5877. In the \domoticz\config\fibaro\fgd212.xml I can see parameter 38, but within Domoticz Settings - Hardware I'm missing parameter 38. It goes from 37 to 39....
- htilburgs
Rolfie, to add parameter 38 you have to exclude the dimmer from Domoticz / ZWave and then include it again.Rolfie wrote:In Domoticz settngs you can set the release channel for updates to beta, this will give you the latest beta updates. Not sure if this will give you parameter 38. Also be aware that beta versions are called beta versions for a reason, things could not work 100%.htilburgs wrote:Somebody? Im using Domoticz v3.5877. In the \domoticz\config\fibaro\fgd212.xml I can see parameter 38, but within Domoticz Settings - Hardware I'm missing parameter 38. It goes from 37 to 39....
Then you get parameter 38.
But..... the flickering still exists. I'm currently playing with the settings, but no result.
Hardware:
