Page 6 of 30
Re: dtgbot - Domoticz TeleGram BOT
Posted: Sunday 23 August 2015 20:28
by Slayer007
The TelegramBotOffset. I changed the current value +1 as it says in the wiki. That worked for me.
Another thing, that (i think) is very nice. I implemented the custom keyboard to respons to telegram. I'm a rookie in scripting and get everything off the internet. I now place an extra line for the custom keyboard at the end of every bash script I make. Maybe it can be done in lua, so you get standaard a coupe of buttons to push. You don't need to type anymore. Just hit the button. I'll post a screenshot later on.
Posted: Sunday 23 August 2015 21:53
by simonrg
Slayer007 wrote:The TelegramBotOffset. I changed the current value +1 as it says in the wiki. That worked for me.
Strange the error you were showing was due to Domoticz replying "not authorized" so by adding one to the offset you have skipped the command that caused the problem, but if do the same command again you should see the same error.
Jvdz (and I) is (are) In the process of implementing custom keyboards in dtgbot, it is in the menus branch of dtgbot on github, but not yet ready for mass consumption, as you say very neat, just trying to automate it and make it possible for others to use. Hope to have it on the wiki soon, why don't you document your approach on the wiki too, (if you haven't already).
Posted: Monday 24 August 2015 12:29
by Slayer007
Here a little example from my custom keyboard. This is a code in bash I put at the end of every bash script. The "id=" extract the username who asked for a command. So it says: How can I help you, user?
id=`curl --data 'chat_id='$SendMsgTo --data-urlencode 'text='"$ResultString" 'https://api.telegram.org/bot'$TelegramBotToken'/sendMessage'| grep -Po ',"chat":{"id":.*,"first_name":"\K.*?(?=")'`
sleep 1
curl --data 'chat_id='$SendMsgTo --data-urlencode 'reply_markup= {"keyboard":[["Coffee "],["Meterstanden"],[" Lights On "]]}' --data-urlencode 'text='"How can I help you, user_name"? 'https://api.telegram.org/bot'$TelegramBotToken'/sendMessage'
In the screenshot you see how it looks like.
Posted: Monday 24 August 2015 19:22
by jvdz
Let me share a "teaser" on what Simon and I have been working on in the last couple of weeks.
Please remember that this is still work in progress as we are also trying to make this as dynamic as possible to fit everybody's needs without too much manual config effort.
Base approach we have taken at this moment for dtgmenu's logic:
  • Read all Rooms from domoticz and make that the level 1 menu. (image 1)
  • Read all devices/scenes in the room and show them as buttons with their current status (image 2)
  • When you select a device, a 3rd level menu is shown at the top which gives you the pre-defined actions for the device type (image 2 middle/right)
  • Currently supports "Lighting 2" => Switch (On/Off) and Dimmers (On/Off and pre-defines levels) but also ? for a manual option to specify the level.
  • Also the option to just show the weather/ temperature info on a menu with buttons.(image 3)
  • Static options: This will allow for any bash/lua commands to start them via the menu with also the option to prompt for a parameter before running that command.
  • It does also have language support so the below Dutch standard replies will be available in any language we define and we plan to use the Domoticz settings as the language to use.
Stay tuned,
Jos
Image 1
Image 1
Image 2
Image 2
Image 3: Weather information
Posted: Monday 24 August 2015 19:28
by G3rard
That looks great! I hope this can be shared soon.
Posted: Monday 24 August 2015 22:37
by Slayer007
Looks really great. Can't wait to implement this. Keep up the good work!
Can anyone help me. I have a little bit problems with the command. I have multiple bash-scripts, for example:
meter.sh
system.sh
morning.sh
room.sh
living_room.sh
When I send a textmessage to my bot, for example "m", it executes all scripts.
When I send a message "ro", then it execute's morning.sh and room.sh. And when I send "em" it executes meter/system.sh.
The same with "room". Sending a message "room" will execute both scripts with room in it.
Is there anyway to send a message wich only executes the exact match? Or can I make my own commands? For example: When I send a message "Sunny", it will execute system.sh?
I'm trying to understand the script, but I can't really see what I have to adapt?
(and can you please send an example of your lua-script that handles the custom keyboard, so I already can play with it?)
Posted: Thursday 27 August 2015 21:47
by simonrg
Slayer007 wrote:When I send a textmessage to my bot, for example "m", it executes all scripts.
Messages should only be executing with exact match ignoring case, it looks like you might have something funny with the prefix character, have you set it for your bot on Telegram?
Below is an example function from @jvdz of a Lua function which uses a custom keyboard within Lua, using curl to do the https communications.
The function will send a message to one or both of the people based on names with the given user codes.
— Send Telegram Bot message
— sendid can be a send2userx name or their id and also be send2both to send to both telegram accounts
— the function will also minimise the Keyboard to just the Menu button
function TelegramMsg(sendto,message)
 token = "yourbottoken"
 usercode1 = 12343567
 usercode2 = 12345678
  send2both = "both"
  send2user1 = "Henk"
  send2user2 = "Greta"
 reply_markup = '--data-urlencode \"reply_markup={\\\"keyboard\\\":[[\\\"menu\\\"]],\\\"resize_keyboard\\\":true}\"'
 if (sendto == 'Both' or sendto == send2user1 or sendto == usercode1) then
  os.execute('curl —data chat_id='..usercode1.. ' —data-urlencode "text='..message..'" '..reply_markup..' "https://api.telegram.org/bot'..token..'/sendMessage" ')
 if (sendto == 'Both' or sendto == send2user2 or sendto == usercode2) then
  os.execute('curl —data chat_id='..usercode2..' —data-urlencode "text='..message..'" '..reply_markup..' "https://api.telegram.org/bot'..token..'/sendMessage" ')
Posted: Thursday 27 August 2015 22:20
by jvdz
This is an updated version which will only send the reply_markup when the dtgmenu is enabled.
Cheers
Jos
-- Send Telegram Bot message
-- sendid can be a send2userx name or their id and also be send2both to send to both telegram accounts
-- the function will also minimise the Keyboard to just the Menu button
  send2both = "both"
  send2user1 = "Henk"
  reply_markup = ""
  -- Check whether the dtgmenu is switched on and only then send the reply_markup
  if uservariables['TelegramBotMenu'] == "On" then
  -- check and send to user1
  if (sendto == send2both or sendto == send2user1 or sendto == usercode1) then
  -- check and send to user2
  if (sendto == send2both or sendto == send2user2 or sendto == usercode2) then
Posted: Tuesday 08 September 2015 14:28
by rjnl
I've installed the bot according to the latest wiki. However I am getting the following error when starting the service:
domoticz@domoticz:/var/tmp$ cat dtb.log.errors
/usr/bin/lua5.2: error loading module 'socket.core' from file '/usr/local/lib/lua/5.2/socket/core.so':
	/usr/local/lib/lua/5.2/socket/core.so: [b]wrong ELF class: ELFCLASS32[/b]
stack traceback:
	[C]: in ?
	[C]: in function 'require'
	/usr/local/share/lua/5.2/socket.lua:12: in main chunk
	/usr/local/share/lua/5.2/socket/http.lua:10: in main chunk
	/home/domoticz/dtgbot/dtgbot.lua:92: in main chunk
	[C]: in ?
Edit: Fixed by manually compiling and installing luasocket, luasec, luajson so they are 64-bit compatible. Now however, I get this error, for which i have no idea what to do :) Seems to me like a bug in lua-json...
/usr/bin/lua5.2: /usr/local/share/lua/5.2/json/util.lua:55: bad argument #1 to 'pairs' (table expected, got string)
stack traceback:
	[C]: in function 'pairs'
	/usr/local/share/lua/5.2/json/util.lua:55: in function </usr/local/share/lua/5.2/json/util.lua:50>
	(...tail calls...)
	/usr/local/share/lua/5.2/json/decode.lua:108: in function </usr/local/share/lua/5.2/json/decode.lua:107>
	(...tail calls...)
	/usr/local/share/lua/5.2/json/decode.lua:157: in function </usr/local/share/lua/5.2/json/decode.lua:156>
	(...tail calls...)
	/home/domoticz/dtgbot//dtg_domoticz.lua:40: in function 'variable_list'
	/home/domoticz/dtgbot//dtg_domoticz.lua:47: in function 'variable_list_names_idxs'
	/home/domoticz/dtgbot/dtgbot.lua:172: in function 'dtgbot_initialise'
	/home/domoticz/dtgbot/dtgbot.lua:229: in main chunk
	[C]: in ?
Posted: Wednesday 16 September 2015 14:22
by savage007
how can i control Domoticz from an url? When i send a message through https://api.telegram.org/bot11111111:BB ... 78&text=0N 2
Domoticz doesnt respond, it looks like dtgbot doesnt listen to the messages that are sent throug the bots account instead of my own.
Posted: Wednesday 16 September 2015 22:16
by jvdz
Won't you create an endless message loop when you send a message to the Bot account from the Bot Account as DTGBOT will reply with a success/failure message, and how would you know whether or not it was successful?
Jos
Posted: Saturday 19 September 2015 8:06
by savage007
Is it possible to send a message from a url/http request as the user instead of the bot?
Posted: Saturday 19 September 2015 10:49
by simonrg
savage007 wrote:Hi,
I guess you would need to create another Bot and then send the message from there to common group chat.
If you think about it there is no way for the bot to know whether Domoticz sent the bot message or another instance of the bot sent the message.
Posted: Saturday 19 September 2015 17:26
by jvdz
savage007 wrote:Is it possible to send a message from a url/http request as the user instead of the bot?
I am not sure what the exact underlying goal is of your question, but in general I would say JSON is the way to go for URL links to change devices in Domoticz.
Sending an telegram message via an URL feels more like a workaround for something that is already available directly, but maybe you can share the scenario you are thinking of?
Jos
Posted: Monday 28 September 2015 23:42
by mschut
I feel stupid, but I followed the complet wiki (at least I think I did), but it isn't working YET.
The log dtg.log shows
2015-09-28 23:34:21 - DomoticzIP: X.X.X.X
2015-09-28 23:34:21 - DomoticzPort: 8080
2015-09-28 23:34:21 - BotHomePath: /home/pi/dtgbot/
2015-09-28 23:34:21 - BotLuaScriptPath: /home/pi/dtgbot/lua/
2015-09-28 23:34:21 - BotBashScriptPath: /home/pi/dtgbot/bash/
2015-09-28 23:34:21 - TelegramBotToken: 11111111:KEYKEYKEYKEYKEYKEY
2015-09-28 23:34:21 - TelegramBotOffset: TelegramBotOffset
2015-09-28 23:34:21 - -----------------------------------------
2015-09-28 23:34:21 - Starting Telegram api Bot message handler
The log dtg.log.errors says:
/usr/bin/lua5.2: /home/pi/dtgbot/dtgbot.lua:92: module 'socket.http' not found:
        no field package.preload['socket.http']
        no file '/usr/local/share/lua/5.2/socket/http.lua'
        no file '/usr/local/share/lua/5.2/socket/http/init.lua'
        no file '/usr/local/lib/lua/5.2/socket/http.lua'
        no file '/usr/local/lib/lua/5.2/socket/http/init.lua'
        no file './socket/http.lua'
        no file '/usr/share/lua/5.2/socket/http.lua'
        no file '/usr/share/lua/5.2/socket/http/init.lua'
        no file '/usr/local/lib/lua/5.2/socket/http.so'
        no file '/usr/lib/arm-linux-gnueabihf/lua/5.2/socket/http.so'
        no file '/usr/lib/lua/5.2/socket/http.so'
        no file '/usr/local/lib/lua/5.2/loadall.so'
        no file './socket/http.so'
        no file '/usr/local/lib/lua/5.2/socket.so'
        no file '/usr/lib/arm-linux-gnueabihf/lua/5.2/socket.so'
        no file '/usr/lib/lua/5.2/socket.so'
        no file './socket.so'
stack traceback:
        /home/pi/dtgbot/dtgbot.lua:92: in main chunk
        [C]: in ?
My bet: my lua 5.2 is not complete? Is there some easy way to fix this?
Posted: Tuesday 29 September 2015 0:13
by simonrg
mschut wrote:My bet: my lua 5.2 is not complete? Is there some easy way to fix this?
Installation is not plug and play and all of it has to work for any of it to work.
Looks like you haven't got the Lua libraries installed correctly, repeat this part of the wiki instructions, and that should fix it:
http://www.domoticz.com/wiki/Remote_Con ... _Libraries
Posted: Tuesday 29 September 2015 7:17
by mschut
Wow, thanks. So simple, now it's working like a charm!
Posted: Monday 19 October 2015 12:55
by satanasinc
Hi!
First of all. excuse my bad english. :oops:
After install Telegrambot i cant start the service.
I cant find where is the problem. Anybody can help me please?. :?
Here is my log file.
dtb.log.errors
/usr/bin/lua5.2: /usr/local/share/lua/5.2/JSON.lua:383: html passed to JSON:decode(): <html><head><title>Bad Request</title></head><body><h1>400 Bad Request</h1></body></html>
stack traceback:
[C]: in function 'assert'
/usr/local/share/lua/5.2/JSON.lua:383: in function 'onDecodeOfHTMLError'
/usr/local/share/lua/5.2/JSON.lua:655: in function 'decode'
/home/pi/dtgbot//dtg_domoticz.lua:113: in function 'device_list'
/home/pi/dtgbot/lua//dtgmenu.lua:407: in function 'MakeRoomMenus'
/home/pi/dtgbot/lua//dtgmenu.lua:382: in function 'PopulateMenuTab'
/home/pi/dtgbot/dtgbot.lua:210: in function 'dtgbot_initialise'
/home/pi/dtgbot/dtgbot.lua:229: in main chunk
[C]: in ?
and dtb.log
2015-10-19 12:45:28 - DomoticzIP: 192.168.X.XXXX
2015-10-19 12:45:28 - DomoticzPort: 8080
2015-10-19 12:45:28 - BotHomePath: /home/pi/dtgbot/
2015-10-19 12:45:28 - BotLuaScriptPath: /home/pi/dtgbot/lua/
2015-10-19 12:45:28 - BotBashScriptPath: /home/pi/dtgbot/bash/
2015-10-19 12:45:28 - TelegramBotToken: 123456789:XXXXXXXXXXXXXXXXXXXXXXXXXX
2015-10-19 12:45:28 - TelegramBotOffset: 1
2015-10-19 12:45:28 - -----------------------------------------
2015-10-19 12:45:28 - Starting Telegram api Bot message handler
2015-10-19 12:45:28 - Domoticz returned getuservariables after 1 attempts
2015-10-19 12:45:29 - dtgbotLogLevel set to: 0
2015-10-19 12:45:29 - Loading command modules...
2015-10-19 12:45:29 - Loading module <utility>
2015-10-19 12:45:29 - found command <refresh>
2015-10-19 12:45:29 - Loading module <dtgmenu>
2015-10-19 12:45:29 - define LastCommand
2015-10-19 12:45:29 - Domoticz language is not available for dtgmenus
2015-10-19 12:45:29 - found command <dtgmenu>
2015-10-19 12:45:29 - Loading module <list>
2015-10-19 12:45:29 - found command <list>
2015-10-19 12:45:29 - found command <dump>
2015-10-19 12:45:29 - Loading module <devices>
2015-10-19 12:45:29 - found command <devices>
2015-10-19 12:45:29 - found command <scenes>
2015-10-19 12:45:29 - Loading module <flick>
2015-10-19 12:45:29 - found command <flick>
2015-10-19 12:45:29 - Loading module <nflick>
2015-10-19 12:45:29 - found command <nflick>
2015-10-19 12:45:29 - Loading module <on>
2015-10-19 12:45:29 - found command <on>
2015-10-19 12:45:29 - found command <off>
2015-10-19 12:45:29 - Loading module <battery>
2015-10-19 12:45:29 - found command <batteries>
2015-10-19 12:45:29 - found command <battery>
2015-10-19 12:45:29 - Loading module <help>
2015-10-19 12:45:29 - found command <start>
2015-10-19 12:45:29 - found command <help>
2015-10-19 12:45:29 - Loading module <temperature>
2015-10-19 12:45:29 - found command <tempall>
2015-10-19 12:45:29 - found command <temperature>
2015-10-19 12:45:29 - found command <temperatures>
2015-10-19 12:45:29 - Decoded On
IP and telegramtoken cchanged.
Thanx and greeting from spain.
satanasinc
Posted: Monday 19 October 2015 18:20
by jvdz
It seems there is an issue retrieving the Room information for the defined rooms in Domoticz.
How many rooms do you have defined?
Could you :
  • create the uservariable: TelegramBotLoglevel as Integer
  • Set TelegramBotLoglevel to: 1
  • Start dtgbot and post the logs again as that should now show more details.
Jos
Posted: Tuesday 20 October 2015 10:15
by satanasinc
jvdz wrote:It seems there is an issue retrieving the Room information for the defined rooms in Domoticz.
Could you :
Jos
Hi!
jvdz thanks for your help. ;)
Two rooms configured in domoticz.
I added the variable to domoticz with these result...
dtb.log
2015-10-20 10:00:11 - DomoticzIP: 192.168.1.XXX
2015-10-20 10:00:11 - DomoticzPort: 8080
2015-10-20 10:00:11 - BotHomePath: /home/pi/dtgbot/
2015-10-20 10:00:11 - BotLuaScriptPath: /home/pi/dtgbot/lua/
2015-10-20 10:00:11 - BotBashScriptPath: /home/pi/dtgbot/bash/
2015-10-20 10:00:11 - TelegramBotToken: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
2015-10-20 10:00:11 - TelegramBotOffset: 1
2015-10-20 10:00:11 - -----------------------------------------
2015-10-20 10:00:11 - Starting Telegram api Bot message handler
2015-10-20 10:00:11 - Domoticz returned getuservariables after 1 attempts
2015-10-20 10:00:11 - Decoded 1
2015-10-20 10:00:11 - dtgbotLogLevel set to: 1
2015-10-20 10:00:11 - Loading command modules...
2015-10-20 10:00:11 - Loading module <utility>
2015-10-20 10:00:11 - found command <refresh>
2015-10-20 10:00:11 - Loading module <dtgmenu>
2015-10-20 10:00:11 - define LastCommand
2015-10-20 10:00:11 - Domoticz language is not available for dtgmenus
2015-10-20 10:00:11 - found command <dtgmenu>
2015-10-20 10:00:11 - Loading module <list>
2015-10-20 10:00:11 - found command <list>
2015-10-20 10:00:11 - found command <dump>
2015-10-20 10:00:11 - Loading module <devices>
2015-10-20 10:00:11 - found command <devices>
2015-10-20 10:00:11 - found command <scenes>
2015-10-20 10:00:11 - Loading module <flick>
2015-10-20 10:00:11 - found command <flick>
2015-10-20 10:00:11 - Loading module <nflick>
2015-10-20 10:00:11 - found command <nflick>
2015-10-20 10:00:11 - Loading module <on>
2015-10-20 10:00:11 - found command <on>
2015-10-20 10:00:11 - found command <off>
2015-10-20 10:00:11 - Loading module <battery>
2015-10-20 10:00:11 - found command <battery>
2015-10-20 10:00:11 - found command <batteries>
2015-10-20 10:00:11 - Loading module <help>
2015-10-20 10:00:11 - found command <help>
2015-10-20 10:00:11 - found command <start>
2015-10-20 10:00:11 - Loading module <temperature>
2015-10-20 10:00:11 - found command <tempall>
2015-10-20 10:00:11 - found command <temperatures>
2015-10-20 10:00:11 - found command <temperature>
2015-10-20 10:00:11 - JSON request <http://192.168.1.XXX:8080/json.htm?type ... able&idx=9>
2015-10-20 10:00:11 - Decoded On
2015-10-20 10:00:11 - #### Start populating menuarray
2015-10-20 10:00:11 - Submenu table including buttons defined in menu.cfg: (1) 1 (2)
2015-10-20 10:00:11 - => (1) Misc (2) (3) n (4) 3
2015-10-20 10:00:11 - static -> (1) Misc (2) refresh (3) (4) 9999 (5) command (6) command (7) command (8) 100 (9)
2015-10-20 10:00:11 - static -> (1) Misc (2) battery (3) (4) 9999 (5) command (6) command (7) command (8) 100 (9)
2015-10-20 10:00:11 - static -> (1) Misc (2) tempall (3) (4) 9999 (5) command (6) command (7) command (8) 100 (9)
2015-10-20 10:00:11 - static -> (1) Misc (2) batteries (3) (4) 9999 (5) command (6) command (7) command (8) 100 (9)
2015-10-20 10:00:11 - static -> (1) Misc (2) systemstatus (3) (4) 9999 (5) command (6) command (7) command (8) 100 (9)
2015-10-20 10:00:11 - static -> (1) Misc (2) dtgmenu (3) (4) 9999 (5) command (6) command (7) command (8) 100 (9)
2015-10-20 10:00:11 - Creating Room Menus: (1) 1 (2)
2015-10-20 10:00:11 - JSON request <http://192.168.1.XXX:8080/json.htm?type ... idx=Planta Baja&order=name&used=true>
dtb.log.error
[C]: in ?
Thank you again jvdz.
Greetings from spain
