Page 6 of 29
Re: How to install Domoticz on a Synology NAS
Posted: Sunday 03 January 2016 19:44
by jumbotroll
Jango wrote:Hello is it difficult to install ssl for use with domoticz on a synology NAS?
SSL is not suported for synology ATM.
You can use VPN or maybe MyDomoticz
https://my.domoticz.com/mydomoticz/login
Jumbotroll
Posted: Sunday 03 January 2016 19:53
by jumbotroll
sanderl wrote:Thank, you. Do you have any direction where to search/look/start?
I am not familiar with zwave plus stick. Maybe your device is not supported?
Add your problem here:
http://www.domoticz.com/forum/viewforum.php?f=24
Jumbotroll
Posted: Sunday 03 January 2016 19:57
by sanderl
jumbotroll wrote:sanderl wrote:Thank, you. Do you have any direction where to search/look/start?
Jumbotroll
Thank you for your replies. I added pictures on the previous post (jou replied to). It's this stick (ZME_UZB1)
http://www.z-wave.me/index.php?id=28
and
http://www.robbshop.nl/usb-stick-met-zwave-plus
and
http://tweakers.net/pricewatch/434681/z ... -plus.html
may help...?
It seems to be added to OpenZwave:
https://groups.google.com/forum/#!searc ... nVduC-7QUJ
Posted: Sunday 03 January 2016 21:40
by dtech
jumbotroll wrote:
UPDATE!
I have the same issue with 2.4020 after a reset of my browser.
Went back to stable release 2.3530 and it's ok again.
I think this is a bug in domoticz beta source.
Jumbotroll
Thank you for confirmation I also roll back to stable release and now battery status is proper updated. Also I found another bug in the latest beta. Data from the wind detector are not not show in the diagram. I can see only data from max last 7 days, once I back to stable version there is no issue with the wind data chart.
Posted: Sunday 17 January 2016 12:27
by jumbotroll
Posted: Friday 22 January 2016 13:01
by keurdelion
After many efforts I won't comment here. I didn't succeed in configuring Domoticz on a Synology NAS 209+ under the latest version available DSM 4.2 AND an AEON Z-Stick GEN5.
AM I right if I say that this configuration will never work because Domoticz + Openzwave is definitely not compatible with older version than DSM 4.3? I just need a certitude from experts to stop searching uselessly.
Many thanks,
Keurdelion
Posted: Friday 22 January 2016 13:46
by jumbotroll
keurdelion wrote:After many efforts I won't comment here. I didn't succeed in configuring Domoticz on a Synology NAS 209+ under the latest version available DSM 4.2 AND an AEON Z-Stick GEN5.
Many thanks,
Keurdelion
My domoticz build for arch-ppc853x (DSM 4.2 or DSM 4.3) does NOT support OpenZwave, to much hazzel to compile.
If anyone else has managed to compile , I do not know .
Posted: Monday 25 January 2016 23:05
by jumbo70
Need some help with next step in installing domoticz.
I'm newby with Linux
Aim is to install jadahl package
domoticz_88f6282-5.2_2.0.3530-7.spk
which I believe should match my DS112+ with DSM5.2.
Before I installed debian chroot,
I can further use ssh and putty to go to chroot environment and do the required commandline entries.
What is now easy / preferred way to install?
I tried to edit the etc/apt/sources.list to add the jadahl repository but that leads to error (line not recognized). Is this method of adding Jadahl repositories possible/supported within chroot ? If yes what should be the correct entry in the sources.list file?
Next I tried manual install by downloading the spk file and copied the file (using winSCP) to a new directory domoticz within the chroot environment.
Subsequently tried manual install by
apt-get install domoticz_88f6282-5.2_2.0.3530-7.spk
but then the package is not found. Should I put the package in a specific directory ?
Should I in another way make clear that the package is available to install?
Please some advise.
Thanks,
Jumbo70
Posted: Sunday 10 April 2016 8:48
by gdusordet
hi,
I had to reset my Aeotec Z-Stick Gen5 contoller which is connected to my Synology server. Each time I am rebooting Synology, it keep changing the serial port from /dev/ttyacm0 to /dev/ttyacm1 or /dev/ttyacm1 to /dev/ttyacm0. Any idea how to prevent it from changing the serial port after a restart?
thanks
G
Posted: Saturday 07 May 2016 1:46
by dobber
jumbotroll wrote:Jango wrote:Hello is it difficult to install ssl for use with domoticz on a synology NAS?
Jumbotroll
Should work with reverse proxy within DSM 6.0.
Great package! I'm switching from Pi to this build with my rfxtrx433e
Posted: Monday 09 May 2016 19:09
by jumbotroll
dobber wrote:jumbotroll wrote:Jango wrote:Hello is it difficult to install ssl for use with domoticz on a synology NAS?
Jumbotroll
BTW SSL is supported in the latest build
Posted: Saturday 14 May 2016 18:04
by mvveelen
Darn..... just installed the latest and it gives me a dead node (Qubino dimmer). Tried rebooting the Synology, healing the node, healing the ZWave network....nothing....
What could be the problem here?
Edit:
Just updated with the same package again and...same problem. But, after waiting about 15 minutes, the light suddenly turned on and when I checked, the node was alive again. Weird, but true.
Edit 2:
Just got a message that the node was dead again
Shoot !!
Edit 3:
At the same time I updated Domoticz, the Qubino died. It revived for a few minutes as you can see above, but after that it was broken. I got a new one and that one is working fine now. Hope this one will stay alive
Posted: Saturday 21 May 2016 0:36
by dobber
I noticed this, but I get an error:
2016-05-19 19:21:02.928 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 8443: use_certificate_chain_file: No such file or directory
The ssl part just wont start for me. Any suggestions?
Posted: Monday 18 July 2016 13:35
by Joshuapr
Its not impossible but its also not recommended. The best way to install is with the OSDial CD itself.
Posted: Sunday 31 July 2016 13:59
by Andi80
I am facing the same issue. All of the following addresses result in the 'invalid location' error:
http://www.jadahl.com/domoticz_stable_6/
http://www.jadahl.com/domoticz_beta_6/
http://jadahl.dscloud.me/sspks/
http://packages.synocommunity.com is working fine!
I ticked the check box for third party distributors.
Any ideas?
Best,
Andi
Posted: Sunday 31 July 2016 16:30
by jumbotroll
http://jadahl.dscloud.me/sspks/ is not in use!
You have to use these url for DSM 6.0 :
And remember to tick the check box
Any Publisher
Take a look on my webpage for more info
Posted: Sunday 31 July 2016 17:22
by Andi80
Well, I used these two addresses and it gave me the aformentioned error. I also ticked the respective check box.
Gesendet von meinem ONE A2003 mit Tapatalk
Posted: Sunday 31 July 2016 17:50
by jumbotroll
Andi80 wrote:Well, I used these two addresses and it gave me the aformentioned error. I also ticked the respective check box.
What type NAS du you have?
Have you tried to download and install manually?
Posted: Sunday 31 July 2016 18:04
by Andi80
DS716+II
I didn't try to install manually, yet.
Posted: Sunday 31 July 2016 18:13
by jumbotroll
Andi80 wrote:DS716+II
DS716+II was not added on my server, but you can try again now.
