Page 6 of 8
Re: MyToyota Dashboard
Posted: Saturday 07 March 2026 10:36
by mxpwr
I think the problem is that the odometer is showing the total driven km of the car, while the ev distance is showing you the ev distance driven since you registered your account with Toyota.
Based on your numbers that's about 13.4km (probably the distance from the dealer to your place).
I can see if I can find a fix for that.
Posted: Friday 17 April 2026 19:47
by manjh
Did something break?
I've enjoyed getting data from my Toyota into Domoticz for months now, without problems.
But today, since 11:51 AM, nothing. I tried refreshing the data on the MyToyota dashboard, but it will not refresh.
The "official" MyToyota app works OK.
Is there a problem somewhere? I tried looking at the log, but cannot see any obvious reason...
Posted: Friday 17 April 2026 19:51
by mxpwr
yes, there is an issue with the API and how the data is fetched after an update of pytoyoda.
I m currently fixing this. If you do a pull most things should be fixed again. There is still some data missing, but i hope i can fix this soon.
Posted: Friday 17 April 2026 19:57
by manjh
I refreshed the app and restarted the whole Pi, just to make sure.
It now works again.
Great support, thank you!
Posted: Friday 17 April 2026 21:58
by manjh
One small thing. When I click refresh, it does not change the "last updated" field. It stays "never".
Posted: Friday 17 April 2026 22:22
by mxpwr
manjh wrote: Friday 17 April 2026 21:58 One small thing. When I click refresh, it does not change the "last updated" field. It stays "never".
It's on my to-do list. But it's only cosmetic so no highest prio.
Posted: Saturday 18 April 2026 0:13
by manjh
Again, no big deal. Just wanted to mention it.
Posted: Sunday 19 April 2026 10:30
by wim57
Nice app, until now I've found 3 little bugs, maybe you can correct/improve them?
First, I noticed that after changing the MQTT settings I needed to restart the app to make it work. No problem, maybe you can put a notice on the screen.
The other bugs I found are related to having 2 cars registered in MyToyota. On the dashboard I can only see one car.
For the other car devices are created in Domoticz through MQTT but the name of the devices does not contain the VIN (the unique_id does however). Example:
{"name": "N/A Odometer", "unique_id": "JTD..........9_odometer", "state_topic": "mytoyota/JTD...........9/odometer", "device": {"identifiers": ["JTD.........9"], "name": "N/A", "model": "Yaris Cross - MC '24", "manufacturer": "Toyota"}, "unit_of_measurement": "km", "icon": "mdi:counter", "value_template": "{{ value_json.value | int }}"}
Edit: I see you are using the alias as part of the device name. In the MyToyota app I see that the alias for one of the cars has been filled with the vin and for the other one it is blank. So, I can change this in the MyToyota app. Also you might use the vin as the default alias instead of "N/A".
Posted: Friday 01 May 2026 12:18
by mxpwr
This should be fixed now
Posted: Friday 01 May 2026 12:19
by mxpwr
wim57 wrote: Sunday 19 April 2026 10:30 Nice app, until now I've found 3 little bugs, maybe you can correct/improve them?
I'll take a look at that. I have only one car, so haven't really looked into multi car display yet.
Posted: Friday 01 May 2026 20:21
by mxpwr
The mqtt problem should be fixed now. The settings are properly restored, the testing gives the correct result and you can change settings without restarting the app.
Posted: Saturday 09 May 2026 11:50
by manjh
mxpwr wrote: Friday 01 May 2026 12:18
Confirmed, it is fixed now. Thanks!
Posted: Sunday 10 May 2026 8:53
by mxpwr
I added a multi car selector and the code now reverts to the vin if the alias is not defined. I only have one car, so give it a try and let me know how it works. Also, if you post bugs/feature requests in the issues page of the repo, it is easier for me to keep track
https://github.com/stone17/mytoyota-dashboard/issues
Posted: Sunday 10 May 2026 10:20
by wim57
Thank you, I just tried the new version and it looks ok!
Posted: Wednesday 13 May 2026 11:49
by manjh
On the original Toyota app, I occasionally see "warning lights" at the bottom. E.g. for a low 12V battery.
Is it possible to show these in the mytoyota plugin as well, and keep a history?
Posted: Wednesday 13 May 2026 12:28
by mxpwr
I can check if pytoyoda fetches this already.
Posted: Thursday 14 May 2026 10:02
by wim57
manjh wrote: Wednesday 13 May 2026 11:49 On the original Toyota app, I occasionally see "warning lights" at the bottom. E.g. for a low 12V battery.
I can see these messages under 'notifications'.
Posted: Thursday 14 May 2026 10:27
by mxpwr
If it's shown in the notifications page, we could wrap it into a sensor. What is the exact string?
Posted: Monday 18 May 2026 16:55
by manjh
Got it, the messages I was looking for are there. Along with a lot of other messages, such as the door is not locked"".
It would be great if I could mark messages and then copy them, for future reference.
Bit of background, reason I am looking for this.
My car is a1 year old RAV4 PHEV. It gives me warning messages about the 12V battery being low. I talked to the dealership, they said it is not serious and I should ignore it. They even said it is in the app, not in the car. But beside these app warnings, I have also seen a warning on the dashboard. So it is definitely something in the car.
This is why I am keeping track of this special message, so I can prove when I run into real problems (has not happened yet, car drives great).
Posted: Sunday 28 June 2026 12:40
by manjh
I have a problem. Since 2 days, the location of the car is no longer fed into Domoticz.
After some investigation, I found out that the original Toyota app also does not show location. On the spot where the map used to be is now a grey square.
So I suspect the car does not send out location info. It does transmit other data(e.g. odometer, fuel and battery status, etc.).
Is there some kind of setting in the car system that I could check?
edit: I found out there is a privacy mode setting. The Toyota app showed Location data sharing is "off". So I went into the car, and found the entry in the settings menu: it was "on"!! So I switched it off and back on again, and now the Toyota app shows location data sharing is on again. Not sure what caused this.
Then I checked the MyToyota app, and it did not change anything. Also found out the odometer value is not correct, it is the one of two days ago, while the Toyota app does show the correct value.
Weird.
I will give it some time to see if it somehow synchronizes again.
