Page 6 of 19
Re: Satel Integra (Security System) with ethernet module
Posted: Wednesday 09 December 2015 19:46
by fantom
And this fix is deploy on today beta version of domoticz (2.3788)
Fantom
Posted: Monday 28 December 2015 13:33
by proohu01
Hello Fantom,
After doing a fresh installation of the latest Domoticz, I do no longer get the OUTPUT devices from my Satel.
I only get INPUT zones and TEXT object for the Outputs.
Any ideas on how this is possible?
Second question. Is it possible to add something to the code so that it ignores zones that are not used? I only use a couple of the 32 possible input zones and I get a lot of errors when I first connect the satel. I know this is not a real problem but it would be nice if it didn't show up at all.
2015-12-28 12:28:29.094 Error: Satel Integra: Receive info about zone 12 failed
2015-12-28 12:28:29.316 Error: Satel Integra: receive error: other error
etc.
Posted: Monday 28 December 2015 14:19
by fantom
Do you have outputs type bi, mono etc ? Please send me some logs where integra started.
About next error - i thinking about this, but I would have to turn off all errors when reading zones. I have not found another solution.
Fantom
Posted: Sunday 03 January 2016 22:38
by free_nsc
@fantom - in relation to proohu01's problem - I created 4 new outputs type 25 in the Integra and then in Domoticz I disabled/enabled Satel hardware and 8 new devices have been recognised. Four of these are of the text type with names populated as per the Integra and another 4 of the swtich type but with no names allocaated.
I'm not sure if that was intended process however I was able to name them accordingly and use them so adding outputs still works but just no names are added that's all.
NB. I created them as type 25 and I am going the status of these devices to control status of my z-wave devices. I have already created nice new tab in the INT-TSI and have them linked using blocky in domoticz and they work a treat!
This proves that Integration that you completed allows to use domoticz devices in Integra.
Satel INT-TSI controller home automation screen
Posted: Monday 04 January 2016 8:36
by fantom
So great that module works.
In the coming days, I will look at what those names.
Fantom
ps. I think, that this INT-TSI is normal tablet 7" :) I want install normal tablet (much cheaper) and use domoticz on it or maybe own application.
Posted: Monday 04 January 2016 8:39
by mmormon
Hello
My Domoticz on Raspberry PI (v2.3530) properly recognized Satel Integra 128 WLR devices. I can see 25-BI switches state properly but when I want to switch it from Domoticz I get error: Error sending switch command, check device/hardware ! popup window. Logs shows:
2016-01-04 08:33:21.190 Error: Satel Integra: received frame is too short.
2016-01-04 08:33:21.191 Error: Satel Integra: Switch output 19 failed
2016-01-04 08:33:21.217 Satel Integra: connected to 192.168.0.25:7094
Can someone help?
Posted: Monday 04 January 2016 8:41
by fantom
I have two comments :
1) do you set password (user code) in settings (hardware Integra) ?
2) Pls install the newest version of domoticz (actually is 4025). A few weeks ago i corrected one bug in code (related to bad CRC)
Fantom
Posted: Monday 04 January 2016 9:06
by mmormon
Thanks for quick reply
1. Password was set
2. There is only windows version 4025 in download section. I use RPI. How can I update?
Posted: Monday 04 January 2016 9:08
by fantom
I use RPI too.
In Settings->Ssytem you must set "Release Channel" to Beta
Fantom
Posted: Monday 04 January 2016 9:23
by mmormon
I made update but still the same: Error: Satel Integra: received frame is too short.
Posted: Monday 04 January 2016 9:36
by fantom
A switch (output on Integra) is toggled or not?
Because this error is only a confirmation to domoticz.
Does anyone else have this problem? For me not occur.
Fantom
ps. Please after install this new version, delete Integra hardware in Domoticz and add again.
Posted: Monday 04 January 2016 9:44
by fantom
free_nsc wrote:@fantom - in relation to proohu01's problem - I created 4 new outputs type 25 in the Integra and then in Domoticz I disabled/enabled Satel hardware and 8 new devices have been recognised. Four of these are of the text type with names populated as per the Integra and another 4 of the swtich type but with no names allocaated.
Hmmm.
I do not understand.
So there were four new devices like the text type? And what do they show? They should not be :( Text type is only for outputs other than BI / Mono, etc.
Fantom
Posted: Monday 04 January 2016 9:54
by mmormon
I can switch the output from Integra panel.
I checked Ethm1 firmware, it's 1.05. Can you check yours please.
Maybe I should update.
ps. Hardware was removed and added again.
Posted: Monday 04 January 2016 10:08
by fantom
I have latest 1.07 version
1.05 is old.
The best download the latest from Satel.
For futer You need a little careful, because they releasing versions with the same numbers but with different dates.
And you can have the same version numbers but that other firmware inside (newer and older with this same version number).
Best to look at the date (info button in the installer)
Fantom
ps. Connect ETHM-1 with board using serial port (not only bus). This is very faster and working from version 1.07. You must use this cable : http://www.satel.pl/en/product/334/RJ/P ... azdem-PIN5
Posted: Monday 04 January 2016 10:25
by mmormon
I have such a cable connected all the time.
I can read satel output status but cant switch it from domoticz.
I'll update firmware soon and let you know if helped.
Posted: Monday 04 January 2016 11:20
by proohu01
fantom wrote:Do you have outputs type bi, mono etc ? Please send me some logs where integra started.
Fantom
I only have outputs with type 17 (READY status); 21 (Armed status) and 1 (Burglary). Should all of them be 25 (BI switch) ??
This is the log when I start the Satel integration:
2016-01-04 11:14:11.942 Satel Integra: Create instance
2016-01-04 11:14:11.960 Satel Integra: connected to 192.168.xxx.xxx:xxxx
2016-01-04 11:14:11.992 Satel Integra: Model Integra 32
2016-01-04 11:14:12.034 Satel Integra: RTC 2016-01-04 11:14:11
2016-01-04 11:14:12.052 Satel Integra: ETHM-1 ver. 1.07 2014-05-09
2016-01-04 11:14:12.072 Satel Integra: Alarm not set
2016-01-04 11:14:12.092 Satel Integra: System not arm
2016-01-04 11:14:12.092 (Satel) Light/Switch (Arm)
2016-01-04 11:14:12.584 (Satel) General/Alert (Zone:Sirene Tamper)
2016-01-04 11:14:12.802 Error: Satel Integra: receive error: other error
2016-01-04 11:14:12.802 Error: Satel Integra: Receive info about zone 2 failed
2016-01-04 11:14:13.073 Error: Satel Integra: receive error: other error
2016-01-04 11:14:13.073 Error: Satel Integra: Receive info about zone 3 failed
2016-01-04 11:14:13.344 Error: Satel Integra: receive error: other error
2016-01-04 11:14:13.344 Error: Satel Integra: Receive info about zone 4 failed
2016-01-04 11:14:13.668 (Satel) General/Alert (Zone:xxxx Tamper)
2016-01-04 11:14:14.062 (Satel) General/Alert (Zone:xxxx)
2016-01-04 11:14:14.383 (Satel) General/Alert (Zone:xxxx)
2016-01-04 11:14:15.073 Error: Satel Integra: receive error: other error
2016-01-04 11:14:15.073 Error: Satel Integra: Receive info about zone 9 failed
2016-01-04 11:14:15.295 Error: Satel Integra: receive error: other error
2016-01-04 11:14:15.295 Error: Satel Integra: Receive info about zone 10 failed
2016-01-04 11:14:15.565 Error: Satel Integra: receive error: other error
2016-01-04 11:14:15.565 Error: Satel Integra: Receive info about zone 11 failed
2016-01-04 11:14:15.787 Error: Satel Integra: receive error: other error
2016-01-04 11:14:15.787 Error: Satel Integra: Receive info about zone 12 failed
2016-01-04 11:14:16.059 Error: Satel Integra: receive error: other error
2016-01-04 11:14:16.059 Error: Satel Integra: Receive info about zone 13 failed
2016-01-04 11:14:16.330 Error: Satel Integra: receive error: other error
2016-01-04 11:14:16.330 Error: Satel Integra: Receive info about zone 14 failed
2016-01-04 11:14:16.550 Error: Satel Integra: receive error: other error
2016-01-04 11:14:16.551 Error: Satel Integra: Receive info about zone 15 failed
2016-01-04 11:14:16.821 Error: Satel Integra: receive error: other error
2016-01-04 11:14:16.822 Error: Satel Integra: Receive info about zone 16 failed
2016-01-04 11:14:17.194 Error: Satel Integra: receive error: other error
2016-01-04 11:14:17.194 Error: Satel Integra: Receive info about zone 17 failed
2016-01-04 11:14:17.414 Error: Satel Integra: receive error: other error
2016-01-04 11:14:17.414 Error: Satel Integra: Receive info about zone 18 failed
2016-01-04 11:14:17.687 Error: Satel Integra: receive error: other error
2016-01-04 11:14:17.687 Error: Satel Integra: Receive info about zone 19 failed
2016-01-04 11:14:17.958 Error: Satel Integra: receive error: other error
2016-01-04 11:14:17.958 Error: Satel Integra: Receive info about zone 20 failed
2016-01-04 11:14:18.179 Error: Satel Integra: receive error: other error
2016-01-04 11:14:18.179 Error: Satel Integra: Receive info about zone 21 failed
2016-01-04 11:14:18.500 Error: Satel Integra: receive error: other error
2016-01-04 11:14:18.500 Error: Satel Integra: Receive info about zone 22 failed
2016-01-04 11:14:18.721 Error: Satel Integra: receive error: other error
2016-01-04 11:14:18.721 Error: Satel Integra: Receive info about zone 23 failed
2016-01-04 11:14:19.194 Error: Satel Integra: receive error: other error
2016-01-04 11:14:19.194 Error: Satel Integra: Receive info about zone 24 failed
2016-01-04 11:14:19.465 Error: Satel Integra: receive error: other error
2016-01-04 11:14:19.465 Error: Satel Integra: Receive info about zone 25 failed
2016-01-04 11:14:20.008 Error: Satel Integra: receive error: other error
2016-01-04 11:14:20.008 Error: Satel Integra: Receive info about zone 27 failed
2016-01-04 11:14:20.229 Error: Satel Integra: receive error: other error
2016-01-04 11:14:20.229 Error: Satel Integra: Receive info about zone 28 failed
2016-01-04 11:14:20.450 Error: Satel Integra: receive error: other error
2016-01-04 11:14:20.450 Error: Satel Integra: Receive info about zone 29 failed
2016-01-04 11:14:20.671 Error: Satel Integra: receive error: other error
2016-01-04 11:14:20.671 Error: Satel Integra: Receive info about zone 30 failed
2016-01-04 11:14:20.942 Error: Satel Integra: receive error: other error
2016-01-04 11:14:20.942 Error: Satel Integra: Receive info about zone 31 failed
2016-01-04 11:14:21.214 Error: Satel Integra: receive error: other error
2016-01-04 11:14:21.214 Error: Satel Integra: Receive info about zone 32 failed
Posted: Monday 04 January 2016 11:33
by fantom
As I wrote earlier:
viewtopic.php?f=17&t=4260&start=60#p56646
Only for those types switching makes sense. The rest types of ouput are read-only (and in domoticz as TextType)
Fantom
Posted: Monday 04 January 2016 11:37
by proohu01
:oops:
Posted: Monday 04 January 2016 15:12
by free_nsc
fantom wrote:ps. I think, that this INT-TSI is normal tablet 7" I want install normal tablet (much cheaper) and use domoticz on it or maybe own application.
It kinda is a tablet but not really. I wanted to keep it all in the same place but the tablet for domoticz is a good idea - people here have done similar things with 7" Raspberry PI screen but again cost wise you're better off with cheap tablet from Aliexpress.
fantom wrote:Hmmm.
So there were four new devices like the text type? And what do they show? They should not be Text type is only for outputs other than BI / Mono, etc.
Fantom
I know they shouldn't be coming in as TextType but here what they look like when I disabled/enabled the Satel hardware:
New4Devices
New4Devices
Posted: Tuesday 05 January 2016 22:28
by mmormon
fantom wrote:I have latest 1.07 version
1.05 is old.
Fantom
Ethm1 was updated to 1.07.
Everything works wery well :)
Thanks for help
