Re: 15326 - [WebServer] Depricated RType
Posted: Friday 28 July 2023 13:41
I see! Thanks,
So i need wait App update?
Or is there anything I can do?
Open source Home Automation System
https://forum.domoticz.com/
2023-07-28 23:19:49.719 Debug: [web:443] 'DH PARAMETERS' found in file ./server_cert.pem
2023-07-28 23:19:49.719 Status: WebServer(SSL) started on address: :: with port 443
2023-07-28 23:19:49.720 Debug: [web:443] Adding IPv4 network (192.168.1.*) to list of trusted networks.
2023-07-28 23:19:49.720 Debug: [web:443] Adding IPv4 network (127.0.0.1) to list of trusted networks.
2023-07-28 23:19:49.721 Debug: WebServer(SSL) started with 260 Registered Commands
2023-07-28 23:19:49.721 Debug: cWebEm Registration: 23 pages, 10 actions, 4 whitelist urls, 12 whitelist commands
2023-07-28 23:19:49.722 Starting shared server on: :::6144
2023-07-28 23:19:49.722 Status: TCPServer: shared server started...
2023-07-28 23:19:49.722 Status: RxQueue: queue worker started...
2023-07-28 23:19:51.723 Status: NotificationSystem: thread started...
2023-07-28 23:19:51.723 Status: EventSystem: reset all events...
2023-07-28 23:19:51.724 Status: EventSystem: reset all device statuses...
2023-07-28 23:19:51.751 Status: Python EventSystem: Initializing event module.
2023-07-28 23:19:51.751 Status: EventSystem: Started
2023-07-28 23:19:51.751 Status: EventSystem: Queue thread started...
2023-07-28 23:19:52.724 Status: MQTT: Connecting to 127.0.0.1:1883
2023-07-28 23:19:52.807 Debug: [web:8080] Host:192.168.1.11 Uri:/json.htm?type=devices&rid=50
2023-07-28 23:19:52.807 Debug: [web:8080] IP (192.168.1.11) is within Trusted network range!
2023-07-28 23:19:52.807 Debug: CWebServer::GetJSonPage(rtype) :devices :/json.htm?type=devices&rid=50
2023-07-28 23:19:52.807 [WebServer] Deprecated RType (devices) for API request. Handled via fallback (getdevices), please use correct API Command! (192.168.1.11)
2023-07-28 23:19:52.808 Status: [web:8080] Incoming connection from: 192.168.1.11
2023-07-28 23:19:52.808 Debug: [web:8080] generate new session id token f5232d8a700555590be921f0e2ed5af0
2023-07-28 23:19:52.808 Debug: [web:8080] generate new authentication token MGRlMzYxNTQtYzJkOS00ODU3LWJlZWUtMTc0YWFlMzU3MDU2 for user Domoticz
2023-07-28 23:19:52.809 Debug: Web ACLF: 192.168.1.11 - - [28/Jul/2023:23:19:52.807 +0200] "GET /json.htm?type=devices&rid=50 HTTP/1.1" 200 1782 - -
2023-07-28 23:19:52.925 Status: MQTT: connected to: 127.0.0.1:1883
2023-07-28 23:19:57.808 Debug: [web:8080] Host:192.168.1.11 Uri:/json.htm?type=devices&rid=50
2023-07-28 23:19:57.808 Debug: [web:8080] IP (192.168.1.11) is within Trusted network range!
2023-07-28 23:19:57.808 Debug: CWebServer::GetJSonPage(rtype) :devices :/json.htm?type=devices&rid=50
2023-07-28 23:19:57.808 [WebServer] Deprecated RType (devices) for API request. Handled via fallback (getdevices), please use correct API Command! (192.168.1.11)
2023-07-28 23:19:57.809 Debug: Web ACLF: 192.168.1.11 - - [28/Jul/2023:23:19:57.808 +0200] "GET /json.htm?type=devices&rid=50 HTTP/1.1" 200 1782 - -
2023-07-28 23:20:00.990 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=devices_list
2023-07-28 23:20:00.991 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:00.991 Debug: CWebServer::GetJSonPage :devices_list :/json.htm?type=command¶m=devices_list
2023-07-28 23:20:00.992 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:00.990 +0200] "GET /json.htm?type=command¶m=devices_list HTTP/1.1" 200 5293 - "curl/7.81.0"
2023-07-28 23:20:01.011 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.012 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.012 Debug: CWebServer::GetJSonPage :devices_list :/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.013 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.011 +0200] "GET /json.htm?type=command¶m=devices_list HTTP/1.1" 200 5293 - "curl/7.81.0"
2023-07-28 23:20:01.042 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=udevice&idx=87&nvalue=0&svalue=178;S;6.925;11.08;20;0
2023-07-28 23:20:01.042 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.043 Debug: CWebServer::GetJSonPage :udevice :/json.htm?type=command¶m=udevice&idx=87&nvalue=0&svalue=178;S;6.925;11.08;20;0
2023-07-28 23:20:01.044 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.042 +0200] "GET /json.htm?type=command¶m=udevice&idx=87&nvalue=0&svalue=178;S;6.925;11.08;20;0 HTTP/1.1" 200 49 - "curl/7.81.0"
2023-07-28 23:20:01.045 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.045 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.045 Debug: CWebServer::GetJSonPage :devices_list :/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.047 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.045 +0200] "GET /json.htm?type=command¶m=devices_list HTTP/1.1" 200 5293 - "curl/7.81.0"
2023-07-28 23:20:01.071 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=udevice&idx=88&nvalue=0&svalue=2.5
2023-07-28 23:20:01.071 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.071 Debug: CWebServer::GetJSonPage :udevice :/json.htm?type=command¶m=udevice&idx=88&nvalue=0&svalue=2.5
2023-07-28 23:20:01.072 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.070 +0200] "GET /json.htm?type=command¶m=udevice&idx=88&nvalue=0&svalue=2.5 HTTP/1.1" 200 49 - "curl/7.81.0"
2023-07-28 23:20:01.072 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.072 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.073 Debug: CWebServer::GetJSonPage :devices_list :/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.074 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.072 +0200] "GET /json.htm?type=command¶m=devices_list HTTP/1.1" 200 5293 - "curl/7.81.0"
2023-07-28 23:20:01.092 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=getdevices&rid=85
2023-07-28 23:20:01.092 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.092 Debug: CWebServer::GetJSonPage :getdevices :/json.htm?type=command¶m=getdevices&rid=85
2023-07-28 23:20:01.093 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.092 +0200] "GET /json.htm?type=command¶m=getdevices&rid=85 HTTP/1.1" 200 1316 - "curl/7.81.0"
2023-07-28 23:20:01.107 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_Automation_Volets_V1.3.lua: ...oticz/scripts/lua/script_time_Automation_Volets_V1.3.lua:517: attempt to index a nil value (global 'otherdevices_temperature')
2023-07-28 23:20:01.125 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.125 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.125 Debug: CWebServer::GetJSonPage :devices_list :/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.126 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.125 +0200] "GET /json.htm?type=command¶m=devices_list HTTP/1.1" 200 5293 - "curl/7.81.0"
2023-07-28 23:20:01.147 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=getdevices&rid=59
2023-07-28 23:20:01.147 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.147 Debug: CWebServer::GetJSonPage :getdevices :/json.htm?type=command¶m=getdevices&rid=59
2023-07-28 23:20:01.148 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.147 +0200] "GET /json.htm?type=command¶m=getdevices&rid=59 HTTP/1.1" 200 1626 - "curl/7.81.0"
2023-07-28 23:20:01.169 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.169 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.170 Debug: CWebServer::GetJSonPage :devices_list :/json.htm?type=command¶m=devices_list
2023-07-28 23:20:01.171 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.169 +0200] "GET /json.htm?type=command¶m=devices_list HTTP/1.1" 200 5293 - "curl/7.81.0"
2023-07-28 23:20:01.190 Debug: [web:8080] Host:127.0.0.1 Uri:/json.htm?type=command¶m=getdevices&rid=59
2023-07-28 23:20:01.190 Debug: [web:8080] IP (127.0.0.1) is within Trusted network range!
2023-07-28 23:20:01.190 Debug: CWebServer::GetJSonPage :getdevices :/json.htm?type=command¶m=getdevices&rid=59
2023-07-28 23:20:01.191 Debug: Web ACLF: 127.0.0.1 - - [28/Jul/2023:23:20:01.190 +0200] "GET /json.htm?type=command¶m=getdevices&rid=59 HTTP/1.1" 200 1626 - "curl/7.81.0"
2023-07-28 23:20:02.811 Debug: [web:8080] Host:192.168.1.11 Uri:/json.htm?type=devices&rid=50
2023-07-28 23:20:02.811 Debug: [web:8080] IP (192.168.1.11) is within Trusted network range!
2023-07-28 23:20:02.811 Debug: CWebServer::GetJSonPage(rtype) :devices :/json.htm?type=devices&rid=50
2023-07-28 23:20:02.811 [WebServer] Deprecated RType (devices) for API request. Handled via fallback (getdevices), please use correct API Command! (192.168.1.11)
2023-07-28 23:20:02.812 Debug: Web ACLF: 192.168.1.11 - - [28/Jul/2023:23:20:02.811 +0200] "GET /json.htm?type=devices&rid=50 HTTP/1.1" 200 1782 - -
2023-07-28 23:20:07.812 Debug: [web:8080] Host:192.168.1.11 Uri:/json.htm?type=devices&rid=50
2023-07-28 23:20:07.812 Debug: [web:8080] IP (192.168.1.11) is within Trusted network range!
2023-07-28 23:20:07.812 Debug: CWebServer::GetJSonPage(rtype) :devices :/json.htm?type=devices&rid=50
2023-07-28 23:20:07.813 [WebServer] Deprecated RType (devices) for API request. Handled via fallback (getdevices), please use correct API Command! (192.168.1.11)
2023-07-28 23:20:07.814 Debug: Web ACLF: 192.168.1.11 - - [28/Jul/2023:23:20:07.812 +0200] "GET /json.htm?type=devices&rid=50 HTTP/1.1" 200 1782 - -It will probably not come from Dutch "Buienradar" or ¨OpenWeatherMap"studiocascade wrote: Tuesday 08 August 2023 21:28 I got this same message:
[Webserver] Deprecated RType (devices) for API request. Handled via fallback (getdevices), please use correct API Command! (192.168.x.xx)
I'm using another custom dashboard (not Dashticz)
The only possible API-request could be from Dutch "Buienradar" or ¨OpenWeatherMap"
Possibly i can be of help in solving the problem... although i'm not a script wizard.
So maybe someone can help me where to look and i could share the contents of the script.
With that info we might get any further in solving the problem.
Does someone also know where i can set the log level for the webserver?
I now get the above message every few seconds, i'm afraid my log is getting overloaded from that.
