Page 6 of 28
Re: Python Plugin : Broadlink
Posted: Monday 17 August 2020 19:32
by wizardnl
when running the setup i get the following error
File "setup.py", line 223
print("\r>> Bytes downloaded -->" + state + str(leng) + state, end='', flush =True)
SyntaxError: invalid syntax
Posted: Monday 17 August 2020 21:07
by zak45
wizardnl wrote: Monday 17 August 2020 19:32
please check that :
Be sure that your active python version is > 3.4
this mean: python --version
should give output e.g. python 3.x.x and not python 2.x.x
see this link
https://www.domoticz.com/wiki/Using_Python_plugins
or this one :
https://linuxconfig.org/how-to-change-f ... bian-linux
Posted: Thursday 20 August 2020 11:15
by DrMacabre
Gret work. How do import my commands from the official app ?
Posted: Thursday 20 August 2020 11:59
by zak45
DrMacabre wrote: Thursday 20 August 2020 11:15
Thanks.
Import work only from e-control app.
if you use it, see this link :
https://www.domoticz.com/wiki/Plugins/B ... RM2_Device
Posted: Thursday 20 August 2020 15:49
by DrMacabre
Oh ok, like the old version then. I thought there was something else. What’s the « upload » « import » and « econtrol » buttons for ?
I got a broadlink bad key when trying to connect to the web interface/import
Posted: Thursday 20 August 2020 16:16
by zak45
DrMacabre wrote: Thursday 20 August 2020 15:49
1:
upload : allow to upload file
import : read ini files from import directory and try to generate ini files to be used by the plugin
econtrol: generate ini files into import folder from e-control database files ( the 3 files required )
2: ????
Posted: Thursday 20 August 2020 16:49
by DrMacabre
zak45 wrote: Thursday 20 August 2020 16:16
2: ????
I want to import the 3 files, in the instructions, it says connect to
http://mydomoticzIP:9000/import
That’s where i get broadlink bad key onscreen message.
Is there another way to upload the 3 files from the app to the plugin ?
Posted: Thursday 20 August 2020 17:05
by DrMacabre
Ok the 3 files are now in /ini/ but from there, what should i do ?
Posted: Thursday 20 August 2020 17:22
by zak45
DrMacabre wrote: Thursday 20 August 2020 17:05
the files need to be under import folder ....
Just click on e-control button, should create all ini files for import. (name start by IMP-)
If all is ok, click on import and should create ini files that will be under plugin control after.
I let the old WiKi for reference only, but all is now into the admin file (including the file transfert - upload button)
Posted: Thursday 20 August 2020 19:16
by DrMacabre
Sorry, i still mostly get it, i have now a bunch of ini files in /import/ and some broadlink ini files in /ini/ but i don’t remember how to turn this into devices. I recently lost my whole domoticz and had to start from scratch but with time i totally forgot the process to make this plugin works. All i can remember is having all my buttons from e-control showing up as devices in domoticz before i crashed
Posted: Thursday 20 August 2020 21:03
by zak45
DrMacabre wrote: Thursday 20 August 2020 19:16
No problem.
This is a new plugin with new logic.
Now, Domoticz device is not automatically created, you select the ini file you want and click on create device.
Posted: Thursday 20 August 2020 23:06
by wizardnl
zak45 wrote: Monday 17 August 2020 21:07
please check that :
see this link
or this one :
We execute this command : sudo -H python -m pip install python-broadlink-master/.
Looking in indexes:
https://pypi.org/simple,
https://www.piwheels.org/simple
Processing ./python-broadlink-master
Requirement already satisfied: cryptography>=2.1.1 in /usr/lib/python2.7/dist-packages (from broadlink==0.14.1) (2.6.1)
Building wheels for collected packages: broadlink
Running setup.py bdist_wheel for broadlink ... done
Stored in directory: /root/.cache/pip/wheels/22/00/bf/e3f9625cfd51378837b1b45ad17d219988821a8bf1c810e9d6
Successfully built broadlink
Installing collected packages: broadlink
Found existing installation: broadlink 0.14.1
Uninstalling broadlink-0.14.1:
Successfully uninstalled broadlink-0.14.1
Successfully installed broadlink-0.14.1
We have installed : python-broadlink-master/.
________________________________________
# We do necessary modifications depend of Platform
put *.py files executable (+x) OK
put *.sh files executable (+x) OK
Checking installation ....
Successfully imported googletrans
Error importing translate
Thank this was indeed my error change my python version now during the setup i get a "Error importing translate" error sorry i am a noob with these things
Posted: Thursday 20 August 2020 23:26
by zak45
wizardnl wrote: Thursday 20 August 2020 23:06
Looking in indexes:
please type in term session : python --version
and provide your output ....
debian@debian10:~$ python --version
Python 3.7.3
debian@debian10:~$
Posted: Thursday 20 August 2020 23:29
by zak45
@wizardnl
I need also this :
sudo -H python -m pip list
Posted: Thursday 20 August 2020 23:32
by wizardnl
pi@raspberrypi:~ $ python --version
Python 3.8.0
pi@raspberrypi:~ $
pi@raspberrypi:~ $ sudo -H python -m pip list
Package Version
asn1crypto 0.24.0
broadlink 0.14.1
certifi 2018.8.24
chardet 3.0.4
configparser 3.5.0b2
cryptography 2.6.1
entrypoints 0.3
enum34 1.1.6
idna 2.6
ipaddress 1.0.17
keyring 17.1.1
keyrings.alt 3.1.1
pip 18.1
pycrypto 2.6.1
PyGObject 3.30.4
pyOpenSSL 19.0.0
pyxdg 0.25
requests 2.21.0
requests-toolbelt 0.9.1
RPi.GPIO 0.7.0
SecretStorage 2.3.1
setuptools 40.8.0
six 1.12.0
urllib3 1.24.1
wheel 0.32.3
pi@raspberrypi:~ $
Posted: Thursday 20 August 2020 23:38
by zak45
wizardnl wrote: Thursday 20 August 2020 23:32
Python 3.8.0
pi@raspberrypi:~ $
Package Version
asn1crypto 0.24.0
broadlink 0.14.1
pi@raspberrypi:~ $
Looks ok....
Do you install with "python setup.py" or "sudo python setup.py" ???
Posted: Thursday 20 August 2020 23:42
by wizardnl
zak45 wrote: Thursday 20 August 2020 23:38
Python 3.8.0
pi@raspberrypi:~ $
Package Version
asn1crypto 0.24.0
broadlink 0.14.1
pi@raspberrypi:~ $
Looks ok....
python setup.py
Posted: Thursday 20 August 2020 23:43
by zak45
wizardnl wrote: Thursday 20 August 2020 23:42
python setup.py
[/quote]
do with : sudo python setup.py
Posted: Thursday 20 August 2020 23:47
by wizardnl
zak45 wrote: Thursday 20 August 2020 23:43
python setup.py
[/quote]
pi@raspberrypi:~/domoticz/plugins/broadlink $ sudo python setup.py
print("\r>> Bytes downloaded -->" + state + str(leng) + state, end='', flush=True)
Posted: Thursday 20 August 2020 23:52
by zak45
wizardnl wrote: Thursday 20 August 2020 23:47
So, come back error occur with wrong python version ...
and when you do : sudo python --version ??
