Page 6 of 7
Re: dzVents get garbage collection dates (various)
Posted: Saturday 22 August 2020 15:06
by waaren
riko wrote: Saturday 22 August 2020 13:48
.. I'm also looking to customize the notification timing. I would like to have a notification the night before the garbage collection day.
Try changing the part
-- Update text device
if myTextDevice then
local garbageLines = ''
for _, key in ipairs(sortedKeys) do
garbageLines = garbageLines .. string2Date(garbage[key][1], '%a %e %b' ) .. ': ' .. longGarbageName(garbage[key][2]) .. '\n'
dz.devices(myTextDevice).updateText(garbageLines)
from the version posted 14 June 2020 to
-- Update text device / Notify for tomorrow
if dz.time.addHours(24).rawDate == garbage[key][1] and dz.time.matchesRule("at 18:00-22:00") then
dz.notify('Huisafval',longGarbageName(garbage[key][2]) .. ' wordt morgen opgehaald',dz.PRIORITY_NORMAL,dz.SOUND_DEFAULT, "" , myNotificationTable)
if myTextDevice then dz.devices(myTextDevice).updateText(garbageLines) end
Posted: Saturday 22 August 2020 21:46
by ronaldbro
I had the same on my wish list. Already did a change to get the message a day before but I noticed that when I have two pickups in two days that I don't have the message for the second day.
To make it work I'm think of splitting the alert widget into 3 widgets, 1 for each container I have.
Just need a few hours of spare time...
Posted: Saturday 22 August 2020 22:17
by waaren
ronaldbro wrote: Saturday 22 August 2020 21:46
Can you try the change I proposed earlier today? It should also work for your requirement.
Posted: Saturday 22 August 2020 23:06
by ronaldbro
Thanks waaren, just changed the code and will see in the coming days. Got a plastics pickup on Monday and paper on Tuesday so should get a notification tomorrow and Monday.
Posted: Sunday 23 August 2020 0:53
by plugge
Hm, the script gives an error. See the last two lines.
Any ideas?
Version: 2020.2 (build 12252)
Build Hash: ce7f13306
Compile Date: 2020-08-20 15:38:42
dzVents Version: 3.0.11
Python Version: 3.8.3 (tags/v3.8.3:6f8c832, May 13 2020, 22:20:19) [MSC v.1925 32 bit (Intel)]
2020-08-23 00:43:00.115 Status: dzVents: Info: collectGarbage: ------ Start internal script: GetGarbageDates:, trigger: "at 00:43"
2020-08-23 00:43:00.116 Status: dzVents: Debug: collectGarbage: OpenURL: url = http://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode [removed for privacy reasons]
2020-08-23 00:43:00.116 Status: dzVents: Debug: collectGarbage: OpenURL: method = GET
2020-08-23 00:43:00.116 Status: dzVents: Debug: collectGarbage: OpenURL: post data = nil
2020-08-23 00:43:00.116 Status: dzVents: Debug: collectGarbage: OpenURL: headers = nil
2020-08-23 00:43:00.116 Status: dzVents: Debug: collectGarbage: OpenURL: callback = getGarbage_Response
2020-08-23 00:43:00.117 Status: dzVents: Info: collectGarbage: ------ Finished GetGarbageDates
2020-08-23 00:43:00.117 Status: EventSystem: Script event triggered: D:\Program Files (x86)\Domoticz\dzVents\runtime\dzVents.lua
2020-08-23 00:43:01.438 Status: dzVents: Info: collectGarbage: ------ Start internal script: GetGarbageDates: HTTPResponse: "getGarbage_Response"
2020-08-23 00:43:01.488 Status: dzVents: Info: collectGarbage: 2020-08-28
2020-08-23 00:43:01.489 Status: dzVents: Info: collectGarbage: 2020-09-03
2020-08-23 00:43:01.489 Status: dzVents: Info: collectGarbage: 2020-08-28
2020-08-23 00:43:01.489 Status: dzVents: Debug: collectGarbage: Papier en kartonnen verpakkingen
2020-08-23 00:43:01.489 Friday 28 August, 2020
2020-08-23 00:43:01.507 Status: dzVents: Debug: collectGarbage: Processing device-adapter for GarbageAlert: Alert sensor adapter
2020-08-23 00:43:01.508 Status: dzVents: Debug: collectGarbage:
2020-08-23 00:43:01.508 alertLevel: 1, alertText: Papier en kartonnen verpakkingen
2020-08-23 00:43:01.508 Friday 28 August, 2020
2020-08-23 00:43:01.508 Status: dzVents: Info: collectGarbage: 2020-08-28
2020-08-23 00:43:01.508 Status: dzVents: Info: collectGarbage: ------ Finished GetGarbageDates
2020-08-23 00:43:01.508 Status: EventSystem: Script event triggered: D:\Program Files (x86)\Domoticz\dzVents\runtime\dzVents.lua
2020-08-23 00:43:01.508 Error: dzVents: Error: (3.0.11) collectGarbage: An error occurred when calling event handler GetGarbageDates
2020-08-23 00:43:01.508 Error: dzVents: Error: (3.0.11) collectGarbage: ...cz\scripts\dzVents\generated_scripts/GetGarbageDates.lua:117: bad argument #1 to 'date' (invalid conversion specifier '%e %b')
Somewhere in
local function string2Date(str,fmt) -- convert string from json into datevalue
if fmt then return os.date(fmt,string2Epoch(str)) end
return os.date(' %A %d %B, %Y',string2Epoch(str))
Posted: Sunday 23 August 2020 1:07
by waaren
plugge wrote: Sunday 23 August 2020 0:53
Any ideas?
Lua os.date behaves a little bit different on windows systems.
Try changing
to
garbageLines = garbageLines .. string2Date(garbage[key][1], '%a %d %b' ) .. ': ' .. longGarbageName(garbage[key][2]) .. '\n'
Posted: Sunday 23 August 2020 1:12
by plugge
Thanks waaren! It works fine now.
And thanks for the heads-up that Lua os.date behaves different on Windows systems.
Posted: Sunday 23 August 2020 1:33
by plugge
@waaren does this difference with Windows occurs elsewhere in the script, because it misses a date (27 august), but lists 03 september.
2020-08-23 01:32:01.927 Status: dzVents: Info: collectGarbage: ------ Start internal script: GetGarbageDates: HTTPResponse: "getGarbage_Response"
2020-08-23 01:32:01.983 Status: dzVents: Info: collectGarbage: 2020-08-28
2020-08-23 01:32:01.983 Status: dzVents: Info: collectGarbage: 2020-09-03
2020-08-23 01:32:01.984 Status: dzVents: Info: collectGarbage: 2020-08-28
2020-08-23 01:32:01.984 Status: dzVents: Debug: collectGarbage: Papier en kartonnen verpakkingen
2020-08-23 01:32:01.984 Friday 28 August, 2020
2020-08-23 01:32:02.002 Status: dzVents: Debug: collectGarbage: Processing device-adapter for GarbageAlert: Alert sensor adapter
2020-08-23 01:32:02.002 alertLevel: 1, alertText: Papier en kartonnen verpakkingen
2020-08-23 01:32:02.002 Friday 28 August, 2020
2020-08-23 01:32:02.002 Status: dzVents: Info: collectGarbage: 2020-08-28
2020-08-23 01:32:02.002 Status: dzVents: Info: collectGarbage: 2020-09-03
2020-08-23 01:32:02.003 Status: dzVents: Debug: collectGarbage: Processing device-adapter for GarbageText: Text device
2020-08-23 01:32:02.005 Status: dzVents: Info: collectGarbage: ------ Finished GetGarbageDates
Posted: Sunday 23 August 2020 4:36
by plugge
plugge wrote: Sunday 23 August 2020 1:33
Found the culprit.
The keyword is different for my community: "restgft" (kliko with two sections) instead of "restafval", plus some other keywords "kerstbomen", "textiel".
Posted: Sunday 23 August 2020 14:16
by riko
Thanks, I now realise that I use an older script which one enabled me to make use of the RMN.nl schedule. I just tried to adjust the newest 14 June version to be able to load the RMN data. As my town doesn't support MijnAfvalwijzer. This older script made use of the BagId in the following REST call:
https://inzamelschema.rmn.nl/rest/adressen/" ..myBagId .. "/kalender/" .. myYear (check
https://inzamelschema.rmn.nl/rest/adres ... ender/2020 for an example of the response, which has possible another structure than Mijnafvalwijzer)
This is the adjusted part of the script that I tried:
execute = function(dz, item)
--++++--------------------- Mandatory: Set your values and device names below this Line --------------------------------------
-- local myZipcode = '3085RA' -- Your zipcode like '3085RA'
-- local myHousenumber = 38 -- Your housenumber like 38
local myBagId = "0312200000006752"
local myTextDevice = 'GarbageText2' -- Name with quotes or idx without when created as virtual text device
local myAlertDevice = 'GarbageAlert2' -- Name with quotes or idx without when created as virtual alert device
local myYear = os.date("%Y") -- Rik: weet niet zeker of deze er ook uit kan met dit nieuwe script?
local myNotificationTable =
-- table with one or more notification systems.
-- uncomment the notification systems that you want to be used
-- Can be one or more of
-- dz.NSS_FIREBASE_CLOUD_MESSAGING,
-- dz.NSS_PUSHOVER,
-- dz.NSS_HTTP,
-- dz.NSS_KODI,
-- dz.NSS_LOGITECH_MEDIASERVER,
-- dz.NSS_NMA,
-- dz.NSS_PROWL,
-- dz.NSS_PUSHALOT,
-- dz.NSS_PUSHBULLET,
-- dz.NSS_PUSHOVER,
-- dz.NSS_PUSHSAFER,
dz.NSS_TELEGRAM,
--++++---------------------------- No changes required below this line --------------------------------------------
local debug = ( dz.utils.LOG_MODULE_EXEC_INFO == dz.LOG_DEBUG )
local garbageTypes = {100,3,87,1}
local function collectGarbageDates(secondsFromNow)
local getGarbage_url = "https://inzamelschema.rmn.nl/rest/adressen/" ..myBagId .. "/kalender/" .. myYear
dz.openURL ({ url = getGarbage_url ,
method = "GET",
callback = "getGarbage_Response" }).afterSec(secondsFromNow)
This didn't work
Do you know a way how I can get the notification part working for the older script? Which worked fine for me till now. The notification on the day of collection used to work with the following code:
if dz.time.matchesRule("at 06:00-17:00") and garbageToday then
dz.notify(longGarbageName(overallEarliestType) .. "wordt vandaag opgehaald")
Posted: Sunday 23 August 2020 18:23
by waaren
riko wrote: Sunday 23 August 2020 14:16
If you share the older script you use and still gives you a warning on the garbage collection day itself, I will have a look.
Posted: Monday 24 August 2020 8:07
by riko
Thanks. I'll test it first myself on Thursday (Friday is the next collection day
). I'll let you know the result
waaren wrote: Sunday 23 August 2020 18:23
Posted: Tuesday 25 August 2020 14:28
by ronaldbro
ronaldbro wrote: Saturday 22 August 2020 23:06
Thanks waaren, the change worked perfectly
Posted: Monday 31 August 2020 14:58
by riko
Last Friday's garbage collection proofed my adjustments didn't work
This is the full code of the script I use. As you see I've adjusted the garbage types according to my local situation:
--[[ getGarbageDates.lua for [ dzVents >= 2.4 ]
This script is only useful in those areas of the Netherlands where the HVC group collects household garbage
Enter your zipcode and housenumber in the appropriate place between the lines starting with --++++
Next is to set your virtual text and or virtual alert device.
the text device will contain the most nearby collectdates for the four types of household garbage
the alert device will contain the date and type for the garbagecollecion that will arrive first
Ga naar de volgende url in de browser, waarbij je de juiste url voor jouw afvalverwerker kiest, en postcode en huisnummer wijzigd.
https://apps.hvcgroep.nl/rest/adressen/3328LN-35
de output die je krijgt te zien bevat een bagID wat je later nodig hebt.
Dit bagId wordt gebruikt in de volgende URLs:
Ophaaldagen: https://apps.hvcgroep.nl/rest/adressen/BagID/kalender/2018 <<replace BagID
De ophaaldagen gebruiken ID's om aan te geven welk afvaltype het betreft.
Informatie over deze afvaltypes kan opgehaald worden via:
https://apps.hvcgroep.nl/rest/adressen/BagID/afvalstromen <<replace BagID
active = true,
on = { timer = { "at 20:00","at 07:00" }, -- daily run twice
-- { timer = {'every 1 minutes'},
httpResponses = { "getGarbage_Response" } -- Trigger the handle Json part
logging = { level = domoticz.LOG_INFO, -- Remove the "-- at the beginning of this and next line for debugging the script
marker = "collectGarbage" },
data = { garbage = {initial = {} }, -- Keep a copy of last json just in case
execute = function(dz, triggerObject)
local myTextDevice = "Garbage" -- Name with quotes or idx without when created as virtual text device
local myAlertDevice = "GarbageAlert" -- Name with quotes or idx without when created as virtual alert device
-- it can happen that other examples then HVC uses other numbers, change them at line
--++++---------------------------- Set your values and device names above this Line --------------------------------------------
method = "GET",
-- Add entry to log and notify to all subsystems
local function errorMessage(message)
dz.log(message,dz.LOG_ERROR)
dz.notify(message)
local function string2Epoch(dateString) -- seconds from epoch based on stringdate (used by string2Date)
-- Assuming a date pattern like: yyyy-mm-dd
local pattern = "(%d+)-(%d+)-(%d+)"
local runyear, runmonth, runday= dateString:match(pattern)
local convertedTimestamp = os.time({year = runyear, month = runmonth, day = runday})
return convertedTimestamp
return os.date(" %A %d %B, %Y",string2Epoch(str))
local function alertLevel(delta)
if delta < 2 then return dz.ALERTLEVEL_RED end
if delta < 3 then return dz.ALERTLEVEL_YELLOW end
if delta < 4 then return dz.ALERTLEVEL_ORANGE end
return dz.ALERTLEVEL_GREEN
local function setGarbageAlertDevice(alertDevice,alertText,alertDate)
local delta = tonumber(string2Date(alertDate,"%d")) - tonumber(os.date("%d")) -- delta in days between today and first garbage collection date
dz.devices(alertDevice).updateAlertSensor(alertLevel(delta),alertText)
return (delta == 0)
local function longGarbageName(str) -- Use descriptive strings
str = tostring(str)
str = str:gsub("100"," Plastic ")
str = str:gsub("3"," GFT afval (bruin) ")
str = str:gsub("87"," Oud papier en kartonnen (blauw) ")
str = str:gsub("1"," Restafval (grijs) ")
return str
local function handleResponse()
if #triggerObject.json > 0 then
dz.data.garbage = triggerObject.json
rt = triggerObject.json
errorMessage("Problem with response from hvcgroep (no data) using data from earlier run")
rt = dz.data.garbage -- json empty. Get last valid from dz.data
if #rt < 1 then -- No valid data in dz.data either
errorMessage("No previous data. are zipcode and housenumber ok and in HVC group area ?")
return false
local garbageLines = ""
local typeEarliestDate
local overallEarliestDate = "2999-12-31" -- Hopefully we will have a different garbage collection system by then
local garbageToday = false
local today = os.date("%Y-%m-%d")
for i = 1,#garbageTypes do --walk the the type Table
typeEarliestDate = "2999-12-31"
for j = 1,#rt do -- walk the result Table
-- walk the response table
if rt[j].ophaaldatum >= today and rt[j].ophaaldatum < typeEarliestDate and
rt[j].afvalstroom_id == garbageTypes[i] then -- Keep date closest to today per type
typeEarliestDate = rt[j].ophaaldatum
if typeEarliestDate < overallEarliestDate then -- date closest to today overall ?
overallEarliestDate = typeEarliestDate -- keep date
overallEarliestType = garbageTypes[i] -- keep type
garbageLines = garbageLines .. string2Date(typeEarliestDate,"%a %e %b" ) .. longGarbageName(rt[j].afvalstroom_id) .. " " .. "\n"
typeEarliestDate = rt[j].ophaaldatum -- Keep date closest to today
if myAlertDevice then -- Update AlertDevice with nearby date / type
garbageToday = setGarbageAlertDevice( myAlertDevice,
longGarbageName(overallEarliestType) .. "\n" ..
string2Date(overallEarliestDate),
if myTextDevice then -- Update defined virtual text device with dates / types
if (dz.time.addHours(24).rawDate == garbage) and dz.time.matchesRule("at 18:00-22:00") then
dz.notify(longGarbageName(overallEarliestType) .. "wordt morgen opgehaald")
-- Main
if triggerObject.isHTTPResponse then
if triggerObject.ok then
handleResponse()
errorMessage("Problem with response from hvcgroep (not ok)")
collectGarbageDates(600) -- response not OK, try again after 10 minutes
collectGarbageDates(1)
I tried to create a line myself, but it doesn't work (see one of the latest lines in the script):
Could you help me in fixing this? Or even better: if it is easy for you to enable the RMN schedule in your latest release of the script it is even better. I think it was there in earlier versions. I also like your new feature of the sorting on date, which is neither there in the old script.
Posted: Monday 31 August 2020 17:19
by waaren
riko wrote: Monday 31 August 2020 14:58
Can you try this?
--[[ getGarbageDates.lua for [ dzVents >= 2.4.28 ]
Enter your bagid in the appropriate place between the lines starting with --++++
return
on =
timer =
'at 20:00',
'at 07:00'
devices =
-- 'getGarbage', -- Only for test purposes can be ignored
httpResponses =
'getGarbage_Response' -- Trigger to handle Json part
logging =
level = domoticz.LOG_ERROR, -- set to LOG_DEBUG when something does not work as expected
marker = 'collectGarbage',
data =
garbage =
initial = {}, -- Keep a copy of last json just in case
dz.NSS_PUSHOVER,
-- dz.NSS_HTTP,
-- dz.NSS_KODI,
-- dz.NSS_NMA,
-- dz.NSS_PROWL,
-- dz.NSS_PUSHALOT,
-- dz.NSS_PUSHOVER,
-- dz.NSS_TELEGRAM,
local longGarbageName =
[100] = "Plastic",
[3] = "GFT afval (bruin)",
[87] = "Oud papier en kartonnen (blauw)",
[1] = "Restafval (grijs)"
-- Add entry to log and notify to set subsystems
dz.notify('Garbage',message, dz.PRIORITY_HIGH, dz.SOUND_DEFAULT, "" , myNotificationTable)
local function convertDateFormat(dateString, fromPattern, toFormat)
local fromPattern = fromPattern or '(%d+)-(%d+)-(%d+)'
local toFormat = toFormat or '%a %d %b'
local runyear, runmonth, runday= dateString:match(fromPattern)
return os.date(toFormat, os.time({year = runyear, month = runmonth, day = runday}) )
local function text(lines)
if dz.utils.deviceExists(myTextDevice) then
dz.devices(myTextDevice).updateText( table.concat(lines, '\n') )
local function alert(lines)
if dz.utils.deviceExists(myAlertDevice) then
dz.devices(myAlertDevice).updateAlertSensor(alertLevel(lines.delta), lines[1])
if dz.time.matchesRule('at 05:00-09:00') and lines.delta == 0 then
dz.notify('Huisafval',lines[1]:match('%: (.*)') .. ' will be collected today', dz.PRIORITY_NORMAL,dz.SOUND_DEFAULT, "" , myNotificationTable)
elseif dz.time.matchesRule('at 17:00-22:00') and lines.delta == 1 then
dz.notify('Huisafval',lines[1]:match('%: (.*)') .. ' will be collected tomorrow', dz.PRIORITY_NORMAL,dz.SOUND_DEFAULT, "" , myNotificationTable)
local function selectRecords(t)
dateRecords = {}
for _, garbage in ipairs(t) do
if garbage.ophaaldatum >= dz.time.rawDate then
if dateRecords[garbage.ophaaldatum] then
table.insert(dateRecords[garbage.ophaaldatum], longGarbageName[garbage.afvalstroom_id] )
dateRecords[garbage.ophaaldatum] = { longGarbageName[garbage.afvalstroom_id] }
dz.log(garbage.ophaaldatum .. ' = ' .. longGarbageName[garbage.afvalstroom_id], dz.LOG_DEBUG)
return dateRecords
local function makeLines(t)
local startDate = dz.time
local futureDay = 0
local lineCounter = 1
local textLines = {}
while lineCounter < 5 and futureDay < 60 do
local traverseDate = startDate.addDays(futureDay).rawDate
if t[traverseDate] then
local textLine = convertDateFormat(traverseDate) .. ': ' .. table.concat(t[traverseDate], ' plus ')
if lineCounter == 1 then textLines.delta = futureDay end
textLines[lineCounter] = textLine
lineCounter = lineCounter + 1
futureDay = futureDay + 1
return textLines
if not(item.ok and item.json) then
errorMessage('Problem with response (no data). Try using data from earlier run')
errorMessage('No previous data. is bagnumber ok?')
return false
rt = selectRecords(item.json)
textLines = makeLines(rt)
alert(textLines)
text(textLines)
-- Main
if item.isHTTPResponse then
if item.ok then
handleResponse()
errorMessage('Problem with response (not ok)')
Posted: Tuesday 01 September 2020 7:25
by riko
waaren wrote: Monday 31 August 2020 17:19
Can you try this?
Thanks, waaren. The script is working so far: devices are updated, and sorted(!), no errors
I'll have to test the notifications this weekend again. I'll let you know about the result
Posted: Friday 04 September 2020 13:49
by riko
It is working, thanks a lot waaren!
For all others who want to use RMN.nl as the data source (for certain Dutch municipalities). This is the script that works. Simply fill-in the bag ID field with the number you can find on:
https://inzamelschema.rmn.nl/rest/adressen/0000aa-99 (0000aa = zip code - 00 = house number)
return
on =
timer =
'at 20:00',
'at 07:00'
devices =
httpResponses =
logging =
level = domoticz.LOG_DEBUG, -- set to LOG_DEBUG when something does not work as expected
data =
garbage =
local myBagId = "XXXXXXXX" -- Find bagid at https://inzamelschema.rmn.nl/rest/adressen/0000aa-99 (zip code - house number)
-- dz.NSS_PUSHOVER,
-- dz.NSS_HTTP,
-- dz.NSS_KODI,
-- dz.NSS_NMA,
-- dz.NSS_PROWL,
-- dz.NSS_PUSHALOT,
-- dz.NSS_PUSHOVER,
dz.NSS_TELEGRAM,
[100] = "Plastic",
dateRecords = {}
return dateRecords
local futureDay = 0
return textLines
return false
alert(textLines)
text(textLines)
-- Main
if item.ok then
handleResponse()
Posted: Saturday 05 September 2020 19:56
by riko
Unfortunately one more bug to report with the script above.
The 'tomorrow notification' works correctly in normal cases, but doesn't work when there is also garbage to be collected today (and tomorrow again)
I don't recognise this problem in the script, anyone knows how to fix this?
Posted: Saturday 05 September 2020 21:49
by waaren
riko wrote: Saturday 05 September 2020 19:56
Can you try with this? Idea is that you will get a notification in the morning for a collection today and a notification in the evening for a collection tomorrow.
local eveningRun = 'at 20:00'
local morningRun = 'at 07:00'
return
on =
timer =
morningRun,
eveningRun,
devices =
httpResponses =
logging =
data =
garbage =
-- dz.NSS_PUSHOVER,
-- dz.NSS_HTTP,
-- dz.NSS_KODI,
-- dz.NSS_NMA,
-- dz.NSS_PROWL,
-- dz.NSS_PUSHALOT,
-- dz.NSS_PUSHOVER,
dz.NSS_TELEGRAM,
[100] = "Plastic",
dateRecords = {}
return dateRecords
local futureDay = 0
if dz.time.matchesRule(eveningRun) then futureDay = 1 end
return textLines
return false
alert(textLines)
text(textLines)
-- Main
if item.ok then
handleResponse()
Posted: Thursday 17 September 2020 20:26
by riko
Yes, this one seems to be working, thanks!!
