Alexa text to speech Topic is solved
- emme
- Domoticz version: latest
Re: Alexa text to speech
that's not a domoticz native application,
you have to install nodered, install the palette for Alexa and then interact somehow with it...
I use to send from my scripts a MQTT telegram on a specific topic for the Alexa TTS...
Then I have node intercept the telegram and send it to ALexa-Remote2
"We always done this way"
Damsee
- Domoticz version: 4.10717
It works like a charmHesmink wrote: Monday 02 September 2019 14:55 For anyone who has abandoned this because of the cookie thing: There is now support for 2 factor authentication, supposedly eliminating the re-logging in.
Check https://blog.loetzimmer.de/2017/10/amaz ... -echo.html
You have to enable 2 factor authentication at amazon and add another app that will do the 2 factor stuff on linux for you.
Hope it would still be OK within 3 weeks for cookie stuff...
RPI3 Raspbian Buster + Domoticz v2020.1 stable + RFXtrx433E + Z-Stick Gen5 + Amazon Echo (alexicz)
x5 THGN810 / x5 ZMNHJD1 / x2 Flood sensor FGFS101 / x1 Smoke sensor FGSD002
x1 ZMNHAD1 / x2 FGS213 / x3 Wallplug FGWPE/F / NodOn Soft remote CRC-3-6-0
philipgoodfellow
- Domoticz version: 4.10085
There has been a sudden change in Alexa!
I have been using the text to speech script without issue for some time.
Now, suddenly, Alexa is saying the word "underscore" between each word.
Any ideas? Any cure?
Philip
Philip
sammyke007
- Domoticz version: 2022.1
I will try it later today when I get home.philipgoodfellow wrote: Saturday 02 May 2020 12:55 There has been a sudden change in Alexa!
Philip
EDIT: working still like it should over here!
philipgoodfellow
Still useful data!working still like it should over here!
My Echo is in the UK. (talking to co.uk address)
Can anyone in uk replicate?
sammyke007
I live in Belgium, but I have it configured with a .co.uk account.
Can you share your script without personal data ?
philipgoodfellow
I have not modified this script myself beyond the url and personal details.
##!/bin/sh
# Amazon Alexa Remote Control
# alex(at)loetzimmer.de
# 2017-10-10: v0.1 initial release
# 2017-10-11: v0.2 TuneIn Station Search
# 2017-10-11: v0.2a commands on special device "ALL" are executed on all ECHO+WHA
# 2017-10-16: v0.3 added playback of library tracks
# 2017-10-24: v0.4 added playback information
# 2017-11-21: v0.5 added Prime station and playlist
# 2017-11-22: v0.6 added Prime historical queue and replaced getopts
# 2017-11-25: v0.6a cURL is now configurable
# 2017-11-25: v0.7 added multiroom create/delete, playback of library playlist
# 2017-11-30: v0.7a added US config, fixed device names containing spaces
# 2017-12-07: v0.7b added Bluetooth connect/disconnect
# 2017-12-18: v0.7c fixed US version
# 2017-12-19: v0.7d fixed AWK csrf extraction on some systems
# 2017-12-20: v0.7e moved get_devlist after check_status
# 2018-01-08: v0.7f added echo-show to ALL group, TuneIn station can now be up to 6 digits
# 2018-01-08: v0.8 added bluetooth list function
# 2018-01-10: v0.8a abort when login was unsuccessful
# 2018-01-25: v0.8b added echo-spot to ALL group
# 2018-01-28: v0.8c added configurable browser string
# 2018-02-17: v0.8d no need to write the cookie file on every "check_status"
# 2018-02-27: v0.8e added "lastalexa" option for HA-Bridge to send its command to a specific device
# (Markus Wennesheimer: https://wennez.wordpress.com/light-on-with-alexa-for-each-room/)
# 2018-02-27: v0.9 unsuccessful logins will now give a short info how to debug the login
# 2018-03-09: v0.9a workaround for login problem, force curl to use http1.1
# 2018-05-17: v0.9b update browser string and accept language
# 2018-05-23: v0.9c update accept language (again)
# 2018-06-12: v0.10 introducing TTS and more
# (thanks to Michael Geramb and his openHAB2 Amazon Echo Control binding)
# https://github.com/openhab/openhab2-addons/tree/master/addons/binding/org.openhab.binding.amazonechocontrol
# (thanks to Ralf Otto for implementing this feature in this script)
# 2018-06-13: v0.10a added album play of imported library
# 2018-06-18: v0.10b added Alex routine execution
# (no BASHisms were used, should run with any shell)
# - requires cURL for web communication
# - (GNU) sed and awk for extraction
# - jq as command line JSON parser (optional for the fancy bits)
EMAIL=<email>
PASSWORD=<password>
#LANGUAGE="de-DE"
LANGUAGE="en-GB"
AMAZON='amazon.co.uk'
#AMAZON='amazon.com'
ALEXA='alexa.amazon.co.uk'
#ALEXA='pitangui.amazon.com'
# cURL binary
CURL='/usr/bin/curl'
# cURL options
# -k : if your cURL cannot verify CA certificates, you'll have to trust any
# --compressed : if your cURL was compiled with libz you may use compression
# --http1.1 : cURL defaults to HTTP/2 on HTTPS connections if available
OPTS='--compressed --http1.1'
#OPTS='-k --compressed --http1.1'
# browser identity
BROWSER='Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0'
# nothing to configure below here
TMP="/tmp"
COOKIE="${TMP}/.alexa.cookie"
DEVLIST="${TMP}/.alexa.devicelist.json"
GUIVERSION=0
LIST=""
LOGOFF=""
COMMAND=""
TTS=""
UTTERANCE=""
SEQUENCECMD=""
STATIONID=""
QUEUE=""
SONG=""
ALBUM=""
ARTIST=""
TYPE=""
ASIN=""
SEEDID=""
HIST=""
LEMUR=""
CHILD=""
PLIST=""
BLUETOOTH=""
LASTALEXA=""
usage()
echo "$0 [-d <device>|ALL] -e <pause|play|next|prev|fwd|rwd|shuffle|vol:<0-100>> |"
echo " -b [list|<\"AA:BB:CC:DD:EE:FF\">] | -q | -r <\"station name\"|stationid> |"
echo " -s <trackID|'Artist' 'Album'> | -t <ASIN> | -u <seedID> | -v <queueID> | -w <playlistId> |"
echo " -i | -p | -P | -S | -a | -m <multiroom_device> [device_1 .. device_X] | -lastalexa | -l | -h"
echo
echo " -e : run command, additional SEQUENCECMDs:"
echo " weather,traffic,flashbriefing,goodmorning,singasong,tellstory,speak:'<text>',automation:'<routine name>'"
echo " -b : connect/disconnect/list bluetooth device"
echo " -q : query queue"
echo " -r : play tunein radio"
echo " -s : play library track/library album"
echo " -t : play Prime playlist"
echo " -u : play Prime station"
echo " -v : play Prime historical queue"
echo " -w : play library playlist"
echo " -i : list imported library tracks"
echo " -p : list purchased library tracks"
echo " -P : list Prime playlists"
echo " -S : list Prime stations"
echo " -a : list available devices"
echo " -m : delete multiroom and/or create new multiroom containing devices"
echo " -lastalexa : print device that received the last voice command"
echo " -l : logoff"
echo " -h : help"
while [ "$#" -gt 0 ] ; do
case "$1" in
-d)
if [ "${2#-}" != "${2}" -o -z "$2" ] ; then
echo "ERROR: missing argument for ${1}"
usage
exit 1
fi
DEVICE=$2
shift
-e)
usage
exit 1
fi
COMMAND=$2
shift
-b)
if [ "${2#-}" = "${2}" -a -n "$2" ] ; then
BLUETOOTH=$2
shift
BLUETOOTH="null"
fi
-m)
usage
exit 1
fi
LEMUR=$2
shift
while [ "${2#-}" = "${2}" -a -n "$2" ] ; do
CHILD="${CHILD} ${2}"
shift
done
-r)
usage
exit 1
fi
STATIONID=$2
shift
# stationIDs are "s1234" or "s12345"
if [ -n "${STATIONID##s[0-9][0-9][0-9][0-9]}" -a -n "${STATIONID##s[0-9][0-9][0-9][0-9][0-9]}" -a -n "${STATIONID##s[0-9][0-9][0-9][0-9][0-9][0-9]}" ] ; then
# search for station name
STATIONID=$(${CURL} ${OPTS} -s --data-urlencode "query=${STATIONID}" -G "https://api.tunein.com/profiles?fullTextSearch=true" | jq -r '.Items[] | select(.ContainerType == "Stations") | .Children[] | select( .Index==1 ) | .GuideId')
if [ -z "$STATIONID" ] ; then
echo "ERROR: no Station \"$2\" found on TuneIn"
exit 1
fi
fi
-s)
usage
exit 1
fi
SONG=$2
shift
ALBUM=$2
ARTIST=$SONG
shift
fi
-t)
usage
exit 1
fi
ASIN=$2
shift
-u)
usage
exit 1
fi
SEEDID=$2
shift
-v)
usage
exit 1
fi
HIST=$2
shift
-w)
usage
exit 1
fi
PLIST=$2
shift
-l)
LOGOFF="true"
-a)
LIST="true"
-i)
TYPE="IMPORTED"
-p)
TYPE="PURCHASES"
-P)
PRIME="prime-playlist-browse-nodes"
-S)
PRIME="prime-sections"
-q)
QUEUE="true"
-lastalexa)
LASTALEXA="true"
-h|-\?|--help)
usage
exit 0
echo "ERROR: unknown option ${1}"
usage
exit 1
esac
shift
done
case "$COMMAND" in
pause)
COMMAND='{"type":"PauseCommand"}'
play)
COMMAND='{"type":"PlayCommand"}'
next)
COMMAND='{"type":"NextCommand"}'
prev)
COMMAND='{"type":"PreviousCommand"}'
fwd)
COMMAND='{"type":"ForwardCommand"}'
rwd)
COMMAND='{"type":"RewindCommand"}'
shuffle)
COMMAND='{"type":"ShuffleCommand","shuffle":"true"}'
vol:*)
VOL=${COMMAND##*:}
# volume as integer!
if [ $VOL -le 100 -a $VOL -ge 0 ] ; then
COMMAND='{"type":"VolumeLevelCommand","volumeLevel":'${VOL}'}'
echo "ERROR: volume should be an integer between 0 and 100"
usage
exit 1
fi
speak:*)
SEQUENCECMD='Alexa.Speak'
TTS=$(echo ${COMMAND##*:} | sed -r 's/[^-a-zA-Z0-9_,?! ]//g' | sed 's/ /_/g')
TTS=",\\\"textToSpeak\\\":\\\"${TTS}\\\""
automation:*)
SEQUENCECMD='automation'
UTTERANCE=$(echo ${COMMAND##*:} | sed -r 's/[^-a-zA-Z0-9_,?! ]//g')
weather)
SEQUENCECMD='Alexa.Weather.Play'
traffic)
SEQUENCECMD='Alexa.Traffic.Play'
flashbriefing)
SEQUENCECMD='Alexa.FlashBriefing.Play'
goodmorning)
SEQUENCECMD='Alexa.GoodMorning.Play'
singasong)
SEQUENCECMD='Alexa.SingASong.Play'
tellstory)
SEQUENCECMD='Alexa.TellStory.Play'
echo "ERROR: unknown command \"${COMMAND}\"!"
usage
exit 1
esac
# Amazon Login
log_in()
# following headers are required:
# Accept-Language (possibly for determining login region)
# User-Agent (cURL wouldn't store cookies without)
rm -f ${DEVLIST}
rm -f ${COOKIE}
rm -f ${TMP}/.alexa.*.list
# get first cookie and write redirection target into referer
${CURL} ${OPTS} -s -D "${TMP}/.alexa.header" -c ${COOKIE} -b ${COOKIE} -A "${BROWSER}" -H "Accept-Language: ${LANGUAGE}" -H "DNT: 1" -H "Connection: keep-alive" -H "Upgrade-Insecure-Requests: 1" -L\
https://alexa.${AMAZON} | grep "hidden" | sed 's/hidden/\n/g' | grep "value=\"" | sed -r 's/^.*name="([^"]+)".*value="([^"]+)".*/\1=\2\&/g' > "${TMP}/.alexa.postdata"
# login empty to generate session
${CURL} ${OPTS} -s -c ${COOKIE} -b ${COOKIE} -A "${BROWSER}" -H "Accept-Language: ${LANGUAGE}" -H "DNT: 1" -H "Connection: keep-alive" -H "Upgrade-Insecure-Requests: 1" -L\
-H "$(grep 'Location: ' ${TMP}/.alexa.header | sed 's/Location: /Referer: /')" -d "@${TMP}/.alexa.postdata" https://www.${AMAZON}/ap/signin | grep "hidden" | sed 's/hidden/\n/g' | grep "value=\"" | sed -r 's/^.*name="([^"]+)".*value="([^"]+)".*/\1=\2\&/g' > "${TMP}/.alexa.postdata2"
# login with filled out form
# !!! referer now contains session in URL
${CURL} ${OPTS} -s -D "${TMP}/.alexa.header2" -c ${COOKIE} -b ${COOKIE} -A "${BROWSER}" -H "Accept-Language: ${LANGUAGE}" -H "DNT: 1" -H "Connection: keep-alive" -H "Upgrade-Insecure-Requests: 1" -L\
-H "Referer: https://www.${AMAZON}/ap/signin/$(awk "\$0 ~/.${AMAZON}.*session-id[ \\s\\t]+/ {print \$7}" ${COOKIE})" --data-urlencode "email=${EMAIL}" --data-urlencode "password=${PASSWORD}" -d "@${TMP}/.alexa.postdata2" https://www.${AMAZON}/ap/signin > "${TMP}/.alexa.login"
# check whether the login has been successful or exit otherwise
if [ -z "$(grep 'Location: https://alexa.*html' ${TMP}/.alexa.header2)" ] ; then
echo "ERROR: Amazon Login was unsuccessful. Possibly you get a captcha login screen."
echo " Try logging in to https://alexa.${AMAZON} with your browser. In your browser"
echo " make sure to have all Amazon related cookies deleted and Javascript disabled!"
echo
echo " (For more information have a look at ${TMP}/.alexa.login)"
rm -f ${COOKIE}
rm -f "${TMP}/.alexa.header"
rm -f "${TMP}/.alexa.header2"
rm -f "${TMP}/.alexa.postdata"
rm -f "${TMP}/.alexa.postdata2"
exit 1
fi
# get CSRF
${CURL} ${OPTS} -s -c ${COOKIE} -b ${COOKIE} -A "${BROWSER}" -H "DNT: 1" -H "Connection: keep-alive" -L\
-H "Referer: https://alexa.${AMAZON}/spa/index.html" -H "Origin: https://alexa.${AMAZON}"\
https://${ALEXA}/api/language > /dev/null
rm -f "${TMP}/.alexa.login"
# get JSON device list
get_devlist()
${CURL} ${OPTS} -s -b ${COOKIE} -A "${BROWSER}" -H "DNT: 1" -H "Connection: keep-alive" -L\
-H "Content-Type: application/json; charset=UTF-8" -H "Referer: https://alexa.${AMAZON}/spa/index.html" -H "Origin: https://alexa.${AMAZON}"\
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})"\
"https://${ALEXA}/api/devices-v2/device?cached=false" > ${DEVLIST}
check_status()
# bootstrap with GUI-Version writes GUI version to cookie
# returns among other the current authentication state
AUTHSTATUS=$(${CURL} ${OPTS} -s -b ${COOKIE} -A "${BROWSER}" -H "DNT: 1" -H "Connection: keep-alive" -L https://${ALEXA}/api/bootstrap?version=${GUIVERSION} | sed -r 's/^.*"authenticated":([^,]+),.*$/\1/g')
if [ "$AUTHSTATUS" = "true" ] ; then
return 1
fi
return 0
# set device specific variables from JSON device list
set_var()
DEVICE=$(echo ${DEVICE} | sed -r 's/%20/ /g')
if [ -z "${DEVICE}" ] ; then
# if no device was supplied, use the first Echo(dot) in device list
echo "setting default device to:"
DEVICE=$(jq -r '[ .devices[] | select(.deviceFamily == "ECHO" or .deviceFamily == "KNIGHT" or .deviceFamily == "ROOK" ) | .accountName] | .[0]' ${DEVLIST})
echo ${DEVICE}
fi
DEVICETYPE=$(jq --arg device "${DEVICE}" -r '.devices[] | select(.accountName == $device) | .deviceType' ${DEVLIST})
DEVICESERIALNUMBER=$(jq --arg device "${DEVICE}" -r '.devices[] | select(.accountName == $device) | .serialNumber' ${DEVLIST})
MEDIAOWNERCUSTOMERID=$(jq --arg device "${DEVICE}" -r '.devices[] | select(.accountName == $device) | .deviceOwnerCustomerId' ${DEVLIST})
if [ -z "${DEVICESERIALNUMBER}" ] ; then
echo "ERROR: unkown device dev:${DEVICE}"
exit 1
fi
# list available devices from JSON device list
list_devices()
jq -r '.devices[].accountName' ${DEVLIST}
# execute command
# (SequenceCommands by Michael Geramb and Ralf Otto)
run_cmd()
if [ -n "${SEQUENCECMD}" ]
then
if [ "${SEQUENCECMD}" = 'automation' ] ; then
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X GET \
"https://${ALEXA}/api/behaviors/automations" > "${TMP}/.alexa.automation"
AUTOMATION=$(jq --arg utterance "${UTTERANCE}" -r '.[] | select( .triggers[].payload.utterance == $utterance) | .automationId' "${TMP}/.alexa.automation")
if [ -z "${AUTOMATION}" ] ; then
echo "ERROR: no such utterance '${UTTERANCE}' in Alexa routines"
rm -f "${TMP}/.alexa.automation"
exit 1
fi
SEQUENCE=$(jq --arg utterance "${UTTERANCE}" -rc '.[] | select( .triggers[].payload.utterance == $utterance) | .sequence' "${TMP}/.alexa.automation" | sed 's/"/\\"/g' | sed "s/ALEXA_CURRENT_DEVICE_TYPE/${DEVICETYPE}/g" | sed "s/ALEXA_CURRENT_DSN/${DEVICESERIALNUMBER}/g" | sed "s/ALEXA_CUSTOMER_ID/${MEDIAOWNERCUSTOMERID}/g" | sed 's/ /_/g')
echo "Running routine: ${UTTERANCE}"
COMMAND="{\"behaviorId\":\"${AUTOMATION}\",\"sequenceJson\":\"${SEQUENCE}\",\"status\":\"ENABLED\"}"
echo "Sequence command: ${SEQUENCECMD}"
COMMAND="{\"behaviorId\":\"PREVIEW\",\"sequenceJson\":\"{\\\"@type\\\":\\\"com.amazon.alexa.behaviors.model.Sequence\\\",\\\"startNode\\\":{\\\"@type\\\":\\\"com.amazon.alexa.behaviors.model.OpaquePayloadOperationNode\\\",\\\"type\\\":\\\"${SEQUENCECMD}\\\",\\\"operationPayload\\\":{\\\"deviceType\\\":\\\"${DEVICETYPE}\\\",\\\"deviceSerialNumber\\\":\\\"${DEVICESERIALNUMBER}\\\",\\\"locale\\\":\\\"${LANGUAGE}\\\",\\\"customerId\\\":\\\"${MEDIAOWNERCUSTOMERID}\\\"${TTS}}}}\",\"status\":\"ENABLED\"}"
fi
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d ${COMMAND}\
"https://${ALEXA}/api/behaviors/preview"
"https://${ALEXA}/api/np/command?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}"
fi
# play TuneIn radio station
play_radio()
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST\
"https://${ALEXA}/api/tunein/queue-and-play?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&guideId=${STATIONID}&contentType=station&callSign=&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}"
# play library track
play_song()
if [ -z "${ALBUM}" ] ; then
JSON="{\"trackId\":\"${SONG}\",\"playQueuePrime\":true}"
JSON="{\"albumArtistName\":\"${ARTIST}\",\"albumName\":\"${ALBUM}\"}"
fi
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "${JSON}"\
"https://${ALEXA}/api/cloudplayer/queue-and-play?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}&shuffle=false"
# play library playlist
play_playlist()
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "{\"playlistId\":\"${PLIST}\",\"playQueuePrime\":true}"\
# play PRIME playlist
play_prime_playlist()
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "{\"asin\":\"${ASIN}\"}"\
"https://${ALEXA}/api/prime/prime-playlist-queue-and-play?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}"
# play PRIME station
play_prime_station()
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "{\"seed\":\"{\\\"type\\\":\\\"KEY\\\",\\\"seedId\\\":\\\"${SEEDID}\\\"}\",\"stationName\":\"none\",\"seedType\":\"KEY\"}"\
"https://${ALEXA}/api/gotham/queue-and-play?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}"
# play PRIME historical queue
play_prime_hist_queue()
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "{\"deviceType\":\"${DEVICETYPE}\",\"deviceSerialNumber\":\"${DEVICESERIALNUMBER}\",\"mediaOwnerCustomerId\":\"${MEDIAOWNERCUSTOMERID}\",\"queueId\":\"${HIST}\",\"service\":null,\"trackSource\":\"TRACK\"}"\
"https://${ALEXA}/api/media/play-historical-queue"
# show library tracks
show_library()
OFFSET="";
SIZE=50;
TOTAL=0;
FILE=${TMP}/.alexa.${TYPE}.list
if [ ! -f ${FILE} ] ; then
echo -n '{"playlist":{"entryList":[' > ${FILE}
while [ 50 -le ${SIZE} ] ; do
"https://${ALEXA}/api/cloudplayer/playlists/${TYPE}-V0-OBJECTID?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&size=${SIZE}&offset=${OFFSET}&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}" > ${FILE}.tmp
OFFSET=$(jq -r '.nextResultsToken' ${FILE}.tmp)
SIZE=$(jq -r '.playlist | .trackCount' ${FILE}.tmp)
jq -r -c '.playlist | .entryList' ${FILE}.tmp >> ${FILE}
echo "," >> ${FILE}
TOTAL=$((TOTAL+SIZE))
done
echo "[]],\"trackCount\":\"${TOTAL}\"}}" >> ${FILE}
rm -f ${FILE}.tmp
fi
jq -r '.playlist.trackCount' ${FILE}
jq '.playlist.entryList[] | .[]' ${FILE}
# show Prime stations and playlists
show_prime()
FILE=${TMP}/.alexa.${PRIME}.list
"https://${ALEXA}/api/prime/{$PRIME}?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}" > ${FILE}
if [ "$PRIME" = "prime-playlist-browse-nodes" ] ; then
for I in $(jq -r '.primePlaylistBrowseNodeList[].subNodes[].nodeId' ${FILE} 2>/dev/null) ; do
"https://${ALEXA}/api/prime/prime-playlists-by-browse-node?browseNodeId=${I}&deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}" >> ${FILE}
done
fi
fi
jq '.' ${FILE}
# current queue
show_queue()
PARENT=""
PARENTID=$(jq --arg device "${DEVICE}" -r '.devices[] | select(.accountName == $device) | .parentClusters[0]' ${DEVLIST})
if [ "$PARENTID" != "null" ] ; then
PARENTDEVICE=$(jq --arg serial ${PARENTID} -r '.devices[] | select(.serialNumber == $serial) | .deviceType' ${DEVLIST})
PARENT="&lemurId=${PARENTID}&lemurDeviceType=${PARENTDEVICE}"
fi
"https://${ALEXA}/api/np/player?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}${PARENT}" | jq '.'
"https://${ALEXA}/api/media/state?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}" | jq '.'
"https://${ALEXA}/api/np/queue?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}" | jq '.'
# deletes a multiroom device
delete_multiroom()
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X DELETE \
"https://${ALEXA}/api/lemur/tail/${DEVICESERIALNUMBER}"
# creates a multiroom device
create_multiroom()
JSON="{\"id\":null,\"name\":\"${LEMUR}\",\"members\":["
for DEVICE in $CHILD ; do
set_var
JSON="${JSON}{\"dsn\":\"${DEVICESERIALNUMBER}\",\"deviceType\":\"${DEVICETYPE}\"},"
done
JSON="${JSON%,}]}"
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "${JSON}" \
"https://${ALEXA}/api/lemur/tail"
# list bluetooth devices
list_bluetooth()
"https://${ALEXA}/api/bluetooth?cached=false" | jq --arg serial "${DEVICESERIALNUMBER}" -r '.bluetoothStates[] | select(.deviceSerialNumber == $serial) | "\(.pairedDeviceList[]?.address) \(.pairedDeviceList[]?.friendlyName)"'
# connect bluetooth device
connect_bluetooth()
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "{\"bluetoothDeviceAddress\":\"${BLUETOOTH}\"}"\
"https://${ALEXA}/api/bluetooth/pair-sink/${DEVICETYPE}/${DEVICESERIALNUMBER}"
# disconnect bluetooth device
disconnect_bluetooth()
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST \
"https://${ALEXA}/api/bluetooth/disconnect-sink/${DEVICETYPE}/${DEVICESERIALNUMBER}"
# device that sent the last command
# (by Markus Wennesheimer)
last_alexa()
${CURL} ${OPTS} -s -b ${COOKIE} -A "Mozilla/5.0" -H "DNT: 1" -H "Connection: keep-alive" -L\
"https://${ALEXA}/api/activities?startTime=&size=1&offset=1" | jq -r '.activities[0].sourceDeviceIds[0].serialNumber' | xargs -i jq -r --arg device {} '.devices[] | select( .serialNumber == $device) | .accountName' ${DEVLIST}
# Serial number: | jq -r '.activities[0].sourceDeviceIds[0].serialNumber'
# Device name: | jq -r '.activities[0].sourceDeviceIds[0].serialNumber' | xargs -i jq -r --arg device {} '.devices[] | select( .serialNumber == $device) | .accountName' ${DEVLIST}
# logout
log_off()
https://${ALEXA}/logout > /dev/null
rm -f ${DEVLIST}
rm -f ${COOKIE}
if [ -z "$LASTALEXA" -a -z "$BLUETOOTH" -a -z "$LEMUR" -a -z "$PLIST" -a -z "$HIST" -a -z "$SEEDID" -a -z "$ASIN" -a -z "$PRIME" -a -z "$TYPE" -a -z "$QUEUE" -a -z "$LIST" -a -z "$COMMAND" -a -z "$STATIONID" -a -z "$SONG" -a -n "$LOGOFF" ] ; then
echo "only logout option present, logging off ..."
log_off
exit 0
fi
if [ ! -f ${COOKIE} ] ; then
echo "cookie does not exist. logging in ..."
log_in
fi
check_status
if [ $? -eq 0 ] ; then
echo "cookie expired, logging in again ..."
log_in
check_status
echo "log in failed, aborting"
exit 1
fi
fi
if [ ! -f ${DEVLIST} ] ; then
echo "device list does not exist. downloading ..."
get_devlist
echo "failed to download device list, aborting"
exit 1
fi
fi
if [ -n "$COMMAND" -o -n "$QUEUE" ] ; then
if [ "${DEVICE}" = "ALL" ] ; then
for DEVICE in $(jq -r '.devices[] | select( .deviceFamily == "ECHO" or .deviceFamily == "KNIGHT" or .deviceFamily == "ROOK" or .deviceFamily == "WHA") | .accountName' ${DEVLIST} | sed -r 's/ /%20/g') ; do
set_var
if [ -n "$COMMAND" ] ; then
echo "sending cmd:${COMMAND} to dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER} customerid:${MEDIAOWNERCUSTOMERID}"
run_cmd
echo "queue info for dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER}"
show_queue
fi
done
set_var
run_cmd
show_queue
fi
fi
elif [ -n "$LEMUR" ] ; then
DEVICESERIALNUMBER=$(jq --arg device "${LEMUR}" -r '.devices[] | select(.accountName == $device and .deviceFamily == "WHA") | .serialNumber' ${DEVLIST})
if [ -n "$DEVICESERIALNUMBER" ] ; then
delete_multiroom
if [ -z "$CHILD" ] ; then
echo "ERROR: ${LEMUR} is no multiroom device. Cannot delete ${LEMUR}".
exit 1
fi
fi
echo "Deleted multi room dev:${LEMUR} serial:${DEVICESERIALNUMBER}"
echo "Creating multi room dev:${LEMUR} member_dev(s):${CHILD}"
create_multiroom
fi
rm -f ${DEVLIST}
get_devlist
elif [ -n "$BLUETOOTH" ] ; then
if [ "$BLUETOOTH" = "list" -o "$BLUETOOTH" = "List" -o "$BLUETOOTH" = "LIST" ] ; then
set_var
echo "bluetooth devices for dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER}:"
list_bluetooth
done
set_var
list_bluetooth
fi
elif [ "$BLUETOOTH" = "null" ] ; then
set_var
echo "disconnecting dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER} from bluetooth"
set_var
echo "connecting dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER} to bluetooth device:${BLUETOOTH}"
connect_bluetooth
fi
elif [ -n "$STATIONID" ] ; then
set_var
echo "playing stationID:${STATIONID} on dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER} mediaownerid:${MEDIAOWNERCUSTOMERID}"
play_radio
elif [ -n "$SONG" ] ; then
set_var
echo "playing library track:${SONG} on dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER} mediaownerid:${MEDIAOWNERCUSTOMERID}"
play_song
elif [ -n "$PLIST" ] ; then
set_var
echo "playing library playlist:${PLIST} on dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER} mediaownerid:${MEDIAOWNERCUSTOMERID}"
play_playlist
elif [ -n "$LIST" ] ; then
echo "the following devices exist in your account:"
list_devices
elif [ -n "$TYPE" ] ; then
set_var
echo -n "the following songs exist in your ${TYPE} library: "
show_library
elif [ -n "$PRIME" ] ; then
set_var
echo "the following songs exist in your PRIME ${PRIME}:"
show_prime
elif [ -n "$ASIN" ] ; then
set_var
echo "playing PRIME playlist ${ASIN}"
play_prime_playlist
elif [ -n "$SEEDID" ] ; then
set_var
echo "playing PRIME station ${SEEDID}"
play_prime_station
elif [ -n "$HIST" ] ; then
set_var
echo "playing PRIME historical queue ${HIST}"
elif [ -n "$LASTALEXA" ] ; then
last_alexa
echo "no alexa command received"
fi
if [ -n "$LOGOFF" ] ; then
echo "logout option present, logging off ..."
log_off
fi
sammyke007
You know there's already an update v0.16a?
Please try the updated script!
https://github.com/thorsten-gehrig/alex ... control.sh
salopette
- Domoticz version: BETA
Hello, can someone give me instructions on how to install Multi-Factor Authentication it on the Pi?
Because at some point it stops working and I have to log in again via the browser.
Thx
Thx
philipgoodfellow
Thank you. All now works. I should have checked I was up-to-date first. Rookie error.
Philip
sammyke007
That's what this community is for, helping each other
Noob Alert!
I would love if someone can please help me - tearing my hair out with this script.
I've not been able to successfully even login yet. I've tried 2FA and got that set up with Oath Tool.
I've tried various cookie methods.
Whenever I run the script, it says, cookie not found then deletes the .alexa.cookie file that I created from my tmp folder.
In the UK with UK settings.
Anyone got any advice?
TIA
Noob Alert!
TIA
xavierlp
- Domoticz version: 2020.2
Hello
Same case here.
Can't find the solution
Any help appreciated
Xavier
Same case here.
Xavier
salopette
Can someone help me please?salopette wrote: Sunday 03 May 2020 11:14 Hello, can someone give me instructions on how to install Multi-Factor Authentication it on the Pi?
Thx
sammyke007
salopette wrote: Thursday 14 May 2020 19:31Can someone help me please?salopette wrote: Sunday 03 May 2020 11:14 Hello, can someone give me instructions on how to install Multi-Factor Authentication it on the Pi?
Thx
https://github.com/thorsten-gehrig/alexa-remote-control
What's wrong with these instructions? They still work fine. Just used it yesterday on a new Pi.
What's not working for you?
salopette
i installed oathtool and amazon i have a long number!
But where and how should oathtool enter the number?
if I oathtool -b --totp asf iskahskah hsashjk ajhdksajsja joskrelkrök enter, nothing comes
sammyke007
You have to put the long number between double quotes " ... "salopette wrote: Thursday 14 May 2020 20:59 i installed oathtool and amazon i have a long number!
Eg:
oathtool -b --totp "1234 5678 9ABC DEFG HIJK LMNO PQRS TUVW XYZ0 1234 5678 9ABC DEFG"Eg:
SET_MFA_SECRET='1234 5678 9ABC DEFG HIJK LMNO PQRS TUVW XYZ0 1234 5678 9ABC DEFG'-
salopette
I did that, but this message comes up
pi@raspberrypi:~/domoticz/scripts $ sudo ./alexa_remote_control.sh -a
/usr/bin/oathtool: base32 decoding failed: Base32 string is invalid
Try logging in to https://alexa.amazon.de with your browser. In your browser
(For more information have a look at /tmp/.alexa.login)
To avoid issues with captcha, try using Multi-Factor Authentication.
To do so, first set up Two-Step Verification on your Amazon account, then
configure this script (or the environment) with your MFA secret.
Support for Multi-Factor Authentication requires 'oathtool' to be installed.
- sshot-1.jpg (22.44 KiB) Viewed 7601 times
sammyke007
That's because your SET_MFA_SECRET is way too short. You wrote down the short 6-digit PIN in the script and that's not what should be in there! You should place your long key over there, not the 6-digit number. The 6-digit number is only for entering once in the Amazon verification window.salopette wrote: Friday 15 May 2020 5:12 I did that, but this message comes up
pi@raspberrypi:~/domoticz/scripts $ sudo ./alexa_remote_control.sh -a cookie does not exist. logging in ... /usr/bin/oathtool: base32 decoding failed: Base32 string is invalid ERROR: Amazon Login was unsuccessful. Possibly you get a captcha login screen. Try logging in to https://alexa.amazon.de with your browser. In your browser make sure to have all Amazon related cookies deleted and Javascript disabled! (For more information have a look at /tmp/.alexa.login) To avoid issues with captcha, try using Multi-Factor Authentication. To do so, first set up Two-Step Verification on your Amazon account, then configure this script (or the environment) with your MFA secret. Support for Multi-Factor Authentication requires 'oathtool' to be installed.
If you like, PM me and maybe I can help over Teamviewer or Anydesk...
salopette
Thank you so much! That was the mistake!
Now it's back!
Now it's back!
