Page 6 of 114
Posted: Sunday 26 November 2017 14:49
by Madgeni
MrDee wrote: Sunday 26 November 2017 13:35
If there's still room I would like to help with the beta as well ... running Domoticz @ Pi2
Already registered with Controlicz on Friday
E-mail starts with domi
Thanks in advance!
I can't see you - need a bit more i'm afraid
Posted: Sunday 26 November 2017 15:20
by MrDee
Madgeni wrote: Sunday 26 November 2017 14:49
Thanks in advance!
My bad ... i've updated my e-mailadress! You should now be able to find
[email protected]
Posted: Sunday 26 November 2017 16:20
by ledje
And while you are at it.. mine is
[email protected] . I am really itching to five my Google home mini a try heheh
Posted: Sunday 26 November 2017 16:39
by Madgeni
Both of you have been added - you should have email
Posted: Sunday 26 November 2017 18:27
by tohn
Can also help with beta testing.
has registred with controlicz with email tony.b...............
Best Regards
Tony
Posted: Sunday 26 November 2017 18:30
by Madgeni
Added
Posted: Sunday 26 November 2017 19:42
by tohn
Thanks,
When i try to link Controlicz to home control, after I have allowed fill access to my accont, I get
"could not update the settings. check your connection."
Any suggestions ?
Posted: Sunday 26 November 2017 19:46
by Failure404
I also have registered myself, look for failure.
I used my proxy settings, hoping that it will work - eventually
Thx alot!
Posted: Sunday 26 November 2017 20:04
by ledje
Just had that problem myself. Your account in domoticz does not have the proper permissions. Try it with your domoticz admin account as a test first.
Posted: Sunday 26 November 2017 20:15
by tohn
Does not help with Domoticz admin account.
Posted: Sunday 26 November 2017 21:36
by Madgeni
usual checklist:
Is your host accessible over the internet? Are you using an https port? Are your devices in Room Plans? In Controlicz, you don't need to specify https:// in your hostname, if you have, please remove it.
Posted: Sunday 26 November 2017 21:54
by tohn
Yes, Its accessible over internet. using 8443 as port that's is nat:ed to https on domoticz box.
ex
https://url.domain.com:8443
Yes has devoces in room plans.
No https in hostname in Controlitcz,
Host : domain.com
Port : 8443
Use the built in certificate in Domoticz if that can be a problem ?
Posted: Sunday 26 November 2017 22:01
by MrDee
Briliant stuff, repect Geni! Finally light in the end of the tunnel to combine Google Home/Assistant with Domoticz!
Some feedback/an issue:
After i cleaned-up my Rooms and added new MiLights (in Domoticz) i wasn't able to see them in 'Home Automation'. So 2-hours later i decided to unlink/link again (Google Home-App), except now i see only 3-devices. All the other ones aren't comming back anymore? Please advice.
Posted: Sunday 26 November 2017 22:02
by Madgeni
tohn wrote: Sunday 26 November 2017 21:54
ex
Host : domain.com
Port : 8443
Hi - can you PM me your email address, i'll take a look
Posted: Sunday 26 November 2017 23:44
by plasmagun86
I would like to use controlicz with my domoticz and google assistant. I am registred on controlicz with email vers***ete.ro***
[email protected].
Could you please send me the email with the instructions ?
Thank you
Posted: Sunday 26 November 2017 23:45
by Madgeni
Madgeni wrote: Sunday 26 November 2017 22:02
ex
Host : domain.com
Port : 8443
This got fixed
Posted: Sunday 26 November 2017 23:47
by Madgeni
plasmagun86 wrote: Sunday 26 November 2017 23:44
[email protected].
Thank you
Added - you should have an email with instructions
Posted: Monday 27 November 2017 8:06
by mottola
Bonjour,
Je suis bien,enregistré sur controlicz.
Comment faire,pour utiliser google home avec?
Merci,
Posted: Monday 27 November 2017 15:10
by knacki123
Hi Madgeni
i would like to test it too.
Can you add me ,please? My Mail starts with christia.schm......... and I´m registered in controlicz.
thanks
Posted: Monday 27 November 2017 15:12
by Madgeni
mottola wrote: Monday 27 November 2017 8:06
Bonjour,
Merci,
Bonjour
Pouvez-vous PM votre email address svp, ou les premiere quattre lettres du votre email ici?
Merci!
