My log shows an error, while the calculation seems te be done just fine. Any ideas?
--version 0.1 02-04-2021: dzVents version of solar battery script
--version 0.1.1 03-04-2021: fix left behind variable and avoidance of power level > max inverter power level, due to rounding of calculation
--version 0.1.2 05-04-2021: changed a check for latest data storage from seconds to milliseconds to accommodate meters that update every second
--version 0.1.3 05-04-2021: Added a check to avoid big deviations in calculation when inverter power level is small while having
-- also a small script interval. Added more debug logging
--version 0.1.4b 10-04-2021: Description text fix + little preparation for future release
--version 0.1.5 11-04-2021: Lost energy due to battery and due to inverter size are now split and only combined during device update
--version 0.2a 14-04-2021: BREAKING CHANGE: -- 'Lost Energy' 'Electric + Instant + Counter' device need to be replaced by a 'P1-meter' device
-- New 'P1-meter' device needs to be added to trace losses in limited battery inverter
--To be created virtual devices in the hardware section of Domoticz:
local solarBattery_name = 'Virtual Solar Battery' -- (1) Virtual 'Custom Sensor' device name for the 'Virtual Solar Battery'. Change axis label to kWh
local batteryUsage_name = 'Virtual Solar Battery Usage' -- (2) Virtual 'P1-meter' device name for monitoring storage in and consumption from the solar battery
--local lostEnergy_name = 'Lost Solar Energy' (No longer needed, will be removed in later version -- (x) Virtual 'Electric Instant + Counter' device name for the 'Lost Solar Energy'
local lostBattery_name = 'Lost Solar Battery Energy' -- (3) Virtual 'P1-meter' device name for the 'Lost Solar Battery Energy'
local lostInverter_name = 'Lost Solar Battery Inverter Energy' -- (4) Virtual 'P1-meter' device name for the 'Lost Solar Battery Inverter Energy'
--To be created User Variable in the Setup - More Options - User Variable section:
local battery_capacity_name = 'SolarBatteryCapacity' -- (5) User Variable name for the 'Solar Battery Capacity'. Type 'Integer'. Value in Wh (4kWh battery = '4000')
local battery_inverter_power_name = 'SolarBatteryInverterCap' -- (6) User variable name for the 'Solar Battery Inverter Power'. Type 'Integer'. Value in W
--Energy meter(s) management
--name the device(s) used for counting energy from/to the grid
--when a P1 meter is used for both 'from' and 'to' the grid, fill in this name for both lines! Else, fill in the name for both requested devices
--Device name for consumed energy FROM the grid:
local consumedEnergyMeter_name = 'Energie kWh' --(7)
--Device name for delivered energy TO the grid:
local returnedEnergyMeter_name = 'Energie kWh' --(8)
--decide if energy consumption with an empty battery counts as 'lost energy'
local emptyBatteryIsLostEnergy = 1 --(1 = yes, 0 = no) --(9)
--decide if energy losses due to limited inverter power count with a full/empty battery
local emptyFullBatteryCountLostInverterEnergy = 1 --(1 = yes, 0 = no) --(10)
--Interval of running the Script
local scriptInterval = 60 --(seconds. Minimum interval depends on update frequency of P1-meter. 0 = P1-meter update frequency) --(11)
-- 1 trigger for P1 meter with both consumption and production meter integrated. Otherwise 2 meters
if (consumedEnergyMeter_name == returnedEnergyMeter_name) then
meterName = consumedEnergyMeter_name
meterName = consumedEnergyMeter_name ..', '.. returnedEnergyMeter_name
active = true,
devices = {
--timer based devices
--sensor based devices
meterName,
--setting devices
--actuator devices
-- timer = {'every minute'}},
data = {
returnedEnergy = {initial=nil, history = true, maxItems = 1},
consumedEnergy = {initial= nil, history = true, maxItems = 1}
logging = {
level = domoticz.LOG_DEBUG, --domoticz.LOG_INFO, domoticz.LOG_MODULE_EXEC_INFO, domoticz.LOG_DEBUG or domoticz.LOG_ERROR
marker = "Hey solar battery"
---error checking functions ---
--check whether devices exist by veryfing their name
if domoticz.utils.deviceExists(solarBattery_name) == false then
domoticz.log('necessary device '.. solarBattery_name ..' doesnt exist. Script will end. Please add the device to Domoticz', domoticz.LOG_ERROR)
goto endScript
elseif domoticz.utils.deviceExists(batteryUsage_name) == false then
domoticz.log('necessary device '.. batteryUsage_name ..' doesnt exist. Script will end. Please add the device to Domoticz', domoticz.LOG_ERROR)
goto endScript
--elseif domoticz.utils.deviceExists(lostEnergy_name) == false then
-- domoticz.log('necessary device '.. lostEnergy_name ..' doesnt exist. Script will end. Please add the device to Domoticz', domoticz.LOG_ERROR)
-- goto endScript
elseif domoticz.utils.deviceExists(lostBattery_name) == false then
domoticz.log('necessary device '.. lostBattery_name ..' doesnt exist. Script will end. Please add the device to Domoticz', domoticz.LOG_ERROR)
goto endScript
elseif domoticz.utils.deviceExists(lostInverter_name) == false then
domoticz.log('necessary device '.. lostInverter_name ..' doesnt exist. Script will end. Please add the device to Domoticz', domoticz.LOG_ERROR)
goto endScript
elseif domoticz.utils.variableExists(battery_capacity_name) == false then
domoticz.log('User variable '.. battery_capacity_name ..' doesnt exist. Script will end. Please add the user variable to Domoticz', domoticz.LOG_ERROR)
goto endScript
elseif domoticz.utils.variableExists(battery_inverter_power_name) == false then
domoticz.log('User variable '.. battery_inverter_power_name ..' doesnt exist. Script will end. Please add the user variable to Domoticz', domoticz.LOG_ERROR)
goto endScript
--Devices exists, now define devices/variable within Domoticz:
local solarBattery = domoticz.devices(solarBattery_name)
local batteryUsage = domoticz.devices(batteryUsage_name)
--local lostEnergy = domoticz.devices(lostEnergy_name)
local lostBattery = domoticz.devices(lostBattery_name)
local lostInverter = domoticz.devices(lostInverter_name)
local consumedEnergyMeter = domoticz.devices(consumedEnergyMeter_name)
local returnedEnergyMeter = domoticz.devices(returnedEnergyMeter_name)
local battery_capacity = domoticz.variables(battery_capacity_name)
local battery_inverter_power = domoticz.variables(battery_inverter_power_name)
--Define script variables
local oldConsumedEnergyMeter
local oldReturnedEnergyMeter
local newConsumedEnergyMeter
local newReturnedEnergyMeter
local energyBalance
local solarBatteryValue
local newSolarBatteryValue
--local newLostEnergy
local newLostEnergyFull
local newLostEnergyEmpty
local batteryUsedEnergy
local batteryProdEnergy
local batteryUsedWatt
local batteryProdWatt
local batter
local deltaTime
local maxBbatteryInverterEnergy -- battery inverter power x (time since last time the script was ran / 3600) in Wh
local inverterLostEnergy -- lost energy to or from the grid due to limitation in battery capacity and/or battery inverter power
local inverterLostEnergyProd
local inverterLostEnergyUsed
local inverterLostEnergyProdFull
local inverterLostEnergyUsedEmpty
local inverterLostProdWatt
local inverterLostUsedWatt
local _ = domoticz.utils._
--check if new created virtual devices are the right type
if (solarBattery.deviceType ~= 'General' and solarBattery.deviceSubType ~= "Custom Sensor") then
domoticz.log('created device '.. solarBattery_name ..' is not of the type Custom Sensor. Script will end. Please add the correct device(type) to Domoticz', domoticz.LOG_ERROR)
goto endScript
elseif (batteryUsage.deviceType ~= 'P1 Smart Meter' and batteryUsage.deviceSubType ~= "Energy") then
domoticz.log('created device '.. batteryUsage_name ..' is not of the type P1-meter. Script will end. Please add the correct device(type) to Domoticz', domoticz.LOG_ERROR)
goto endScript
--elseif (lostEnergy.deviceType ~= 'General' and lostEnergy.deviceSubType ~= "kWh") then
-- domoticz.log('created device '.. lostEnergy_name ..' is not of the type RFXMeter. Script will end. Please add the correct device(type) to Domoticz', domoticz.LOG_ERROR)
-- goto endScript
elseif (lostBattery_name.deviceType ~= 'P1 Smart Meter' and lostBattery.deviceSubType ~= "Energy") then
domoticz.log('created device '.. lostBattery_name ..' is not of the type P1-meter. Script will end. Please add the correct device(type) to Domoticz', domoticz.LOG_ERROR)
elseif (lostInverter.deviceType ~= 'P1 Smart Meter' and lostInverter.deviceSubType ~= "Energy") then
domoticz.log('created device '.. lostEnergy_name ..' is not of the type P1-meter. Script will end. Please add the correct device(type) to Domoticz', domoticz.LOG_ERROR)
--check if variables are the right type and contain a good value
if battery_capacity.type ~= domoticz.INTEGER then
domoticz.log('User variable '.. battery_capacity_name ..' is not of the type INTEGER. Script will end. Please change the user variable to the type INTEGER and put a positive number in there', domoticz.LOG_ERROR)
goto endScript
elseif (battery_capacity.value == nil or battery_capacity.value < 0) then
domoticz.log('Solar battery capacity wrong or <0. Now set at 2000(Wh)', domoticz.LOG_ERROR)
battery_capacity.set(2000)
if battery_inverter_power.type ~= domoticz.INTEGER then
domoticz.log('User variable '.. battery_inverter_power_name ..' is not of the type INTEGER. Script will end. Please change the user variable to the type INTEGER and put a positive number in there', domoticz.LOG_ERROR)
goto endScript
elseif (battery_inverter_power.value == nil or battery_capacity.value < 0) then
domoticz.log('Solar battery inverter capacity wrong or <0. Now set at 4000(W)', domoticz.LOG_ERROR)
battery_inverter_power.set(4000)
if (emptyBatteryIsLostEnergy == nil or (emptyBatteryIsLostEnergy ~= 0 and emptyBatteryIsLostEnergy ~= 1 )) then
domoticz.log('internal variable emptyBatteryIsLostEnergy does not contain a value of 0 or 1. Script will use value 1 and count lost energy at an empty battery')
if (emptyFullBatteryCountLostInverterEnergy == nil or (emptyFullBatteryCountLostInverterEnergy ~= 0 and emptyFullBatteryCountLostInverterEnergy ~= 1)) then
domoticz.log('internal variable emptyFullBatteryCountLostInverterEnergy does not contain a value of 0 or 1. Script will use a value of 1 and count lost inverter energy at empty or full battery')
--check if persistent data exist and is a number. The new 'zero' value will be updated further down the script
if (domoticz.data.consumedEnergy.size == 0 or
_.isNumber(domoticz.data.consumedEnergy.getLatest().data)==false or
domoticz.data.consumedEnergy.getLatest().data < 0) then
domoticz.data.consumedEnergy.add(0)
domoticz.log('dzVents variable consumedEnergy was empty or did not contain a number. Now set as 0',domoticz.LOG_DEBUG)
if (domoticz.data.returnedEnergy.size == 0 or
_.isNumber(domoticz.data.returnedEnergy.getLatest().data)==false or
domoticz.data.returnedEnergy.getLatest().data < 0) then
domoticz.data.returnedEnergy.add(0)
domoticz.log('dzVents variable returnedEnergy was empty or did not contain a number. Now set as 0',domoticz.LOG_DEBUG)
--give a new virtual devices a start load of 0 kWh and 0 W
if solarBattery.sValue == nil then
solarBattery.updateCustomSensor(0)
domoticz.log('solar battery value is nil en will be updated to 0',domoticz.LOG_DEBUG)
if (batteryUsage.usage1 == nil or batteryUsage.return1 == nil) then batteryUsage.updateP1(0,0,0,0,0,0) end
--if lostEnergy.WhTotal == nil then lostEnergy.updateElectricity(0,0) end
if (lostBattery.usage1 == nil or lostBattery.return1 == nil) then lostBattery.updateP1(0,0,0,0,0,0) end
if (lostInverter.usage1 == nil or lostInverter.return1 == nil) then lostInverter.updateP1(0,0,0,0,0,0) end
--Check if scriptInterval value is valid
if (_.isNumber(scriptInterval) == false or scriptInterval < 0) then
domoticz.log('value for scriptInterval is invalid (not a number, or < 0). Script will use P1 update frequency (scriptInterval = 0)',domoticz.LOG_ERROR)
scriptInterval = 0
--Check if inverter power level in relation to script interval and the fact that the minimum energy count is 1Wh, is in balance
--(example: inverter power = 1800 @ scriptInterval of 1 second = 0,5 Wh.
--At 20 seconds ((3600/1800) x (100/10)) = 10Wh +/-0.5Wh(minimum counter value))
-- 10 +/-0.5 is a 10% deviation
local maxDev = 10 --percent
if (3600 / battery_inverter_power.value) * (100 / maxDev) > scriptInterval then
scriptInterval = _.round ((3600 / battery_inverter_power.value) * (100 / maxDev), 3)
domoticz.log('scriptInterval value increased to ' .. scriptInterval .. ' seconds to have a maximum deviation of ' .. maxDev .. ' percent', domoticz.LOG_DEBUG)
---end of error checking functions ---
--check if the script should continue, based on given scriptInterval timer
--check timestamp from persistent data
deltaTime = (domoticz.data.consumedEnergy.getLatest().time.millisecondsAgo)/1000
if (deltaTime < scriptInterval) then
domoticz.log("script trigger interval < than set value for scriptInterval (".. scriptInterval .. ")",domoticz.LOG_DEBUG)
goto endScript
---calculate new energy values
--check if device is a P1 meter
domoticz.log('energymeter type = '.. consumedEnergyMeter.deviceType, domoticz.LOG_DEBUG)
if consumedEnergyMeter.deviceType == 'P1 Smart Meter' then
newConsumedEnergyMeter = consumedEnergyMeter.usage1 + consumedEnergyMeter.usage2
newReturnedEnergyMeter = returnedEnergyMeter.return1 + returnedEnergyMeter.return2
--batteryProdWatt = consumedEnergyMeter.usage
--batteryUsedWatt = consumedEnergyMeter.usageDelivered
domoticz.log('P1 meter: usage and return values will be used', domoticz.LOG_DEBUG)
else -- other meter than P1 Smart Meter
newConsumedEnergyMeter = consumedEnergyMeter.WhTotal
newReturnedEnergyMeter = returnedEnergyMeter.WhTotal
domoticz.log('General Energy meters for consumption and returned: WhTotal will be used per meter', domoticz.LOG_DEBUG)
---load previous energy values for consumption and returnedEnergy
oldReturnedEnergyMeter = domoticz.data.returnedEnergy.getLatest().data
oldConsumedEnergyMeter = domoticz.data.consumedEnergy.getLatest().data
---check if the dzVents variable is new and if so, fill it with the current meter value
if oldConsumedEnergyMeter == 0 then
domoticz.data.consumedEnergy.add(newConsumedEnergyMeter)
if oldReturnedEnergyMeter == 0 then
domoticz.data.returnedEnergy.add(newReturnedEnergyMeter)
goto endScript
if (oldConsumedEnergyMeter == 0 or oldReturnedEnergyMeter == 0) then
domoticz.log('Script is gathering the value for the consumed / produced energy meter for the 1st time. Script will end and be continued at the next interval', domoticz.LOG_DEBUG)
goto endScript
---check for error when new value < old value
if newConsumedEnergyMeter < oldConsumedEnergyMeter then
domoticz.log('New value of consumed enery meter ('.. newConsumedEnergyMeter ..' Wh < previous value of '.. oldConsumedEnergyMeter..' Wh. Script will not continue',domoticz.LOG_ERROR)
goto endScript
elseif newReturnedEnergyMeter < newReturnedEnergyMeter then
domoticz.log('New value of returned enery meter ('.. newReturnedEnergyMeter ..' Wh < previous value of '.. oldReturnedEnergyMeter..' Wh. Script will not continue',domoticz.LOG_ERROR)
goto endScript
---calculate max. Wh that the battery inverter can handle (both directions)
maxBbatteryInverterEnergy = battery_inverter_power.value * (domoticz.data.consumedEnergy.getLatest().time.millisecondsAgo / 3600000)
domoticz.log('maxBbatteryInverterEnergy = '..battery_inverter_power.value .. ' x (' ..
domoticz.data.consumedEnergy.getLatest().time.secondsAgo .. ' / 3600) = ' .. _.round (maxBbatteryInverterEnergy, 1) .. ' Wh',domoticz.LOG_DEBUG)
---calculate the energy balance by: return - consumption
--a negative value means consumption
--a positive value means return
energyBalance = (newReturnedEnergyMeter - oldReturnedEnergyMeter) - (newConsumedEnergyMeter - oldConsumedEnergyMeter)
domoticz.log('Energy balance = '..energyBalance..' Wh (negative = consumption)',domoticz.LOG_DEBUG)
if energyBalance > maxBbatteryInverterEnergy then
inverterLostEnergy = energyBalance - maxBbatteryInverterEnergy
inverterLostEnergyProd = energyBalance - maxBbatteryInverterEnergy
inverterLostEnergyUsed = 0
domoticz.log('Positive energybalance above max inverter capacity. inverterLostEnergy = '.. energyBalance ..' - ' ..maxBbatteryInverterEnergy .. ' = ' .. inverterLostEnergy, domoticz.LOG_DEBUG)
energyBalance = maxBbatteryInverterEnergy
batteryProdWatt = battery_inverter_power.value
batteryUsedWatt = 0
elseif energyBalance < (-1 * maxBbatteryInverterEnergy) then -- more consumption than inverter can deliver
inverterLostEnergy = (-1 * energyBalance ) - maxBbatteryInverterEnergy
inverterLostEnergyUsed = (-1 * energyBalance ) - maxBbatteryInverterEnergy
inverterLostEnergyProd = 0
domoticz.log('Negative Energybalance below max inverter capacity. inverterLostEnergy = '.. -1 *energyBalance ..' - ' ..maxBbatteryInverterEnergy .. ' = ' .. inverterLostEnergy, domoticz.LOG_DEBUG)
energyBalance = -1 * maxBbatteryInverterEnergy
batteryUsedWatt = battery_inverter_power.value
batteryProdWatt = 0
inverterLostEnergy = 0
domoticz.log('Energy balance within capacity of battery inverter', domoticz.LOG_DEBUG)
---check the effect of the energy balance on the solar battery
solarBatteryValue = solarBattery.sValue * 1000 -- custom sensor registers in kWh, while internal calculations are done in Wh
newSolarBatteryValue = solarBatteryValue + energyBalance
domoticz.log('solar battery value = '..solarBatteryValue ..' Wh, battery capacity is '..battery_capacity.value ..' Wh, new solar battery value = '..newSolarBatteryValue, domoticz.LOG_DEBUG)
--initial variable values:
batteryProdEnergy = 0
batteryUsedEnergy = 0
newLostEnergyEmpty = 0
newLostEnergyFull = 0
inverterLostEnergyProdFull = 0
inverterLostEnergyUsedEmpty = 0
--decide what the new state of the battery will be
if newSolarBatteryValue > battery_capacity.value then --more energy produced than fits in battery
--newLostEnergy = newSolarBatteryValue - battery_capacity.value --count all energy that goes above the set capacity level
newLostEnergyFull = newSolarBatteryValue - battery_capacity.value --count all energy that goes above the set capacity level
--update battery level with max value
newSolarBatteryValue = battery_capacity.value
--check if the battery is not already full
if solarBatteryValue < battery_capacity.value then
batteryProdEnergy = battery_capacity.value - solarBatteryValue
if emptyFullBatteryCountLostInverterEnergy == 0 then --battery is already full without lost inverter energy
inverterLostProdWatt = 0
inverterLostEnergyProdFull = inverterLostEnergyProd
inverterLostEnergyProd = 0 -- reset value to zero, because 'ProdFull' is used instead
elseif newSolarBatteryValue < 0 then --more energy consumed than available in battery
--check if the battery is not already empty
if solarBatteryValue > 0 then
--first calculate the battery-used value (old value - 0)
batteryUsedEnergy = solarBatteryValue
if emptyBatteryIsLostEnergy == 1 then -- also count lost energy due to empty battery
--newLostEnergy = newSolarBatteryValue * -1 --(newSolarBatteryValue is negative, but it needs to be added UP to the counter)
newLostEnergyEmpty = newSolarBatteryValue * -1 --(newSolarBatteryValue is negative, but it needs to be added UP to the counter)
--newLostEnergy = 0
if emptyFullBatteryCountLostInverterEnergy == 0 then --battery is already empty without lost inverter energy, don't count (1 = count)
inverterLostUsedWatt = 0
inverterLostEnergyUsedEmpty = inverterLostEnergyUsed
inverterLostEnergyUsed = 0 -- reset value to zero, because 'UsedEmpty' is used instead
--update battery level to zero
newSolarBatteryValue = 0
else --new battery within bandwith of chosen battery capacity
--check if energy from battery is consumed
if energyBalance > 0 then
batteryProdEnergy = energyBalance
elseif energyBalance < 0 then
--negative value means consumption
batteryUsedEnergy = energyBalance*-1 --(energyBalance is negative, but it needs to be added UP to the counter)
--either no energy used or energy is returned
--newLostEnergy = 0
domoticz.log('battery Used Energy = '..batteryUsedEnergy .. 'Wh',domoticz.LOG_DEBUG)
domoticz.log('battery Prod Energy = '..batteryProdEnergy .. 'Wh',domoticz.LOG_DEBUG)
domoticz.log('battery Lost Energy empty = '..newLostEnergyEmpty .. 'Wh',domoticz.LOG_DEBUG)
domoticz.log('battery Lost Energy full = '..newLostEnergyFull .. 'Wh',domoticz.LOG_DEBUG)
domoticz.log('inverter Lost Energy production = '..inverterLostEnergyProd .. 'Wh',domoticz.LOG_DEBUG)
domoticz.log('inverter Lost Energy production when battery is full = '..inverterLostEnergyProdFull .. 'Wh',domoticz.LOG_DEBUG)
domoticz.log('inverter Lost Energy usage = '..inverterLostEnergyUsed .. 'Wh',domoticz.LOG_DEBUG)
domoticz.log('inverter Lost Energy usage when battery is full = '..inverterLostEnergyUsedEmpty .. 'Wh',domoticz.LOG_DEBUG)
--calculate battery power, based on battery energy
if batteryUsedWatt == nil then batteryUsedWatt = _.round (batteryUsedEnergy * (3600/deltaTime), 0) end
if batteryProdWatt == nil then batteryProdWatt = _.round (batteryProdEnergy * (3600/deltaTime), 0) end
--calculate lost energy power, based on lost energy
if lostEnergyWatt == nil then lostEnergyWatt = _.round ((newLostEnergyFull + newLostEnergyEmpty) * (3600/deltaTime), 0) end
--calculate lost inverter power, based on lost inverter energy
if inverterLostEnergyUsedEmpty == nil then inverterLostEnergyUsedEmpty = 0 end
if inverterLostEnergyProdFull == nil then inverterLostEnergyProdFull = 0 end
if inverterLostUsedWatt == nil then inverterLostUsedWatt = _.round ((inverterLostEnergyUsed + inverterLostEnergyUsedEmpty) * (3600/deltaTime), 0) end
if inverterLostProdWatt == nil then inverterLostProdWatt = _.round ((inverterLostEnergyProd + inverterLostEnergyProdFull)* (3600/deltaTime), 0) end
---update devices
--update battery level with new value
solarBattery.updateCustomSensor(_.round(newSolarBatteryValue / 1000,3))
--update battery usage with new value
batteryUsage.updateP1(batteryUsage.usage1 + batteryUsedEnergy, 0, batteryUsage.return1 + batteryProdEnergy, 0, batteryUsedWatt, batteryProdWatt)
--update lost energy with new value
--lostEnergy.updateElectricity(_.round(newLostEnergy * (3600/deltaTime),0), _.round(lostEnergy.WhTotal + newLostEnergy + inverterLostEnergy,0))
lostBattery.updateP1(lostBattery.usage1 + newLostEnergyEmpty, 0, lostBattery.return1 + newLostEnergyFull, 0, lostEnergyWatt, 0)
--update lost inverter energy with new value
lostInverter.updateP1(lostInverter.usage1 + inverterLostEnergyUsed, lostInverter.usage2 + inverterLostEnergyUsedEmpty,
lostInverter.return1 + inverterLostEnergyProd, lostInverter.return2 + inverterLostEnergyProdFull,
inverterLostUsedWatt, inverterLostProdWatt)
---Update dzVents variables with the new meter values
::endScript::
