Page 6 of 20
Re: Buienradar Weather Lookup Plugin
Posted: Tuesday 28 February 2017 13:46
by schulpr
Hi ffes,
I hope you can find some time to implement the other available weather data soon. I think it's very stable.
<zichtmeters>39000</zichtmeters>
<windstotenMS>13.8</windstotenMS>
<zonintensiteitWM2>292</zonintensiteitWM2>
Thanks for all your work!
Rob
Posted: Tuesday 28 February 2017 13:55
by ffes
@sander815
And when it stops working, what is shown in the log? Do you see the plugin's log lines appear?
Posted: Saturday 04 March 2017 19:15
by ffes
I just released a new version of my Buienradar plugin. This uses the new Settings dictionary that was added to the Python plugin in recent betas. So before you upgrade to this version of the Buienradar plugin be sure to have the latest beta of Domoticz.
So for new users there is zero configuration to get the plugin running initially.
Posted: Saturday 04 March 2017 22:25
by Bengelen
It works for me now, is it hard or possible to get data from buienradar.be also?
Posted: Sunday 05 March 2017 13:14
by ffes
Bengelen wrote:Is it hard or possible to get data from buienradar.be also?
That seems not possible. I use http://xml.buienradar.nl to get the weather information. http://xml.buienradar.be doesn't work, so there is no data to use for me.
Also notice that things they provide on http://www.buienradar.be/overbuienradar ... uw-website is much smaller then http://www.buienradar.nl/overbuienradar ... uw-website. Maybe multiple requests from various Belgian users will help them to bring those features to Belgium as well.
Posted: Sunday 05 March 2017 14:50
by RayAmsterdam
Beta 3.6863
Rpi 3b
Today I installed the plugin. After selecting it in the hardware menu, it said the devices are added to the devices tab. Unfortunately they aren't. Am I missing something?
Posted: Sunday 05 March 2017 17:50
by EdwinK
When trying to restart domoticz I get the following
root@DiskStation:/volume3/@appstore/domoticz/plugins/buienrader# sudo service domoticz.sh restart
sudo: service: command not found
Stopping and restarting from Synology panel didn't help either
Running on Synology 6.1
Posted: Sunday 05 March 2017 18:30
by ffes
RayAmsterdam wrote:Today I installed the plugin. After selecting it in the hardware menu, it said the devices are added to the devices tab. Unfortunately they aren't. Am I missing something?
What do you see in the log? Did you try to filter the devices based on the name you gave on the hardware page?
Posted: Sunday 05 March 2017 18:32
by RayAmsterdam
I get error "Error: Buienradar hardware (21) thread seems to have ended unexpectedly" in the log. I used the filter.
Posted: Sunday 05 March 2017 18:40
by ffes
RayAmsterdam wrote:I get error "Error: Buienradar hardware (21) thread seems to have ended unexpectedly" in the log. I used the filter.
Pfff, I have never seen that before. I don't think it is something I can do much about. A script should not be able to end a thread that way, I would think.
Do you run the latest beta of domoticz? Could you restart domoticz and look at the logs?
Posted: Sunday 05 March 2017 18:47
by RayAmsterdam
Yep, running latest beta. Already restarted Domoticz and pi. Sonos plugin is running normal.
Posted: Tuesday 07 March 2017 20:54
by RayAmsterdam
I reinstalled the plugin and reconfugured it in Domoticz. It stated again the hardware is created and devices added. I got the following errors in the log:
2017-03-07 20:50:34.186 Error: (Buienradar) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Buienradar/:/usr/local/lib/python35.zip:/usr/local/lib/python3.5/:/usr/local/lib/python3.5/plat-linux:/usr/local/lib/python3.5/lib-dynload'.
2017-03-07 20:50:34.186 Error: (Buienradar) Module Import failed, exception: 'ImportError'
2017-03-07 20:50:34.186 Error: (Buienradar) Module Import failed: ' Name: buienradar'
Posted: Wednesday 08 March 2017 12:34
by Snowtiger
RayAmsterdam wrote:I reinstalled the plugin and reconfugured it in Domoticz. It stated again the hardware is created and devices added. I got the following errors in the log:
there is a problem with the library the plugin uses - in your error code you see /plugins/Buienradar - if you do a
git clone
you get /plugins/domoticz-buienradar, this discrepancy can also be read in the Readme.md in Git
1.In your domoticz/plugins directory do
cd domoticz/plugins
git clone https://github.com/ffes/domoticz-buienradar.git
2.Alternatively you can download the latest version from https://github.com/ffes/domoticz-buienradar/archive/master.zip and unzip it. Then create a directory on your Domoticz device in domoticz/plugins named buienradar and transfer all the files to your device.
So - if you use the 2nd method the plugin should work.
@ffes should update git to get the modules in /plugins/Buienradar to let this work via git - my choice of method btw ;)
I created an issue in Git to address this
Posted: Wednesday 08 March 2017 12:37
by RayAmsterdam
Thanks! I missed the files.
Posted: Thursday 09 March 2017 7:35
by Derik
mmm
Is there a how to for plugins?
Posted: Thursday 09 March 2017 10:04
by htca
I got this error:
2017-03-09 09:54:20.583 (buienradar) Initialized version 1.1.0, author 'ffes'
2017-03-09 09:54:20.663 (buienradar) Devices created.
2017-03-09 09:54:20.663 Error: (buienradar) 'onStart' failed 'NameError':'name 'Settings' is not defined'.
2017-03-09 09:54:20.663 Error: (buienradar) ----> Line 55 in /home/pi/domoticz/plugins/domoticz-buienradar/plugin.py, function onStart
My version is 3.6802
Posted: Thursday 09 March 2017 10:17
by EdwinK
EdKo66 wrote:When trying to restart domoticz I get the following
No one?
Posted: Thursday 09 March 2017 13:00
by ffes
htca wrote:I got this error:
Not sure which version of the beta the Settings were added, but I know in 3.6839 they were available. At the moment the latest beta is 3.6882. So please upgrade to the latest beta and that will most likely solve your issue.
Posted: Thursday 09 March 2017 13:06
by ffes
No one?
No sorry. Don't own a Synology so can't really help you. There has to be a way to restart a service without restarting the entire device though.
Posted: Thursday 09 March 2017 13:16
by EdwinK
Thanks. I hope someone here will have a Synology and will answer.
