Page 6 of 18
Re: Help with Yeelight Bulb
Posted: Friday 21 October 2016 10:42
by Derik
farhanito wrote:Does the script works in terminal? Maybe nc isn't installed
how do i try that?
My hue scripts [ and much others ] work fine...
Re: [Plugin now available in Beta] Help with Yeelight Bulb
Posted: Friday 21 October 2016 11:19
by corbin
open terminal
type or paste the command in and hit enter
If that works to control the light, then you can put it in the bash script and run from Domoticz
Posted: Friday 21 October 2016 11:22
by corbin
I've tested to confirm it works:
contents of bright.sh:
#!/bin/bash
echo -ne '{"id":1,"method":"set_bright","params":[50, "smooth", 500]}\r\n' | nc -w1 192.168.5.29 55443
bright.sh is located in the Domoticz scripts folder:
Posted: Friday 21 October 2016 11:31
by corbin
Also with your bash command, using start_cf requires the bulb to already be on. if you want to run from off state, replace start_cf with set_scene
Posted: Friday 21 October 2016 11:35
by corbin
one more thing I just saw in your setup, you have 3 slashes. Change to two:
script:///home
change to
script://home
Posted: Friday 21 October 2016 11:50
by Derik
corbin wrote:one more thing I just saw in your setup, you have 3 slashes. Change to two:
script:///home
change to
script://home
Make no different...
Posted: Friday 21 October 2016 12:01
by corbin
does the command work in terminal for you?
Posted: Friday 21 October 2016 12:05
by corbin
weiweipossible wrote: Besides that, if we implement the same form of API, we may receive a letter from Philips' lawyer ... just like when we develop this bulb using the everyone-is-using PWM technique ...
Are you able to talk about this PWM lawyer letter? Interested to know what it was about?
Posted: Friday 21 October 2016 13:28
by Derik
Terminal:
linaro@cubie:~$ cd /home/linaro/domoticz/scripts/bash/yeelight
linaro@cubie:~/domoticz/scripts/bash/yeelight$ echo -ne '{"id":1,"method":"set_s                            cene", "params": ["color", 65280, 70]}\r\n' | nc -w1 192.168.5.30 55443
{"id":1, "result":["ok"]}
{"method":"props","params":{"power":"on"}}
{"method":"props","params":{"color_mode":1,"bright":70,"rgb":65280}}
Light was off..
And after this on wih a green light...
Other things i try:
linaro@cubie:~/domoticz/scripts/bash/yeelight$ ^C
linaro@cubie:~/domoticz/scripts/bash/yeelight$ echo -ne '{"id":1, "method":"start_cf", "params":[3,1,"50,1,16731392,1,360000,2,1700,10,540000,2,2700,100"]}\r\n' | nc -w1 192.168.5.30 55443
{"method":"props","params":{"flowing":1}}
{"method":"props","params":{"flow_params":"3,1,50,1,16731392,1,360000,2,1700,10,540000,2,2700,100"}}
linaro@cubie:~/domoticz/scripts/bash/yeelight$ ./start_1.sh
{"id":(null), "error":{"code":-1, "message":"invalid command"}}
linaro@cubie:~/domoticz/scripts/bash/yeelight$ ./ start_1.sh
-bash: ./: Is a directory
linaro@cubie:~/domoticz/scripts/bash/yeelight$ ./sunrise_1.sh
Think the script is not ok.
Posted: Friday 21 October 2016 14:28
by corbin
Can you upload your start_1.sh file please?
Posted: Friday 21 October 2016 14:47
by Derik
#!/bin/sh
echo -ne '{"id":1,"method":"set_scene", "params": ["color", 65280, 70]}\r\n' | nc -w1 192.168.5.30 55443
And then:
Working with the portal..
Posted: Friday 21 October 2016 15:33
by weiweipossible
Derik wrote:Terminal:
Light was off..
Other things i try:
You missed the "id" field which is mandatory.
Posted: Friday 21 October 2016 16:17
by Derik
linaro@cubie:~/domoticz/scripts/bash/yeelight$ echo -ne '{"id":1,"method":"set_scene", "params": ["color", 65280, 70]}\r\n' | nc -w1 192.168.5.30 55443
{"method":"props","params":{"color_mode":1}}
{"method":"props","params":{"bright":70}}
Te correct way....
Looks
Light was chancing
Only i still get the script in the document not working...
Posted: Saturday 22 October 2016 2:32
by corbin
So it looks like there is a problem with your bash file. are you able to execute other bash files?
Posted: Saturday 22 October 2016 8:33
by Derik
corbin wrote:So it looks like there is a problem with your bash file. are you able to execute other bash files?
Yes other scripts are working fine.
Posted: Saturday 22 October 2016 9:11
by Derik
strange:
the scripts ..when i try to run them
linaro@cubie:~/domoticz/scripts/bash/yeelight$ ./start.sh
linaro@cubie:~/domoticz/scripts/bash/yeelight$ ./sunrise.sh
There are 2 things.
1 says ok, only there is no thing happend with the bulb.
1 error.
When i use start in the terminal
The light is working ok.
is there perhaps a other type of script necessary..?
My Hue is ussing without the extention .sh
While there is in the the same, start.
#!/bin/bash
Posted: Saturday 22 October 2016 9:24
by corbin
Did you create your Hue script file the same way you created the Yeelight file? Same text editor, file permissions exactly the same etc? Maybe try a Cubieboard forum and see if someone else can run the script ok.
Can you also post up more information about your Cubieboard setup?
Posted: Saturday 22 October 2016 21:45
by Derik
corbin wrote:Did you create your Hue script file the same way you created the Yeelight file? Same text editor, file permissions exactly the same etc? Maybe try a Cubieboard forum and see if someone else can run the script ok.
everything the same
CB2 is the same setup as a Rpi.. so that cannot be the problem.
Is there perhaps someone else that have a script working in a Linux board?
Posted: Sunday 23 October 2016 3:20
by farhanito
This is my test script..
#!/bin/bash
toggle="{\"id\":1,\"method\":\"toggle\",\"params\":[]}\r\n"
on="{\"id\":1,\"method\":\"set_power\",\"params\":[\"on\",\"smooth\",500]}\r\n"
off="{\"id\":1,\"method\":\"set_power\",\"params\":[\"off\",\"smooth\",500]}\r\n"
b="{\"id\":1,\"method\":\"set_bright\",\"params\":[$2,\"smooth\",500]}\r\n"
ct="{\"id\":1,\"method\":\"set_ct_abx\",\"params\":[$2,\"smooth\",500]}\r\n"
exec 3<> /dev/tcp/192.168.31.101/55443
# echo $1
case $1 in
	toggle)
		printf "$toggle" >&3
	on)
		printf "$on" >&3
	off)
		printf "$off" >&3
	b)
		printf "$b" >&3
	ct)
		printf "$ct" >&3
esac
Only has few functions. Toggle, on, off, brightness (b), and color temperature (ct).
Change the IP according to yours.
Usage:
./toggle.sh toggle
./toggle.sh on
./toggle.sh off
./toggle.sh b [1-100]
./toggle.sh ct [2700-6500]
Posted: Sunday 23 October 2016 10:58
by Derik
@ Farhanito
Thanks for the script..
Only .....
./ is the command for the portal?
Do you use separate scriptfiles?
How do you make them excuteble?
And please a screendump of your script command in the Domoticz button.
What hardware do you use?
