Page 6 of 10
Re: ESP8266 Air quality sensor
Posted: Saturday 20 January 2018 20:29
by Mads
Mads wrote:
jvdz wrote:Great, so that means it works. Now only add the Rule back and leave the Device tickbox unchecked.
This should trigger the update to domoticz each time the MHZ19 is updated on ESPEasy.
Jos
Can i setup to update om every minutter?
Sendt fra min ONEPLUS A3003 med Tapatalk
Nothing has changed the last 10 min. Image
Posted: Saturday 20 January 2018 20:34
by Mads
Jos
**problem Solved***
Was the wrong idx in the rules ImageImage
I own you a beer.
Posted: Saturday 20 January 2018 20:36
by jvdz
Mads wrote: Saturday 20 January 2018 20:34 **problem Solved***
Great !!
Mads wrote: Saturday 20 January 2018 20:34 I own you a beer.
Sounds good... just leave me a place to stop by ;)
Enjoy... Jos
Posted: Saturday 20 January 2018 20:46
by Mads
Great !!
Enjoy... Jos
If your way crossed Denmark, then give me a headsup :)
Is IT only the mh-z19 where this problem is. With the box should be uncheck (send to controller)
Posted: Saturday 20 January 2018 22:27
by jvdz
I do not know all devices supported by Espeasy, but yes, the code for the mhz19 is wrong. That is why I have my own version on github which actually does work now using the build in update mechanism.
Jos
Posted: Friday 26 January 2018 7:55
by nixalsschrott
Dear friends,
by the way, is there any chance to also get the forecast for the baro values, e.g. cloudy, sunny, rain, dry, etc.? Actually on the switch no value or not available is shown?
Kind regards
Matty
Posted: Friday 26 January 2018 8:21
by jvdz
With an airquality sensor?
Nah .... Not going to work :roll:
Jos
In other words... Your question is totally unrelated to this thread.
Posted: Friday 26 January 2018 16:51
by nixalsschrott
no I mean baro=baromether (BMP180) which is giving pressure values.
Kind regards
Posted: Friday 26 January 2018 16:58
by jvdz
I guess I did understand and have a bmp180 myself in use connected to the same wemos/Espeasy setup and together with a dht22 for temp/hum.
My point was that this thread is specifically about the setup for airquality. ;)
Jos
Posted: Friday 23 November 2018 13:51
by astrapowerrr
nice!
I have ordered a wemo and a mhz19b and getting some stuff together.
As I was reading this post I wanted to check the github link.
But is it correct that that link isn’t working anymore?
Do I just download the flash software mega?
Greets Marco
Posted: Sunday 20 January 2019 12:07
by nixalsschrott
jvdz wrote: Friday 03 November 2017 17:27 .... So the below only works with my GIT version at this moment.
[/list]...
Dear jos,
did you erase your modified MHZ19b branch which sends automatically the values to domoticz?
Kind regards
matty
Posted: Sunday 20 January 2019 14:41
by jvdz
Correct, it was merged into the (my) development branch: https://github.com/jvanderzande/ESPEasy ... evelopment
I've also created a new Development v2.0 branch for the newer version of ESPEasy: https://github.com/jvanderzande/ESPEasy ... lopmentv20.
The latter one also contains a compiled version.
The Development branches contain all the modifications I have made to ESPEasy:
  • My MHZ19b version that also will update Domoticz via an HTTP link.
  • My _P145_Itho.ino version.
  • Couple of fixes for other sensors which where not updating via HTTP.
.. having said this: The standard branch is already nicely supporting the MHZ19b these days, just the HTTP update isn't working without a rule as discussed earlier in this thread.
Jos
Posted: Wednesday 23 January 2019 23:14
by astrapowerrr
Hi.
Just got my parts together and the co2 is working perfect.
I just can’t fix the lux sensor.
In the espeasy log it’s giving data. I used the Domoticz dummy idx.
But Domoticz stays on 0 lux. So not getting data?
First time user with this today and don’t know where to start.
Can someone help me?
Posted: Thursday 24 January 2019 9:36
by jvdz
Which version of espeasy are you using?
What type of dummy device did you?
How did you define the espeasy settings for this lux sensor?
Jos
Posted: Thursday 24 January 2019 9:56
by astrapowerrr
jvdz wrote:Which version of espeasy are you using?
Jos
I used the version of Espeasy 2 posts above.
The 2.0 version.
In Domoticz I used the dummy sensor and selected lux sensor.
In espeasy I made a screenshot.
You need more info?
Posted: Thursday 24 January 2019 15:50
by jvdz
I see it is showing 0 lux in espeasy already. Are you sure it is connected and configured correctly in espeasy?
Jos
Posted: Thursday 24 January 2019 19:56
by astrapowerrr
jvdz wrote:I see it is showing 0 lux in espeasy already. Are you sure it is connected and configured correctly in espeasy?
Jos
It was hidden in my casing.
It pulled it out right now and made some pictures of the value and settings.
Also as you can see in Domoticz value stay zero.
Posted: Thursday 24 January 2019 20:49
by jvdz
That config looks good to me.
You are sure about the IDX being 577 for the LUX sensor?
It does look like something is received for the LUX device looking at the last update timestamp. What does the Log show for the device?
Jos
Posted: Thursday 24 January 2019 21:01
by astrapowerrr
jvdz wrote:That config looks good to me.
Jos
And Domoticz log is showing nothing of a lux sensor. But that log is huge...
So strange this..
Just made a dummy sensor with setting lux sensor.
Posted: Thursday 24 January 2019 21:11
by jvdz
Yea, that all looks good, but what does it show when you click on the Log button for the "Lux sensor Woonkamer" ?
That should show whether values are actually send for the sensor.
Jos
