izSynth: make domoticz talk with many TTS engines in a easy way
All kinds of 'OS' scripts
jin
Re: izSynth: make domoticz talk with many TTS engines in a easy way
Post by jin »
I just release 4.4 version of izSynth:
4.4 - 20161028
- implemented -C option to write/overwrite the izsynth user config file
- some sanity checks to detect the $HOME directory of user
follow the domoticz wiki for update/install instructions:
http://www.domoticz.com/wiki/IzSynth
can someone confirm that this version fix the $HOME directory variable not working when running inside domoticz?
with kind regards
deennoo
Post by deennoo »
Looking some same kind of solution, best best best thing will be to integrate it to domoticz core and use notification system (easy to say, not to do, i know because need a C implantation and a C embedded tts engine).
Dream can be a upnp/dlna integration and aviability to use tts true this.
http://domo-attitude.fr
deennoo
Post by deennoo »
Or one first easy improvement can be use http notification system :
Something base of this french user provid a python script who allow to send sms using android app : SMSGATEWAY ULTIMATE.
With this we can use notification system quite easily, and freeing action on/off for something else.
Config Pics :
https://drive.google.com/open?id=0B9emA ... zU4Qi1VNWM
https://drive.google.com/open?id=0B9emA ... TdPeE53UE0
french Howto about it :
http://easydomoticz.com/une-plateforme- ... omoticz-2/
If it can give you some help
remb0
Post by remb0 »
first: great app! But I was looking to get it working with voicerss (works!) but then in dutch. But is this possible with an parameter?
korniza
Domoticz version: V3.6028
Post by korniza »
I used this for some months and it is working perfect! I've got Google Home which does not include any bluetooth interface and still do not have any push notifactions. I'm curious if there is any way to use Google Home as speaker and send the output of izsynth using chromecast protocol.
I found a player that is suppose to do it ( https://github.com/xat/castnow ) but izsynth use mplayer as default to play sound.
I also found that there is pulseaudio-dlna plugin but
1. not available for raspberry/debian
2. I do not like pulseaudio for many reasons.
>>>> Google Home <<<<<
jin
Post by jin »
korniza wrote: I found a player that is suppose to do it ( https://github.com/xat/castnow ) but izsynth use mplayer as default to play sound.
Hi, you can choose the audio player in two way, for example:
Command Line:
izsynth -k castnow -K "" -d "" -t "Welcome home korniza"
Configuration File:
vim ~/.config/izsynth/izsynth.conf
PLAYBACK_COMMAND="castnow"
PLAYBACK_COMMAND_OPTS=""
PLAYBACK_DEVICE=""
With kind regards
jin
Post by jin »
remb0 wrote:first: great app! But I was looking to get it working with voicerss (works!) but then in dutch. But is this possible with an parameter?
Hi remb0,
like this?
izsynth -v voicerss -v "German Reiner" -t "Guten morgen rembo" -w
explain me better please.
remb0
Post by remb0 »
in the voicers api I found: nl-nl for Dutch.
but in the settings file there is no language sample ?
what to put in the config file?
remb0
Post by remb0 »
great thanks justin. I made an sh script that start speaking the givin parameter.
#!/bin/sh
killall mplayer
#mplayer -ao alsa -noconsolecontrols -endpos $1 -playlist $2 > /dev/null 2>&1
izsynth -t "$1"
#izsynth -e google -v nl
in lua I have a function in a separate lua function file:
function My.PlaySound(msg)
	Debug='Y'
    if (Debug == 'Y') then print('>> Alarm zegt: '.. msg)     end
	os.execute ("sudo killall mplayer")
	os.execute ("sh /home/pi/domoticz/scripts/bash/Play_sound.sh '" .. msg .. "' ")
and in my scripts:
	package.path = package.path .. ';' .. '/home/pi/domoticz/scripts/lua/?.lua'
	My = require('MyFunc')
    My.PlaySound('Alarm gaat over 60 sec af.')
dgonneau
Post by dgonneau »
Has anyone been able to run izSynth on synology ? (debian chroot maybe ?)
I have domoticz and LMS on the synology and my target is to make domoticz speak with tts :)
Kind Regards
jin
Post by jin »
I never tested izsynth on Synology, I'm sorry.
anyway, izsynth need:
bash
gnu coreutils
gnu awk
gnu sed
curl
md5sum
file
iconv
soxi
sox
lame
mplayer
Kind Regards
Derik
Post by Derik »
Is there some youtube example of this script?
Include dutch language?
Is there a hardware advice?
Is it possible to use multiple mics on 1 Pi?
Can i share mic from a master Domoticz to a slave?
I will have in more rooms a mic and speakers...
In the whole house,.... :-)
EdddieN
Domoticz version: 4.9700
Post by EdddieN »
Fantastic work! All working great!
Just one thing I noticed:
If I edit the config file it uses its settings when using the command line, but if I call it from within Domotics [script:// izsynth "Hola"] it reverts back to defaults settings in english. However I can change it by adding the [-v voicerequired] within the call of the script.
Has anyone experienced this?
11101101 - www.machinon.com
EdddieN
Post by EdddieN »
Quick question, is is possible to tell izSynth to pick up a random mp3 file from a folder?
Basically I want Domoticz to randomly say curious/funny things. Trying to add a bit of personality to it, not just pure logical stuff. A bit like having a special folder with jokes, funny comments or phrases that would make the system to fake a bit of AI
EdddieN
Post by EdddieN »
Anyone knows how to make izsynth to play an mp3 instead of converting it. I have tried with izsynth -i file.mp3 and work ok on console but not on the scripts.
Then tried to use mplayer but same results, works on console but not in script.
I'm using: os.execute ('mplayer faith.mp3')
glsf91
Post by glsf91 »
jin wrote: Sunday 18 December 2016 20:38
Command Line:
Configuration File:
PLAYBACK_DEVICE=""
With kind regards
It is a long time ago but when I try
I get:
ERROR: wrong PLAYBACK engine specified: 'castnow'
please select an engine from the following list:
Engine Version Name HomePage
mplayer 2016-12-18 MPlayer http://www.mplayerhq.hu/
castnow is working when using command: castnow coldplay.mp3
What is going wrong?
jin
Post by jin »
glsf91 wrote: Thursday 15 March 2018 20:21 I get:
just updated izsynth to 4.9 release
Update with:
cd /usr/local/bin && wget https://raw.githubusercontent.com/ugoviti/izsynth/master/izsynth -O izsynth && chmod 755 izsynth
  • Implemented generic playback engine support. You can use -k to specify your playback command, and -K for the command options
Let's me know if it works as expected
Kind Regards
EdddieN
Post by EdddieN »
Any idea why is returning an error?
sudo izsynth "Door opens"
== [1/1] - izsynth Name:[Door_opens] ===========================================
Synthesizing - input:[/dev/shm/izsynth-20180411-153426/Door_opens.txt] engine:[naturalreaders] voice:[Peter] output:[/dev/shm/Door_opens.mp3] size:[4.0K] type:[text/plain] result:[ERROR]
The folder has full permissions, etc..
I tried with sudo and it generates de mp3 file but still results on ERROR
DewGew
Domoticz version: V4.10618
Post by DewGew »
EdddieN wrote: Wednesday 11 April 2018 16:43 Hello,
I have the same issue as EdddieN. Is there any solution??
EdddieN
Post by EdddieN »
I ended up using mpg134 and just play mp3 files. Not as convenient as izsynth but faster to play within events
