Page 6 of 22
Re: Controlling Toon [HACKED] from Domoticz
Posted: Friday 20 October 2017 9:19
by ronalddehaan
Maes wrote: Friday 20 October 2017 9:13
Ahh.. I didn't know. Unfortunately it looks like I have to flash my Toon again. Which I can't do, Marcelr did it for me last time
Is there something wrong with it or do you mean you have to reflash because of the app store?
Posted: Friday 20 October 2017 9:23
by Maes
Because of the app store. Marcelr rooted my toon on 4th of april 2016. A lot has changed since then and the "software" that's loaded on my Toon does not support automatic updates.
So, if I want to use any of this new stuff, the Toon will have to be flashed again to the newest version.
Too much trouble for me. Anyway I'm thinking about changing to the Evohome system next year because I moved to a new house which is a lot bigger than the previous one. I would like to control the temperature per room.
Posted: Friday 20 October 2017 9:24
by ronalddehaan
Maes wrote: Friday 20 October 2017 9:23
Ah I see, yeah you are probably right
Maybe MarcelR can help you again or someone in the neighborhood who is handy with these things?
Posted: Sunday 22 October 2017 9:55
by FunFair
I've updated the php script that reads out the production values from the smartmeter (trough Toon) aswell.
This one works with a virtual P1 Meter.
I am still testing it. Seeing as today there is almost no sun and I only have 2 solarpanels. I don't expect to return any power.
#!/usr/bin/php
<?php
/* Version 1.0 written by Ierlandfan */
/* Version 1.0 modified by DennisD */
/* Version 2.0 rewritten by FunFair */
/* Version 2.1 update by FunFair */
/* 24-10-2017 */
Changelog Version 2.2:
- Corrected Low and Normal tariff. They were reversed.
Changelog Version 2.1:
- Implemented production counters for P1 meter.
- Removed the compare to previous value, so it will update every minute.
Changelog Version 2.0:
- Rewrite from version 1.0
- Define IP adresses and idx value at start
- Check if Toon value is lower than Domoticz Value. (In case connection is lost with meteradapter, Toon will output wrong values.) */
/* Instructions:
- Create a virtual P1 meter in Domoticz and write down idx value.
- Place script in Domoticz folder /home/pi/domoticz/scripts/p1_meter/ or desired folder.
- Set IP numbers and idx values below.
- Make sure Curl is installed (sudo apt-get install php-curl).
- Make sure script is executable (chmod +x filename.php).
- All echo's are used for debugging.
- Put script in 'crontab -e' to run every minute. */
#Example crontab: (*/1 * * * * /home/pi/domoticz/scripts/p1_meter/p1_meter_data_json.php)
/* Set IP addresses and idx*/
$IPDomoticz = '192.168.0.200:8080';
$IPToon = '192.168.0.11';
$idx = 26;
/* read electricity value from Domoticz */
$json_string = file_get_contents("http://$IPDomoticz/json.htm?type=devices&rid=$idx");
$parsed_json = json_decode($json_string, true);
$parsed_json = $parsed_json['result'][0];
$ElecUsageCounterDomoticz = $parsed_json['Counter']*1000;
$ElecProductionCounterDomoticz = $parsed_json['CounterDeliv']*1000;
echo "Electricity Usage Counter Domoticz = ";
echo $ElecUsageCounterDomoticz;
echo " Wh";
echo "\n";
echo "Electricity Production Counter Domoticz = ";
echo $ElecProductionCounterDomoticz;
echo " Wh";
echo "\n";
echo "\n";
/* start of the total Energy Usage counter import */
$file_string_ElecUsageCounter = file_get_contents("http://$IPToon/hdrv_zwave?action=getDevices.json");
$parsed_json_ElecCounter = json_decode($file_string_ElecUsageCounter, true);
/* start of current Energy Usage import */
$file_string_ElecUsage = file_get_contents("http://$IPToon/happ_pwrusage?action=GetCurrentUsage");
$parsed_json_ElecUsage = json_decode($file_string_ElecUsage, true);
/* start of the total Energy Production counter import */
$file_string_ElecProductionCounter = file_get_contents("http://$IPToon/hdrv_zwave?action=getDevices.json");
$parsed_json_ElecProductionCounter = json_decode($file_string_ElecProductionCounter, true);
/* start of current Energy Production import */
$file_string_ElecProduction = file_get_contents("http://$IPToon/happ_pwrusage?action=GetCurrentUsage");
$parsed_json_ElecProduction = json_decode($file_string_ElecProduction, true);
/* extract counter normal tariff and low tariff and add them together */
$ElecUsageCounterNT = $parsed_json_ElecCounter['dev_3.3']['CurrentElectricityQuantity']; #normal tariff
$ElecUsageCounterLT = $parsed_json_ElecCounter['dev_3.5']['CurrentElectricityQuantity']; #low tariff
$ElecUsageCounterToon = $ElecUsageCounterNT + $ElecUsageCounterLT;
$ElecProductionCounterNT = $parsed_json_ElecProductionCounter['dev_3.4']['CurrentElectricityQuantity']; #normal tariff
$ElecProductionCounterLT = $parsed_json_ElecProductionCounter['dev_3.6']['CurrentElectricityQuantity']; #low tariff
$ElecProductionCounterToon = $ElecProductionCounterNT + $ElecProductionCounterLT;
echo "Electricity Counter Toon Low Tariff = ";
echo $ElecUsageCounterLT;
echo " Wh";
echo "\n";
echo "Electricity Counter Toon Normal Tariff = ";
echo $ElecUsageCounterNT;
echo " Wh";
echo "\n";
echo "Electricity Counter Toon Total = ";
echo $ElecUsageCounterToon;
echo " Wh";
echo "\n";
echo "\n";
echo "Electricity Production Counter Toon Low Tariff = ";
echo $ElecProductionCounterLT;
echo " Wh";
echo "\n";
echo "Electricity Production Counter Toon Normal Tariff = ";
echo $ElecProductionCounterNT;
echo " Wh";
echo "\n";
echo "Electricity Production Counter Toon Total = ";
echo $ElecProductionCounterToon;
echo " Wh";
echo "\n";
echo "\n";
/* extract the current powerusage */
$ElecUsageToon=$parsed_json_ElecUsage['powerUsage']['value'];
echo "Electricity Usage Toon = ";
echo $ElecUsageToon;
echo " Watt";
echo "\n";
/* extract the current powerProduction */
$ElecProductionToon=$parsed_json_ElecProduction['powerProduction']['value'];
echo "Electricity Production Toon = ";
echo $ElecProductionToon;
echo " Watt";
echo "\n";
/* write new value to Domoticz */
if ($ElecUsageCounterDomoticz == 0){ #this is for the first run only, when the idx is still empty.
$WriteInitValue = curl_init("http://$IPDomoticz/json.htm?type=command¶m=udevice&idx=$idx&nvalue=0&svalue=$ElecUsageCounterLT;$ElecUsageCounterNT;$ElecProductionCounterLT;$ElecProductionCounterNT;$ElecUsageToon;$ElecProductionToon;");
curl_exec($WriteInitValue);
else if ($ElecUsageCounterToon < $ElecUsageCounterDomoticz){
echo "Toon value incorrect, do nothing \n";
else if ($ElecUsageCounterToon >= $ElecUsageCounterDomoticz){
$WriteValue = curl_init("http://$IPDomoticz/json.htm?type=command¶m=udevice&idx=$idx&nvalue=0&svalue=$ElecUsageCounterLT;$ElecUsageCounterNT;$ElecProductionCounterLT;$ElecProductionCounterNT;$ElecUsageToon;$ElecProductionToon;");
echo "\n";
echo "Write new value \n";
curl_exec($WriteValue);
else {
echo "Domoticz value incorrect, do nothing \n";
-edit-
Tested it and changed it a bit. Changed the code above and attached new verion as zip. Corrected a huge rror by confusing daytime and nighttime.
corrected the other scripts aswell
-edit2-
corrected some variables for all scripts. See new attached file.
Posted: Sunday 22 October 2017 20:43
by bertbigb
I try to make the hacked Toon work with Domoticx work but I get an error and don't know what's wrong
The error is this:
2017-10-22 20:33:00.621 Error: dzVents: Error: An error occured when calling event handler ToonGetInfo
2017-10-22 20:33:00.621 Error: dzVents: Error: ...cz/var/scripts/dzVents/generated_scripts/ToonGetInfo.lua:61: attempt to call field 'round' (a nil value)
Line 61 is this one out of the script:
if domoticz.round(domoticz.devices(ToonTemperatureSensorName).temperature, 1) ~= domoticz.round(currentTemperature, 1) then
The following :
local ToonThermostatSensorName = domoticz.variables('UV_ToonThermostatSensorName').value -- Sensor showing current setpoint:
the user variable UV_ToonTemperatureSensorName is filled in as Toon Temperature and Toon Temperature exist as a virtual Temp(erature) variable.
I hope someone can point me out what is wrong
Posted: Monday 23 October 2017 11:14
by FunFair
Can you post a screenshot of your "Devices" and "User variables" ?
Posted: Monday 23 October 2017 11:30
by bertbigb
Of course I will.
My variables:
- user-variables.jpg (77.55 KiB) Viewed 3948 times
My devices:
- devices.jpg (70.2 KiB) Viewed 3948 times
One other thing I have changed since I work with a synology is:
-- Handle json
--local json = assert(loadfile "C:\\Program Files (x86)\\Domoticz\\scripts\\lua\\json.lua")() -- For Windows
--local json = assert(loadfile "/home/maes/domoticz/scripts/lua/JSON.lua")() -- For Linux
local json = assert(loadfile "/volume1/@appstore/domoticz/var/scripts/lua/JSON.lua")() -- For Synology
I hope someone can help me with this one, tried a lot already but haven't found the cause
Posted: Monday 23 October 2017 19:47
by FunFair
Do you have curl installed?
Posted: Tuesday 24 October 2017 7:06
by bertbigb
FunFair wrote: Monday 23 October 2017 19:47
Yes, curl is installed.
Personally I have the feeling that it is something in the dzVents scripts.
Is there anyone who can confirm to have the dzVentz scripts as available on the first page working?
I say this since with the lua scripts it is working OK, but the dzVentz gives problems.
Hereby my code (only changed the part for Synology) and moved the part what gives an error to the end to check the rest of the script (what is working fine)
It is the part:
where the nil error occurs
-- Check the wiki at
-- http://www.domoticz.com/wiki/%27dzVents%27:_next_generation_LUA_scripting
timer = {
'every minute'
execute = function(domoticz)
local ToonTemperatureSensorName = domoticz.variables('UV_ToonTemperatureSensorName').value -- Sensor showing current room temperature
local ToonScenesSensorName = domoticz.variables('UV_ToonScenesSensorName').value -- Sensor showing current program
local ToonAutoProgramSensorName = domoticz.variables('UV_ToonAutoProgramSensorName').value -- Sensor showing current auto program status
local ToonProgramInformationSensorName = domoticz.variables('UV_ToonProgramInformationSensorName').value -- Sensor showing displaying program information status
local ToonIP = domoticz.variables('UV_ToonIP').value
local DomoticzIP = domoticz.variables('UV_DomoticzIP').value
-- Handle json
--local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
local handle = assert(io.popen(string.format('curl http://192.168.3.104/happ_thermstat?action=getThermostatInfo', ToonIP)))
local ThermostatInfo = handle:read('*all')
handle:close()
local jsonThermostatInfo = json:decode(ThermostatInfo)
if jsonThermostatInfo == nil then
return
local currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
local currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
local currentProgramState = tonumber(jsonThermostatInfo.programState)
if currentProgramState == 0 then currentProgramState = 10 -- No
elseif currentProgramState == 1 then currentProgramState = 20 -- Yes
elseif currentProgramState == 2 then currentProgramState = 30 -- Temporary
local currentActiveState = tonumber(jsonThermostatInfo.activeState)
if currentActiveState == -1 then currentActiveState = 50 -- Manual
elseif currentActiveState == 0 then currentActiveState = 40 -- Comfort
elseif currentActiveState == 1 then currentActiveState = 30 -- Home
elseif currentActiveState == 2 then currentActiveState = 20 -- Sleep
elseif currentActiveState == 3 then currentActiveState = 10 -- Away
local currentNextTime = jsonThermostatInfo.nextTime
local currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
local currentBoiletSetPoint = jsonThermostatInfo.currentInternalBoilerSetpoint
-- Update the thermostat sensor to current setpoint
if domoticz.devices(ToonThermostatSensorName).setPoint*100 ~= currentSetpoint*100 then
domoticz.log('Updating thermostat sensor to new set point: ' ..currentSetpoint)
domoticz.devices(ToonThermostatSensorName).updateSetPoint(currentSetpoint).silent()
-- Update the toon scene selector sensor to current program state
if domoticz.devices(ToonScenesSensorName).level ~= currentActiveState then -- Update toon selector if it has changed
domoticz.log('Updating Toon Scenes selector to: '..currentActiveState)
domoticz.devices(ToonScenesSensorName).switchSelector(currentActiveState).silent()
-- Updates the toon auto program switch
if domoticz.devices(ToonAutoProgramSensorName).level ~= currentProgramState then -- Update toon auto program selector if it has changed
domoticz.log('Updating Toon Auto Program selector to: '..currentProgramState)
domoticz.devices(ToonAutoProgramSensorName).switchSelector(currentProgramState).silent()
-- Updates the toon program information text box
if currentNextTime == 0 or currentNextSetPoint == 0 then
ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°'
ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
if domoticz.devices(ToonProgramInformationSensorName).text ~= ToonProgramInformationSensorValue then
domoticz.log('Updating Toon Program Information to: '..ToonProgramInformationSensorValue)
domoticz.devices(ToonProgramInformationSensorName).updateText(ToonProgramInformationSensorValue)
print("currentTemperature - " .. currentTemperature)
-- Update the temperature sensor to current room temperature
domoticz.log('Updating the temperature sensor to new value: ' ..currentTemperature)
domoticz.devices(ToonTemperatureSensorName).updateTemperature(currentTemperature)
Posted: Tuesday 24 October 2017 9:56
by FunFair
oh that is quite possible. I remember someone else in this topic also having problems with the new dzVents. For me it's not working either, so I use the LUA aswell.
Posted: Friday 10 November 2017 10:59
by pascal34
FunFair wrote: Sunday 22 October 2017 9:55
#!/usr/bin/php
<?php
/* 24-10-2017 */
/* Instructions:
$idx = 26;
echo " Wh";
echo "\n";
echo " Wh";
echo "\n";
echo "\n";
echo " Wh";
echo "\n";
echo " Wh";
echo "\n";
echo " Wh";
echo "\n";
echo "\n";
echo " Wh";
echo "\n";
echo " Wh";
echo "\n";
echo " Wh";
echo "\n";
echo "\n";
echo " Watt";
echo "\n";
echo " Watt";
echo "\n";
echo "\n";
else {
-edit-
-edit2-
Hi, I am using this scripts for my energy readings.
But wen I set in Domoticz Setup > Settings in Website Protection a username and Password the scripts stopped working, wen I remove my username and password they are updating again. How can I fix this.
Using Domoticz V3.8153 on a Rasberry Pi 3 B
Thanks, Pascal
Posted: Saturday 11 November 2017 7:44
by gielie
i tried the gas/electra php script but in both i get an error, im running Domoticz on a pi2 and i use a hacked Toon.
pi@raspberrypi:~/domoticz/scripts/php $ ./electricity_data_json.php
Electricity Counter Domoticz = 0 Wh
Electricity Counter Toon = 0 Wh
Electricity Usage Toon = 413 Watt
PHP Fatal error: Call to undefined function curl_init() in /home/pi/domoticz/scripts/php/electricity_data_json.php on line 71
and
pi@raspberrypi:~/domoticz/scripts/php $ ./gas_data_json.php
Gas Value Domoticz = 0 liters
Gas Value Toon = 590.00 liters
PHP Fatal error: Call to undefined function curl_init() in /home/pi/domoticz/scripts/php/gas_data_json.php on line 55
Can someone point me in the right direction?
======update========
solved by installing the right curl.
1 problem remains, i dont get the electricity counter this remain 0
Electricity Usage Toon = 654 Watt
"status" : "OK",
"title" : "Update Device"
Posted: Saturday 11 November 2017 9:12
by DennisD
Curl doesn't seem installed!
Try:
sudo apt-get install php5-curl
sudo service apache2 restart
Posted: Saturday 11 November 2017 9:22
by FunFair
Check if the dev_x.x are correct in
http://192.168.0.11/hdrv_zwave?action=getDevices.json
Change ip to your toon.
Maybe they are different from my Toon?
Look for "elec_delivered_nt" and "elec_delivered_lt"
Posted: Saturday 11 November 2017 9:26
by FunFair
pascal34 wrote: Friday 10 November 2017 10:59
Thanks, Pascal
https://www.domoticz.com/wiki/Domoticz_ ... 27s#Format
Add this to the $IPDomoticz setting.
So $IPDomoticz = 'username:password@domoticz-ip:port';
Posted: Saturday 11 November 2017 10:16
by pascal34
FunFair wrote: Saturday 11 November 2017 9:26
Thanks, Pascal
Yes thats works
Thanks, FunFair
Posted: Sunday 12 November 2017 16:43
by gielie
This is my output
"dev_settings_device":{"uuid":"eneco-001-003065:hdrv_zwave_722E1463E52", "name":"settings_device", "internalAddress":"settings_device", "type":"settings_device", "supportsCrc":"0", "location":"(null)"},
"dev_3":{"uuid":"eneco-001-003065:hdrv_zwave_72262C23F3F", "name":"HAE_METER_v2", "internalAddress":"3", "type":"HAE_METER_v2", "supportsCrc":"1", "ccList":"22 3c 3d 3e 56 60 70 72 7a 86 8b 73", "supportedCC":"22 3c 3d 3e 56 60 70 72 7a 86 8b 73", "IsConnected":"1", "HealthValue":"10", "DeviceName":"", "location":"(null)"},
"dev_3.1":{"uuid":"eneco-001-003065:hdrv_zwave_72227F83F45", "name":"HAE_METER_v2_1", "internalAddress":"3.1", "type":"gas", "supportsCrc":"0", "ccList":"3c 3d 3e 72 86", "supportedCC":"3c 3d 3e 72 86", "CurrentGasFlow":"0.00", "CurrentGasQuantity":"1990.00", "location":"(null)"},
"dev_3.2":{"uuid":"eneco-001-003065:hdrv_zwave_722E9E83F45", "name":"HAE_METER_v2_2", "internalAddress":"3.2", "type":"elec", "supportsCrc":"0", "CurrentElectricityFlow":"3682.00", "CurrentElectricityQuantity":"9640.00", "location":"(null)"},
"dev_3.3":{"uuid":"eneco-001-003065:hdrv_zwave_722438D3F45", "name":"HAE_METER_v2_3", "internalAddress":"3.3", "type":"elec_delivered_nt", "supportsCrc":"0", "CurrentElectricityFlow":"NaN", "CurrentElectricityQuantity":"NaN", "location":"(null)"},
"dev_3.4":{"uuid":"eneco-001-003065:hdrv_zwave_722255A3F45", "name":"HAE_METER_v2_4", "internalAddress":"3.4", "type":"elec_received_nt", "supportsCrc":"0", "CurrentElectricityFlow":"NaN", "CurrentElectricityQuantity":"NaN", "location":"(null)"},
"dev_3.5":{"uuid":"eneco-001-003065:hdrv_zwave_72272633F45", "name":"HAE_METER_v2_5", "internalAddress":"3.5", "type":"elec_delivered_lt", "supportsCrc":"0", "CurrentElectricityFlow":"NaN", "CurrentElectricityQuantity":"NaN", "location":"(null)"},
"dev_3.6":{"uuid":"eneco-001-003065:hdrv_zwave_722D79F3F45", "name":"HAE_METER_v2_6", "internalAddress":"3.6", "type":"elec_received_lt", "supportsCrc":"0", "CurrentElectricityFlow":"NaN", "CurrentElectricityQuantity":"NaN", "location":"(null)"}
does this make sense?
Posted: Sunday 12 November 2017 18:31
by FunFair
gielie wrote: Sunday 12 November 2017 16:43
This is my output
Do you have a smartmeter?
If not please check the currentgas and currentelectricity quantity if they are the same as on your toon display.
If so the script needs some changes to read out the correct values.
Posted: Sunday 12 November 2017 20:05
by gielie
FunFair wrote: Sunday 12 November 2017 18:31
This is my output
I don’t have a smart meter, so I figured out I have to change a lot in the script, I will take a shot to change this or does someone here allready have this script ready?
Posted: Sunday 12 November 2017 20:30
by FunFair
Not that much, just change the parser to read the value from the correct dev_x and do some editing to the calculations. If you can wait a few days I'll change it for elec and gas aswell.
