Introducing dzVents - Domoticz Lua file based event scripting made e-z!
Locked
dakipro
Domoticz version: 3.5877
Re: Introducing dzVents - Domoticz Lua file based event scripting made e-z!
Post by dakipro »
yeah, I made a simple script that turns on and off every minute to test one of the new switches I made, so I am doing an
if(livingRoomLights.state == 'On') then
livingRoomLights.switchOff()
and else for switching on.
In Json there is json.htm?type=command&param=switchlight&idx=46&switchcmd=Toggle
so I was thinking maybe there is a similar function in Lua. But it is not a missing critical, just an very cool convenient feature :)
Raspberry Pi 2 B - MySensors (dimmers, switches, motion, temperature, lux, humidity sensors)
zWave (220v switches)
various 433 via RFLink
dannybloe
Post by dannybloe »
I think the json call does the same as what you would do manually with Lua.
commodore white
Post by commodore white »
I thought this:
 test = domoticz.devices["vIsDark"]
 test.setState( not test.state)
should work to toggle a variable, but got this:
2016-03-20 12:19:00.376 LUA: An error occured when calling event handler Night-and-Day
2016-03-20 12:19:00.377 LUA: /home/pi/domoticz/scripts/lua/Domoticz.lua:98: invalid value (boolean) at index 1 in table for 'concat'
... and little trace back. Any ideas?
dannybloe
Post by dannybloe »
Well, the state attribute is a string (like 'On' or 'Off'). You cannot negate strings, only booleans. So unfortunately this will not work.
But I'll add the necessary logic to dzVents soon. For now you have to write a few lines:
if (device.state == 'On') then
	device.switchOff()
	device.switchOn()
I'll add
device.toggleSwitch()
that checks the current state and finds the matching opposing state.
dakipro
Post by dakipro »
sounds great. Maybe it can be called device.switchToggle(), to be consistent to switchOn and switchOff
dannybloe
Post by dannybloe »
Agreed.
commodore white
.. or could write:
test.setState(test.bState and "Off" or "On")
:oops:
commodore white
dannybloe wrote:Agreed.
While you're it, could you add Normal and Alarm as opposites for my marmitek door/window sensors
dannybloe
Post by dannybloe »
You mean something like this: switchToNormal(), switchToAlarm()
And the toggles of course.
commodore white
dannybloe wrote:You mean something like this: switchToNormal(), switchToAlarm()
Hmmm. Probably not since the devices are read-only.
I'm looking in domoticz.lua about line 170 where you booleanize some strings. I'm suggesting you add:
state == "normal" or
and
state == "alarm" or
... pretty please.
BTW I'm thinking you're going to be a hostage to fortune trying to implement your negate function because a) you'll find it hard to get a complete list of things to negate, and b) find it even harder to produce a correct list of their inverts for all devices.
By all means have a capability to Invert On to Off and vis versa but anything else is only going to complicate things, not necessarily the code but the documentation. Where do you stop in providing capabilities that can be done in native LUA fairly easily? Are you going to provide and a .increment and .decrement function because it takes two extra lines of code, or perhaps provide a .area or .circumference function? Where do you stop?
What might be handy, however, is a capability whereby users can have a library of functions that are accessible to each of their scripts. Such a library might include a users very own Negate function. I used to have LUA scripts that used the require function but I'm not sure if dzVents would preclude this. Used to be neat because I could write code that created LUA modules on the fly and then include them conditionally or at some future time. It proved useful to provide persistence before variables were introduced.
Keep up the good work. I really don't want to go back to native LUA.
Peter
Last edited by commodore white on Sunday 20 March 2016 20:53, edited 1 time in total.
dannybloe
Post by dannybloe »
and
state == "alarm" or
... pretty please.
Oh, yeah, already added that today. I recognize all the states I could find in the domoticz code.. I hope ;-)
NietGiftig
Domoticz version: V3.6224
Post by NietGiftig »
commodore white wrote: What might be handy, however, is a capability whereby users can have a library of functions that are accessible to each of their scripts. Such a library might include a users very own Negate function.
Peter
Looks like a nice addition, i like structure.
But is this not already possible with :
myLua = require("MyLUACode") -- Include the module with common functions
Beware, I'm just beginning to discover lua
RPI-2 + SSD / ESPEasy Sensors & Switches / Sonoff / RFLink / Action Switches / TP-Link switch / Node-Red / Reacticz
Westcott
Post by Westcott »
<shameless-plug>
A bit like this?
http://www.domoticz.com/forum/viewtopic ... 23&t=11151
</shameless-plug>
commodore white
Beware, I'm just beginning to discover lua[/quote]
Yes, I'm already aware of the require function. However, I'm also aware that dzVents does things differently so I'm not sure where I'd have to put the require statement so that it didnt get executed repeatedly.
Danny already make the point of not putting too much code in the "active" clause since it gets executed every time a device triggers so I don't want to make matters worse.
Guess I'll just try it. Whats the worse that can happen, eh?
woody4165
Post by woody4165 »
Hi all
sorry for my "stupid" question. :?
To install dzVents from the dzVents-master zip files, do I need to copy only those files to the domoticz/scripts/lua folder
event_helpers.lua
script_time_main.lua
script_device_main.lua
Domoticz.lua
dzVents_settings.lua
and create a scripts folder within domoticz/scripts/lua ?
What about all the other files in the zip under dzVents folder?
NietGiftig
I think danny is busy with some changes in github
You only need those files, your own files go in the scripts folder inside the lua
folder
And do not forget to have the examples folder ready, make the jump somewhat easier
NietGiftig
commodore white wrote: Danny already make the point of not putting too much code in the "active" clause since it gets executed every time a device triggers so I don't want to make matters worse.
Yeah, read that to
Maybe you can place the require outside the execute function, in the beginning of your function.
But I don't know what the effect on the whole business is
woody4165
Post by woody4165 »
If I put those files in the domoticz/scripts/lua I get all these errors in the log:
2016-03-21 12:23:50.600 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_main.lua: /home/pi/domoticz/scripts/lua/EventHelpers.lua:4: module 'utils' not found:
no field package.preload['utils']
no file '/usr/local/share/lua/5.2/utils.lua'
no file '/usr/local/share/lua/5.2/utils/init.lua'
no file '/usr/local/lib/lua/5.2/utils.lua'
no file '/usr/local/lib/lua/5.2/utils/init.lua'
no file './utils.lua'
no file '/home/pi/domoticz/scripts/lua/utils.lua'
no file '/home/pi/domoticz/scripts/lua//dzVents/utils.lua'
no file '/usr/local/lib/lua/5.2/utils.so'
no file '/usr/local/lib/lua/5.2/loadall.so'
no file './utils.so'
And it keeps going this way.
I tried with naming the event_helper.lua (as written in GitHub installation description, as well renaming it as EventHelpers.lua overwriting the actual files.
What am I doing wrong?
NietGiftig
use branch 0.9.13 master is rebuild i think
woody4165
Post by woody4165 »
I just downloaded the zip from github, but I get the same error.... :?
Locked
