phpMyDomo: a convenient Domoticz Web Interface
Re: phpMyDomo: a convenient Domoticz Web Interface
This should work fine without any speed issues. BTW If you're not really familiar with NGINX, i suggest you to install it with Apache, which is the "supported way" for installing PMD.
Whitout hundred of client at the same time, you wont notice any speed difference between Apache vs Nginx. And if memory is an issue (which I really doubt), you could simply tweak the Apache config to reduce the number of servers started.
a+
a+
Developer of phpMyDomo, a Web Interface for Domoticz
vincent13
thanks, but what's BTW ?
and , if i want save the PMD's config , what are the main file i must save ? (excuse my poor english )
1x Raspberry - Domoticz - PhpMyDomo - ISS-Domo - ImperiHome (Lite)
1x RFXTRX USB 433
4x Chacon 54755
3x prises chacon
1x THN132N
2x TX17
3x TX3
1x RFXTRX USB 433
4x Chacon 54755
3x prises chacon
1x THN132N
2x TX17
3x TX3
gertjuhh
By The Wayvincent13 wrote:thanks, but what's BTW ?
PMD/inc/conf is the directory that contains all the config filesvincent13 wrote: if i want save the PMD's config , what are the main file i must save ? (excuse my poor english )
et ya pas de probleme pour ton anglais
vincent13
thank you WXOP, i came to install phpmydomo on the sd card of domoticz with apache.
But in my browser , i 've always the same message: 403 forbidden
this is th directory /var/www:
drwxr-xr-x 4 root root 4096 Mar 3 18:53 .
drwxr-xr-x 12 root root 4096 Mar 3 18:30 ..
-rw-r--r-- 1 pi pi 57 Feb 8 20:02 _boot.php
-rw-r--r-- 1 pi pi 69 Feb 8 20:02 controller.php
-rw-r--r-- 1 pi pi 377 Feb 8 20:02 .htaccess
drwxr-xr-x 14 pi pi 4096 Mar 3 18:27 inc
-rw-r--r-- 1 root root 177 Mar 3 18:31 index.html
-rw-r--r-- 1 pi pi 430 Feb 8 20:02 index.php
drwxr-xr-x 5 pi pi 4096 Feb 8 20:02 static
And now this is the .htaccess file
root@domoticzpi:/var/www# more .htaccess
# BEGIN Controller
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteRule ^(.*)controller\.php$ - [L]
RewriteRule ^(.*)static/ - [L]
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . controller.php [L]
</IfModule>
# END Controller
somebody can help me ?
# BEGIN Controller
RewriteEngine On
</IfModule>
# END Controller
1x RFXTRX USB 433
4x Chacon 54755
3x prises chacon
1x THN132N
2x TX17
3x TX3
1x RFXTRX USB 433
4x Chacon 54755
3x prises chacon
1x THN132N
2x TX17
3x TX3
vincent13
i 've testing a modification of the file defautl:
<VirtualHost *:80>
ServerAdmin webmaster@localhost
DocumentRoot /var/www
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory /var/www/>
Options Indexes FollowSymLinks MultiViews
# the above line is good but the bellow line is not good !!!!!!!!!!!!!!!!!
# Options Indexes
AllowOverride All
Order allow,deny
allow from all
</Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
Order allow,deny
Allow from all
</Directory>
ErrorLog ${APACHE_LOG_DIR}/error.log
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
CustomLog ${APACHE_LOG_DIR}/access.log combined
</VirtualHost>
are you agree with my file ???
<VirtualHost *:80>
<Directory />
AllowOverride None
</Directory>
# Options Indexes
AllowOverride All
Order allow,deny
allow from all
</Directory>
AllowOverride None
Order allow,deny
Allow from all
</Directory>
# alert, emerg.
LogLevel warn
</VirtualHost>
1x RFXTRX USB 433
4x Chacon 54755
3x prises chacon
1x THN132N
2x TX17
3x TX3
1x RFXTRX USB 433
4x Chacon 54755
3x prises chacon
1x THN132N
2x TX17
3x TX3
I cant fully understand what you means...
remet le en francais
Si tu suis bien scrupulesement le manuel de PMD ca devrait marcher sans probleme!
Si tu as un message d'erreur 403, etudie bien le /var/log/apache2/error.log qui va t'indiquer plus précisement le probleme que tu rencontre.
NB; si tu change quelque chose dans la config d'apache, il faut le redemarer pour que ca soit actif : apache2ctl restart
A ce stade, c'est pas tres clair pour moi: poste plus précisément ce que tu fait (en francais) et je pourrais peut etre t'aider.
a+
a+
vincent13
pour supprimer mon erreur 403 , je viens de modifier le fichier default d'apache dont le contenu d'origine est ci dessous:
<VirtualHost *:80>
<Directory />
AllowOverride None
</Directory>
Options Indexes
AllowOverride All
Order allow,deny
allow from all
</Directory>
AllowOverride None
Order allow,deny
Allow from all
</Directory>
# alert, emerg.
LogLevel warn
</VirtualHost>
justement après avoir regardé le fichier error.log d'apache dans lequel on peut voir des erreurs de " FollowSymLinks "ci dessous:
[Mon Mar 03 20:13:50 2014] [notice] Apache/2.2.22 (Debian) PHP/5.4.4-14+deb7u8 configured -- resuming normal operat
ions
[Mon Mar 03 20:19:50 2014] [error] [client 192.168.0.3] Options FollowSymLinks or SymLinksIfOwnerMatch is off which
implies that RewriteRule directive is forbidden: /var/www/
[Mon Mar 03 20:19:51 2014] [error] [client 192.168.0.3] Options FollowSymLinks or SymLinksIfOwnerMatch is off which
implies that RewriteRule directive is forbidden: /var/www/favicon.ico
[Mon Mar 03 20:19:53 2014] [error] [client 192.168.0.3] Options FollowSymLinks or SymLinksIfOwnerMatch is off which
j'ai changé la ligne "options" du fichier "default" par ceci:
et depuis je peux me connecter à PMD, est ce que tu trouves cela normal ,au vue des indications dans les docs d'installation ????
<VirtualHost *:80>
<Directory />
AllowOverride None
</Directory>
Options Indexes
AllowOverride All
Order allow,deny
allow from all
</Directory>
AllowOverride None
Order allow,deny
Allow from all
</Directory>
# alert, emerg.
LogLevel warn
</VirtualHost>
ions
1x RFXTRX USB 433
4x Chacon 54755
3x prises chacon
1x THN132N
2x TX17
3x TX3
1x RFXTRX USB 433
4x Chacon 54755
3x prises chacon
1x THN132N
2x TX17
3x TX3
C'est tout a fait normal qu'il faille mettre FollowSymLinks. Pour la doc, je me suis basé sur une install de base debian qui a DEJA le FollowSymLinks, mais qui par contre a le AllowOverride à None. Sinon je pense que le "MultiViews" n'est pas necessaire
Comme quoi la conf apache par defaut de la Rasbian, n'est pas identique a la conf par defaut de la Debian...
Grace a toi, Je vais mieux le preciser dans la doc.
vincent13
In english:
"options" without "multiviews" is well.
For information, my distribution is a package on SDcard image with raspbian and domoticz included.
If i want to access of my PMD from internete , there is no security (login/password or anything else), can you predict this option ?
thanks
En français:
C'est mieux en français non ??
Sinon je viens en effet de supprimer le "multiviews" et tout fonctionne nickel aussi .
Pour information mon installation provient d'une image de carte sd avec domoticz intégré
Par contre as-tu déjà intégrer une option pour sécuriser l'accès à PMD car j'ai configuré ma freebox pour avoir un accès externe et du coup n'importe qui peut faire n'importe quoi avec mon PMD (comme dirait Rémi Gaillard)
bon dev
thanks
En français:
bon dev
1x RFXTRX USB 433
4x Chacon 54755
3x prises chacon
1x THN132N
2x TX17
3x TX3
1x RFXTRX USB 433
4x Chacon 54755
3x prises chacon
1x THN132N
2x TX17
3x TX3
- mbliek
English please.
So everyone can use this information.
Or continue by PM.
Or continue by PM.
Op zoek naar een Domoticz Start Set?
You're perfectly rightmbliek wrote:English please.
Or continue by PM.
To resume : we've found that there is a different Apache Default config for the Pi compared to a default Debian install. So i've updated the Installation Documentation to reflect this. (this will be online in a fews days, when I'll update the PMD version)
Question is about : securing the PMD access, especially when the PMD site is forwarded to the Internet public IP.vincent13 wrote: Par contre as-tu déjà intégrer une option pour sécuriser l'accès à PMD car j'ai configuré ma freebox pour avoir un accès externe...
If you tweak the Apache configuration for PMD, it is easy to add an Authentication scheme for the PMD's Virtual Host, at the Apache conf level:
http://httpd.apache.org/docs/2.2/howto/auth.html
I might add this at the .htaccess level of PMD, but only if I find a transparent way to add this to the default install, without adding complexness for a "newbie" user. (PullRequests are welcome!)
Best Regards
vincent13
thanks
1x RFXTRX USB 433
4x Chacon 54755
3x prises chacon
1x THN132N
2x TX17
3x TX3
1x RFXTRX USB 433
4x Chacon 54755
3x prises chacon
1x THN132N
2x TX17
3x TX3
BigDog
- Domoticz version: V3.9269
i have it running but the Doorsensors are displaying as unknown device with a ? in front of it
is there anyting i or the dev. can do?
Greetz Bob
Greetz Bob
1X Raspberry4B : Domoticz Version 2023.1 [Linux 5.10.63-v7l+ armv7l]
1X Conbee II : 2.25.3 - 26720700
1X RFXtrx433 USB Firmware:183
1X Mysensors Gateway 1.5 -3
6X ESP8266: Tosmota firmware
Zigbee : 6 Operators, 13 Sensors
BigDog
the icons @ the top and foot menu arent showing
dont know why becose all the other images are ok
greetz Bob
--------------EDITED-----------------
have found a BUG
i have changed the directory that it isnt in the root ---> domo
but the images stil use the root to find the images(fonts)
have copyed the fonts to to right place but it stil need to be changed by the dev
Greetz Bob
greetz Bob
have found a BUG
Greetz Bob
BigDog
hi
i was wondering if the domo website can only be accesed in the local area and not the internet
becose there isnt a pass on it and if they know the adres they could control the switches
Greetz Bob
Greetz Bob
As soon as your PMD install is not on your Internet router, you can't access it from the internet, except if you manually setup a "forward" on your router.BigDog wrote:hi
Greetz Bob
In this case is it not password protecetd, but you can either redirected a hard to guess port ie (internet_ip:65327-> PMD_ip:80), or (way bteter) modify the apache virtual host configuration to setup a secure authentication:
HTH
shardik
I'm trying to get the PMD interface to work on my linux machine, but it's not working.
I used to get a forbidden message, i fixed that but now i only get a white empty screen....
my .htaccess file:
the needed part from /etc/apache2/apache2.conf
Quick edit: Not running on a Pi but on ubuntu server.
Quick edit2: mod_rewrite is enabled ->
my .htaccess file:
# BEGIN Controller
RewriteEngine On
</IfModule>
# END Controller
AllowOverride All
Require all granted
</Directory>
Loaded Modules:
core mod_so mod_watchdog http_core mod_log_config mod_logio mod_version mod_unixd mod_access_compat mod_alias mod_auth_basic mod_authn_core mod_authn_file mod_authz_core mod_authz_host mod_authz_user mod_autoindex mod_deflate mod_dir mod_env mod_filter mod_mime prefork mod_negotiation mod_php5 mod_rewrite mod_setenvif mod_status
please check the apache error_log, should be in /var/log/apache2 or something like that.
If you can figure what's happening, post the corresponding log.
HTH
HTH
