How to check presence of Beacon ?
Raspberry Piet
Re: How to check presence of Beacon ?
Post by Raspberry Piet »
This is what i made so far from the examples.
(i also speak better russian than lua) :lol:
x = tonumber(uservariables['Tag_Green'])
 if ( uservariables["Tag_Green"] ~= "AWAY" ) and (otherdevices["TAG"]=='Off') then
	print('<b style="color:#0099FF">Tag_Green AANWEZIG RSSI:'..x .. ' dBm</b>')
    commandArray['TAG']='On'
 elseif ( uservariables["Tag_Green"] == "AWAY" ) and (otherdevices["TAG"]=='On') then
  	print('<b style="color:Red">Tag_Green AFWEZIG</b>')
    commandArray['TAG']='Off'
 elseif ( uservariables["Tag_Green"] ~= "AWAY" ) then
	 commandArray['UpdateDevice']='2606|0|'..tostring(uservariables['Tag_Green'])
if ( uservariables["Tag_Green"] ~= "AWAY" ) and  tonumber(x) <= -68 and tonumber(x) >= -76 then
	 print('<b style="color:#0099FF">Tag_Green EETKAMER RSSI:'..x .. ' dBm</b>')
if ( uservariables["Tag_Green"] ~= "AWAY" ) and  tonumber(x) <= -77 and tonumber(x) >= -87 then
	 print('<b style="color:#0099FF">Tag_Green WOONKAMER RSSI:'..x .. ' dBm</b>')
Last edited by Raspberry Piet on Monday 16 May 2016 21:53, edited 1 time in total.
jvdz
Domoticz version: 4.107
Post by jvdz »
What is the result in the log when you use this code? It will show the current processed info:
for variableName, variableValue in pairs(uservariablechanged) do
	print("variableName:", variableName, "   variableValue:", variableValue)
	if (variableName == 'Zhenya_SitRm') then
		if tonumber(variableValue) <= -51 and tonumber(variableValue) >= -71 then
			commandArray['ZSitRoomBT'] = "On"
		if variableValue == "AWAY" then
			commandArray['ZSitRoomBT'] = "Off"
ps. what is the name of the script you use?
Jos
woody4165
Post by woody4165 »
I understand that you have an uservariable that is updated by the script.
The you have a switch, TAG, that is updated within this script.
What is doing this?
Is it an uservariable event driven or device driven?
Raspberry Piet
woody4165 wrote:Thanks
What is doing this?
I put the RSSI value in a virtual custom sensor (idx2606) for graph.
jmleglise
Domoticz version: 2022.1
Post by jmleglise »
Raspberry Piet wrote:It is possible with the Nut app to make the Nut Beacon beep (find keys when lost), is it somehow possible to do the same through a script?
What this has to do with Domoticz ? What is the use case ?
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
blackdog65
Post by blackdog65 »
Hi Jos
I get
2016-05-16 20:39:35.105 LUA: variableName:
2016-05-16 20:39:35.105 LUA: Zhenya_SitRm
2016-05-16 20:39:35.105 LUA: variableValue:
2016-05-16 20:39:35.105 LUA: -79
2016-05-16 20:39:36.086 LUA: variableName:
2016-05-16 20:39:36.087 LUA: Sean_Hall
2016-05-16 20:39:36.087 LUA: variableValue:
2016-05-16 20:39:36.087 LUA: -79
2016-05-16 20:39:36.115 LUA: variableName:
2016-05-16 20:39:36.115 LUA: Sean_SitRm
2016-05-16 20:39:36.115 LUA: variableValue:
2016-05-16 20:39:36.115 LUA: -80
2016-05-16 20:39:38.947 LUA: variableName:
2016-05-16 20:39:38.948 LUA: Zhenya_SitRm
2016-05-16 20:39:38.948 LUA: variableValue:
2016-05-16 20:39:38.948 LUA: -78
2016-05-16 20:39:38.979 LUA: variableName:
2016-05-16 20:39:38.980 LUA: Zhenya_Hall
2016-05-16 20:39:38.980 LUA: variableValue:
2016-05-16 20:39:38.980 LUA: -88
showing both NUTs as seen by my sitting room raspi and my hall raspi
and my script is "script_variable_bt2.lua"
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
jvdz
Post by jvdz »
I don't see the LUA error out there, so what is shown when that is happening?
Jos
blackdog65
Sorry Jos,
It triggers a fault when the variable switches to "AWAY"
2016-05-16 21:01:05.868 Error: EventSystem: in script_variable_bt2.lua: [string "--script_variable_bt2.lua..."]:6: attempt to compare nil with number
Would this be when the script attempts "tonumber" when the variable string is "AWAY"?
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
blackdog65
Very pretty! How do you do this?
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Westcott
Post by Westcott »
Perhaps when the beacon is away, the reported value is NIL?
blackdog65 wrote:Sorry Jos,
Raspberry Piet
Sean
Setup => Hardware => Dummy=> Create Virtual Sensors ;) (Domoticz Beta version needed i think)
Last edited by Raspberry Piet on Monday 16 May 2016 22:19, edited 1 time in total.
jvdz
Post by jvdz »
Maybe something like this works:
	numVal = tonumber(variableValue)
	if numVal == nil then numVal = 0 end
		elseif numVal <= -51 and numVal >= -71 then
Jos
blackdog65
@Jos, Yes! I just need to fiddle with my numbers now for accurate switching... MANY MANY THANKS!
@Raspberry Piet Spasiba bolshoi moi drook
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Raspberry Piet
blackdog65 wrote: @Raspberry Piet Spasiba bolshoi moi drook
Sean
:lol: :lol: :lol: I'm glad there is google translate. I lied, i dont speak russian.
jvdz
Post by jvdz »
Our language probably sounds as foreign to Sean as Russian anyways ;)
Raspberry Piet
When i lost my keys AND phone at the same time :lol:
No, you're right. It was just something that came up to my mind.
blackdog65
jvdz wrote:Our language probably sounds as foreign to Sean as Russian anyways ;)
:D
This is why when English people hear something garbled and unintelligible, we describe it as sounding like "Double Dutch". :lol:
Bizarrely, the Dutch language is The English Language's closest relative... go figure :roll:
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
woody4165
Post by woody4165 »
I'm still getting issues on reboot
The status is active(exited) after reboot
the log says:
2016-05-17 17:58:23,835 - root - CRITICAL - Error : hci0 interface not Running. Do you have a BLE device connected to hci0 ? Check with hciconfig !
pi@raspberrypi:~$ hciconfig
hci0:	Type: BR/EDR  Bus: UART
	BD Address: xx:xx:xx:xx:xx:xx  ACL MTU: 1021:8  SCO MTU: 64:1
	UP RUNNING
	RX bytes:717 acl:0 sco:0 events:42 errors:0
	TX bytes:1532 acl:0 sco:0 commands:42 errors:0
in /etc/init.d/check_beacon_presence
DAEMON_USER=root
I have 3 Nut and all visible with a BLE scanner
Any idea what I should do or check?
Raspberry Piet
Hmmm. This is odd. I left my Nut Tag at the same place this whole night and day.
Looking at the RSSI graph of this Tag it shows a clear difference when someone is at home or all left (for work)
When no one is at home the signal is quite stable according to the graph.
When i want to use it for indoor positioning system it would be better when the signal is stable as well when someone is at home.
Maybe it is some device that interferes the bluetooth signal... Have to investigate further.
Is there already somebody with this same experience?
blackdog65
I found placing a bottle of "Dr. Pepper" next to my tag caused a 25 point move. Took me a while to figure it out. :x
Stranger still, cups of tea or coffee had not affected it before :? ....... Maybe I'll stick with tea :lol:
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
