Learn LUA for Domoticz
Evelen
Domoticz version: 2.4538
Post by Evelen »
I can se Blockly now is just too limited to do the home automation on.
So I have to choises, buy the very expensive HomeSeer to replace Domoticz, or learn LUA.
The problem is that I do not have much programmering experience, yust a little powershell (windows) and batch (windows), but not much more.
So how to learn it? And not just in general, but for use with Domoticz.
Maybe first just like "If BUTTON1 = off and TEMP < 20C set BUTTOM2 = on"
But also like "If ENERGY > 10W for 10 minutes turn BUTTON2 off"
and like: "If BUTTON1= off Set BUTTON2 = off, else if BUTTON1=on set BUTTON2= on"
And things like that?
I think some easy examples and description of what all the commands and symbols in the script do will helt alot.
Eks: I see many people write "commandArray" someplaces in the script, what does that meen?
EDIT: Got this to work :D
if (devicechanged['1 - Stue, Stålampe'] == 'On') then
   commandArray['21 - Kjøkken, Taklampe']='On'
But why does this meen:
and this:
return CommandArray
Egregius
Domoticz version: v2024.7
Re: Learn LUA for Domoticz
Post by Egregius »
I think PHP is easier to learn and it can do much more then lua in a simpler way and it's even faster.
simonrg
Domoticz version: 3.8807
Post by simonrg »
and this:
is simply defining an empty list, then
is giving the list, which you have now written commands into, back to Domoticz, so Domoticz can execute those commands.
It would worthwhile reading some introductory information on Lua, so you have an idea of the way in which it handles data, the fact it is case sensitive so Commandarray is a different variable to commandArray etc..
https://awesome.naquadah.org/wiki/The_briefest_introduction_to_Lua
Then have a look around the Wiki there are quite a lot of commented scripts and information on how Lua works with Domoticz - probably start with http://www.domoticz.com/wiki/Domoticz_and_Scripting and then have a look at
http://www.domoticz.com/wiki/Events
Personally, I think Lua is probably the eaisest scripting to start with Domoticz, as your script shows Domoticz does all the set up for you and is well linked to Lua. I came from classic computer languages like Pascal / DOS-Windows scriptting etc. with little web programming experience and learning Lua purely to use with Domoticz and found it not too hard. However, Lua is quite clever so things like being able to have '1 - Stue, Stålampe' as index (key) to an array are very powerful.
Obviously if you already knew another language then that would be easier. Python / Php all look more difficult to me, but I would any hints in forum posts or Wiki articles on how to get started would be great.
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
dannybloe
Post by dannybloe »
Just take a look at dzVents. Very easy and lots of documentation and examples.
