Find my iPhone notification with apache
Mazzokun
Post by Mazzokun »
Hi, I used find my iPhone utility with apache 2 since yesterday and it worked like a charm but today I had to reinstall and I can't use it anymore. viewtopic.php?t=6358.
I can't secure my secure folder ( I can still see the content if I browse with a pc ) and the scripts doesn't work...
Any idea? A step by step guide for noobs should be great! :)
Thank you
Egregius
Domoticz version: v2024.7
Re: Find my iPhone notification with apache
Post by Egregius »
What do you mean by 'content'? Directory listing? Put a empty index.html in.
More secure is a .htaccess file or thru the Apache virtual host file.
What does the script display?
Do you have error reporting enabled?
Is there something in the error log?
Mazzokun
Post by Mazzokun »
Egregius wrote:What do you mean by 'content'? Directory listing? Put a empty index.html in.
ok something is progressing; :o
I created a folder called "secure" in var/www/html and I placed here my php files.
So my directory is var/www/html/secure. This is a portion of /etc/apache2/apache2.conf file that I edited to secure the folder from the outside word. Is it secure? I don't know how to create a .htaccess file and I don't know where to put it :oops:
# Sets the default security model of the Apache2 HTTPD server. It does
# not allow access to the root filesystem outside of /usr/share and /var/www.
# The former is used by web applications packaged in Debian,
# the latter may be used for local directories served by the web server. If
# your system is serving content from a sub-directory in /srv you must allow
# access here, or in any related virtual host.
<Directory />
        Options FollowSymLinks
        AllowOverride None
        Require all denied
</Directory>
<Directory /usr/share>
        AllowOverride None
        Require all granted
</Directory>
<Directory /var/www/>
        Options Indexes FollowSymLinks
        AllowOverride None
        Require all granted
</Directory>
<Directory /var/www/secure>
   order deny,allow
   Deny from All
   allow from 127.0.0.1
</Directory>
#<Directory /srv/>
#       Options Indexes FollowSymLinks
#       AllowOverride None
#       Require all granted
#</Directory>
# AccessFileName: The name of the file to look for in each directory
# for additional configuration directives.  See also the AllowOverride
# directive.
AccessFileName .htaccess
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<FilesMatch "^\.ht">
        Require all denied
</FilesMatch>
If i type into terminal through ssh connection "php -f turnoniphone.php " then my iPhone sound, but if into GUI I execute it from the folder the iPhone doesn't sound. Same in domotic: I created a virtual switch called iPhone and into on action I wrote: http://127.0.0.1/secure/turnoniphone.php but nothing happens..
Before the great ko and reinstall anything worked ok.
Permission of files in secure folder are Read only owner; modify only owner;Execute ANYONE. and the owner is pi.
Where is the mistake?
Egregius
Post by Egregius »
Mazzokun wrote:Is it secure?
Yes, by this part of your virtualhosts:
   order deny,allow
   Deny from All
</Directory>
If you do it in virtualhost config file you don't need to do it again in a .htaccess. But don't know how? Ever tried google?
Mazzokun wrote: Permission of files in secure folder are Read only owner; modify only owner;Execute ANYONE. and the owner is pi.
So the permissions are 601?
like this?
8.0K -rw------x 1 http http 86 Oct 16 09:40 test.php
How can it be executed if the user doesn't has read rights?
Change the permissions to 777 for testing, it shouldn't even be a problem leaving it that way because the files are secured by the virtualhosts file.
Mazzokun
Post by Mazzokun »
Changed permission to 777
sudo chmod 777 /var/www/secure/turnoniphone.php
but nothing changed.. It doesn't workin GUI or Domoticz. It works only if I type in terminal
php turnoniphone.php
I'm a bit :o :roll:
Egregius
Post by Egregius »
What is the output? What's in the logfiles?
Don't expect help with just 'doesn't work'.
Mazzokun
Post by Mazzokun »
ok i changed folder "secure" permission to view "only owner and group", change content to "only owner and group" , access content anyone and now it work.. but.. Is it safe?
Thank you very much for support and excuse me :)
