RFLink - USB Gateway - Introduction
RidingTheFlow
Re: RFLink - USB Gateway - Introduction
Main issue with 433Mhz and PIR is that you get no transmission acknowledgement, so for one-time events like PIRs there is possibility of missed signal - consider if its ok for your usage scenario.
vodor
At this stage I am just experimenting a bit with alarm systems without purchasing anything commercial. So any information / recommendations are welcome.
- sincze
- Domoticz version: 2024.4
Let's try it out
really curious about the performance of this one compared to traditional rfxcom.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
niki68
At this moment I use the RFLink for a bunch of kaku dimmers and switches. I built the unit from the parts sold at nodo. I'm using the external antenna. Our house is concrete built and I have no issues with signal. The RFLink and Arduino are in the attic (zolder). I found that I can control not only my own switches but also many doorbells, swiches, dimmers of multiple neighbours
Hesmink
A big thumbs up for this project!
I have an RFXCom, but since it couldn't cover all of my house, I got an RFLink.
Works great out of the box, and it even supports more devices. I can now also use the temperature sensor from my TFA weather station.
darmokusumo
Does this also work on XPEnology? I already installed the Domoticz package.
deennoo
Re: RE: Re: RFLink - USB Gateway - Introduction
Yes it isdarmokusumo wrote:Does this also work on XPEnology? I already installed the Domoticz package.
http://domo-attitude.fr
Calzor Suzay
- Target OS: -
- Domoticz version: 4.9700
I have intermittent issues with my RFX433E and range etc, I'm using an updated aerial but still have issues, Looking at the kits on https://www.nodo-shop.nl/en/21-rflink-gateway they look like the same aerials or are the boards more powerful/sensitive? i.e. with the same aerial I'd get better range?
Anyone swapped from an RFX433E to RFLINK kit for aerial issues and solved it?
Hesmink
I have both, and my reception quality is up a bit with RFLink.Calzor Suzay wrote:Hi,
I can even receive signals from a thermometer in my fridge which I couldn't with RFX433E.
Calzor Suzay
- Target OS: -
Thanks,Hesmink wrote: I have both, and my reception quality is up a bit with RFLink.
Just to confirm are you using the kit from nodo-shop link or a home built kit?
Rolo
- Domoticz version: 3.8153
Whar type of antenna are you using now ? My experience with 433 mhz is that a simple stiff 173 mm long wire works best. And is cheap
Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk
Hesmink
Yes, the kit for nodo-shop with solder service.Calzor Suzay wrote:Thanks,Hesmink wrote: I have both, and my reception quality is up a bit with RFLink.
This excludes the antenna, but I have a simple one from a china shop.
All attempts of better antenna's for the RFX433E had no effect for me.
Calzor Suzay
- Target OS: -
Ok thanks, I'm guessing the device itself has a higher gain/stronger signal then.
Nautilus
Just to confirm (was not able to find this info on Nodo shop or in the nemcon site) - the Nodo shop RFLink products like https://www.nodo-shop.nl/en/rflink-gate ... tenna.html come already equipped with the nRF24L01+ chip? So no need to buy separately...Stuntteam wrote: 2.4ghz support (nRF24L01+) is available on the rflink boards that are available at the Nodo shop. So the hardware for this is in place if you got such a board.
- sincze
To the best of my knowledge you have to ADD the nRF24L01+ yourself.
The item you buy comes with 433 mhz transceiver. or 868mhz depending on what you order.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Nautilus
This is how I assumed it in the first place as well.sincze wrote:To the best of my knowledge you have to ADD the nRF24L01+ yourself.
But when I saw the post from Stuntteam with:
I though it meant it is already equipped with it. Btw, if I need both 433 and 868 support, do I need to have two RFLinks or can I add both to single RFLink unit?...So the hardware for this is in place if you got such a board.
- sincze
No currently it needs 2 RFLINKNautilus wrote: But when I saw the post from Stuntteam with:I though it meant it is already equipped with it. Btw, if I need both 433 and 868 support, do I need to have two RFLinks or can I add both to single RFLink unit?...So the hardware for this is in place if you got such a board.
- 1x 433mhz
- 1x 868mhz
The 2,4ghz antenna can be attached for mi-light via wires.. for nodo via the connector on the rflink.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- Stuntteam
I think one can order the nrf additionally.
The NRF includes an on board antenna, so you dont need external.
Nautilus
Ok, now I found the wiring page from the Nemcon site with some more details on this
Have to ask this from Nodo shop but if someone already knows here: Can I get a fully working 433Mhz+Milight NRF with the soldering service (of course have to pay for the nRF24L01+ as well)? Or just the 433Mhz without nRF24L01? My soldering skills are not that good especially with the low budget equipment I have...
- sincze
Last time I ordered solder service rflink 433 mhz
Had a separate nrf in a drawer.
Attached it with jumper wires to the arduino. (see wiring scheme)
Flashed the firmware.
And the whole thing is controlling my milight and 433mhz devices from within domoticz nicely.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
